Database Backend Is Not Running
mcwhorts
Re: Database Backend Is Not Running
Post by mcwhorts »
I'm starting to see this now
jolson
Attack Rabbit
Post by jolson »
In your ndo2db configuration file:
lock_file=/usr/local/nagiosxi/var/subsys/ndo2db.lock
Let's change the debug level to -1:
debug_level=-1
And restart it:
service ndo2db restart
Is any log generated at /usr/local/nagios/var/ndo2db.debug? If so, what are the contents?
cat /usr/local/nagios/var/ndo2db.debug
Twits Blog
mcwhorts
Post by mcwhorts »
I made those changes to the ndo2db config and restarted. So far nothing has been logged at /usr/local/nagios/var/ndo2db.debug
mcwhorts
Post by mcwhorts »
I'm seeing this in the logs. I don't know if it's useful.
[1436994795.390529] [002.0] [pid=9722] INSERT INTO nagios_hoststatus SET instance_id='1', host_object_id='5604', status_update_time=FROM_UNIXTIME(1436994795), output='PING OK - Packet loss = 0%, RTA = 0\.85 ms', long_output='', perfdata='rta=0\.853000ms;3000\.000000;5000\.000000;0\.000000 pl=0%;80;100;0', current_state='0', has_been_checked='1', should_be_scheduled='1', current_check_attempt='1', max_check_attempts='3', last_check=FROM_UNIXTIME(1436994790), next_check=FROM_UNIXTIME(1436994975), check_type='0', last_state_change=FROM_UNIXTIME(1435803964), last_hard_state_change=FROM_UNIXTIME(1434561932), last_hard_state='0', last_time_up=FROM_UNIXTIME(1436994795), last_time_down=FROM_UNIXTIME(1430592573), last_time_unreachable=FROM_UNIXTIME(1435803922), state_type='1', last_notification=FROM_UNIXTIME(0), next_notification=FROM_UNIXTIME(0), no_more_notifications='0', notifications_enabled='1', problem_has_been_acknowledged='0', acknowledgement_type='0', current_notification_number='0', passive_checks_enabled='1', active_checks_enabled='1', event_handler_enabled='1', flap_detection_enabled='1', is_flapping='0', percent_state_change='0.000000', latency='0.000000', execution_time='4.502390', scheduled_downtime_depth='0', failure_prediction_enabled='0', process_performance_data='1', obsess_over_host='1', modified_host_attributes='0', event_handler='', check_command='check_nrpe_jpnmon!check_alive_nsin!!!!!!!', normal_check_interval='3.000000', retry_check_interval='1.000000', check_timeperiod_object_id='2' ON DUPLICATE KEY UPDATE instance_id='1', host_object_id='5604', status_update_time=FROM_UNIXTIME(1436994795), output='PING OK - Packet loss = 0%, RTA = 0\.85 ms', long_output='', perfdata='rta=0\.853000ms;3000\.000000;5000\.000000;0\.000000 pl=0%;80;100;0', current_state='0', has_been_checked='1', should_be_scheduled='1', current_check_attempt='1', max_check_attempts='3', last_check=FROM_UNIXTIME(1436994790), next_check=FROM_UNIXTIME(1436994975), check_type='0', last_state_change=FROM_UNIXTIME(1435803964), last_hard_state_change=FROM_UNIXTIME(1434561932), last_hard_state='0', last_time_up=FROM_UNIXTIME(1436994795), last_time_down=FROM_UNIXTIME(1430592573), last_time_unreachable=FROM_UNIXTIME(1435803922), state_type='1', last_notification=FROM_UNIXTIME(0), next_notification=FROM_UNIXTIME(0), no_more_notifications='0', notifications_enabled='1', problem_has_been_acknowledged='0', acknowledgement_type='0', current_notification_number='0', passive_checks_enabled='1', active_checks_enabled='1', event_handler_enabled='1', flap_detection_enabled='1', is_flapping='0', percent_state_change='0.000000', latency='0.000000', execution_time='4.502390', scheduled_downtime_depth='0', failure_prediction_enabled='0', process_performance_data='1', obsess_over_host='1', modified_host_attributes='0', event_handler='', check_command='check_nrpe_jpnmon!check_alive_nsin!!!!!!!', normal_check_interval='3.000000', retry_check_interval='1.000000', check_timeperiod_object_id='2'
[1436994795.391147] [002.0] [pid=9722] INSERT INTO nagios_hoststatus SET instance_id='1', host_object_id='5604', status_update_time=FROM_UNIXTIME(1436994795), output='PING OK - Packet loss = 0%, RTA = 0\.85 ms', long_output='', perfdata='rta=0\.853000ms;3000\.000000;5000\.000000;0\.000000 pl=0%;80;100;0', current_state='0', has_been_checked='1', should_be_scheduled='1', current_check_attempt='1', max_check_attempts='3', last_check=FROM_UNIXTIME(1436994790), next_check=FROM_UNIXTIME(1436994975), check_type='0', last_state_change=FROM_UNIXTIME(1435803964), last_hard_state_change=FROM_UNIXTIME(1434561932), last_hard_state='0', last_time_up=FROM_UNIXTIME(1436994795), last_time_down=FROM_UNIXTIME(1430592573), last_time_unreachable=FROM_UNIXTIME(1435803922), state_type='1', last_notification=FROM_UNIXTIME(0), next_notification=FROM_UNIXTIME(0), no_more_notifications='0', notifications_enabled='1', problem_has_been_acknowledged='0', acknowledgement_type='0', current_notification_number='0', passive_checks_enabled='1', active_checks_enabled='1', event_handler_enabled='1', flap_detection_enabled='1', is_flapping='0', percent_state_change='0.000000', latency='0.000000', execution_time='4.502390', scheduled_downtime_depth='0', failure_prediction_enabled='0', process_performance_data='1', obsess_over_host='1', modified_host_attributes='0', event_handler='', check_command='check_nrpe_jpnmon!check_alive_nsin!!!!!!!', normal_check_interval='3.000000', retry_check_interval='1.000000', check_timeperiod_object_id='2' ON DUPLICATE KEY UPDATE instance_id='1', host_object_id='5604', status_update_time=FROM_UNIXTIME(1436994795), output='PING OK - Packet loss = 0%, RTA = 0\.85 ms', long_output='', perfdata='rta=0\.853000ms;3000\.000000;5000\.000000;0\.000000 pl=0%;80;100;0', current_state='0', has_been_checked='1', should_be_scheduled='1', current_check_attempt='1', max_check_attempts='3', last_check=FROM_UNIXTIME(1436994790), next_check=FROM_UNIXTIME(1436994975), check_type='0', last_state_change=FROM_UNIXTIME(1435803964), last_hard_state_change=FROM_UNIXTIME(1434561932), last_hard_state='0', last_time_up=FROM_UNIXTIME(1436994795), last_time_down=FROM_UNIXTIME(1430592573), last_time_unreachable=FROM_UNIXTIME(1435803922), state_type='1', last_notification=FROM_UNIXTIME(0), next_notification=FROM_UNIXTIME(0), no_more_notifications='0', notifications_enabled='1', problem_has_been_acknowledged='0', acknowledgement_type='0', current_notification_number='0', passive_checks_enabled='1', active_checks_enabled='1', event_handler_enabled='1', flap_detection_enabled='1', is_flapping='0', percent_state_change='0.000000', latency='0.000000', execution_time='4.502390', scheduled_downtime_depth='0', failure_prediction_enabled='0', process_performance_data='1', obsess_over_host='1', modified_host_attributes='0', event_handler='', check_command='check_nrpe_jpnmon!check_alive_nsin!!!!!!!', normal_check_interval='3.000000', retry_check_interval='1.000000', check_timeperiod_object_id='2'
Is there something specific that I need to look for?
The ndo2db lock file is being created in the wrong folder and that is causing the Database Backend Status to be wrong.
Stop the ndo2db process
service ndo2db stop
Edit /usr/local/nagios/etc/ndo2db.cfg
change
to
lock_file=/usr/local/nagios/var/ndo2db.lock
Now delete the old files
rm /usr/local/nagiosxi/var/subsys/ndo2db*
rm /usr/local/nagios/var/ndo2db.lock
Start ndo2db
service ndo2db start
Run this too and post back the output
tail -50 /var/log/cron
mcwhorts
Post by mcwhorts »
Jul 15 12:47:01 niteowl CROND[366]: (root) CMD (ps -ef|grep -v grep |grep vmtoolsd > /dev/null || echo " To restart: vmtoolsd -b /var/run/vmtoolsd.pid" | mailer.sh -s "VMware tools down" -system root)
Jul 15 12:47:01 niteowl CROND[368]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php > /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jul 15 12:47:01 niteowl CROND[369]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jul 15 12:47:01 niteowl CROND[370]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jul 15 12:47:01 niteowl CROND[371]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php > /usr/local/nagiosxi/var/nom.log 2>&1)
Jul 15 12:47:01 niteowl CROND[372]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jul 15 12:47:01 niteowl CROND[380]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jul 15 12:48:01 niteowl CROND[4148]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php > /usr/local/nagiosxi/var/nom.log 2>&1)
Jul 15 12:48:01 niteowl CROND[4149]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php > /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jul 15 12:48:01 niteowl CROND[4150]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jul 15 12:48:01 niteowl CROND[4151]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1)
Jul 15 12:48:01 niteowl CROND[4152]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jul 15 12:48:01 niteowl CROND[4153]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jul 15 12:48:01 niteowl CROND[4155]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php > /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jul 15 12:48:01 niteowl CROND[4154]: (root) CMD (/etc/webmin/sysstats/sysstats.pl)
Jul 15 12:48:01 niteowl CROND[4163]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jul 15 12:49:01 niteowl CROND[8070]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1)
Jul 15 12:49:01 niteowl CROND[8071]: (root) CMD (/etc/webmin/sysstats/sysstats.pl)
Jul 15 12:49:01 niteowl CROND[8072]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php > /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jul 15 12:49:01 niteowl CROND[8073]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php > /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jul 15 12:49:01 niteowl CROND[8075]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jul 15 12:49:01 niteowl CROND[8078]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jul 15 12:49:01 niteowl CROND[8079]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jul 15 12:49:01 niteowl CROND[8080]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php > /usr/local/nagiosxi/var/nom.log 2>&1)
Jul 15 12:49:01 niteowl CROND[8082]: (root) CMD (differ.sh -a -f /var/adm/alert 2>&1 | mailer.sh -s "alert" -system [email protected],root`[ -f /.text ] && ( echo -n ,; cat /.text; )`)
Jul 15 12:49:01 niteowl CROND[8081]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jul 15 12:50:01 niteowl CROND[11902]: (root) CMD (/etc/webmin/sysstats/sysstats.pl)
Jul 15 12:50:01 niteowl CROND[11903]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php > /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jul 15 12:50:01 niteowl CROND[11904]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php > /usr/local/nagiosxi/var/dbmaint.log 2>&1)
Jul 15 12:50:01 niteowl CROND[11905]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php > /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jul 15 12:50:01 niteowl CROND[11906]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php > /usr/local/nagiosxi/var/nom.log 2>&1)
Jul 15 12:50:01 niteowl CROND[11909]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php > /usr/local/nagiosxi/var/deadpool.log 2>&1)
Jul 15 12:50:01 niteowl CROND[11912]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jul 15 12:50:01 niteowl CROND[11914]: (root) CMD (LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var/lib/mrtg/mrtg.ok)
Jul 15 12:50:01 niteowl CROND[11911]: (root) CMD (/usr/lib64/sa/sa1 1 1)
Jul 15 12:50:01 niteowl CROND[11910]: (root) CMD (topper.sh)
Jul 15 12:50:01 niteowl CROND[11915]: (root) CMD (access-mon.sh -rebuild 30 | egrep -v 'itchy|10.33.34.95|dbaud|toptrack' >> /var/log/access.log 2>>/tmp/access-mon-err)
Jul 15 12:50:01 niteowl CROND[11921]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jul 15 12:50:01 niteowl CROND[11919]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jul 15 12:50:01 niteowl CROND[11916]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1)
Jul 15 12:50:01 niteowl CROND[11926]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jul 15 12:51:01 niteowl CROND[13619]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php > /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jul 15 12:51:01 niteowl CROND[13620]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jul 15 12:51:01 niteowl CROND[13621]: (root) CMD (/etc/webmin/sysstats/sysstats.pl)
Jul 15 12:51:01 niteowl CROND[13622]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jul 15 12:51:01 niteowl CROND[13623]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php > /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jul 15 12:51:01 niteowl CROND[13625]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jul 15 12:51:01 niteowl CROND[13626]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jul 15 12:51:01 niteowl CROND[13628]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php > /usr/local/nagiosxi/var/nom.log 2>&1)
Jul 15 12:51:01 niteowl CROND[13629]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1)
mcwhorts
Post by mcwhorts »
After running these commands again
service nagios stop
killall -9 nagios
service ndo2db stop
service mysqld stop
service crond stop
service mysqld start
service nagios start
service crond start
It seems as though ndo2bd finally came to life. Everything appears to running as it should.
Thanks for all your help guys!
