Log Server Mointoring
gdolidze
Re: Log Server Mointoring
Post by gdolidze »
[root@nagios ~]# /usr/local/nagios/libexec/check_nrpe -H 67.111.179.155 -c check_log_3 -n
CHECK_NRPE: Error receiving data from daemon.
OK: Found 0 lines (limit=1/1): No matches found.|lines=0
jolson
Attack Rabbit
Post by jolson »
Good stuff - so it's working!
Feel free to change the client machines nrpe.cfg as you see fit - currently it's scanning for the string "someline". You can change this to whatever you'd like.
You could also add several different ones, and issue multiple calls to them. For example:
Client NRPE.cfg:
command[check_log_3]=/usr/local/nagios/libexec/check_log3.pl -l /var/log/messages -p error -c 1
command[check_log_4]=/usr/local/nagios/libexec/check_log3.pl -l /var/log/httpd/error_log -p 502 -c 1
command[check_log_5]=/usr/local/nagios/libexec/check_log3.pl -l /var/log/cron -p 'cron failure' -c 1
From XI:
/usr/local/nagios/libexec/check_nrpe -H x.x.x.x -c check_log_3
/usr/local/nagios/libexec/check_nrpe -H x.x.x.x -c check_log_4
/usr/local/nagios/libexec/check_nrpe -H x.x.x.x -c check_log_5
Twits Blog
gdolidze
Post by gdolidze »
Ok we know that its working now but how come i get this on the XI web
(No output on stdout) stderr: sudo: no tty present and no askpass program specified
jolson
Attack Rabbit
Post by jolson »
Try removing sudo from the XI web interface command - it doesn't appear to be necessary from the command line. After removing the sudo command, report your results back.
Twits Blog
gdolidze
Post by gdolidze »
Unable to open '/var/log/messages': Permission denied
even with giving other rw still get same issue.
jolson
Attack Rabbit
Post by jolson »
Can you post a screenshot of what you have configured on the XI GUI please? I would like to see what we're working with so that I can better assist you. Thanks!
Twits Blog
gdolidze
Post by gdolidze »
you mean all the service or just the log one?
jolson
Attack Rabbit
Post by jolson »
Forget about that command definition - you can delete it if you want. It would only be useful for checking the contents of your local (XI) machine, not running remote NRPE checks.
What we need to do is define a service that runs a command exactly as we typed it. So, that command being:
Our new service might look something like:
Finish filling out all of the appropriate 'service' definitions, and you should be good to go.
Twits Blog
gdolidze
Post by gdolidze »
Great it works. The issue was I was using the wrong command.
Thank you for you help I appreciate.
I can going to try this on the other server now.
jolson
Attack Rabbit
Post by jolson »
No problem - glad I could help out. My apologies for the confusion. Let me know if you have any further questions. Thanks!
Twits Blog
