Alerts generating for "DataFile IO Traffic"
wiproltdwiv
Re: Alerts generating for "DataFile IO Traffic"
After bulk modification also we are facing the same issue.
Can you PM me your System Profile?
To send us your system profile
Click "Admin"
Under "System Config", click "System Profile"
Save the file and PM it back to us.
Click "Admin"
wiproltdwiv
PFA System profile details.
wiproltdwiv
PFA..
wiproltdwiv
PFA.
wiproltdwiv
PFA..
wiproltdwiv
PFA..
The file I need to see starts with a numeric date code and ends .tar.gz, could you Private Message that file to me?
wiproltdwiv
That file size is 2mb even after zipping that file..It will not come as attachment.
wiproltdwiv
hello ,
To continue with this issue we got the below from main configuration file:
enable_notifications=<0/1>
This option determines whether or not Nagios will send out notifications when it initially (re)starts. If this option is disabled, Nagios will not send out notifications for any host or service. Note: If you have state retention enabled, Nagios will ignore this setting when it (re)starts and use the last known setting for this option (as stored in the state retention file), unless you disable the use_retained_program_state option. If you want to change this option when state retention is active (and the use_retained_program_state is enabled), you'll have to use the appropriate external command or change it via the web interface.
according to this we did change the retain_status_information "on" and retain_nostatus_information "off" insipte of this alerts are generting with datafile IO Traffic for all 104 hosts. So please suggest us what to next and please provide us permanent solution as this issue has already running since long time .
