CHECK_NRPE: Socket timeout after 20 seconds.
kakaluru
Re: CHECK_NRPE: Socket timeout after 20 seconds.
Post by kakaluru »
find below outputs from client side.
[root@BUGZILLABCK ~]# ps auxw | grep nrpe
root 13783 0.0 0.0 103240 868 pts/0 S+ 15:07 0:00 grep nrpe
[root@BUGZILLABCK ~]# netstat -at | grep nrpe
tcp 0 0 bugzillabck:nrpe 10.174.0.38:45881 SYN_ RECV
tcp 0 0 bugzillabck:nrpe 10.174.0.38:45877 SYN_ RECV
tcp 0 0 bugzillabck:nrpe 10.174.0.38:45884 SYN_ RECV
tcp 0 0 bugzillabck:nrpe 10.174.0.38:45888 SYN_ RECV
tcp 0 0 bugzillabck:nrpe 10.174.0.38:45876 SYN_ RECV
tcp 0 0 bugzillabck:nrpe 10.174.0.38:45879 SYN_ RECV
tcp 0 0 *:nrpe *:* LISTEN
[root@BUGZILLABCK ~]# sestatus
SELinux status: disabled
Post by Box293 »
From your remote server, can you please get these files and post them as attachments.
Please post them as attachments to prevent any copy / paste problems.
/etc/xinetd.d/nrpe
/usr/local/nagios/etc/nrpe.cfg
ALL Files in /usr/local/nagios/etc/nrpe/
kakaluru
Post by kakaluru »
Hi Box293,
Sorry for the delay. I have attached nrpe and nrpe.cfg conf files which you asked. I hope you will give positive response to me.
nrpe.cfg.txt
(9.8 KiB) Downloaded 319 times
nrpe.txt
(489 Bytes) Downloaded 326 times
Post by Box293 »
I believe this is your problem:
In your /etc/xinetd.d/nrpe file:
only_from = 127.0.0.1 192.168.30.38[NagiosServer]
Change it to:
Then:
service xinetd restart
kakaluru
Post by kakaluru »
Hi Box293,
I made a note for your reference only. Actual file is same as what you mentioned.
Kindly go through both files again let me know any changes. This issue is facing since 1month. plz do the needful.
Are you using TCP wrappers? Do you have anything in "/etc/hosts.allow" or/and "/etc/hosts.deny"?
kakaluru
Post by kakaluru »
Where i need to check either server or client.
If NRPE is blocking Nagios then you would want to check hosts.allow and hosts.deny on the NRPE machine.
kakaluru
Post by kakaluru »
[root@BUGZILLABCK ~]# cat /etc/hosts.allow
# hosts.allow This file contains access rules which are used to
# allow or deny connections to network services that
# either use the tcp_wrappers library or that have been
# started through a tcp_wrappers-enabled xinetd.
# See 'man 5 hosts_options' and 'man 5 hosts_access'
# for information on rule syntax.
# See 'man tcpd' for information on tcp_wrappers
nrpe: 192.168.30.38 son1840
/etc/hosts.deny file is empty
abrist
Red Shirt
Post by abrist »
Are you using tcpd wrappers or xinetd?
What do your iptables rules look like?
