Apply Configuration does not work after 2.6 upgrade
Re: Apply Configuration does not work after 2.6 upgrade
I fixed the \n problem by upgrading to the latest gearman as described in Integrating_Mod_Gearman_with_Nagios_XI.pdf.
check_gearman: version 1.5.0b1 running on libgearman 1.1.8
Guess what, suddenly the Apply Configuration started to work fine again.
Will confirm again tomorrow if it still works.
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
RHEL 6 & 7
I'm glad your issue has been resolved! Let us know if it is safe to lock this topic.
Can you please advice how to have the services start up in correct sequence on reboot?lmiltchev wrote:I'm glad your issue has been resolved! Let us know if it is safe to lock this topic.
Looks like gearman is not starting up since I just uninstalled and installed a new version.
This is easily fixed but I want to ensure it follows the correct sequence.
RHEL 6 & 7
RHEL 6 & 7
Bad news. Apply Configuration does not work anymore.
It seems Nagios starts for a moment and dies.
I was checking using service nagios status when Apply Configuration.
RHEL 6 & 7
RHEL 6 & 7
Did you update gearman on your workers as well?
Do you have multiple nagios parent processes running?
Also, Are the old gearman processes still running?
ps -aef | grep nagios.cfgCode: Select all
ps -aef | grep gearmanFormer Nagios employee
abrist wrote:Did you update gearman on your workers as well?
Do you have multiple nagios parent processes running?Also, Are the old gearman processes still running?Code: Select all
Currently we have only 1 worker in the same machine.
[nagios@nagiosprodxi1 ~]$ ps -aef | grep nagios.cfg
nagios 2205 1 10 Mar18 ? 01:19:14 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 4645 1696 0 07:07 pts/0 00:00:00 grep nagios.cfg
nagios 7250 2205 0 Mar18 ? 00:00:20 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
[nagios@nagiosprodxi1 ~]$ ps -aef | grep gearman
nagios 682 1512 0 05:56 ? 00:00:13 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 1131 1512 0 06:55 ? 00:00:01 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 1132 1512 0 06:55 ? 00:00:02 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 1133 1512 0 06:55 ? 00:00:01 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 1134 1512 0 06:55 ? 00:00:02 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
gearmand 1295 1 19 Mar18 ? 02:31:47 /usr/sbin/gearmand -d
nagios 1317 1512 0 06:55 ? 00:00:01 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 1318 1512 0 06:55 ? 00:00:01 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 1319 1512 0 06:55 ? 00:00:01 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 1320 1512 0 06:55 ? 00:00:01 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 1321 1512 0 06:55 ? 00:00:01 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 1448 1512 0 06:17 ? 00:00:08 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 1451 1512 0 06:17 ? 00:00:08 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 1512 1 0 Mar18 ? 00:00:17 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 1623 1512 0 06:17 ? 00:00:08 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 1626 1512 0 06:17 ? 00:00:08 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 2197 1512 0 05:59 ? 00:00:12 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 2198 1512 0 05:59 ? 00:00:11 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 3577 1512 0 05:02 ? 00:00:24 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 4135 1512 1 07:01 ? 00:00:00 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 4702 26338 44 07:02 ? 00:00:00 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 4970 1512 0 05:40 ? 00:00:16 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 6062 1512 0 07:00 ? 00:00:00 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 6064 1512 0 07:00 ? 00:00:00 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 6065 1512 0 07:00 ? 00:00:00 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 6066 1512 0 07:00 ? 00:00:00 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 6310 1512 0 04:38 ? 00:00:25 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 6456 1512 0 07:00 ? 00:00:00 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 6457 1512 0 07:00 ? 00:00:00 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 6458 1512 0 07:00 ? 00:00:00 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 6459 1512 0 07:00 ? 00:00:00 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 6460 1512 0 07:00 ? 00:00:00 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 6901 1512 0 06:03 ? 00:00:11 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 6906 1512 0 06:03 ? 00:00:11 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 8676 1512 0 06:26 ? 00:00:06 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 8686 1696 0 07:02 pts/0 00:00:00 grep gearman
nagios 8853 1512 0 06:29 ? 00:00:05 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 8855 1512 0 06:29 ? 00:00:06 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 9171 1512 0 06:59 ? 00:00:00 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 9416 1512 0 05:21 ? 00:00:19 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 10720 1512 0 04:52 ? 00:00:26 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 11772 1512 0 05:25 ? 00:00:19 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 11973 1512 0 06:47 ? 00:00:03 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 11974 1512 0 06:47 ? 00:00:03 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 11975 1512 0 06:47 ? 00:00:02 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 11976 1512 0 06:47 ? 00:00:04 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 12188 1512 0 06:31 ? 00:00:06 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 12763 1512 0 06:28 ? 00:00:05 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 12764 1512 0 06:28 ? 00:00:06 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 12765 1512 0 06:28 ? 00:00:06 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 16542 1512 0 05:41 ? 00:00:14 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 17514 1512 0 06:54 ? 00:00:01 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 18354 1512 0 04:25 ? 00:00:30 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 19036 1512 0 06:39 ? 00:00:04 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 19039 1512 0 06:39 ? 00:00:04 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 19040 1512 0 06:39 ? 00:00:04 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 19569 1512 0 04:05 ? 00:00:31 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 20023 1512 0 06:00 ? 00:00:11 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 20092 1512 0 07:01 ? 00:00:00 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 21069 1512 0 06:19 ? 00:00:08 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 21070 1512 0 06:19 ? 00:00:08 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 22343 1512 0 05:28 ? 00:00:17 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 22585 1512 0 06:04 ? 00:00:11 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 23941 1512 0 06:31 ? 00:00:06 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 23946 1512 0 06:31 ? 00:00:05 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 24021 1512 0 05:22 ? 00:00:18 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 24195 1512 0 05:54 ? 00:00:12 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 24197 1512 0 05:54 ? 00:00:11 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 25945 1512 0 06:34 ? 00:00:04 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 26241 1512 0 04:05 ? 00:00:30 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 26338 1512 0 06:14 ? 00:00:09 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 26342 1512 0 06:14 ? 00:00:08 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 26343 1512 0 06:14 ? 00:00:08 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 26652 1512 0 06:14 ? 00:00:09 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 26653 1512 0 06:14 ? 00:00:08 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 26656 1512 0 06:14 ? 00:00:08 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 26907 1512 0 05:50 ? 00:00:12 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 27997 1512 0 06:43 ? 00:00:04 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 27999 1512 0 06:43 ? 00:00:04 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 28000 1512 0 06:43 ? 00:00:03 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 28001 1512 0 06:43 ? 00:00:04 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 28714 1512 0 06:34 ? 00:00:06 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 28715 1512 0 06:34 ? 00:00:05 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 28716 1512 0 06:34 ? 00:00:05 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 28848 1512 0 05:08 ? 00:00:21 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 29000 1512 0 06:13 ? 00:00:08 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 29003 1512 0 06:13 ? 00:00:09 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 29274 1512 0 05:25 ? 00:00:17 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 29277 1512 0 05:25 ? 00:00:17 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 30434 1512 0 05:32 ? 00:00:18 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 30576 1512 0 06:49 ? 00:00:02 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 32524 6310 16 07:02 ? 00:00:00 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pid
nagios 32761 1512 0 06:36 ? 00:00:05 /usr/bin/mod_gearman_worker -d --config=/etc/mod_gearman/mod_gearman_worker.conf --pidfile=/var/mod_gearman/mod_gearman_worker.pidps -e
RHEL 6 & 7
RHEL 6 & 7
- Box293
- Too Basu
gearmand -V
/usr/bin/mod_gearman_worker -VAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Box293 wrote:Code: Select all
gearmand -V /usr/bin/mod_gearman_worker -V
[nagios@nagiosprodxi1 ~]$ gearmand -V
gearmand 1.1.8 - https://bugs.launchpad.net/gearmand
[nagios@nagiosprodxi1 ~]$ /usr/bin/mod_gearman_worker -V
mod_gearman_worker: version 1.5.0b1 running on libgearman 1.1.8
RHEL 6 & 7
RHEL 6 & 7
Are you still having problems Applying Configurations?
If so, login as root and run the following and post the results here.
./reconfigure_nagios.sh
Yes, still having issues. Sometimes it works fine which baffles me.tgriep wrote:Are you still having problems Applying Configurations?
If so, login as root and run the following and post the results here.Code: Select all
cd /usr/local/nagiosxi/scripts ./reconfigure_nagios.sh
CPU, Memory everything checks out ok.
Running the script under root no errors.
Nagios starts up and then dies
Starting up nagios using root - service nagios start
Nagios does not start up
Starting up nagios using nagios id - service nagios start
Nagios starts up
Output is listed below.
[root@nagiosprodxi1 ~]# cd /usr/local/nagiosxi/scripts
[root@nagiosprodxi1 scripts]# ./reconfigure_nagios.sh
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=nagiosqldb' -O nagiosql.login--2015-03-20 07:00:59-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... ::1, 127.0.0.1
Connecting to localhost|::1|:80... connected.
Length: unspecified [text/html]
Saving to: ânagiosql.loginâ
[ <=> ] 10,320 --.-K/s in 0.006s
2015-03-20 07:01:00 (1.69 MB/s) - ânagiosql.loginâ
LOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...URL: http://localhost/nagiosxi/includes/components/ccm/
Array
SETUID ROOT OK
RESETTING PERMS
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=nagiosqldb' -O nagiosql.login--2015-03-20 07:01:02-- http://localhost/nagiosxi/includes/components/ccm/
[ <=> ] 10,320 --.-K/s in 0.01s
2015-03-20 07:01:02 (1.01 MB/s) - ânagiosql.loginâ
LOGIN SUCCESSFUL!
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
Saving to: ânagiosql.export.monitoringâ
[ <=> ] 13,172 4.79K/s in 8.0s
2015-03-20 07:01:11 (1.60 KB/s) - ânagiosql.export.monitoringâ
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for service 'AS400 Disk Usage System Alt' on host 'Cambodia_UAT_SIT_DR' (config file '/usr/local/nagios/etc/services/TRACSPROD-AS400-ALT-Disk-Usage_XSSL.cfg', starting on line 16)
Warning: Duplicate definition found for service 'AS400 Disk Usage System Alt' on host 'Cambodia_S06FF69' (config file '/usr/local/nagios/etc/services/AS400-ALT-Disk-Usage_XSSL.cfg', starting on line 14)
Checking objects...
Checked 13911 services.
Checked 1763 hosts.
Checked 208 host groups.
Checked 11 service groups.
Checked 155 contacts.
Checked 46 contact groups.
Checked 175 commands.
Checked 67 time periods.
Checked 0 host escalations.
Checked 1763 hosts
Checked 690 service dependencies
Checked 0 host dependencies
Checked 67 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
RET: 0
Running configuration check...done.
Stopping nagios: ..done.
Starting nagios: done.
[root@nagiosprodxi1 scripts]# service nagios status
nagios (pid 19686) is running...
nagios is not running
You have new mail in /var/spool/mail/root
[root@nagiosprodxi1 scripts]# service nagios start
[root@nagiosprodxi1 scripts]# su - nagios service nagios start
nagios (pid 15363) is running...
RHEL 6 & 7
RHEL 6 & 7
