box293_check_vmware.pl plugin timed out Nagios Core 3.4.1
miracledisease
Re: box293_check_vmware.pl plugin timed out Nagios Core 3.4.
Post by miracledisease »
When I run the command as a nagios user (su nagios) the results are as expected. When I run the commands from root it asked for the root password for the vMA. I a trying to achieve a correct configuration so that Nagios' web interface displays the results. Nagios displays
UNKNOWN: 'Host_OS_Name_Version10124$$$$$' is not a valid --check argument!
command.cfg:
command_name box293_check_vmware
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H 10.xxx.xxx.xxx -C "nice -n19 ~/box293_check_vmware.pl --server $ARG1$ --check $ARG2$\"$ARG3$\"\"$ARG$$\"\"$ARG5$\"\"$ARG6$\"\"$ARG7$\"\"$ARG8$\""
Linux.cfg:
use local-service
host_name 10.zzz.zzz.zzz
service_description vCenter Version1
check_command box293_check_vmware!$HOSTADDRESS$!vCenter_Name_Version!!!!!!
initial_state u
max_check_attempts 3
check_interval 1440
retry_interval 7
active_checks_enabled 1
check_period 24x7
register 1
Check command: as nagios user (su nagios)- checks work this way, as root user they do not......
/usr/local/nagios/libexec/check_by_ssh -E 1 -l vi-admin -H 10.xxx.xxx.xxx -C "~/box293_check_vmware.pl --server 10.zzz.zzz.zzz --check vCenter_Name_Version"
Could you edit the service check and hard code the IP address in it for a test?
Change this from
to
check_command box293_check_vmware!10.zzz.zzz.zzz!vCenter_Name_Version!!!!!!
Also, could you run the command as nagios from the command line and post the output here?
I would like to see if there are and illegal characters in it.
miracledisease
[nagios@nagios objects]$ /usr/local/nagios/libexec/check_by_ssh -E 1 -l vi-admin -H 10.xxx.xxx.xxx -C "~/box293_check_vmware.pl --server 10.zzz.zzz.zzz --check vCenter_Name_Version"
OK: VMware vCenter Server 5.5.0 build-xxxxxx
Nagios web interface output ----- after changing $HOSTADDRESS$ to 10.zzz.zzz.zzz
UNKNOWN: 'vCenter_Name_Version3337$$$$$' is not a valid --check argument!
Post by Box293 »
miracledisease wrote:command.cfg:
All of these arguments need a space separating them AND what *should* be $ARG4$ is currently $ARG$$, these are both contributing to your issues. Here is what it should be::
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H 10.xxx.xxx.xxx -C "nice -n19 ~/box293_check_vmware.pl --server $ARG1$ --check $ARG2$ \"$ARG3$\" \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
miracledisease
Thank you guys for all your help. The check is finally producing desired results on the web interface. Now it is time to get more checks running. Again thank you to all the Nagios champs that helped out.
I'll be closing this thread now, but feel free to open another if you need anything in the future!
