How to Add Windows Mailqueue Notification
rlinux57
Re: How to Add Windows Mailqueue Notification
Post by rlinux57 »
Great it's working perfectly fine.
Now how can i add this command in nagios monitoring server ?
/usr/lib64/nagios/plugins/check_nrpe -H 142.4.215.171 -t 30 -c CheckFiles -a path='C:\\Program Files (x86)\\Parallels\\Plesk\\Mail Servers\\Mail Enable\\Queues\\SMTP\\Outgoing\\Messages' pattern=*.* 'master-syntax={%total% Files Found}' MaxWarn=500 MaxCrit=1000
{1 Files Found}|'found files'=1;500;1000
Post by Box293 »
Excellent, we are making good progress.
You will need a command:
       command_name                  		nrpe_checkfiles
       command_line                  		$USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c CheckFiles -a $ARG1$
And a service (I've assigned it to the host named "142.4.215.171"):
	host_name			142.4.215.171
	service_description		Plesk Outgoing Messages File Count
	use				local-service
	check_command			nrpe_checkfiles!path='C:\\Program Files (x86)\\Parallels\\Plesk\\Mail Servers\\Mail Enable\\Queues\\SMTP\\Outgoing\\Messages' pattern=*.* 'master-syntax={%total% Files Found}' MaxWarn=500 MaxCrit=1000
	register			1
Something like that
rlinux57
Post by rlinux57 »
Gettings error in nagstamon: no handler for command check_winmailqueue
command_name check_winmailqueue
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c check_winmailqueue -a $ARG1$
host_name winserver
service_description Mail Queue
register 1
Post by Box293 »
This is incorrect:
It should be:
This is incorrect:
It should be:
check_command check_winmailqueue!path='C:\\Program Files (x86)\\Parallels\\Plesk\\Mail Servers\\Mail Enable\\Queues\\SMTP\\Outgoing\\Messages' pattern=*.* 'master-syntax={%total% Files Found}' MaxWarn=500 MaxCrit=1000
rlinux57
Post by rlinux57 »
It's working perfectly fine. You can check this ticket now.
I sincerely appreciate your kind support, please accept my sincere thanks.
Your co-operation will be highly appriciated. :)
