report rendering to pdf broken after upgrade
CBoekhuis
Re: report rendering to pdf broken after upgrade
Post by CBoekhuis »
Sure, nor problem. The three uploaded screenshots are alert histogram's from monthly scheduled reports that run on the first of the month. These three screenshots show changes opposed to the previous reports.
Before 01-nov-2013 the graph looked fine, from 01-nov-2013 the graph has a thick grey line
from 01-feb-2014 it's a thick grey line with blue dots
from 01-jul-2014 it's a thick black line with blue dots
and starting 01-dec-2014 it stopped all together.
I can only guess which versions were running at these dates, but we are usually reasonably in sync with the new releases.
Greetings...Hans
I am happy that your original issue was resolved, but man, these graphs don't look right (not "before" and not "after")... I've seen this only once (a long time ago) and I can't remember what was causing it. :(
I will do some more digging into this and will get back to you.
Actually, I just noticed that these are very old graphs (the newest if from July 1, 2004). Can you verify that your graphs are fine now? Is it safe to lock this post as "resolved"? Thanks!
CBoekhuis
Post by CBoekhuis »
my collegue has a day off. The grafhs look fine now as far as we can judge.
So far its ok to set the post as "resolved".
Thanx for the help.
Regards,
Christian
