Automate Linux NRPE installation
cmerchant
Re: Automate Linux NRPE installation
Post by cmerchant »
Running './A-subcomponents'...
chown: invalid user: `nagios:nagios'
This message would indicate to me that the 2-usergroups was not completed. (you actually mentioned you had added the users in a previous post).
Could you issue the following command:
grep nagios /etc/group
grep nagios /etc/passwd
BTW, could you tell us what version of SUSE the linux agent is being installed in.
cat /etc/*release
ssax
Dreams In Code
Post by ssax »
Since the nagios user/group is already created, can't you just removed the nagios/nagcmd user/group, delete the file that you touched to skip it, and try reinstalling again? I assume the nagios/nagcmd user/group won't be on the rest of them, right?
jkinning
Post by jkinning »
nagios:!:106:
nagcmd:!:107:nagios
nagios:x:105:106:User for Nagios:/var/lib/nagios:/bin/bash
cat /etc/*release
LSB_VERSION="core-2.0-noarch:core-3.2-noarch:core-4.0-noarch:core-2.0-x86_64:core-3.2-x86_64:core-4.0-x86_64"
SUSE Linux Enterprise Desktop 11 (x86_64)
VERSION = 11
PATCHLEVEL = 3
VERSION = 11
PATCHLEVEL = 3
cat /etc/*release
SUSE Linux Enterprise Server 11 (x86_64)
VERSION = 11
PATCHLEVEL = 3
cmerchant
Post by cmerchant »
Could I have you check the following (as root):
id nagios
chage -l nagios
