Capacity Planning Graphs - values not JSON compliant
Re: Capacity Planning Graphs - values not JSON compliant
I've followed all the instructions on the link. I do get this error
192.168.21.4_149.rrd 192.168.45.2_12.rrd 192.168.7.6_4.rrd
192.168.21.4_14.rrd 192.168.45.2_13.rrd 192.168.7.6_5.rrd
192.168.21.4_153.rrd 192.168.45.2_14.rrd 192.168.7.6_6.rrd
192.168.21.4_157.rrd 192.168.45.2_15.rrd mrtg.ok
[root@localhost mrtg]# ./check_rrdtraf -f '/var/lib/mrtg/192.168.7.6_4.rrd' -w 1 -c 2
-bash: ./check_rrdtraf: No such file or directory
I also did not have this directory and created it: mkdir /var/lock/mrtg
I deleted unused IP addresses as instructed from
I am applying the fix now from section ICMP and Ping Checks Stopped Graphing After XI 2014 Upgrade . - Missed it the first time executing ./fix_ds_quantity.sh -i -d /usr/local/nagios/share/perfdata/
Let us know of the result. This should fix any rrds with datasource quantity mismatches.FLCUISIT wrote:I am applying the fix now from section ICMP and Ping Checks Stopped Graphing After XI 2014 Upgrade . - Missed it the first time executing ./fix_ds_quantity.sh -i -d /usr/local/nagios/share/perfdata/
Also:
This command must be run from the plugins (libexec) folder:FLCUISIT wrote:[root@localhost mrtg]# ./check_rrdtraf -f '/var/lib/mrtg/192.168.7.6_4.rrd' -w 1 -c 2
/usr/local/nagios/libexec/check_rrdtraf -f '/var/lib/mrtg/192.168.7.6_4.rrd' -w 1 -c 2Former Nagios employee
The fix corrected some of the graphs and more now show data collected since yesterday - However many more still do not show data. Appears to be the older monitors configured (in previous versions) and most windows hosts.
Checking the rrd folder /var/lib/mrtg/ only displays files with IP addresses like switches and routers. Running the check command /usr/local/nagios/libexec/check_rrdtraf -f '/var/lib/mrtg/<servername>.rrd' -w 1 -c 2 returns file does not exist. See attached - Ajax is a switch
These rrd files are found in the folder but return no values and do not display any data in the capacity graphs
[root@localhost mrtg]# /usr/local/nagios/libexec/check_rrdtraf -f '/var/lib/mrtg/192.168.5.4_10.rrd' -w 1 -c 2
OK - Current BW in: 0bps Out: 0bps|in=0b/s;1;2 out=0b/s;1;2
[root@localhost mrtg]# /usr/local/nagios/libexec/check_rrdtraf -f '/var/lib/mrtg/192.168.5.4_11.rrd' -w 1 -c 2
[root@localhost mrtg]# /usr/local/nagios/libexec/check_rrdtraf -f '/var/lib/mrtg/192.168.5.4_12.rrd' -w 1 -c 2
[root@localhost mrtg]# /usr/local/nagios/libexec/check_rrdtraf -f '/var/lib/mrtg/192.168.5.4_13.rrd' -w 1 -c 2
[root@localhost mrtg]# /usr/local/nagios/libexec/check_rrdtraf -f '/var/lib/mrtg/192.168.5.4_14.rrd' -w 1 -c 2
[root@localhost mrtg]# /usr/local/nagios/libexec/check_rrdtraf -f '/var/lib/mrtg/192.168.5.4_15.rrd' -w 1 -c 2
From the support page: http://support.nagios.com/wiki/index.ph ... _Displayed
•Make sure none of the mrtg.cfg entries are using SNMP v2c. Older verions of the Switch Wizard called mrtg with arguments for SNMPv2c, which MRTG does not use. Open up /etc/mrtg/mrtg.cfg and look for
Target[www.hostaddress.com]: 1:[email protected]:::::1
Notice that after the multitude of colons, there is a 1, this represents the SNMP version MRTG will use to poll the device. If this is instead 2c, change it to 2 and save the file. This will need to be done to every metric that is affected by being created with 2c.
I have the following in my file
I do not have Target[www.hostaddress.com]: 1:[email protected]:::::1 in this file. But in each of the *.cfg files in the /conf.d/ sub folder there appears to be that line. Once again not all of my hosts are listed in the conf.d subfolder. Only the routers in the conf.d subfolder have the ::::::2 value at the end all of the switch IP .cfg files have no value
[root@localhost conf.d]# grep -i 'target' 192.168.3.4.cfg
Target[192.168.3.4_1]: 1:[email protected]:
Target[192.168.3.4_2]: 2:[email protected]:
Target[192.168.3.4_3]: 3:[email protected]:
Target[192.168.3.4_4]: 4:[email protected]:
# Target[192.168.3.4_5]: 5:[email protected]:
Target[192.168.3.4_6]: 6:[email protected]:
# Target[192.168.3.4_7]: 7:[email protected]:
Target[192.168.3.4_8]: 8:[email protected]:
Target[192.168.3.4_9]: 9:[email protected]:
Target[192.168.3.4_10]: 10:[email protected]:
Target[192.168.3.4_11]: 11:[email protected]:
Target[192.168.3.4_12]: 12:[email protected]:
Target[192.168.3.4_13]: 13:[email protected]:
# Target[192.168.3.4_14]: 14:[email protected]:
Target[192.168.3.4_15]: 15:[email protected]:
Target[192.168.3.4_16]: 16:[email protected]:
Target[192.168.3.4_17]: 17:[email protected]:
Target[192.168.3.4_18]: 18:[email protected]:
Target[192.168.3.4_19]: 19:[email protected]:
Target[192.168.3.4_20]: 20:[email protected]:
Target[192.168.3.4_21]: 21:[email protected]:
Target[192.168.3.4_22]: 22:[email protected]:
Target[192.168.3.4_23]: 23:[email protected]:
# Target[192.168.3.4_24]: 24:[email protected]:
# Target[192.168.3.4_25]: 25:[email protected]:
Target[192.168.3.4_26]: 26:[email protected]:
Target[192.168.3.4_27]: 27:[email protected]:
Target[192.168.3.4_28]: 28:[email protected]:
However, when I use the current wizard for switch and router it defaults to SNMPv2c - Is it possible that these older configuration used an invalid SNMP string and my mrtg data has not been collecting for some time?
[root@localhost mrtg]# cat mrtg.cfg
# Multi Router Traffic Grapher -- Example Configuration File
# This file is for use with mrtg-2.0
# Note:
# * Keywords must start at the begin of a line.
# * Lines which follow a keyword line which do start
# with a blank are appended to the keyword line
# * Empty Lines are ignored
# * Lines starting with a # sign are comments.
# Where should the logfiles, and webpages be created?
# Minimal mrtg.cfg
HtmlDir: /var/www/mrtg
ImageDir: /var/www/mrtg
LogFormat: rrdtool
LogDir: /var/lib/mrtg
ThreshDir: /var/lib/mrtg
WorkDir: /var/lib/mrtg
Include: conf.d/*.cfg
Forks: 4
I deleted one of my switch monitors and recreated it with the wizard yesterday afternoon. The capacity planning graphs display a blank panel with no error or message now - Performance graphs are displaying
Did you also remove the old configs and mrtgscans from "/usr/local/nagiosxi/tmp" folder? Did you test the mrtg config for errors?I deleted one of my switch monitors and recreated it with the wizard yesterday afternoon.
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfghttp://assets.nagios.com/downloads/nagi ... Router.pdf
Ok I will follow the steps outlined for the two I recreated.
However the Capacity Planning Graphs show blank for ALL hosts, not just the ones I recreated.
In other words, if I try to access 50 hosts graphs per page, I get 50 of the blank graphs like I posted in the attachment above. There is no host name or service name displayed and no data, just the blank frame sections.
After looking at the mrtg.cfg it has a statement that includes all the .CFG files from /etc/mrtg/conf.d
I ran LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg .check
and found several errors - I deleted those .cfg files that were in error and now have clean report. I deleted any monitors associated with those .cfg files and Still no capacity graphs
I believe we will need to move this to our email ticketing system and get our developers involved. Can you send us your latest profile to [email protected]? Type "Capacity Planning Graphs - values not JSON compliant" in the email's subject filed.
Admin->System Profile->Download Profile
