Multiple filters
jolson
Attack Rabbit
Re: Multiple filters
Post by jolson »
The tcp input looks fine to me, and should work here. Are your logs being transferred via UDP? Are you sure that you have tcp/5548 open on your firewall?
Willem, I am a little confused - I do not understand where 'dcc' for the 'program' field is being set. Please see below:
if [program] == "dcc" {
To me it looks like this is being set in the syslog-brocade filter - but the dcc logs never hit that filter - obviously that is not the case.
{GREEDYDATA:program}
I do not see where your 'dcc' logs are inheriting the 'program == dcc' field. Am I missing something here?
Twits Blog
WillemDH
Post by WillemDH »
Jesse, dcc is assigned in the syslog-f5 filter => %{SYSLOGPROG}
I don't know what's wrong with the tcp input. I was pretty sure it was actually tcp and I'm 100 % sure the port in iptables is open as it works when set with syslog input...
Nagios XI 5.8.1
https://outsideit.net
jolson
Attack Rabbit
Post by jolson »
Willem,
I may have figured this out. Let's take a look at the following log, and the processes it goes through:
<155>Mar 28 13:23:21 slot1/cpf_f5_1_vir_pr err dcc[9206]: 01310033:3: [SECEV] Request blocked, violations: Attack signature detected. HTTP protocol compliance sub violations: N/A. Evasion techniques sub violations: N/A. Web services security sub violations: N/A. Virus name: N/A. Support id: 8375986001652311748, source ip: 40.70.0.8, xff ip: 40.70.0.8, source port: 49949, destination ip: 40.70.1.138, destination port: 80, route_domain: 0, HTTP classifier: /Common/F5_External_1_RAMP_Policy, scheme HTTP, geographic location: , request: www.digipolis.be\r\nUser-Agent: libwww-perl/6.04\r\n>, username: , session_id:
Once grokked by your first filter, it turns into the following:
  "loglevel": [
      "err"
  "SYSLOGPROG": [
      "dcc[9206]"
  "program": [
      "dcc"
  "pid": [
      "9206"
  "info": [
      "01310033:3: [SECEV] Request blocked, violations: Attack signature detected. HTTP protocol compliance sub violations: N/A. Evasion techniques sub violations: N/A. Web services security sub violations: N/A. Virus name: N/A. Support id: 8375986001652311748, source ip: 40.70.0.8, xff ip: 40.70.0.8, source port: 49949, destination ip: 40.70.1.138, destination port: 80, route_domain: 0, HTTP classifier: /Common/F5_External_1_RAMP_Policy, scheme HTTP, geographic location: , request: www.digipolis.be\\r\\nUser-Agent: libwww-perl/6.04\\r\\n>, username: , session_id:"
After this, we are running the 'info' field through your second filter, which is defined as follows:
%{GREEDYDATA:info}, source ip: %{IP:sourceip}, xff ip: %{IP:xffip}, source port: %{NUMBER:sourceport}, destination ip: %{IP:destinationip}, destination port: %{NUMBER:destinationport}, route_domain: %{NUMBER:routedomain}, HTTP classifier: %{GREEDYDATA:httpclassifier}, geographic location: , request: %{GREEDYDATA:request}, username: %{GREEDYDATA:username}, session_id: %{GREEDYDATA:sessionid}
Let's compare the very end of your log with the end of your filter.
Log:
Filter:
Do you see what I'm seeing? ;)
It looks like there is an extra space after session ID in your filter. This means a literal 'space' must be observed or the filter will not match - there is no such space in your log. Removing the space, your filter looks like this:
%{GREEDYDATA:info}, source ip: %{IP:sourceip}, xff ip: %{IP:xffip}, source port: %{NUMBER:sourceport}, destination ip: %{IP:destinationip}, destination port: %{NUMBER:destinationport}, route_domain: %{NUMBER:routedomain}, HTTP classifier: %{GREEDYDATA:httpclassifier}, geographic location: , request: %{GREEDYDATA:request}, username: %{GREEDYDATA:username}, session_id:%{GREEDYDATA:sessionid}
Give that a try please - let me know if it works for you. Thanks!
Twits Blog
WillemDH
Post by WillemDH »
Jesse,
Seems like it could have solved something, but our dcc filter does not get applied yet.. :(
if [type] == "syslog-f5" {
    grok {
      break_on_match => false
      match => [ "message", "\A%{SYSLOG5424PRI}%{SYSLOGTIMESTAMP} slot1\/%{HOSTNAME:logsource} %{LOGLEVEL:loglevel} %{SYSLOGPROG}: %{GREEDYDATA:info}" ]
      remove_tag => "_grokparsefailure"
      add_tag => "grokked_syslog_f5"
    grok {
      match => [ "info", "%{GREEDYDATA:info}, source ip: %{IP:sourceip}, xff ip: %{IP:xffip}, source port: %{NUMBER:sourceport}, destination ip: %{IP:destinationip}, destination port: %{NUMBER:destinationport}, route_domain: %{NUMBER:routedomain}, HTTP classifier: %{GREEDYDATA:httpclassifier}, geographic location: , request: %{GREEDYDATA:request}, username: %{GREEDYDATA:username}, session_id:%{GREEDYDATA:sessionid}" ]
      add_tag => "grokked_syslog_f5_dcc"
Last example log:
01310038:2: [SECEV] Request violations: Illegal URL,Illegal file type. HTTP protocol compliance sub violations: N/A. Evasion techniques sub violations: N/A. Web services security sub violations: N/A. Virus name: N/A. Support id: 2705742410514919698, source ip: 20.10.55.39, xff ip: 20.10.55.39, source port: 50680, destination ip: 10.40.1.139, destination port: 80, route_domain: 0, HTTP classifier: /Common/POISHPPR_class, scheme HTTP, geographic location: , request: http://shp.antw.be/sites/>, username: , session_id: <8ea44a15eea17901>
tags of this log: grokked_syslog_f5,_grokparsefailure
Maybe it might be an idea to make an email support ticket for this? I truly want to understand how to make multiple filters for one source and I've tried like 100 + combinations but still no luck..
Also the fact that I'm not getting tcp input to work troubles me. If you think it would help to start a remote session to try resolving both issues, let me know then I send an email to support.
Grtz
Willem
Nagios XI 5.8.1
jolson
Attack Rabbit
Post by jolson »
Willem,
I am almost sure that a part of the problem here is the syslog input we're using. The syslog input has a built in filter that is applied before other filters - this filter is defined as follows:
"match" => { "message" => "<%{POSINT:priority}>%{SYSLOGLINE}"
The above filter is going to mess with your logs so that we have unexpected results, which is why we need to use an input that does not have a built-in filter. The syslog input sets up both a tcp and udp listener on whatever port you define - a proper tcp or udp input should work almost exactly the same.
I think we should move over to a ticket - feel free to email your response to this message in and reference this thread, and I'll pick up the ticket. Thanks!
Twits Blog
WillemDH
Post by WillemDH »
Jesse,
Seems like something went wrong somewhere with the maintenance plan support subscription. I'm getting an email from xisupport-owner that I have no active subscription. Sent an email to sales for more information. I also just read that for Nagios Log Server with 2 nodes only 3 email support tickets are included. As I already used one for earlier issues, I'm not sure it's a good idea to use email support, as I would only be left with one ticket for 9 months..
Grtz
Willem
Nagios XI 5.8.1
I just replied to you in a PM since it's account-related and I don't like posting that publicly.
WillemDH
Post by WillemDH »
Jsut posting this for everyone, as I put alot of time in it's creation. It could be useful for F5 Load Balancer users.
Main filter
    grok {
      match => [ "message", "\A%{SYSLOG5424PRI}%{SYSLOGTIMESTAMP} slot1\/%{HOSTNAME:logsource} %{LOGLEVEL:severity_label} %{SYSLOGPROG}: %{GREEDYDATA:info}" ]
DCC filter
        grok {
          patterns_dir => "/usr/local/nagioslogserver/logstash/patterns"
          match => [ "info", "%{F5SEQ:f5_sequence}: %{GREEDYDATA:info}violations: %{GREEDYDATA:f5_violations}. HTTP protocol compliance sub violations: %{GREEDYDATA:f5_http_violations}. Evasion techniques sub violations: %{GREEDYDATA:f5_evasion_violations}. Web services security sub violations: %{GREEDYDATA:f5_web_svc_violations}. Virus name: %{GREEDYDATA:f5_virusname}. Support id: %{GREEDYDATA:f5_supportid}, source ip: %{IPNA:f5_sourceip}, xff ip: %{IPNA:f5_xffip}, source port: %{NUMBER:f5_sourceport}, destination ip: %{IPNA:f5_destinationip}, destination port: %{NUMBER:f5_destinationport}, route_domain: %{NUMBER:f5_routedomain}, HTTP classifier: %{GREEDYDATA:f5_http_classifier}, scheme %{SCHEME:f5_scheme}, geographic location:%{GREEDYDATA:f5_geolocation}, request: %{GREEDYDATA:f5_request}, username:%{GREEDYDATA:f5_username}, session_id: %{GREEDYDATA:f5_sessionid}" ]
          match => [ "info", "%{GREEDYDATA:info}" ]
          remove_tag => "grokked_syslog_f5"
          overwrite => [ "info" ]
In order for the above to work you will also need the following grok pattens:
HOSTNAMEUND \b(?:[_0-9A-Za-z][_0-9A-Za-z-]{0,62})(?:\.(?:[_0-9A-Za-z][_0-9A-Za-z-]{0,62}))*(\.?|\b)
IPNA (?:%{IPV6}|%{IPV4}|N\/A)
SCHEME (HTTPS?)
F5SEQ ([0-9]*:[0-9])
For Nagios support, it's all working relatively well now, but I'm having one small issue where the f5 logs are assigning different format of syslog levels to the severity_label field. Would I need a 'conditional alter' in order change the value of the field
err to error
info to informational
crit to critical
etc
  alter {
    condrewriteother => [
         "field_name", "expected_value", "field_name_to_change", "value",
         "field_name2", "expected_value2, "field_name_to_change2", "value2",
Is alter supported by NLS?
Grtz
Willem
Nagios XI 5.8.1
jolson
Attack Rabbit
Post by jolson »
err to error
crit to critical
etc
alter {
What do the different formats look like? This could be something that mutate is capable of handling: http://logstash.net/docs/1.4.2/filters/mutate
There should be no problems installing the contrib package to gain access to the alter filter:
/usr/local/nagioslogserver/logstash/bin/plugin install contrib
Twits Blog
WillemDH
Post by WillemDH »
Jesse,
I did
on both nodes. It did not really gave any confirmation it was installed or anything..
What do you mean with
ABout the mutate, I guess I'll have to use the gsub?
filter {
  mutate {
    gsub => [
      # replace all forward slashes with underscore
      "fieldname", "/", "_",
      # replace backslashes, question marks, hashes, and minuses with
      # dot
      "fieldname2", "[\\?#-]", "."
I'll do some tests.
EDIT: I can confirm this works 100 %:
    mutate {
        gsub => [
            "severity_label", "err", "error",
            "severity_label", "info", "informational"
Grtz
Willem
Nagios XI 5.8.1
