returned an invaled return code 255
Re: returned an invaled return code 255
You're right - it is odd that it's working locally but not remotely. Have you tried restarting NSClient already?
Please open services.msc and find NSClient++ - restart the service and re-try the check from Nagios.
ooooh great now this run
but now you need another server than not read
Could you please rephrase this sentence? I am not sure what you mean.but now you need another server than not read
Now I have no servers that instead reads the logs locally if
Do you have a server that reads logs remotely instead of locally - or something similar?
I'm still not 100% clear on what you're asking.
yes, the server have got logs.
Local this program is running but remot not run.
And the other server remot not run, this error is:
Sorry my english is bad.
COMMAND: /usr/local/nagios/libexec/check_nrpe -H [SERVER] -p 5666 -c check_log3 -t 30 -a -p "unable" -l "D:/alert_enetvae.log" -c 1
OUTPUT: Plug-in error: time out after 15 seconds
Let's try giving your command a longer timeout:
How does that work for you?
/usr/local/nagios/libexec/check_nrpe -H 10.82.4.115 -p 5666 -c check_log3 -t 30 -a -p "unable" -l "D:/alert_enetvae.log" -t 45 -c 1 Re: returned an invaled return code 255
then not read the second -t but i write
COMMAND: /usr/local/nagios/libexec/check_nrpe -H [HOST] -p 5666 -c check_log3 -t 30 -a -p "unable" -l "D:/alert_enetvae.log" -a -t 45 -a -c 1
OUTPUT: Cannot read $ARG2$
Sorry - I missed that you already had a timeout added. Here, try the following:
/usr/local/nagios/libexec/check_nrpe -H [HOST] -p 5666 -c check_log3 -t 30 -a -p "unable" -l "D:/alert_enetvae.log" -a --no-timeout -a -c 1http://exchange.nagios.org/directory/Pl ... pl/detailsThis plugin will set an internal time-out alarm based on the $TIMEOUT
setting found in utils.pm. You can use the --no-timeout option to disable
this.
thanks
but then this not read arg2 = D:/alert_enetvae.log but in server there are logs. And the other server i haver got same problem, local the program run good
