Nagios Log Server - Backup and Maintenance
Re: Nagios Log Server - Backup and Maintenance
this could be a mis-matched version of pip or virtualenv
Lets run the following
pip install --upgrade pip
pip install --upgrade virtualenv
then
curator -v
roddergreg
Post by roddergreg »
Requirement already up-to-date: pip in /usr/lib/python2.6/site-packages
Cleaning up...
Downloading/unpacking virtualenv
  Downloading virtualenv-1.11.6-py2.py3-none-any.whl (1.6MB): 1.6MB downloaded
Installing collected packages: virtualenv
Successfully installed virtualenv
Cleaning up...
curator -v
Traceback (most recent call last):
  File "/usr/bin/curator", line 5, in <module>
    from pkg_resources import load_entry_point
  File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 2655, in <module>
    working_set.require(__requires__)
  File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 648, in require
    needed = self.resolve(parse_requirements(requirements))
  File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 546, in resolve
    raise DistributionNotFound(req)
pkg_resources.DistributionNotFound: elasticsearch>=1.0.0,<2.0.0
roddergreg
Not running a CentOS install running RHEL 6.5 but i've googled this error. This page was found.
https://github.com/elasticsearch/curator/wiki/FAQ
Were you able to run the full path?
python /usr/lib/python2.6/site-packages/curator/curator.py -v
roddergreg
curator.py 1.2.2
The curator command runs successfully when I specify the full path
su nagios -c "python /usr/lib/python2.6/site-packages/curator/curator.py close --older-than 5"
2014-12-16 16:46:23,043 INFO      Job starting...
2014-12-16 16:46:23,115 INFO      Beginning CLOSE operations...
2014-12-16 16:46:23,155 INFO      Attempting to close index logstash-2014.12.07.
2014-12-16 16:46:23,164 INFO      Skipping index logstash-2014.12.07: Already closed.
2014-12-16 16:46:23,164 INFO      Attempting to close index logstash-2014.12.08.
2014-12-16 16:46:23,173 INFO      Skipping index logstash-2014.12.08: Already closed.
2014-12-16 16:46:23,173 INFO      Attempting to close index logstash-2014.12.09.
2014-12-16 16:46:23,181 INFO      Skipping index logstash-2014.12.09: Already closed.
2014-12-16 16:46:23,181 INFO      Attempting to close index logstash-2014.12.10.
2014-12-16 16:46:23,191 INFO      Skipping index logstash-2014.12.10: Already closed.
2014-12-16 16:46:23,192 INFO      Attempting to close index logstash-2014.12.11.
2014-12-16 16:46:23,965 INFO      logstash-2014.12.11: Successfully closed.
2014-12-16 16:46:23,966 INFO      logstash-2014.12.12 is within the threshold period (5 days).
2014-12-16 16:46:23,966 INFO      logstash-2014.12.13 is within the threshold period (5 days).
2014-12-16 16:46:23,966 INFO      logstash-2014.12.14 is within the threshold period (5 days).
2014-12-16 16:46:23,966 INFO      logstash-2014.12.15 is within the threshold period (5 days).
2014-12-16 16:46:23,966 INFO      logstash-2014.12.16 is within the threshold period (5 days).
2014-12-16 16:46:23,966 INFO      CLOSE index operations completed.
2014-12-16 16:46:23,966 INFO      Done in 0:00:00.933866.
jomann
Development Lead
Post by jomann »
Can you do a:
pip show elasticsearch
We are looking into a fix for this for the next release so this doesn't happen. As for now, you can change the curator command in cmdsubsys_helper.php if you'd like in the /var/www/html/nagioslogserver/application/helpers I would like the line numbers but there are multiple places in the file. You could find/replace "curator" with the full "python /x/x/x/curator.py" for now.
roddergreg
Version: 1.2.0
Requires: urllib3
I've replaced all the entries of curator in cmdsubsys_helper.php with /usr/lib/python2.6/site-packages/curator/curator.py
Thanks for the workaround.
lgroschen
Post by lgroschen »
So the backups are working fully now? Let us know if we can close this topic.
/Luke
roddergreg
curl -XGET 'http://localhost:9200/nagioslogserver/commands/_search?pretty&q=command:do_maintenance'
  "took" : 2,
  "timed_out" : false,
  "_shards" : {
    "total" : 1,
    "successful" : 1,
    "failed" : 0
  "hits" : {
    "total" : 1,
    "max_score" : 4.8642325,
    "hits" : [ {
      "_index" : "nagioslogserver",
      "_type" : "commands",
      "_id" : "7CefFIprSgmAv0HEM0dxPg",
      "_score" : 4.8642325,
      "_source":{"created":"2014-10-28 11:46:59","active":1,"status":"waiting","type":"system","node":"global","command":"do_maintenance","run_time":1418918191,"frequency":"86400","last_run_output":"Maintenance and Backup jobs are being executed","last_run_time":"2014-12-17 10:56:31","last_run_status":"SUCCESS"}
It appears the maintenance ran successfully. The indexes were closed older than 5 days and indexes older than 10 were deleted. However the the backup location is empty. So it appears the maintenance is running correctly but the backups are failing nothing is created.
lgroschen
Post by lgroschen »
You have them going to /tmp right? Anything change since you posted last?
Post a screenshot of your Backup & Maintenance page
/Luke
