Logs stop coming in
Re: Logs stop coming in
I am trying to confirm whether you and the OP in this topic are the same person. We can't close the topic if the OP's issue has not been resolved.
- globalgiving
This is OP. The other poster was not me or someone in my organization.
I increased the heap size and set the max locked memory as per the response I got, way back on the first page of this thread.
That did in fact solve my problem. I have not hit an issue where logs have stopped coming in anymore.
However, checking today on the system running NLS, I see that there are a lot of create_backup.sh processes running. They have been building up for a long time.. has not built to the point of causing elasticsearch to stop working.. but I am guessing that it will still eventually get there.
Process list on the NLS server:
ll /store/backups/nagioslogserver
All the state.json files contain the same thing:
Where should I look from here to figure out why these processes are not cleaning up?
nagios 707 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
nagios 708 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
nagios 709 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
nagios 710 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
nagios 711 0.0 0.0 100904 572 ? S 16:04 0:00 sleep 5
nagios 712 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
nagios 713 0.0 0.0 100904 572 ? S 16:04 0:00 sleep 5
nagios 714 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
nagios 715 0.0 0.0 100904 572 ? S 16:04 0:00 sleep 5
nagios 716 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
root 733 0.0 0.0 0 0 ? S 2014 7:48 [jbd2/sda3-8]
root 734 0.0 0.0 0 0 ? S 2014 0:00 [ext4-dio-unwrit]
nagios 752 0.0 0.0 100904 572 ? S 16:04 0:00 sleep 5
nagios 753 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
nagios 754 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
nagios 755 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
nagios 756 0.0 0.0 100904 572 ? S 16:04 0:00 sleep 5
nagios 757 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
nagios 758 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
nagios 759 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
nagios 760 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
nagios 761 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
nagios 762 0.0 0.0 100904 568 ? S 16:04 0:00 sleep 5
root 764 0.0 0.0 140176 1728 ? S 16:04 0:00 CROND
root 765 0.0 0.0 140176 1728 ? S 16:04 0:00 CROND
nagios 766 0.0 0.0 106092 1136 ? Ss 16:04 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1
nagios 767 2.0 0.0 216176 10636 ? S 16:04 0:00 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller
nagios 768 0.0 0.0 106092 1132 ? Ss 16:04 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 769 2.0 0.0 216176 10708 ? S 16:04 0:00 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
root 822 0.0 0.0 10736 784 ? S<s 2014 0:00 /sbin/udevd -d
root 1596 0.0 0.0 0 0 ? S 2014 0:00 [kjournald]
root 1630 0.0 0.0 0 0 ? S 2014 10:29 [flush-8:0]
root 1640 0.0 0.0 0 0 ? S 2014 0:52 [kauditd]
apache 1706 0.0 0.0 246188 15564 ? S Jan18 0:17 /usr/sbin/httpd
apache 1707 0.0 0.1 247164 16420 ? S Jan18 0:16 /usr/sbin/httpd
apache 1708 0.0 0.0 244768 13892 ? S Jan18 0:16 /usr/sbin/httpd
apache 1709 0.0 0.0 244772 13832 ? S Jan18 0:16 /usr/sbin/httpd
apache 1711 0.0 0.0 246592 14264 ? S Jan18 0:16 /usr/sbin/httpd
apache 1712 0.0 0.0 243236 12520 ? S Jan18 0:16 /usr/sbin/httpd
apache 1713 0.0 0.0 241592 11176 ? S Jan18 0:16 /usr/sbin/httpd
apache 1714 0.0 0.0 243256 11556 ? S Jan18 0:16 /usr/sbin/httpd
root 1772 0.0 0.0 0 0 ? S 2014 12:28 [bond0]
root 1951 0.0 0.0 93200 872 ? S<sl 2014 2:55 auditd
root 1967 0.0 0.0 485592 8308 ? Sl 2014 1:57 /sbin/rsyslogd -i /var/run/syslogd.pid -c 5
root 1981 0.0 0.0 10876 696 ? Ss 2014 21:16 irqbalance --pid=/var/run/irqbalance.pid
rpc 1995 0.0 0.0 18976 816 ? Ss 2014 0:04 rpcbind
rpcuser 2013 0.0 0.0 23348 1192 ? Ss 2014 0:00 rpc.statd
dbus 2127 0.0 0.0 21404 684 ? Ss 2014 0:00 dbus-daemon --system
root 2171 0.0 0.0 4080 576 ? Ss 2014 0:00 /usr/sbin/acpid
root 2243 0.0 0.0 385736 3368 ? Ssl 2014 0:42 automount --pid-file /var/run/autofs.pid
root 2260 0.0 0.0 197948 4700 ? S 2014 16:11 /usr/sbin/snmpd -LS0-6d -Lf /dev/null -p /var/run/snmpd.pid
root 2272 0.0 0.0 66616 1136 ? Ss 2014 0:00 /usr/sbin/sshd
root 2280 0.0 0.0 22180 848 ? Ss 2014 0:00 xinetd -stayalive -pidfile /var/run/xinetd.pid
root 2418 0.0 0.0 83060 2496 ? Ss 2014 1:12 sendmail: accepting connections
smmsp 2426 0.0 0.0 78656 2004 ? Ss 2014 0:00 sendmail: Queue runner@01:00:00 for /var/spool/clientmqueue
root 2449 0.0 0.0 110316 944 ? Ss 2014 0:00 /usr/sbin/abrtd
root 2491 0.0 0.0 238860 7880 ? Ss 2014 2:02 /usr/sbin/httpd
root 2499 0.0 0.0 117292 1260 ? Ss 2014 0:36 crond
root 2518 0.0 0.0 131172 1372 ? SN 2014 0:00 runuser -s /bin/sh -c exec /usr/local/nagioslogserver/logstash/bin/logstash agent -f /usr/local/nagioslogserver/logstash/etc/conf.d -l /var/log/lo
nagios 2520 8.1 5.0 14044052 817496 ? SNsl 2014 4830:27 /usr/bin/java -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp -Xmx500m -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -Djava.awt.headless=true -XX:CMSI
root 2581 0.0 0.0 342036 7580 ? Sl 2014 12:55 /usr/bin/python /usr/bin/fail2ban-server -b -s /var/run/fail2ban/fail2ban.sock
root 2583 0.0 0.0 9364 1040 ? S 2014 1:23 /usr/libexec/gam_server
root 2598 0.0 0.0 21540 484 ? Ss 2014 0:00 /usr/sbin/atd
root 2612 0.0 0.0 4064 528 tty1 Ss+ 2014 0:00 /sbin/mingetty /dev/tty1
root 2614 0.0 0.0 4064 528 tty2 Ss+ 2014 0:00 /sbin/mingetty /dev/tty2
root 2616 0.0 0.0 4064 528 tty3 Ss+ 2014 0:00 /sbin/mingetty /dev/tty3
root 2618 0.0 0.0 4064 532 tty4 Ss+ 2014 0:00 /sbin/mingetty /dev/tty4
root 2620 0.0 0.0 4064 532 tty5 Ss+ 2014 0:00 /sbin/mingetty /dev/tty5
root 2622 0.0 0.0 4064 528 tty6 Ss+ 2014 0:00 /sbin/mingetty /dev/tty6
root 2624 0.0 0.0 10732 748 ? S< 2014 0:00 /sbin/udevd -d
root 2625 0.0 0.0 10732 736 ? S< 2014 0:00 /sbin/udevd -d
root 7540 0.0 0.0 140176 1728 ? S Jan09 0:00 CROND
nagios 7545 0.0 0.0 106092 1132 ? Ss Jan09 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 7546 0.0 0.0 218504 10960 ? S Jan09 0:03 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 7779 0.0 0.0 106096 1292 ? S Jan09 2:22 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 8271 0.0 0.0 140176 1728 ? S Jan01 0:00 CROND
nagios 8277 0.0 0.0 106092 1136 ? Ss Jan01 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 8278 0.0 0.0 219020 11356 ? S Jan01 0:05 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 8299 0.0 0.0 106096 1292 ? S Jan01 3:53 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 9399 0.0 0.0 140176 1728 ? S Jan15 0:00 CROND
nagios 9401 0.0 0.0 106092 1136 ? Ss Jan15 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 9403 0.0 0.0 218248 10960 ? S Jan15 0:01 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 9924 0.0 0.0 106096 1292 ? S Jan15 1:11 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 11056 0.0 0.0 140176 1728 ? S Jan13 0:00 CROND
nagios 11058 0.0 0.0 106092 1132 ? Ss Jan13 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 11064 0.0 0.0 218248 10744 ? S Jan13 0:02 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 11508 0.0 0.0 106096 1292 ? S Jan13 1:34 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 11547 0.0 0.0 140176 1728 ? S Jan08 0:00 CROND
nagios 11552 0.0 0.0 106092 1132 ? Ss Jan08 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 11555 0.0 0.0 218504 10976 ? S Jan08 0:03 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 11732 0.0 0.0 106096 1296 ? S Jan08 2:34 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 12996 0.0 0.0 140176 1728 ? S Jan18 0:00 CROND
nagios 13000 0.0 0.0 106092 1132 ? Ss Jan18 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 13001 0.0 0.0 218248 10912 ? S Jan18 0:00 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
apache 13157 0.0 0.0 241072 10604 ? S 12:38 0:02 /usr/sbin/httpd
nagios 13683 0.0 0.0 106096 1292 ? S Jan18 0:37 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 14317 0.0 0.0 140176 1728 ? S Jan20 0:00 CROND
nagios 14321 0.0 0.0 106092 1132 ? Ss Jan20 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 14324 0.0 0.0 218248 10880 ? S Jan20 0:00 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 15077 0.0 0.0 106096 1292 ? S Jan20 0:14 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 15111 0.0 0.0 140176 1728 ? S Jan11 0:00 CROND
nagios 15114 0.0 0.0 106092 1136 ? Ss Jan11 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 15116 0.0 0.0 218504 10924 ? S Jan11 0:02 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 15460 0.0 0.0 106096 1296 ? S Jan11 1:58 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 18635 0.0 0.0 140176 1728 ? S Jan06 0:00 CROND
nagios 18639 0.0 0.0 106092 1132 ? Ss Jan06 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 18643 0.0 0.0 218504 11004 ? S Jan06 0:04 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 18762 0.0 0.0 106096 1292 ? S Jan06 2:57 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
apache 18784 0.0 0.0 241072 10420 ? S Jan20 0:16 /usr/sbin/httpd
root 19786 0.0 0.0 140176 1728 ? S Jan17 0:00 CROND
nagios 19788 0.0 0.0 106092 1132 ? Ss Jan17 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 19792 0.0 0.0 218248 10932 ? S Jan17 0:01 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
root 20016 0.0 0.0 140176 1728 ? S Jan04 0:00 CROND
nagios 20019 0.0 0.0 106092 1132 ? Ss Jan04 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 20020 0.0 0.0 219020 11304 ? S Jan04 0:04 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 20086 0.0 0.0 106096 1296 ? S Jan04 3:20 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
nagios 20439 0.0 0.0 106096 1296 ? S Jan17 0:49 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 20811 0.0 0.0 140176 1728 ? S Jan07 0:00 CROND
nagios 20815 0.0 0.0 106092 1128 ? Ss Jan07 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 20818 0.0 0.0 218504 10992 ? S Jan07 0:03 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 20987 0.0 0.0 106096 1296 ? S Jan07 2:44 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
apache 21858 0.0 0.0 246628 14808 ? S Jan20 0:16 /usr/sbin/httpd
root 24883 0.0 0.0 140176 1728 ? S Jan10 0:00 CROND
nagios 24886 0.0 0.0 106092 1132 ? Ss Jan10 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 24889 0.0 0.0 218504 10944 ? S Jan10 0:03 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 25198 0.0 0.0 106096 1296 ? S Jan10 2:10 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 27361 0.0 0.0 140176 1728 ? S Jan19 0:00 CROND
root 27362 0.0 0.0 140176 1728 ? S Jan12 0:00 CROND
nagios 27366 0.0 0.0 106092 1136 ? Ss Jan12 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 27367 0.0 0.0 106092 1132 ? Ss Jan19 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 27370 0.0 0.0 218504 10912 ? S Jan12 0:02 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 27372 0.0 0.0 218248 10896 ? S Jan19 0:00 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 27735 0.0 0.0 106096 1292 ? S Jan12 1:46 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
nagios 28088 0.0 0.0 106096 1296 ? S Jan19 0:25 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 32334 0.0 0.0 140176 1728 ? S Jan03 0:00 CROND
nagios 32338 0.0 0.0 106092 1132 ? Ss Jan03 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 32340 0.0 0.0 219020 11316 ? S Jan03 0:05 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 32390 0.0 0.0 106096 1292 ? S Jan03 3:31 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 35912 0.0 0.0 140176 1728 ? S Jan05 0:00 CROND
nagios 35918 0.0 0.0 106092 1128 ? Ss Jan05 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 35921 0.0 0.0 219020 11288 ? S Jan05 0:04 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 36003 0.0 0.0 106096 1292 ? S Jan05 3:07 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 36918 0.0 0.0 140176 1728 ? S Jan02 0:00 CROND
nagios 36921 0.0 0.0 106092 1132 ? Ss Jan02 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 36923 0.0 0.0 219020 11332 ? S Jan02 0:05 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 36950 0.0 0.0 106096 1296 ? S Jan02 3:45 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
nagios 37015 14.0 58.6 49121612 9548632 ? SLl 2014 4459:41 /usr/bin/java -Xms8g -Xmx8g -Xss256k -Djava.awt.headless=true -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:
root 39376 0.0 0.0 140176 1728 ? S Jan16 0:00 CROND
nagios 39380 0.0 0.0 106092 1128 ? Ss Jan16 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 39382 0.0 0.0 218248 10940 ? S Jan16 0:01 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 39938 0.0 0.0 106096 1292 ? S Jan16 1:00 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 47038 0.0 0.0 140176 1728 ? S Jan14 0:00 CROND
nagios 47042 0.0 0.0 106092 1132 ? Ss Jan14 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 47045 0.0 0.0 218248 10980 ? S Jan14 0:02 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
nagios 47545 0.0 0.0 106096 1296 ? S Jan14 1:24 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
root 47765 0.0 0.0 140176 1728 ? S 11:00 0:00 CROND
nagios 47769 0.0 0.0 106092 1132 ? Ss 11:00 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
nagios 47773 0.0 0.0 218248 11124 ? S 11:00 0:00 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
root 48439 0.0 0.0 140176 1728 ? S 16:03 0:00 CROND
nagios 48440 0.0 0.0 106092 1132 ? Ss 16:03 0:00 /bin/sh -c /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1
nagios 48443 0.0 0.0 216176 10640 ? S 16:03 0:00 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller
nagios 48586 0.0 0.0 106096 1308 ? S 11:00 0:02 /bin/sh /usr/local/nagioslogserver/scripts/create_backup.sh
drwxrwxrwx 2 nagios nagios 4096 Jan 1 11:00 1420128007
drwxrwxrwx 2 nagios nagios 4096 Jan 2 11:00 1420214412
drwxrwxrwx 2 nagios nagios 4096 Jan 3 11:00 1420300816
drwxrwxrwx 2 nagios nagios 4096 Jan 4 11:00 1420387216
drwxrwxrwx 2 nagios nagios 4096 Jan 5 11:00 1420473617
drwxrwxrwx 2 nagios nagios 4096 Jan 6 11:00 1420560022
drwxrwxrwx 2 nagios nagios 4096 Jan 7 11:00 1420646426
drwxrwxrwx 2 nagios nagios 4096 Jan 8 11:00 1420732827
drwxrwxrwx 2 nagios nagios 4096 Jan 9 11:00 1420819232
drwxrwxrwx 2 nagios nagios 4096 Jan 10 11:00 1420905636
drwxrwxrwx 2 nagios nagios 4096 Jan 11 11:00 1420992036
drwxrwxrwx 2 nagios nagios 4096 Jan 12 11:00 1421078437
drwxrwxrwx 2 nagios nagios 4096 Jan 13 11:00 1421164842
drwxrwxrwx 2 nagios nagios 4096 Jan 14 11:00 1421251241
drwxrwxrwx 2 nagios nagios 4096 Jan 15 11:00 1421337641
drwxrwxrwx 2 nagios nagios 4096 Jan 16 11:00 1421424043
drwxrwxrwx 2 nagios nagios 4096 Jan 17 11:00 1421510447
drwxrwxrwx 2 nagios nagios 4096 Jan 18 11:00 1421596846
drwxrwxrwx 2 nagios nagios 4096 Jan 19 11:00 1421683246
drwxrwxrwx 2 nagios nagios 4096 Jan 20 11:00 1421769646
drwxrwxrwx 2 nagios nagios 4096 Jan 21 11:00 1421856046
-rw-r--r-- 1 nagios nagios 5319621 Dec 30 11:00 nagioslogserver.2014-12-30.1419955201.tar.gz
-rw-r--r-- 1 nagios nagios 5323235 Dec 31 11:00 nagioslogserver.2014-12-31.1420041602.tar.gz
{"count":2,"states":[{"mode":"export","started":"2015-01-01T16:00:07.430Z","path":"file:///store/backups/nagioslogserver/1420128007/nagioslogserver.tar.gz","node_name":"3cb77924-3178-4ba3-8952-1f329efab29c"},{"mode":"export","started":"2015-01-14T16:00:41.732Z","path":"file:///store/backups/nagioslogserver/1421251241/nagioslogserver.tar.gz","node_name":"3cb77924-3178-4ba3-8952-1f329efab29c"}]}
Justin Rupp
Senior Systems Ninja
GlobalGiving Foundation
It might be not enough space to finish the backup (tar.gz). Could you issue the following command on your NLS:
df -h- globalgiving
Plenty of space:
$ df -h
/dev/sda3 908G 127G 736G 15% /
tmpfs 7.8G 0 7.8G 0% /dev/shm
/dev/sda1 243M 57M 173M 25% /boot
Justin Rupp
Lets try this
service elasticsearch restart- globalgiving
So that did cause all of the backup processes to complete. The /store/backups/nagioslogserver directory now has completed backups in it. I will post tomorrow if tonight's backup gets stuck.
Justin Rupp
We have seen this in house too and are looking for resolution in future versions.
