Invalid Freshness Alarms
vinzclortho
Re: Invalid Freshness Alarms
Post by vinzclortho »
I just wanted to post an update. We have been running since Thursday using the new check_results strategy and have not seen any invalid alarms. It seems that the issue was related to that command pipe corruption that I found.
I think it would be prudent to clear out the contents of the buf variable in command_input_handler after each process_external_command1 run. It's certainly not ideal to have corruption pop up at all, but I don't see any reason to keep bogus commands around in that variable to (possibly) be executed later.
cmerchant
Post by cmerchant »
Thank you for the update. I'm sure it will be helpful for those who use the external command pipe to know. Can I close this thread?
vinzclortho
Sure, my problem is fixed since we're not using the command pipe anymore. I still think it would be good to patch nagios to fix this command pipe behavior.
cmerchant
Post by cmerchant »
I have submitted a bug report on github for Nagios Core. We'll close this thread for now.
https://github.com/NagiosEnterprises/na ... /issues/35
