Nagios Log Server not sending alert Emails
muratKURU
Re: Nagios Log Server not sending alert Emails
Post by muratKURU »
Can you tell me where I can find the SMTP settings on CentOS?
Below you can see the Mail Settings on the GUI
Out of curiosity, could the sending problem you were having be related to the DNS issue here
http://support.nagios.com/forum/viewtop ... 90#p128345
Any instance can be the sender of the email message, so all would need to ne able to resolve the DNS properly.
muratKURU
Post by muratKURU »
No it's not.
Even after having corrected the DNS, we are still not able send Alarms via E-Mail.
Same error as reported.
ssax
Dreams In Code
Post by ssax »
Did you verify that you've added the host to the allowed relay list on your mail server?
jolson
Attack Rabbit
Post by jolson »
The solution here is very likely the following:
Edit /var/www/html/nagioslogserver/system/libraries/Email.php and change (around line 48):
    var $newline      = "\n";
    var $crlf         = "\n";
To:
    var $newline      = "\r\n";
    var $crlf         = "\r\n";
Twits Blog
lgroschen
Post by lgroschen »
Jesse is likely right, some mail servers wont accept anything not RFC-compliant.
This bug has been fixed:
http://api.nagios.com/tps/viewtask.php?task_id=5651
/Luke
