check_snmp not working but snmpget works
Kerflumpre
Re: check_snmp not working but snmpget works
Post by Kerflumpre »
64
rhassing
Post by rhassing »
Ok, it took some time, but I was able to reproduce your problem and also solve it.
I installed a VM with Debian 7 (64 bits).
Compiled the nagios-plugins and tried using the check_snmp plugin.
The same problem occurred as you described.
Then I installed net-snmp as it is an requirement for this plugin (see the file REQUIREMENTS).
So I installed net-snmp following this tutorial http://www.net-snmp.org/wiki/index.php/ ... untu_10.04
After that I compiled the nagios_plugins again and noticed it was using /usr/local/bin/snmpget instead of /usr/bin/snmpget.
I only had to run ldconfig to make it find the needed libraries.
Hope this helps you? :-)
Rob Hassing
Kerflumpre
I'm a bit confused by this. If I have snmpget, and it's working, isn't that the requirement?
rhassing
Post by rhassing »
Now I'm confused?
If I have snmpget, and it's working,isn't that the requirement?
Is the check working now?
Have you read the file that comes with the package?
I downloaded the source file of nagios-plugins (version 2.0.3) from http://nagios-plugins.org/download/nagi ... 0.3.tar.gz.
I extracted it using tar zxvf nagios-plugins-2.0.3.tar.gz
It contains the following files:
nagios-plugins-2.0.3/
nagios-plugins-2.0.3/perlmods/
nagios-plugins-2.0.3/perlmods/Config-Tiny-2.14.tar.gz
nagios-plugins-2.0.3/perlmods/parent-0.226.tar.gz
nagios-plugins-2.0.3/perlmods/Test-Simple-0.98.tar.gz
nagios-plugins-2.0.3/perlmods/Makefile.in
nagios-plugins-2.0.3/perlmods/version-0.9903.tar.gz
nagios-plugins-2.0.3/perlmods/Makefile.am
nagios-plugins-2.0.3/perlmods/Module-Runtime-0.013.tar.gz
nagios-plugins-2.0.3/perlmods/Module-Metadata-1.000014.tar.gz
nagios-plugins-2.0.3/perlmods/Params-Validate-1.08.tar.gz
nagios-plugins-2.0.3/perlmods/Class-Accessor-0.34.tar.gz
nagios-plugins-2.0.3/perlmods/Try-Tiny-0.18.tar.gz
nagios-plugins-2.0.3/perlmods/Module-Implementation-0.07.tar.gz
nagios-plugins-2.0.3/perlmods/Perl-OSType-1.003.tar.gz
nagios-plugins-2.0.3/perlmods/install_order
nagios-plugins-2.0.3/perlmods/Nagios-Plugin-0.36.tar.gz
nagios-plugins-2.0.3/perlmods/Math-Calc-Units-1.07.tar.gz
nagios-plugins-2.0.3/perlmods/Module-Build-0.4007.tar.gz
nagios-plugins-2.0.3/ABOUT-NLS
nagios-plugins-2.0.3/configure.ac
nagios-plugins-2.0.3/Makefile.in
nagios-plugins-2.0.3/config.h.in
nagios-plugins-2.0.3/ChangeLog
nagios-plugins-2.0.3/AUTHORS
nagios-plugins-2.0.3/lib/
nagios-plugins-2.0.3/lib/parse_ini.h
nagios-plugins-2.0.3/lib/extra_opts.c
nagios-plugins-2.0.3/lib/Makefile.in
nagios-plugins-2.0.3/lib/utils_cmd.h
nagios-plugins-2.0.3/lib/utils_tcp.h
nagios-plugins-2.0.3/lib/Makefile.am
nagios-plugins-2.0.3/lib/extra_opts.h
nagios-plugins-2.0.3/lib/utils_tcp.c
nagios-plugins-2.0.3/lib/parse_ini.c
nagios-plugins-2.0.3/lib/utils_cmd.c
nagios-plugins-2.0.3/lib/utils_base.h
nagios-plugins-2.0.3/lib/tests/
nagios-plugins-2.0.3/lib/tests/test_disk.c
nagios-plugins-2.0.3/lib/tests/test_base64.c
nagios-plugins-2.0.3/lib/tests/plugin.ini
nagios-plugins-2.0.3/lib/tests/Makefile.in
nagios-plugins-2.0.3/lib/tests/test_opts2.t
nagios-plugins-2.0.3/lib/tests/config-dos.ini
nagios-plugins-2.0.3/lib/tests/test_opts3.c
nagios-plugins-2.0.3/lib/tests/Makefile.am
nagios-plugins-2.0.3/lib/tests/test_opts3.t
nagios-plugins-2.0.3/lib/tests/test_opts1.c
nagios-plugins-2.0.3/lib/tests/test_ini1.c
nagios-plugins-2.0.3/lib/tests/test_opts2.c
nagios-plugins-2.0.3/lib/tests/test_cmd.t
nagios-plugins-2.0.3/lib/tests/config-tiny.ini
nagios-plugins-2.0.3/lib/tests/test_base64.t
nagios-plugins-2.0.3/lib/tests/plugins.ini
nagios-plugins-2.0.3/lib/tests/test_ini3.c
nagios-plugins-2.0.3/lib/tests/config-opts.ini
nagios-plugins-2.0.3/lib/tests/test_cmd.c
nagios-plugins-2.0.3/lib/tests/test_ini1.t
nagios-plugins-2.0.3/lib/tests/README
nagios-plugins-2.0.3/lib/tests/test_tcp.c
nagios-plugins-2.0.3/lib/tests/test_utils.c
nagios-plugins-2.0.3/lib/tests/test_utils.t
nagios-plugins-2.0.3/lib/tests/test_opts1.t
nagios-plugins-2.0.3/lib/tests/test_ini3.t
nagios-plugins-2.0.3/lib/tests/test_disk.t
nagios-plugins-2.0.3/lib/tests/test_tcp.t
nagios-plugins-2.0.3/lib/tests/var/
nagios-plugins-2.0.3/lib/tests/var/missingdataline
nagios-plugins-2.0.3/lib/tests/var/statefile
nagios-plugins-2.0.3/lib/tests/var/baddate
nagios-plugins-2.0.3/lib/tests/var/oldformat
nagios-plugins-2.0.3/lib/tests/var/.gitignore
nagios-plugins-2.0.3/lib/utils_disk.h
nagios-plugins-2.0.3/lib/utils_disk.c
nagios-plugins-2.0.3/lib/utils_base.c
nagios-plugins-2.0.3/config_test/
nagios-plugins-2.0.3/config_test/child_test.c
nagios-plugins-2.0.3/config_test/Makefile
nagios-plugins-2.0.3/config_test/run_tests
nagios-plugins-2.0.3/test.pl.in
nagios-plugins-2.0.3/mkinstalldirs
nagios-plugins-2.0.3/Makefile.am
nagios-plugins-2.0.3/acinclude.m4
nagios-plugins-2.0.3/gl/
nagios-plugins-2.0.3/gl/sha1.c
nagios-plugins-2.0.3/gl/snprintf.c
nagios-plugins-2.0.3/gl/dirname-lgpl.c
nagios-plugins-2.0.3/gl/exitfail.h
nagios-plugins-2.0.3/gl/gethostname.c
nagios-plugins-2.0.3/gl/strsep.c
nagios-plugins-2.0.3/gl/localcharset.h
nagios-plugins-2.0.3/gl/vasprintf.c
nagios-plugins-2.0.3/gl/malloc.c
nagios-plugins-2.0.3/gl/xalloc-die.c
nagios-plugins-2.0.3/gl/netinet_in.in.h
nagios-plugins-2.0.3/gl/msvc-nothrow.h
nagios-plugins-2.0.3/gl/mktime-internal.h
nagios-plugins-2.0.3/gl/locale.in.h
nagios-plugins-2.0.3/gl/Makefile.in
nagios-plugins-2.0.3/gl/streq.h
nagios-plugins-2.0.3/gl/sha1.h
nagios-plugins-2.0.3/gl/regex_internal.h
nagios-plugins-2.0.3/gl/unistd.c
nagios-plugins-2.0.3/gl/basename.c
nagios-plugins-2.0.3/gl/glthread/
nagios-plugins-2.0.3/gl/glthread/lock.h
nagios-plugins-2.0.3/gl/glthread/lock.c
nagios-plugins-2.0.3/gl/glthread/threadlib.c
nagios-plugins-2.0.3/gl/safe-read.h
nagios-plugins-2.0.3/gl/w32sock.h
nagios-plugins-2.0.3/gl/sys_uio.in.h
nagios-plugins-2.0.3/gl/nl_langinfo.c
nagios-plugins-2.0.3/gl/getopt1.c
nagios-plugins-2.0.3/gl/stdint.in.h
nagios-plugins-2.0.3/gl/ref-del.sin
nagios-plugins-2.0.3/gl/timegm.c
nagios-plugins-2.0.3/gl/time_r.c
nagios-plugins-2.0.3/gl/stdalign.in.h
nagios-plugins-2.0.3/gl/sockets.c
nagios-plugins-2.0.3/gl/Makefile.am
nagios-plugins-2.0.3/gl/mountlist.h
nagios-plugins-2.0.3/gl/wchar.in.h
nagios-plugins-2.0.3/gl/ref-add.sin
nagios-plugins-2.0.3/gl/strstr.c
nagios-plugins-2.0.3/gl/math.in.h
nagios-plugins-2.0.3/gl/math.c
nagios-plugins-2.0.3/gl/malloca.c
nagios-plugins-2.0.3/gl/xsize.h
nagios-plugins-2.0.3/gl/float.in.h
nagios-plugins-2.0.3/gl/xstrndup.h
nagios-plugins-2.0.3/gl/idpriv.h
nagios-plugins-2.0.3/gl/malloca.h
nagios-plugins-2.0.3/gl/basename-lgpl.c
nagios-plugins-2.0.3/gl/memchr.c
nagios-plugins-2.0.3/gl/strnlen.c
nagios-plugins-2.0.3/gl/fsusage.c
nagios-plugins-2.0.3/gl/read.c
nagios-plugins-2.0.3/gl/getloadavg.c
nagios-plugins-2.0.3/gl/setenv.c
nagios-plugins-2.0.3/gl/itold.c
nagios-plugins-2.0.3/gl/printf-args.c
nagios-plugins-2.0.3/gl/strndup.c
nagios-plugins-2.0.3/gl/gai_strerror.c
nagios-plugins-2.0.3/gl/vasnprintf.h
nagios-plugins-2.0.3/gl/mbsinit.c
nagios-plugins-2.0.3/gl/mktime.c
nagios-plugins-2.0.3/gl/error.c
nagios-plugins-2.0.3/gl/vasnprintf.c
nagios-plugins-2.0.3/gl/str-two-way.h
nagios-plugins-2.0.3/gl/floorf.c
nagios-plugins-2.0.3/gl/strerror-override.c
nagios-plugins-2.0.3/gl/unsetenv.c
nagios-plugins-2.0.3/gl/size_max.h
nagios-plugins-2.0.3/gl/mbtowc.c
nagios-plugins-2.0.3/gl/dosname.h
nagios-plugins-2.0.3/gl/config.charset
nagios-plugins-2.0.3/gl/string.in.h
nagios-plugins-2.0.3/gl/dirname.h
nagios-plugins-2.0.3/gl/error.h
nagios-plugins-2.0.3/gl/msvc-nothrow.c
nagios-plugins-2.0.3/gl/localcharset.c
nagios-plugins-2.0.3/gl/strerror.c
nagios-plugins-2.0.3/gl/getaddrinfo.c
nagios-plugins-2.0.3/gl/stripslash.c
nagios-plugins-2.0.3/gl/btowc.c
nagios-plugins-2.0.3/gl/mountlist.c
nagios-plugins-2.0.3/gl/sys_socket.in.h
nagios-plugins-2.0.3/gl/netdb.in.h
nagios-plugins-2.0.3/gl/xalloc-oversized.h
nagios-plugins-2.0.3/gl/mbrtowc.c
nagios-plugins-2.0.3/gl/xmalloc.c
nagios-plugins-2.0.3/gl/regex_internal.c
nagios-plugins-2.0.3/gl/malloca.valgrind
nagios-plugins-2.0.3/gl/strerror-override.h
nagios-plugins-2.0.3/gl/asprintf.c
nagios-plugins-2.0.3/gl/wctype-h.c
nagios-plugins-2.0.3/gl/regexec.c
nagios-plugins-2.0.3/gl/float.c
nagios-plugins-2.0.3/gl/alloca.in.h
nagios-plugins-2.0.3/gl/exitfail.c
nagios-plugins-2.0.3/gl/stdlib.in.h
nagios-plugins-2.0.3/gl/errno.in.h
nagios-plugins-2.0.3/gl/stddef.in.h
nagios-plugins-2.0.3/gl/xalloc.h
nagios-plugins-2.0.3/gl/regex.h
nagios-plugins-2.0.3/gl/xsize.c
nagios-plugins-2.0.3/gl/getopt_int.h
nagios-plugins-2.0.3/gl/inet_ntop.c
nagios-plugins-2.0.3/gl/memchr.valgrind
nagios-plugins-2.0.3/gl/sys_types.in.h
nagios-plugins-2.0.3/gl/printf-parse.h
nagios-plugins-2.0.3/gl/dirname.c
nagios-plugins-2.0.3/gl/sys_socket.c
nagios-plugins-2.0.3/gl/mbtowc-impl.h
nagios-plugins-2.0.3/gl/fd-hook.c
nagios-plugins-2.0.3/gl/m4/
nagios-plugins-2.0.3/gl/m4/mktime.m4
nagios-plugins-2.0.3/gl/m4/ltversion.m4
nagios-plugins-2.0.3/gl/m4/ltoptions.m4
nagios-plugins-2.0.3/gl/m4/locale-ja.m4
nagios-plugins-2.0.3/gl/m4/fstypename.m4
nagios-plugins-2.0.3/gl/m4/mmap-anon.m4
nagios-plugins-2.0.3/gl/m4/vasprintf.m4
nagios-plugins-2.0.3/gl/m4/vasnprintf.m4
nagios-plugins-2.0.3/gl/m4/error.m4
nagios-plugins-2.0.3/gl/m4/environ.m4
nagios-plugins-2.0.3/gl/m4/msvc-inval.m4
nagios-plugins-2.0.3/gl/m4/math_h.m4
nagios-plugins-2.0.3/gl/m4/sys_socket_h.m4
nagios-plugins-2.0.3/gl/m4/getloadavg.m4
nagios-plugins-2.0.3/gl/m4/socklen.m4
nagios-plugins-2.0.3/gl/m4/progtest.m4
nagios-plugins-2.0.3/gl/m4/xstrndup.m4
nagios-plugins-2.0.3/gl/m4/unistd_h.m4
nagios-plugins-2.0.3/gl/m4/netinet_in_h.m4
nagios-plugins-2.0.3/gl/m4/inttypes_h.m4
nagios-plugins-2.0.3/gl/m4/double-slash-root.m4
nagios-plugins-2.0.3/gl/m4/eealloc.m4
nagios-plugins-2.0.3/gl/m4/include_next.m4
nagios-plugins-2.0.3/gl/m4/fsusage.m4
nagios-plugins-2.0.3/gl/m4/nls.m4
nagios-plugins-2.0.3/gl/m4/string_h.m4
nagios-plugins-2.0.3/gl/m4/warn-on-use.m4
nagios-plugins-2.0.3/gl/m4/setenv.m4
nagios-plugins-2.0.3/gl/m4/idpriv.m4
nagios-plugins-2.0.3/gl/m4/inet_ntop.m4
nagios-plugins-2.0.3/gl/m4/codeset.m4
nagios-plugins-2.0.3/gl/m4/mountlist.m4
nagios-plugins-2.0.3/gl/m4/ssize_t.m4
nagios-plugins-2.0.3/gl/m4/lt~obsolete.m4
nagios-plugins-2.0.3/gl/m4/float_h.m4
nagios-plugins-2.0.3/gl/m4/servent.m4
nagios-plugins-2.0.3/gl/m4/localcharset.m4
nagios-plugins-2.0.3/gl/m4/gnulib-cache.m4
nagios-plugins-2.0.3/gl/m4/strsep.m4
nagios-plugins-2.0.3/gl/m4/wint_t.m4
nagios-plugins-2.0.3/gl/m4/stdbool.m4
nagios-plugins-2.0.3/gl/m4/off_t.m4
nagios-plugins-2.0.3/gl/m4/lock.m4
nagios-plugins-2.0.3/gl/m4/sockpfaf.m4
nagios-plugins-2.0.3/gl/m4/nocrash.m4
nagios-plugins-2.0.3/gl/m4/strnlen.m4
nagios-plugins-2.0.3/gl/m4/fcntl-o.m4
nagios-plugins-2.0.3/gl/m4/strstr.m4
nagios-plugins-2.0.3/gl/m4/sha1.m4
nagios-plugins-2.0.3/gl/m4/strerror.m4
nagios-plugins-2.0.3/gl/m4/printf.m4
nagios-plugins-2.0.3/gl/m4/nl_langinfo.m4
nagios-plugins-2.0.3/gl/m4/regex.m4
nagios-plugins-2.0.3/gl/m4/threadlib.m4
nagios-plugins-2.0.3/gl/m4/malloca.m4
nagios-plugins-2.0.3/gl/m4/gnulib-comp.m4
nagios-plugins-2.0.3/gl/m4/iconv.m4
nagios-plugins-2.0.3/gl/m4/mbstate_t.m4
nagios-plugins-2.0.3/gl/m4/extensions.m4
nagios-plugins-2.0.3/gl/m4/malloc.m4
nagios-plugins-2.0.3/gl/m4/stdint.m4
nagios-plugins-2.0.3/gl/m4/timegm.m4
nagios-plugins-2.0.3/gl/m4/sockets.m4
nagios-plugins-2.0.3/gl/m4/wchar_h.m4
nagios-plugins-2.0.3/gl/m4/langinfo_h.m4
nagios-plugins-2.0.3/gl/m4/po.m4
nagios-plugins-2.0.3/gl/m4/read.m4
nagios-plugins-2.0.3/gl/m4/longlong.m4
nagios-plugins-2.0.3/gl/m4/gettext.m4
nagios-plugins-2.0.3/gl/m4/mbtowc.m4
nagios-plugins-2.0.3/gl/m4/ls-mntd-fs.m4
nagios-plugins-2.0.3/gl/m4/libtool.m4
nagios-plugins-2.0.3/gl/m4/socketlib.m4
nagios-plugins-2.0.3/gl/m4/sys_uio_h.m4
nagios-plugins-2.0.3/gl/m4/lib-link.m4
nagios-plugins-2.0.3/gl/m4/floorf.m4
nagios-plugins-2.0.3/gl/m4/stddef_h.m4
nagios-plugins-2.0.3/gl/m4/msvc-nothrow.m4
nagios-plugins-2.0.3/gl/m4/errno_h.m4
nagios-plugins-2.0.3/gl/m4/locale-fr.m4
nagios-plugins-2.0.3/gl/m4/multiarch.m4
nagios-plugins-2.0.3/gl/m4/onceonly.m4
nagios-plugins-2.0.3/gl/m4/stdalign.m4
nagios-plugins-2.0.3/gl/m4/mbsinit.m4
nagios-plugins-2.0.3/gl/m4/intlmacosx.m4
nagios-plugins-2.0.3/gl/m4/configmake.m4
nagios-plugins-2.0.3/gl/m4/getaddrinfo.m4
nagios-plugins-2.0.3/gl/m4/safe-read.m4
nagios-plugins-2.0.3/gl/m4/stdlib_h.m4
nagios-plugins-2.0.3/gl/m4/memchr.m4
nagios-plugins-2.0.3/gl/m4/btowc.m4
nagios-plugins-2.0.3/gl/m4/hostent.m4
nagios-plugins-2.0.3/gl/m4/size_max.m4
nagios-plugins-2.0.3/gl/m4/stdint_h.m4
nagios-plugins-2.0.3/gl/m4/strndup.m4
nagios-plugins-2.0.3/gl/m4/locale_h.m4
nagios-plugins-2.0.3/gl/m4/extern-inline.m4
nagios-plugins-2.0.3/gl/m4/netdb_h.m4
nagios-plugins-2.0.3/gl/m4/00gnulib.m4
nagios-plugins-2.0.3/gl/m4/lib-ld.m4
nagios-plugins-2.0.3/gl/m4/wcrtomb.m4
nagios-plugins-2.0.3/gl/m4/snprintf.m4
nagios-plugins-2.0.3/gl/m4/exponentd.m4
nagios-plugins-2.0.3/gl/m4/vsnprintf.m4
nagios-plugins-2.0.3/gl/m4/glibc21.m4
nagios-plugins-2.0.3/gl/m4/largefile.m4
nagios-plugins-2.0.3/gl/m4/mbrtowc.m4
nagios-plugins-2.0.3/gl/m4/locale-zh.m4
nagios-plugins-2.0.3/gl/m4/gethostname.m4
nagios-plugins-2.0.3/gl/m4/wctype_h.m4
nagios-plugins-2.0.3/gl/m4/getopt.m4
nagios-plugins-2.0.3/gl/m4/time_r.m4
nagios-plugins-2.0.3/gl/m4/dirname.m4
nagios-plugins-2.0.3/gl/m4/xsize.m4
nagios-plugins-2.0.3/gl/m4/gnulib-common.m4
nagios-plugins-2.0.3/gl/m4/base64.m4
nagios-plugins-2.0.3/gl/m4/arpa_inet_h.m4
nagios-plugins-2.0.3/gl/m4/xalloc.m4
nagios-plugins-2.0.3/gl/m4/localeconv.m4
nagios-plugins-2.0.3/gl/m4/stdio_h.m4
nagios-plugins-2.0.3/gl/m4/alloca.m4
nagios-plugins-2.0.3/gl/m4/intmax_t.m4
nagios-plugins-2.0.3/gl/m4/wchar_t.m4
nagios-plugins-2.0.3/gl/m4/sys_types_h.m4
nagios-plugins-2.0.3/gl/m4/lib-prefix.m4
nagios-plugins-2.0.3/gl/m4/ltsugar.m4
nagios-plugins-2.0.3/gl/m4/time_h.m4
nagios-plugins-2.0.3/gl/float+.h
nagios-plugins-2.0.3/gl/base64.c
nagios-plugins-2.0.3/gl/sockets.h
nagios-plugins-2.0.3/gl/vsnprintf.c
nagios-plugins-2.0.3/gl/unistd.in.h
nagios-plugins-2.0.3/gl/time.in.h
nagios-plugins-2.0.3/gl/gettext.h
nagios-plugins-2.0.3/gl/regex.c
nagios-plugins-2.0.3/gl/full-read.c
nagios-plugins-2.0.3/gl/intprops.h
nagios-plugins-2.0.3/gl/msvc-inval.h
nagios-plugins-2.0.3/gl/fd-hook.h
nagios-plugins-2.0.3/gl/localeconv.c
nagios-plugins-2.0.3/gl/arpa_inet.in.h
nagios-plugins-2.0.3/gl/base64.h
nagios-plugins-2.0.3/gl/xstrndup.c
nagios-plugins-2.0.3/gl/printf-parse.c
nagios-plugins-2.0.3/gl/safe-read.c
nagios-plugins-2.0.3/gl/getopt.in.h
nagios-plugins-2.0.3/gl/msvc-inval.c
nagios-plugins-2.0.3/gl/floor.c
nagios-plugins-2.0.3/gl/idpriv-droptemp.c
nagios-plugins-2.0.3/gl/wcrtomb.c
nagios-plugins-2.0.3/gl/regcomp.c
nagios-plugins-2.0.3/gl/getopt.c
nagios-plugins-2.0.3/gl/stdbool.in.h
nagios-plugins-2.0.3/gl/verify.h
nagios-plugins-2.0.3/gl/wctype.in.h
nagios-plugins-2.0.3/gl/printf-args.h
nagios-plugins-2.0.3/gl/full-read.h
nagios-plugins-2.0.3/gl/asnprintf.c
nagios-plugins-2.0.3/gl/stdio.in.h
nagios-plugins-2.0.3/gl/fsusage.h
nagios-plugins-2.0.3/gl/full-write.c
nagios-plugins-2.0.3/gl/langinfo.in.h
nagios-plugins-2.0.3/COPYING
nagios-plugins-2.0.3/aclocal.m4
nagios-plugins-2.0.3/THANKS
nagios-plugins-2.0.3/SUPPORT
nagios-plugins-2.0.3/nagios-plugins.spec.in
nagios-plugins-2.0.3/release
nagios-plugins-2.0.3/plugins-root/
nagios-plugins-2.0.3/plugins-root/Makefile.in
nagios-plugins-2.0.3/plugins-root/Makefile.am
nagios-plugins-2.0.3/plugins-root/check_icmp.c
nagios-plugins-2.0.3/plugins-root/check_dhcp.c
nagios-plugins-2.0.3/plugins-root/t/
nagios-plugins-2.0.3/plugins-root/t/check_icmp.t
nagios-plugins-2.0.3/plugins-root/t/check_dhcp.t
nagios-plugins-2.0.3/plugins-root/pst3.c
nagios-plugins-2.0.3/FAQ
nagios-plugins-2.0.3/NP-VERSION-GEN
nagios-plugins-2.0.3/LEGAL
nagios-plugins-2.0.3/NEWS
nagios-plugins-2.0.3/ACKNOWLEDGEMENTS
nagios-plugins-2.0.3/build-aux/
nagios-plugins-2.0.3/build-aux/config.sub
nagios-plugins-2.0.3/build-aux/mkinstalldirs
nagios-plugins-2.0.3/build-aux/compile
nagios-plugins-2.0.3/build-aux/ltmain.sh
nagios-plugins-2.0.3/build-aux/config.guess
nagios-plugins-2.0.3/build-aux/missing
nagios-plugins-2.0.3/build-aux/depcomp
nagios-plugins-2.0.3/build-aux/config.rpath
nagios-plugins-2.0.3/build-aux/snippet/
nagios-plugins-2.0.3/build-aux/snippet/warn-on-use.h
nagios-plugins-2.0.3/build-aux/snippet/arg-nonnull.h
nagios-plugins-2.0.3/build-aux/snippet/c++defs.h
nagios-plugins-2.0.3/build-aux/snippet/_Noreturn.h
nagios-plugins-2.0.3/build-aux/install-sh
nagios-plugins-2.0.3/REQUIREMENTS
nagios-plugins-2.0.3/plugins/
nagios-plugins-2.0.3/plugins/check_snmp.c
nagios-plugins-2.0.3/plugins/check_ntp.c
nagios-plugins-2.0.3/plugins/popen.h
nagios-plugins-2.0.3/plugins/netutils.c
nagios-plugins-2.0.3/plugins/check_game.c
nagios-plugins-2.0.3/plugins/Makefile.in
nagios-plugins-2.0.3/plugins/check_http.c
nagios-plugins-2.0.3/plugins/check_mrtgtraf.c
nagios-plugins-2.0.3/plugins/check_ldap.c
nagios-plugins-2.0.3/plugins/check_apt.c
nagios-plugins-2.0.3/plugins/check_pgsql.c
nagios-plugins-2.0.3/plugins/Makefile.am
nagios-plugins-2.0.3/plugins/check_dig.c
nagios-plugins-2.0.3/plugins/check_ping.c
nagios-plugins-2.0.3/plugins/check_cluster.c
nagios-plugins-2.0.3/plugins/check_mrtg.c
nagios-plugins-2.0.3/plugins/check_overcr.c
nagios-plugins-2.0.3/plugins/runcmd.h
nagios-plugins-2.0.3/plugins/check_by_ssh.c
nagios-plugins-2.0.3/plugins/check_tcp.c
nagios-plugins-2.0.3/plugins/popen.c
nagios-plugins-2.0.3/plugins/negate.c
nagios-plugins-2.0.3/plugins/check_dbi.c
nagios-plugins-2.0.3/plugins/check_load.c
nagios-plugins-2.0.3/plugins/check_smtp.c
nagios-plugins-2.0.3/plugins/check_radius.c
nagios-plugins-2.0.3/plugins/check_time.c
nagios-plugins-2.0.3/plugins/utils.h
nagios-plugins-2.0.3/plugins/check_swap.c
nagios-plugins-2.0.3/plugins/check_ntp_time.c
nagios-plugins-2.0.3/plugins/check_users.c
nagios-plugins-2.0.3/plugins/tests/
nagios-plugins-2.0.3/plugins/tests/check_snmp_agent.pl
nagios-plugins-2.0.3/plugins/tests/check_snmp.t
nagios-plugins-2.0.3/plugins/tests/check_procs.t
nagios-plugins-2.0.3/plugins/tests/check_http.t
nagios-plugins-2.0.3/plugins/tests/check_nt.t
nagios-plugins-2.0.3/plugins/tests/certs/
nagios-plugins-2.0.3/plugins/tests/certs/server-cert.pem
nagios-plugins-2.0.3/plugins/tests/certs/expired-cert.pem
nagios-plugins-2.0.3/plugins/tests/certs/server-key.pem
nagios-plugins-2.0.3/plugins/tests/certs/expired-key.pem
nagios-plugins-2.0.3/plugins/tests/conf/
nagios-plugins-2.0.3/plugins/tests/conf/snmpd.conf
nagios-plugins-2.0.3/plugins/tests/var/
nagios-plugins-2.0.3/plugins/tests/var/ps-axwo.darwin
nagios-plugins-2.0.3/plugins/tests/var/root
nagios-plugins-2.0.3/plugins/tests/var/ps_axwo.debian
nagios-plugins-2.0.3/plugins/sslutils.c
nagios-plugins-2.0.3/plugins/check_mysql_query.c
nagios-plugins-2.0.3/plugins/check_nt.c
nagios-plugins-2.0.3/plugins/check_dns.c
nagios-plugins-2.0.3/plugins/check_ide_smart.c
nagios-plugins-2.0.3/plugins/check_dummy.c
nagios-plugins-2.0.3/plugins/check_procs.c
nagios-plugins-2.0.3/plugins/netutils.h
nagios-plugins-2.0.3/plugins/check_disk.c
nagios-plugins-2.0.3/plugins/check_hpjd.c
nagios-plugins-2.0.3/plugins/t/
nagios-plugins-2.0.3/plugins/t/check_udp.t
nagios-plugins-2.0.3/plugins/t/check_nagios.t
nagios-plugins-2.0.3/plugins/t/check_dbi.t
nagios-plugins-2.0.3/plugins/t/check_apt.t
nagios-plugins-2.0.3/plugins/t/check_dns.t
nagios-plugins-2.0.3/plugins/t/check_ftp.t
nagios-plugins-2.0.3/plugins/t/check_smtp.t
nagios-plugins-2.0.3/plugins/t/check_imap.t
nagios-plugins-2.0.3/plugins/t/check_snmp.t
nagios-plugins-2.0.3/plugins/t/check_jabber.t
nagios-plugins-2.0.3/plugins/t/check_fping.t
nagios-plugins-2.0.3/plugins/t/check_ntp.t
nagios-plugins-2.0.3/plugins/t/check_dummy.t
nagios-plugins-2.0.3/plugins/t/check_procs.t
nagios-plugins-2.0.3/plugins/t/check_http.t
nagios-plugins-2.0.3/plugins/t/negate.t
nagios-plugins-2.0.3/plugins/t/check_tcp.t
nagios-plugins-2.0.3/plugins/t/check_by_ssh.t
nagios-plugins-2.0.3/plugins/t/check_ssh.t
nagios-plugins-2.0.3/plugins/t/check_nagios.nagios2.status.dat
nagios-plugins-2.0.3/plugins/t/check_pop.t
nagios-plugins-2.0.3/plugins/t/check_mysql.t
nagios-plugins-2.0.3/plugins/t/check_disk.t
nagios-plugins-2.0.3/plugins/t/check_apt_input/
nagios-plugins-2.0.3/plugins/t/check_apt_input/ubuntu2
nagios-plugins-2.0.3/plugins/t/check_apt_input/debian2
nagios-plugins-2.0.3/plugins/t/check_apt_input/debian3
nagios-plugins-2.0.3/plugins/t/check_apt_input/ubuntu1
nagios-plugins-2.0.3/plugins/t/check_apt_input/debian1
nagios-plugins-2.0.3/plugins/t/check_swap.t
nagios-plugins-2.0.3/plugins/t/check_ping.t
nagios-plugins-2.0.3/plugins/t/check_mysql_query.t
nagios-plugins-2.0.3/plugins/t/check_time.t
nagios-plugins-2.0.3/plugins/t/check_nagios.nagios1.status.log
nagios-plugins-2.0.3/plugins/t/check_dig.t
nagios-plugins-2.0.3/plugins/t/check_users.t
nagios-plugins-2.0.3/plugins/t/check_cluster.t
nagios-plugins-2.0.3/plugins/t/check_load.t
nagios-plugins-2.0.3/plugins/t/check_hpjd.t
nagios-plugins-2.0.3/plugins/check_fping.c
nagios-plugins-2.0.3/plugins/check_uptime.c
nagios-plugins-2.0.3/plugins/check_ups.c
nagios-plugins-2.0.3/plugins/utils.c
nagios-plugins-2.0.3/plugins/urlize.c
nagios-plugins-2.0.3/plugins/check_nwstat.c
nagios-plugins-2.0.3/plugins/check_real.c
nagios-plugins-2.0.3/plugins/check_ssh.c
nagios-plugins-2.0.3/plugins/check_mysql.c
nagios-plugins-2.0.3/plugins/check_ntp_peer.c
nagios-plugins-2.0.3/plugins/common.h
nagios-plugins-2.0.3/plugins/runcmd.c
nagios-plugins-2.0.3/plugins/check_nagios.c
nagios-plugins-2.0.3/README
nagios-plugins-2.0.3/po/
nagios-plugins-2.0.3/po/de.po
nagios-plugins-2.0.3/po/ChangeLog
nagios-plugins-2.0.3/po/fr.gmo
nagios-plugins-2.0.3/po/fr.po
nagios-plugins-2.0.3/po/Makevars
nagios-plugins-2.0.3/po/Makefile.in.in
nagios-plugins-2.0.3/po/stamp-po
nagios-plugins-2.0.3/po/nagios-plugins.pot
nagios-plugins-2.0.3/po/de.gmo
nagios-plugins-2.0.3/po/remove-potcdate.sin
nagios-plugins-2.0.3/po/POTFILES.in
nagios-plugins-2.0.3/po/LINGUAS
nagios-plugins-2.0.3/m4/
nagios-plugins-2.0.3/m4/np_mysqlclient.m4
nagios-plugins-2.0.3/NPTest.pm
nagios-plugins-2.0.3/INSTALL
nagios-plugins-2.0.3/config.rpath
nagios-plugins-2.0.3/CODING
nagios-plugins-2.0.3/tap/
nagios-plugins-2.0.3/tap/tap.h
nagios-plugins-2.0.3/tap/Makefile.in
nagios-plugins-2.0.3/tap/Makefile.am
nagios-plugins-2.0.3/tap/README
nagios-plugins-2.0.3/tap/tap.c
nagios-plugins-2.0.3/tools/
nagios-plugins-2.0.3/tools/tinderbox_build
nagios-plugins-2.0.3/tools/build_perl_modules
nagios-plugins-2.0.3/plugins-scripts/
nagios-plugins-2.0.3/plugins-scripts/check_file_age.pl
nagios-plugins-2.0.3/plugins-scripts/check_ntp.pl
nagios-plugins-2.0.3/plugins-scripts/Makefile.in
nagios-plugins-2.0.3/plugins-scripts/check_ifoperstatus.pl
nagios-plugins-2.0.3/plugins-scripts/Makefile.am
nagios-plugins-2.0.3/plugins-scripts/subst.in
nagios-plugins-2.0.3/plugins-scripts/check_breeze.pl
nagios-plugins-2.0.3/plugins-scripts/check_log.sh
nagios-plugins-2.0.3/plugins-scripts/check_flexlm.pl
nagios-plugins-2.0.3/plugins-scripts/check_rpc.pl
nagios-plugins-2.0.3/plugins-scripts/check_oracle.sh
nagios-plugins-2.0.3/plugins-scripts/utils.pm.in
nagios-plugins-2.0.3/plugins-scripts/check_disk_smb.pl
nagios-plugins-2.0.3/plugins-scripts/t/
nagios-plugins-2.0.3/plugins-scripts/t/check_ifoperstatus.t
nagios-plugins-2.0.3/plugins-scripts/t/check_rpc.t
nagios-plugins-2.0.3/plugins-scripts/t/check_file_age.t
nagios-plugins-2.0.3/plugins-scripts/t/check_disk_smb.t
nagios-plugins-2.0.3/plugins-scripts/t/check_ifstatus.t
nagios-plugins-2.0.3/plugins-scripts/t/utils.t
nagios-plugins-2.0.3/plugins-scripts/check_mailq.pl
nagios-plugins-2.0.3/plugins-scripts/check_wave.pl
nagios-plugins-2.0.3/plugins-scripts/check_ircd.pl
nagios-plugins-2.0.3/plugins-scripts/utils.sh.in
nagios-plugins-2.0.3/plugins-scripts/check_ifstatus.pl
nagios-plugins-2.0.3/plugins-scripts/check_sensors.sh
nagios-plugins-2.0.3/pkg/
nagios-plugins-2.0.3/pkg/fedora/
nagios-plugins-2.0.3/pkg/fedora/requires
nagios-plugins-2.0.3/pkg/solaris/
nagios-plugins-2.0.3/pkg/solaris/preinstall
nagios-plugins-2.0.3/pkg/solaris/solpkg
nagios-plugins-2.0.3/pkg/solaris/pkginfo.in
nagios-plugins-2.0.3/pkg/redhat/
nagios-plugins-2.0.3/pkg/redhat/requires
If noticed the file REQUIREMENTS
rob@cure-redcap-info nagios-plugins-2.0.3$ grep -B3 snmp REQUIREMENTS
check_hpjd:
	- Requires the NET-SNMP package available from
	  http://net-snmp.sourceforge.net/
	  The snmpget binary is all that is required.
	  probably want to use radiusclient-ng. The original radiusclient library is
	  unmaintained and has many known issues, particularly with 64bit systems.
check_snmp:
There is where it says that the NET-SNMP package is required for check_snmp
I could not find any suggestion that only snmpget was required, where did you read that?
Rob Hassing
Kerflumpre
Net-SNMP is just another way to provide snmpget which is what check_snmp uses.
rhassing
Post by rhassing »
Have you tried installing net-snmp and checked if it solved your problem?
Rob Hassing
Kerflumpre
I'm working on it. Having trouble getting it to compile and install.
Kerflumpre
I've confirmed that what I have installed is net-snmp.
rhassing
Post by rhassing »
Is it working as expected now?
Rob Hassing
Kerflumpre
No change.
