LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfgCode: Select all
[root@usxlc01nagios01 ~]# LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg
Subroutine SNMP_Session::pack_sockaddr_in6 redefined at /usr/share/perl5/vendor_perl/Exporter.pm line 66.
at /usr/bin/../lib/mrtg2/SNMP_Session.pm line 149.
Subroutine SNMP_Session::unpack_sockaddr_in6 redefined at /usr/share/perl5/vendor_perl/Exporter.pm line 66.
Subroutine SNMPv1_Session::pack_sockaddr_in6 redefined at /usr/share/perl5/vendor_perl/Exporter.pm line 66.
at /usr/bin/../lib/mrtg2/SNMP_Session.pm line 604.
Subroutine SNMPv1_Session::unpack_sockaddr_in6 redefined at /usr/share/perl5/vendor_perl/Exporter.pm line 66.
SNMP Error:
no response received
SNMPv2c_Session (remote host: "192.0.2.25" [192.0.2.25].161)
community: "<removed>"
request ID: 825681157
PDU bufsize: 8000 bytes
timeout: 2s
retries: 5
backoff: 1)
at /usr/bin/../lib/mrtg2/SNMP_util.pm line 497.
SNMPGET Problem for ifInOctets.1 ifOutOctets.1 on **biz-info-read**@192.0.2.25:161::::2:v4only
at /usr/bin/mrtg line 2330.
2015-07-15 11:17:16: WARNING: skipping because at least the query for ifInOctets.1 on 192.0.2.25 did not succeed
2015-07-15 11:17:16: WARNING: no data for ifInOctets&ifOutOctets:**biz-info-read**@192.0.2.25. Skipping further queries for Host 192.0.2.25 in this round.
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_1][_IN_] ' $target->[11]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_1][_OUT_] ' $target->[11]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_3][_IN_] ' $target->[12]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_3][_OUT_] ' $target->[12]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_6][_IN_] ' $target->[13]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_6][_OUT_] ' $target->[13]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_7][_IN_] ' $target->[14]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_7][_OUT_] ' $target->[14]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_8][_IN_] ' $target->[15]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_8][_OUT_] ' $target->[15]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_10][_IN_] ' $target->[16]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_10][_OUT_] ' $target->[16]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_14][_IN_] ' $target->[17]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_14][_OUT_] ' $target->[17]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_15][_IN_] ' $target->[18]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_15][_OUT_] ' $target->[18]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_16][_IN_] ' $target->[19]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[192.0.2.25_16][_OUT_] ' $target->[19]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.91_671088642][_IN_] ' $target->[309]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.91_671088642][_OUT_] ' $target->[309]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.91_671088643][_IN_] ' $target->[310]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.91_671088643][_OUT_] ' $target->[310]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.91_2013265971][_IN_] ' $target->[326]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.91_2013265971][_OUT_] ' $target->[326]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_49][_IN_] ' $target->[1427]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_49][_OUT_] ' $target->[1427]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_53][_IN_] ' $target->[1431]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_53][_OUT_] ' $target->[1431]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_57][_IN_] ' $target->[1435]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_57][_OUT_] ' $target->[1435]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_61][_IN_] ' $target->[1439]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_61][_OUT_] ' $target->[1439]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_63][_IN_] ' $target->[1441]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_63][_OUT_] ' $target->[1441]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_65][_IN_] ' $target->[1443]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_65][_OUT_] ' $target->[1443]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_67][_IN_] ' $target->[1445]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_67][_OUT_] ' $target->[1445]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_69][_IN_] ' $target->[1447]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_69][_OUT_] ' $target->[1447]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_71][_IN_] ' $target->[1449]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_71][_OUT_] ' $target->[1449]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_73][_IN_] ' $target->[1451]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_73][_OUT_] ' $target->[1451]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_75][_IN_] ' $target->[1453]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_75][_OUT_] ' $target->[1453]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_77][_IN_] ' $target->[1455]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_77][_OUT_] ' $target->[1455]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_79][_IN_] ' $target->[1457]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_79][_OUT_] ' $target->[1457]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_81][_IN_] ' $target->[1459]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_81][_OUT_] ' $target->[1459]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_87][_IN_] ' $target->[1465]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_87][_OUT_] ' $target->[1465]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_89][_IN_] ' $target->[1467]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_89][_OUT_] ' $target->[1467]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_91][_IN_] ' $target->[1469]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_91][_OUT_] ' $target->[1469]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_93][_IN_] ' $target->[1471]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_93][_OUT_] ' $target->[1471]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_95][_IN_] ' $target->[1473]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_95][_OUT_] ' $target->[1473]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_97][_IN_] ' $target->[1475]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_97][_OUT_] ' $target->[1475]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_99][_IN_] ' $target->[1477]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_99][_OUT_] ' $target->[1477]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_101][_IN_] ' $target->[1479]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_101][_OUT_] ' $target->[1479]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_103][_IN_] ' $target->[1481]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_103][_OUT_] ' $target->[1481]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_105][_IN_] ' $target->[1483]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_105][_OUT_] ' $target->[1483]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_107][_IN_] ' $target->[1485]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_107][_OUT_] ' $target->[1485]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_109][_IN_] ' $target->[1487]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_109][_OUT_] ' $target->[1487]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_111][_IN_] ' $target->[1489]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_111][_OUT_] ' $target->[1489]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_113][_IN_] ' $target->[1491]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_113][_OUT_] ' $target->[1491]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_117][_IN_] ' $target->[1495]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_117][_OUT_] ' $target->[1495]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_119][_IN_] ' $target->[1497]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_119][_OUT_] ' $target->[1497]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_123][_IN_] ' $target->[1501]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_123][_OUT_] ' $target->[1501]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_125][_IN_] ' $target->[1503]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_125][_OUT_] ' $target->[1503]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_127][_IN_] ' $target->[1505]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_127][_OUT_] ' $target->[1505]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_129][_IN_] ' $target->[1507]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_129][_OUT_] ' $target->[1507]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_131][_IN_] ' $target->[1509]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_131][_OUT_] ' $target->[1509]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_133][_IN_] ' $target->[1511]{$mode} ' did not eval into defined data
2015-07-15 11:17:37: ERROR: Target[10.165.134.1_133][_OUT_] ' $target->[1511]{$mode} ' did not eval into defined data
yum install perl-Exporter -yCode: Select all
[root@localhost ~]# yum install perl-Exporter -y
Loaded plugins: fastestmirror, langpacks
base | 3.6 kB 00:00
epel/x86_64/metalink | 9.2 kB 00:00
epel | 4.4 kB 00:00
extras | 3.4 kB 00:00
nagios-base | 1.5 kB 00:00
nagiosxi-deps | 1.5 kB 00:00
rpmforge | 1.9 kB 00:00
updates | 3.4 kB 00:00
(1/3): epel/x86_64/group_gz | 169 kB 00:01
(2/3): epel/x86_64/primary_db | 3.7 MB 00:05
(3/3): updates/7/x86_64/primary_db | 2.5 MB 00:07
(1/2): epel/x86_64/updateinfo | 440 kB 00:02
(2/2): epel/x86_64/pkgtags | 1.6 MB 00:02
Loading mirror speeds from cached hostfile
* base: mirrors.mit.edu
* epel: mirror.nexcess.net
* extras: mirror.nexcess.net
* rpmforge: mirror.teklinks.com
* updates: mirrors.advancedhosters.com
Package perl-Exporter-5.68-3.el7.noarch already installed and latest version
Nothing to do
