Here it is:
host_name DTW-SQL15
service_description FrontLine HDOC
check_command check_mssql_lamin! -H 10.10.0.44 -U vantage -P vantage09 -q 'select count(*) from (detail inner join calllog on detail.callid = calllog.callid) inner join asgnmnt on calllog.callid = asgnmnt.callid where Asgnmnt.Resolution not in ('Reassigned','Resolved','User Canceled','Duplicate','Workaround','Rejected') and CallLog.Priority != 'R'and cpwbusappsct ='frontline'' -r "50" -d heat -e
max_check_attempts 5
check_interval 5
retry_interval 1
check_period 24x7
notification_interval 60
notification_period 24x7
contacts nagiosadmin
contact_groups VantageGroup
_xiwizard windowsserver
register 1
Nagios NPRE: Directory File Count
Re: Nagios NPRE: Directory File Count
Lamin,
check_command check_mssql_lamin! -H 10.10.0.44 -U vantage -P vantage09 -q 'select count(*) from (detail inner join calllog on detail.callid = calllog.callid) inner join asgnmnt on calllog.callid = asgnmnt.callid where Asgnmnt.Resolution not in ("Reassigned","Resolved","User Canceled","Duplicate","Workaround","Rejected") and CallLog.Priority != "R" and cpwbusappsct = "frontline''' -r "50" -d heat -e
Should achieve what I was aiming for.
Nicholas Scott
Hey Nscott,
I am still not seeing any value in nagios even with the changes you suggested.
host_name DTW-SQL15
check_command check_mssql_lamin! -H 10.10.0.44 -U vantage -P vantage09 -q 'select count(*) from (detail inner join calllog on detail.callid = calllog.callid) inner join asgnmnt on calllog.callid = asgnmnt.callid where Asgnmnt.Resolution not in ("Reassigned","Resolved","User Canceled","Duplicate","Workaround","Rejected") and CallLog.Priority != "R" and cpwbusappsct ="Frontline"' -r "50" -d heat -e
check_interval 5
retry_interval 1
check_period 24x7
register 1
host_name DTW-SQL15
check_interval 5
retry_interval 1
check_period 24x7
register 1
I just realized something on this. I think the Core Config Manager does not allow the () characters. I know that's true for host and services names, but it might also apply in command definitions as well. Can you access the service definition in the Core Config Manager, select the "Download" button, and see how that query was actually written to file. I'm wondering if the issue lies there.
No I cannot access it and it not showing in the core config manager under service management. How do you know what character nagios likes or dislikes? I did not see it when search online. This issue is taking much my time and I want to resolve and move on.
lamin,
Please, review the Nagios Main Configuration File Options here:
http://nagios.sourceforge.net/docs/nagi ... gmain.html
There is a section on "illegal character" named: "Illegal Object Name Characters". This is a quote from the document:
Format: illegal_object_name_chars=<chars...>
Example: illegal_object_name_chars=`~!$%^&*"|'<>?,()=
This option allows you to specify illegal characters that cannot be used in host names, service descriptions, or names of other object types. Nagios will allow you to use most characters in object definitions, but I recommend not using the characters shown in the example above. Doing may give you problems in the web interface, notification commands, etc.
Ok, so what do I need to get nagios to display the correct sql query result.?
lamin,
I am sorry, I misunderstood. The quote I posted concerns the use of illegal characters in host and service names - I think I have mislead you.
When you say: "No I cannot access it and it not showing in the core config manager under service management" do you mean you cannot access the Core Config Manager at all or you can access it, but this service is not showing up there?
Lamin, here is a step by step:
Redefine your check command (btw, this step by step is assuming you're using the plugin I sent you)
Then you'll need to change your query service to use your new command, and change the args like such:
Here is a screenshot of it working:
Nicholas Scott
I have followed your steps but still no values displayed. By the way my nagios does not like single quote because it generate some error then I changed it to double quotes then it runs but not returning the right result. Also you have to keep in mind that your query is big time different from mine because mine contain different special characters. Also do I have to install nagios windows agent in that sql server?
host_name DTW-SQL15
service_description Changepoint HDOC
check_command check_mssql!-H 10.10.0.44 -U vantage -P vantage09 -q "select count(*) from (detail inner join calllog on detail.callid = calllog.callid) inner join asgnmnt on calllog.callid = asgnmnt.callid where Asgnmnt.Resolution not in ('Reassigned','Resolved','User Canceled','Duplicate','Workaround','Rejected') and CallLog.Priority != 'R'and cpwbusappsct ='Changepoint'" -d heat -e
check_interval 5
retry_interval 1
check_period 24x7
register 1
host_name DTW-SQL15
check_interval 5
retry_interval 1
check_period 24x7
register 1
