Active Directory Integration with SSL
OptimusB
Re: Active Directory Integration with SSL
Post by OptimusB »
Thanks. That was the original question I wanted to check. So in that case we will leave it to none as we are not ready to go with a 2012 DFL.
Is it alright to close the post then?
OptimusB
Post by OptimusB »
Yes thank you.
