NRPE on Solaris9
jdalrymple
- Skynet Drone
Re: NRPE on Solaris9
Enable debug in nrpe.cfg and watch the log.
Also `ps -ef | grep nrpe` and make sure you aren't running it as a daemon also. I don't think you could without seeing some errors ... double check though.
I am not sure which log file to check for.
ps -ef | grep nrpe is not giving any results; so not running it as daemon.
jdalrymple
- Skynet Drone
I think debug in your case would go to /var/adm/messages
Nothings getting logged in /var/adm/messages
Below is the truss output if it is of any help
bash-4.3# ./check_nrpe -H 127.0.0.1
CHECK_NRPE: Error - Could not complete SSL handshake.
bash-4.3# truss ./check_nrpe -H 127.0.0.1
execve("check_nrpe", 0xFFBFFC84, 0xFFBFFC94) argc = 3
open(".", O_RDONLY|O_LARGEFILE) = 3
fstat64(3, 0xFFBFF398) = 0
close(3) = 0
open("./..", O_RDONLY|O_NDELAY|O_LARGEFILE) = 3
getdents64(3, 0xFFBFC958, 8192) = 208
close(3) = 0
open("./../..", O_RDONLY|O_NDELAY|O_LARGEFILE) = 3
getdents64(3, 0xFFBFC958, 8192) = 384
close(3) = 0
open("./../../..", O_RDONLY|O_NDELAY|O_LARGEFILE) = 3
getdents64(3, 0xFFBFC958, 8192) = 1632
close(3) = 0
open("./../../../..", O_RDONLY|O_NDELAY|O_LARGEFILE) = 3
getdents64(3, 0xFFBFC958, 8192) = 1328
close(3) = 0
open("./../../../../..", O_RDONLY|O_NDELAY|O_LARGEFILE) = 3
close(3) = 0
lstat64("/usr/local/nagios/libexec", 0xFF3F8BB8) = 0
resolvepath("/usr/local/nagios/libexec/check_nrpe", "/usr/local/nagios/libexec/check_nrpe", 1023) = 36
resolvepath("/usr/lib/ld.so.1", "/usr/lib/ld.so.1", 1023) = 16
stat("/usr/local/nagios/libexec/check_nrpe", 0xFFBFFA58) = 0
open("/var/ld/ld.config", O_RDONLY) = 3
fstat(3, 0xFFBFF4F8) = 0
mmap(0x00000000, 160, PROT_READ, MAP_SHARED, 3, 0) = 0xFF3B0000
close(3) = 0
stat("/opt/CA/CAlib/libssl.so.0.9.7", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/CA/SharedComponents/lib/libssl.so.0.9.7", 0xFFBFF39C) Err#2 ENOENT
stat("/usrl/local/ssl/lib/libssl.so.0.9.7", 0xFFBFF39C) Err#2 ENOENT
stat("/lib/libssl.so.0.9.7", 0xFFBFF39C) Err#2 ENOENT
stat("/usr/lib/libssl.so.0.9.7", 0xFFBFF39C) Err#2 ENOENT
stat("/usr/local/lib/libssl.so.0.9.7", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/redhat/rhn/solaris/lib/libssl.so.0.9.7", 0xFFBFF39C) = 0
open("/opt/redhat/rhn/solaris/lib/libssl.so.0.9.7", O_RDONLY) = 3
fstat(3, 0xFFBFF39C) = 0
mmap(0x00000000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xFF3A0000
mmap(0x00000000, 270336, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xFF350000
mmap(0xFF38C000, 22532, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 180224) = 0xFF38C000
munmap(0xFF37E000, 57344) = 0
resolvepath("/opt/redhat/rhn/solaris/lib/libssl.so.0.9.7a", "/opt/redhat/rhn/solaris/lib/libssl.so.0.9.7a", 1023) = 44
memcntl(0xFF350000, 41264, MC_ADVISE, MADV_WILLNEED, 0, 0) = 0
close(3) = 0
stat("/opt/CA/CAlib/libcrypto.so.0.9.7", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/CA/SharedComponents/lib/libcrypto.so.0.9.7", 0xFFBFF39C) Err#2 ENOENT
stat("/usrl/local/ssl/lib/libcrypto.so.0.9.7", 0xFFBFF39C) Err#2 ENOENT
stat("/lib/libcrypto.so.0.9.7", 0xFFBFF39C) Err#2 ENOENT
stat("/usr/lib/libcrypto.so.0.9.7", 0xFFBFF39C) Err#2 ENOENT
stat("/usr/local/lib/libcrypto.so.0.9.7", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/redhat/rhn/solaris/lib/libcrypto.so.0.9.7", 0xFFBFF39C) = 0
open("/opt/redhat/rhn/solaris/lib/libcrypto.so.0.9.7", O_RDONLY) = 3
mmap(0xFF3A0000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0xFF3A0000
mmap(0x00000000, 1171456, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xFF200000
mmap(0xFF304000, 91816, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 999424) = 0xFF304000
mmap(0xFF31C000, 4956, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_ANON, -1, 0) = 0xFF31C000
munmap(0xFF2F6000, 57344) = 0
mmap(0x00000000, 8192, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_ANON, -1, 0) = 0xFF340000
resolvepath("/opt/redhat/rhn/solaris/lib/libcrypto.so.0.9.7a", "/opt/redhat/rhn/solaris/lib/libcrypto.so.0.9.7a", 1023) 47
memcntl(0xFF200000, 237640, MC_ADVISE, MADV_WILLNEED, 0, 0) = 0
close(3) = 0
stat("/opt/CA/CAlib/libnsl.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/CA/SharedComponents/lib/libnsl.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/usrl/local/ssl/lib/libnsl.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/lib/libnsl.so.1", 0xFFBFF39C) = 0
open("/lib/libnsl.so.1", O_RDONLY) = 3
mmap(0x00000000, 712704, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xFF100000
mmap(0xFF19E000, 32732, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 581632) = 0xFF19E000
mmap(0xFF1A6000, 30936, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_ANON, -1, 0) = 0xFF1A6000
munmap(0xFF18E000, 65536) = 0
resolvepath("/usr/lib/libnsl.so.1ris/lib/libcrypto.so.0.9.7a", "/usr/lib/libnsl.so.1", 1023) = 20
memcntl(0xFF100000, 82168, MC_ADVISE, MADV_WILLNEED, 0, 0) = 0
close(3) = 0
stat("/opt/CA/CAlib/libsocket.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/CA/SharedComponents/lib/libsocket.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/usrl/local/ssl/lib/libsocket.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/lib/libsocket.so.1", 0xFFBFF39C) = 0
open("/lib/libsocket.so.1", O_RDONLY) = 3
mmap(0x00000000, 114688, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xFF1E0000
mmap(0xFF1FA000, 4333, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 40960) = 0xFF1FA000
munmap(0xFF1EA000, 65536) = 0
resolvepath("/usr/lib/libsocket.so.1/lib/libcrypto.so.0.9.7a", "/usr/lib/libsocket.so.1", 1023) = 23
memcntl(0xFF1E0000, 13792, MC_ADVISE, MADV_WILLNEED, 0, 0) = 0
close(3) = 0
stat("/opt/CA/CAlib/libc.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/CA/SharedComponents/lib/libc.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/usrl/local/ssl/lib/libc.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/lib/libc.so.1", 0xFFBFF39C) = 0
open("/lib/libc.so.1", O_RDONLY) = 3
mmap(0x00000000, 802816, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xFF000000
mmap(0xFF0BC000, 24560, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 704512) = 0xFF0BC000
mmap(0xFF0C2000, 6788, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_ANON, -1, 0) = 0xFF0C2000
munmap(0xFF0AC000, 65536) = 0
resolvepath("/usr/lib/libc.so.1.so.1", "/usr/lib/libc.so.1", 1023) = 18
memcntl(0xFF000000, 117768, MC_ADVISE, MADV_WILLNEED, 0, 0) = 0
close(3) = 0
stat("/opt/redhat/rhn/solaris/lib/libsocket.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/redhat/rhn/solaris/lib/libnsl.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/CA/CAlib/libdl.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/CA/SharedComponents/lib/libdl.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/redhat/rhn/solaris/lib/libdl.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/usrl/local/ssl/lib/libdl.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/lib/libdl.so.1", 0xFFBFF39C) = 0
open("/lib/libdl.so.1", O_RDONLY) = 3
resolvepath("/usr/lib/libdl.so.1", "/usr/lib/libdl.so.1", 1023) = 19
close(3) = 0
stat("/opt/CA/CAlib/libz.so", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/CA/SharedComponents/lib/libz.so", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/redhat/rhn/solaris/lib/libz.so", 0xFFBFF39C) Err#2 ENOENT
stat("/usrl/local/ssl/lib/libz.so", 0xFFBFF39C) Err#2 ENOENT
stat("/lib/libz.so", 0xFFBFF39C) = 0
open("/lib/libz.so", O_RDONLY) = 3
mmap(0x00000000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xFF330000
mmap(0x00000000, 122880, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xFF1B0000
mmap(0xFF1CA000, 11592, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 40960) = 0xFF1CA000
munmap(0xFF1BC000, 57344) = 0
resolvepath("/usr/lib/libz.so.11", "/usr/lib/libz.so.1", 1023) = 18
memcntl(0xFF1B0000, 4536, MC_ADVISE, MADV_WILLNEED, 0, 0) = 0
close(3) = 0
stat("/opt/redhat/rhn/solaris/lib/libc.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/CA/CAlib/libgcc_s.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/CA/SharedComponents/lib/libgcc_s.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/redhat/rhn/solaris/lib/libgcc_s.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/usrl/local/ssl/lib/libgcc_s.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/lib/libgcc_s.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/usr/lib/libgcc_s.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/usr/local/lib/libgcc_s.so.1", 0xFFBFF39C) = 0
open("/usr/local/lib/libgcc_s.so.1", O_RDONLY) = 3
mmap(0xFF330000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0xFF330000
mmap(0x00000000, 106496, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xFF0E0000
mmap(0xFF0F8000, 3532, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 32768) = 0xFF0F8000
munmap(0xFF0EA000, 57344) = 0
resolvepath("/usr/local/lib/libgcc_s.so.1", "/usr/local/lib/libgcc_s.so.1", 1023) = 28
memcntl(0xFF0E0000, 6540, MC_ADVISE, MADV_WILLNEED, 0, 0) = 0
close(3) = 0
stat("/opt/CA/CAlib/libmp.so.2", 0xFFBFF39C) Err#2 ENOENT
stat("/opt/CA/SharedComponents/lib/libmp.so.2", 0xFFBFF39C) Err#2 ENOENT
stat("/usrl/local/ssl/lib/libmp.so.2", 0xFFBFF39C) Err#2 ENOENT
stat("/lib/libmp.so.2", 0xFFBFF39C) = 0
open("/lib/libmp.so.2", O_RDONLY) = 3
mmap(0x00000000, 90112, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xFEFE0000
mmap(0xFEFF4000, 849, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 16384) = 0xFEFF4000
munmap(0xFEFE4000, 65536) = 0
resolvepath("/usr/lib/libmp.so.2", "/usr/lib/libmp.so.2", 1023) = 19
memcntl(0xFEFE0000, 2464, MC_ADVISE, MADV_WILLNEED, 0, 0) = 0
close(3) = 0
stat("/usr/local/lib/libc.so.1", 0xFFBFF39C) Err#2 ENOENT
stat("/usr/platform/SUNW,UltraSPARC-IIi-cEngine/lib/libc_psr.so.1", 0xFFBFF1AC) = 0
open("/usr/platform/SUNW,UltraSPARC-IIi-cEngine/lib/libc_psr.so.1", O_RDONLY) = 3
fstat(3, 0xFFBFF1AC) = 0
mmap(0x00000000, 8192, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_ANON, -1, 0) = 0xFF0D0000
mmap(0x00000000, 16384, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xFEFD0000
resolvepath("/usr/platform/sun4u/lib/libc_psr.so.1gine/lib/libc_psr.so.1", "/usr/platform/sun4u/lib/libc_psr.so.1", 1023 = 37
close(3) = 0
munmap(0xFF330000, 8192) = 0
getustack(0xFFBFF8C4)
getrlimit(RLIMIT_STACK, 0xFFBFF8BC) = 0
getcontext(0xFFBFF6F8)
setustack(0xFF0C3A0C)
sysconfig(_CONFIG_STACK_PROT) = 7
brk(0x00025990) = 0
brk(0x00027990) = 0
brk(0x00027990) = 0
brk(0x00029990) = 0
brk(0x00029990) = 0
brk(0x0002B990) = 0
brk(0x0002B990) = 0
brk(0x0002D990) = 0
brk(0x0002D990) = 0
brk(0x0002F990) = 0
brk(0x0002F990) = 0
brk(0x00031990) = 0
brk(0x00031990) = 0
brk(0x00033990) = 0
sigaction(SIGALRM, 0xFFBFF2C8, 0xFFBFF348) = 0
alarm(10) = 0
open("/etc/nsswitch.conf", O_RDONLY|O_LARGEFILE) = 3
fcntl(3, F_DUPFD, 0x00000100) Err#22 EINVAL
read(3, " #\n # / e t c / n s s".., 1024) = 783
read(3, 0x00032BE8, 1024) = 0
close(3) = 0
stat("/opt/CA/CAlib/nss_files.so.1", 0xFFBFEAA4) Err#2 ENOENT
stat("/opt/CA/SharedComponents/lib/nss_files.so.1", 0xFFBFEAA4) Err#2 ENOENT
stat("/usrl/local/ssl/lib/nss_files.so.1", 0xFFBFEAA4) Err#2 ENOENT
stat("/lib/nss_files.so.1", 0xFFBFEAA4) = 0
open("/lib/nss_files.so.1", O_RDONLY) = 3
fstat(3, 0xFFBFEAA4) = 0
mmap(0x00000000, 98304, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xFEFB0000
mmap(0xFEFC6000, 1744, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 24576) = 0xFEFC6000
munmap(0xFEFB6000, 65536) = 0
resolvepath("/usr/lib/nss_files.so.1", "/usr/lib/nss_files.so.1", 1023) = 23
memcntl(0xFEFB0000, 6276, MC_ADVISE, MADV_WILLNEED, 0, 0) = 0
close(3) = 0
stat("/opt/CA/CAlib/libc.so.1", 0xFFBFE9E4) Err#2 ENOENT
stat("/opt/CA/SharedComponents/lib/libc.so.1", 0xFFBFE9E4) Err#2 ENOENT
stat("/usrl/local/ssl/lib/libc.so.1", 0xFFBFE9E4) Err#2 ENOENT
stat("/lib/libc.so.1", 0xFFBFE9E4) = 0
stat("/opt/CA/CAlib/libnsl.so.1", 0xFFBFE9E4) Err#2 ENOENT
stat("/opt/CA/SharedComponents/lib/libnsl.so.1", 0xFFBFE9E4) Err#2 ENOENT
stat("/usrl/local/ssl/lib/libnsl.so.1", 0xFFBFE9E4) Err#2 ENOENT
stat("/lib/libnsl.so.1", 0xFFBFE9E4) = 0
open("/etc/protocols", O_RDONLY) = 3
fstat64(3, 0xFFBFF048) = 0
brk(0x00033990) = 0
brk(0x00035990) = 0
fstat64(3, 0xFFBFEEF0) = 0
ioctl(3, TCGETA, 0xFFBFEFD4) Err#25 ENOTTY
read(3, " # i d e n t\t " @ ( # )".., 8192) = 1807
llseek(3, 0xFFFFFFFFFFFFFA58, SEEK_CUR) = 359
close(3) = 0
so_socket(PF_INET, SOCK_STREAM, IPPROTO_TCP, "", 1) = 3
connect(3, 0xFFBFF368, 16, 1) = 0
time() = 1432752062
getpid() = 21736 [21735]
brk(0x00035990) = 0
brk(0x00039990) = 0
brk(0x00039990) = 0
brk(0x0003D990) = 0
brk(0x0003D990) = 0
brk(0x00041990) = 0
open("/dev/urandom", O_RDONLY|O_NONBLOCK|O_NOCTTY) = 4
poll(0xFFBFEED8, 1, 10) = 1
read(4, "8AD9F0D4E8D3D0 :C3 VFFB9".., 32) = 32
close(4) = 0
getuid() = 0 [0]
time() = 1432752062
write(3, "80 A010301\018\0\0\0 \0".., 67) = 67
read(3, " - c : i n v", 7) = 7
ioctl(1, TCGETA, 0xFFBFF1BC) = 0
fstat64(1, 0xFFBFF0D8) = 0
write(1, " C H E C K _ N R P E : ".., 54) = 54
close(3) = 0
_exit(2)
jdalrymple
- Skynet Drone
This is still the current problem right? Not that it really should matter - but did you use the same check_nrpe that you compiled with nrpe? Mine is working as expected:maddev wrote:/usr/local/nagios/libexec/check_nrpe -H localhost/usr/local/nagios/libexec/check_nrpe -H localhost -nCode: Select all
CHECK_NRPE: Error - Could not complete SSL handshake.Code: Select all
CHECK_NRPE: Response packet had invalid CRC32.
bash-2.05# ./nrpe -c ./nrpe.cfg -d
bash-2.05# ps -ef | grep nrpe
nagios 600 1 0 11:34:09 ? 0:00 ./nrpe -c ./nrpe.cfg -d
bash-2.05# ./check_nrpe -H 127.0.0.1
NRPE v2.10Re: NRPE on Solaris9
Yes. I did use the same NRPE that I compiled.
I observed that I am not able to start NRPE as a daemon. I am not being shown a error message but the process is not being launched as a daemon either.
May be I should try to clean all the nrpe traces and recompile/reinstall to make sure only the components corresponding to 2.1 stays. I am not sure of what and all to remove. May be some guidelines on that will help.
jdalrymple
- Skynet Drone
You only need 3 things/files
OpenSSL library (won't compile without it)
nrpe
check_nrpe
You actually don't even need the 3rd one, but it's useful for testing.
No errors when you try to:
nrpe
check_nrpe
nrpe -c /etc/nagios/nrpe.cfg -dRe: NRPE on Solaris9
No errors on the shell. But /var/adm/messages logged the below messages
17th line from the cfg file reads as below
I commented this line out but still the "Network server bind failure" line is being logged
nrpe[17565]: [ID 636728 daemon.warning] Unknown option specified in config file '/etc/nagios/nrpe.cfg' - Line 17
nrpe[17566]: [ID 601491 daemon.notice] Starting up daemon
nrpe[17566]: [ID 434846 daemon.error] Network server bind failure (125: Address already in use)
log_facility=daemon
jdalrymple
- Skynet Drone
Remove it from your inetd.conf, restart inetd, pgrep nrpe, pkill pid, try starting daemonized again. The fact that anything is being logged is progress.maddev wrote:I commented this line out but still the "Network server bind failure" line is being logged
