(No output on stdout) stderr:
abrist
Red Shirt
Re: (No output on stdout) stderr:
Post by abrist »
Can you query other performance counters?
deepshikha20
Post by deepshikha20 »
PFA as requested.
cgi.cfg
cgi.cfg
(12.1 KiB) Downloaded 548 times
nagios.cfg
nagios.cfg
(44.74 KiB) Downloaded 486 times
resource.cfg
resource.cfg
(1.31 KiB) Downloaded 481 times
deepshikha20
I have tried few but didn't get any output.
Post by Box293 »
I believe your issues are with your nagios object definition files.
For example:
        host_name       fghi        ; The name we're giving to this host
        alias           ggggg       ; A longer name associated with the host
        address         10.40.10.2     ; IP address of the host
        hostgroups      servers
        address         10.40.1.33        ; IP address of the host
        check_period            24x7            ; By default, Windows servers are monitored round the clock
        check_interval          5               ; Actively check the server every 5 minutes
        retry_interval          1               ; Schedule host check retries at 1 minute intervals
        max_check_attempts      10              ; Check each server 10 times (max)
        check_command           check-host-alive        ; Default command to check if servers are "alive"
        notification_period     24x7            ; Send notification out at any time - day or night
        notification_interval   30              ; Resend notifications every 30 minutes
        notification_options    d,r             ; Only send notifications for specific host states
        contact_groups          admins          ; Notifications get sent to the admins by default
You have the address defined twice.
Also,
define hostgroup{
        hostgroup_name  sgxnet-servers ; The name of the hostgroup
        alias           sgxnet Servers ; Long name of the group
        members         jklm, fghi
There is no host called "jklm" however there is one called "jklmn". I assume you've changed some entries to hide the real names.
What is the output from:
/usr/local/nagios/bin/nagios -vvv /usr/local/nagios/etc/nagios.cfg
deepshikha20
There were no errors.PFB the output below.
yes, i have used different names to hide the real names.
host_name]:/usr/local/nagios/etc/objects >/usr/local/nagios/bin/nagios -vvv /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config file '/usr/local/nagios/etc/objects/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/templates.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/windows.cfg'...
Checking objects...
Checked 29 services.
Checked 4 hosts.
Checked 3 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 24 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 4 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Things look okay - No serious problems were detected during the pre-flight check.
Thanks.
Regards,
Deepshikha
We have noticed something in several other cases, that may solve your problems
Can you edit your nagios.cfg changing
enable_environment_macros=1
Then restart nagios
service nagios restart
Let us know if this resolves the issue
deepshikha20
This also didn't help.
It remains the same.
Regards,
Deepshikha
Post by Box293 »
Did you resolve the problems I highlighted with your definition files?
For example you have the address defined twice in one of your host definitions.
deepshikha20
yes, i have tried all the solutions which you have told.
Thanks.
Regards,
Deepshikha
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Just to be sure, could you post the three cfg files one more time please?
