I am sure that it was no a space issue. In order to finally manage to create snapshots what I did is:
i) cleared all my backup drive
ii) elasticsearch service restart on both nodes (I did that because it couldn't create a new snapshot since one was in progress!)
iii) reset all system jobs and reschedule to run now (29 snapshots created)
iv)in my "Maintenance Settings" I changed the "Delete backups older than" from 10 to 25 and saved
v)force to run the "backup_maintenance" from the command subsystem
Results:
I have 29 snapshots as you can see below, I also attach the jobs log from the latest jobs...
[root@NagiosLogServer NLSBackup]# df -h
rootfs 99G 87G 11G 90% /
devtmpfs 7.9G 152K 7.9G 1% /dev
tmpfs 7.9G 0 7.9G 0% /dev/shm
/dev/sda1 99G 87G 11G 90% /
/dev/sdb 99G 61G 33G 65% /NLSBackup
[root@NagiosLogServer NLSBackup]# ls -ltr
total 240
-rw-r--r-- 1 nagios users 61 Jun 5 14:27 metadata-logstash-2015.05.11
-rw-r--r-- 1 nagios users 190 Jun 5 14:30 snapshot-logstash-2015.05.11
-rw-r--r-- 1 nagios users 61 Jun 5 14:30 metadata-logstash-2015.05.12
-rw-r--r-- 1 nagios users 189 Jun 5 14:31 snapshot-logstash-2015.05.12
-rw-r--r-- 1 nagios users 61 Jun 5 14:31 metadata-logstash-2015.05.13
-rw-r--r-- 1 nagios users 191 Jun 5 14:33 snapshot-logstash-2015.05.13
-rw-r--r-- 1 nagios users 61 Jun 5 14:33 metadata-logstash-2015.05.14
-rw-r--r-- 1 nagios users 190 Jun 5 14:36 snapshot-logstash-2015.05.14
-rw-r--r-- 1 nagios users 61 Jun 5 14:36 metadata-logstash-2015.05.15
-rw-r--r-- 1 nagios users 190 Jun 5 14:40 snapshot-logstash-2015.05.15
-rw-r--r-- 1 nagios users 61 Jun 5 14:40 metadata-logstash-2015.05.16
-rw-r--r-- 1 nagios users 190 Jun 5 14:42 snapshot-logstash-2015.05.16
-rw-r--r-- 1 nagios users 61 Jun 5 14:42 metadata-logstash-2015.05.17
-rw-r--r-- 1 nagios users 189 Jun 5 14:43 snapshot-logstash-2015.05.17
-rw-r--r-- 1 nagios users 61 Jun 5 14:43 metadata-logstash-2015.05.18
-rw-r--r-- 1 nagios users 189 Jun 5 14:44 snapshot-logstash-2015.05.18
-rw-r--r-- 1 nagios users 61 Jun 5 14:44 metadata-logstash-2015.05.19
-rw-r--r-- 1 nagios users 189 Jun 5 14:45 snapshot-logstash-2015.05.19
-rw-r--r-- 1 nagios users 61 Jun 5 14:45 metadata-logstash-2015.05.20
-rw-r--r-- 1 nagios users 190 Jun 5 14:47 snapshot-logstash-2015.05.20
-rw-r--r-- 1 nagios users 61 Jun 5 14:47 metadata-logstash-2015.05.21
-rw-r--r-- 1 nagios users 189 Jun 5 14:48 snapshot-logstash-2015.05.21
-rw-r--r-- 1 nagios users 61 Jun 5 14:48 metadata-logstash-2015.05.22
-rw-r--r-- 1 nagios users 188 Jun 5 14:49 snapshot-logstash-2015.05.22
-rw-r--r-- 1 nagios users 61 Jun 5 14:49 metadata-logstash-2015.05.23
-rw-r--r-- 1 nagios users 190 Jun 5 14:50 snapshot-logstash-2015.05.23
-rw-r--r-- 1 nagios users 61 Jun 5 14:50 metadata-logstash-2015.05.24
-rw-r--r-- 1 nagios users 190 Jun 5 14:52 snapshot-logstash-2015.05.24
-rw-r--r-- 1 nagios users 61 Jun 5 14:52 metadata-logstash-2015.05.25
-rw-r--r-- 1 nagios users 190 Jun 5 14:53 snapshot-logstash-2015.05.25
-rw-r--r-- 1 nagios users 61 Jun 5 14:53 metadata-logstash-2015.05.26
-rw-r--r-- 1 nagios users 189 Jun 5 14:54 snapshot-logstash-2015.05.26
-rw-r--r-- 1 nagios users 61 Jun 5 14:54 metadata-logstash-2015.05.27
-rw-r--r-- 1 nagios users 190 Jun 5 14:56 snapshot-logstash-2015.05.27
-rw-r--r-- 1 nagios users 61 Jun 5 14:56 metadata-logstash-2015.05.28
-rw-r--r-- 1 nagios users 190 Jun 5 14:57 snapshot-logstash-2015.05.28
-rw-r--r-- 1 nagios users 61 Jun 5 14:57 metadata-logstash-2015.05.29
-rw-r--r-- 1 nagios users 190 Jun 5 14:59 snapshot-logstash-2015.05.29
-rw-r--r-- 1 nagios users 61 Jun 5 14:59 metadata-logstash-2015.05.30
-rw-r--r-- 1 nagios users 190 Jun 5 15:01 snapshot-logstash-2015.05.30
-rw-r--r-- 1 nagios users 61 Jun 5 15:01 metadata-logstash-2015.05.31
-rw-r--r-- 1 nagios users 189 Jun 5 15:03 snapshot-logstash-2015.05.31
-rw-r--r-- 1 nagios users 61 Jun 5 15:03 metadata-logstash-2015.06.01
-rw-r--r-- 1 nagios users 190 Jun 5 15:04 snapshot-logstash-2015.06.01
-rw-r--r-- 1 nagios users 61 Jun 5 15:04 metadata-logstash-2015.06.02
-rw-r--r-- 1 nagios users 190 Jun 5 15:05 snapshot-logstash-2015.06.02
-rw-r--r-- 1 nagios users 61 Jun 5 15:05 metadata-logstash-2015.06.03
-rw-r--r-- 1 nagios users 191 Jun 5 15:07 snapshot-logstash-2015.06.03
-rw-r--r-- 1 nagios users 61 Jun 5 15:07 metadata-logstash-2015.06.04
drwxr-xr-x 31 nagios nagios 4096 Jun 5 15:07 indices
-rw-r--r-- 1 nagios users 190 Jun 5 15:08 snapshot-logstash-2015.06.04
-rw-r--r-- 1 nagios users 61 Jun 5 15:42 metadata-logstash-2015.05.07
-rw-r--r-- 1 nagios users 190 Jun 5 15:45 snapshot-logstash-2015.05.07
-rw-r--r-- 1 nagios users 61 Jun 5 15:45 metadata-logstash-2015.05.08
-rw-r--r-- 1 nagios users 190 Jun 5 15:47 snapshot-logstash-2015.05.08
-rw-r--r-- 1 nagios users 61 Jun 5 15:47 metadata-logstash-2015.05.09
-rw-r--r-- 1 nagios users 189 Jun 5 15:48 snapshot-logstash-2015.05.09
-rw-r--r-- 1 nagios users 61 Jun 5 15:48 metadata-logstash-2015.05.10
-rw-r--r-- 1 nagios users 189 Jun 5 15:49 snapshot-logstash-2015.05.10
-rw-r--r-- 1 nagios users 190 Jun 5 15:49 index
Snapshots
Re: Snapshots
teirekos,
We are re-working the backup process in Nagios Log Server, and the new process will be released in the next version of Nagios Log Server (within a few months). Until then, this thread is getting to the point where I'd like to perform a remote session and troubleshoot. Is there any chance you could send an email to [email protected] with a link to this thread?
Re: Snapshots
thank you very much for your support. Unfortunately a remote login to the system is not possible. Anyway, it seems now that it works fine. Pls close the thread.
Re: Snapshots
No problem - I'll close the thread now. Keep an eye out for our next release. Thanks!
Jesse
Jesse
