turboscrew
Posts: 23 Joined: Wed Jul 30, 2014 6:15 am
Post
by turboscrew » Fri Aug 01, 2014 5:35 pm
Oops, a typo in my last edit - which make it even more weird:
It now GIVES an output:
[root@elukancompute nagios]# su -c "/usr/lib64/nagios/plugins/check_nrpe -H localhost -c check_omat -a 'AARGHH'" nrpe
SERVICE STATUS: OK - Sun Jul 27 08:59:46 EEST 2014
but doesn't write into the fila...
eloyd
Cool Title Here
Posts: 2190 Joined: Thu Sep 27, 2012 9:14 am
Post
by eloyd » Sat Aug 02, 2014 8:54 am
I will have to return to this after the weekend is over.
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Sun Aug 03, 2014 9:06 pm
Going back to the original problem, can you please post the full service definition for the service using the command check_all_disks.
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
turboscrew
Post
by turboscrew » Mon Aug 04, 2014 5:55 am
# groups
define hostgroup{
hostgroup_name computes
alias compute nodes
members 10.27.128.81
# actual hosts
use client
host_name 10.27.128.81
alias compute_node
address 10.27.128.81
# check_disks
contact_groups wheels
service_description Disk usage
check_command check_nrpe2!check_all_disks!20%!10%
command_name check_nrpe2
command_line '/usr/lib64/nagios/plugins/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ $ARG2$ $ARG3$'
On the NRPE client side:
command[check_all_disks]=/usr/lib64/nagios/plugins/check_disk -w $ARG1$ -c $ARG2$ -p /dev/vda
Post
by Box293 » Mon Aug 04, 2014 6:05 am
Change your command to:
command_line /usr/lib64/nagios/plugins/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ -a $ARG2$ $ARG3$
Privacy Policy .
turboscrew
Post
by turboscrew » Mon Aug 04, 2014 6:27 am
So that was it: now also "check_omat" started returning value!
THANKS!
Is there a ranking system where I could put points to you?
[edit]
Sometime at the beginning I removed the '-a', because shooting from the command line it went to the command as a parameter.
There must have been some other errors then because the command didn't work then either.
Post
by Box293 » Mon Aug 04, 2014 6:35 am
Great stuff, glad to see it working
No need for any ranking, it's just good to help others out
Privacy Policy .
eloyd
Cool Title Here
Post
by eloyd » Mon Aug 04, 2014 8:06 am
This is why we like Box293 so much. He lives in Australia and gets to answer questions on his Monday morning, before the rest of the world is awake.
Glad we could all help you out.
