SNMP configuration issue from Nagios XI
ssax
Dreams In Code
Re: SNMP configuration issue from Nagios XI
Post by ssax »
Just leave them unescaped in the resource.cfg file.
raamardhani7 wrote: I have created the password in resource.cfg,
And added the same command which you updated above in the portal and the output is as below.
COMMAND: /usr/local/nagios/libexec/check_snmp -H xx.xx.xx.xx -o '.1.3.6.1.4.1.12356.101.1.1403' -P 3 -U username -L authPriv -a sha -A '\$USER9\$' -x aes -X '\$USER10\$'
OUTPUT: External command error: snmpget: Timeout
As I said before, this will not work by running the test command button, go to Home > Service Detail and find the service, click on it to view the service details, and force an immediate check to see if it works.
raamardhani7
Post by raamardhani7 »
ssax wrote:Just leave them unescaped in the resource.cfg file.
Hi Ssax,
Thanks for the insights. Please find the screenshot attached below.. and advise if I need to something extra.
ssax
Dreams In Code
Post by ssax »
That result means that the device doesn't have that OID (or isn't setup to offer that OID) are you sure it's the proper OID? Are you sure the device is configured properly?
You can try an SNMP walk to see what OIDs are available:
snmpwalk -v 3 -u username -l authPriv -a SHA -A AUTHPASS -x AES -X PRIVPASS XXX.XXX.XXX.XXX:161 -On
raamardhani7
ssax wrote:That result means that the device doesn't have that OID (or isn't setup to offer that OID) are you sure it's the proper OID? Are you sure the device is configured properly?
HI Ssax,
I could find the output of the oid.
grep .1.3.6.1.4.1.12356.101.1.1403 raamtest
.1.3.6.1.2.1.1.2.0 = OID: .1.3.6.1.4.1.12356.101.1.1403
Please find the output file attached. command is still executing :P
raamardhani7
Hi Ssax,
I've changed the OID to the one which it is listing or pointing to.
Screenshot form Portal is uploaded, please check, review and provide your comments on it please.
ssax
Dreams In Code
Post by ssax »
From your service screenshots it looks like you're trying to check system uptime, is that the case?
You would want to use this OID then: .1.3.6.1.2.1.1.3.0
Here is the description of the OID that you used (.1.3.6.1.2.1.1.2.0):
sysObjectID OBJECT-TYPE
              SYNTAX  OBJECT IDENTIFIER
              ACCESS  read-only
              STATUS  mandatory
              DESCRIPTION
                      "The vendor's authoritative identification of the
                      network management subsystem contained in the
                      entity.  This value is allocated within the SMI
                      enterprises subtree (1.3.6.1.4.1) and provides an
                      easy and unambiguous means for determining `what
                      kind of box' is being managed.  For example, if
                      vendor `Flintstones, Inc.' was assigned the
                      subtree 1.3.6.1.4.1.4242, it could assign the
                      identifier 1.3.6.1.4.1.4242.1.1 to its `Fred
                      Router'."
              ::= { system 2 }
Try running the walk command without the -On to get more insight:
raamardhani7
ssax wrote:From your service screenshots it looks like you're trying to check system uptime, is that the case?
              ACCESS  read-only
              STATUS  mandatory
              DESCRIPTION
                      Router'."
              ::= { system 2 }
Hi Ssax,
Thanks a lot for your insights. This worked for device uptime.. i have changed the OID and it worked.
I wanted to configure for CPU, Mem, VPN sessions.
I have tried configuring CPU load using ./check_snmp_load.pl, please find the output and help me where I am going wrong please.
./check_snmp_load.pl -H xx.xx.xx.xx -v 3 -l username -x AUTHPASS -X PRIVPASS -w 50 -c 70 -T fg -L sha,aes -p 161
Alarm at 15 + 5
SNMPv3 login
SNMPv3 AuthPriv login : username, sha, aes
Checking OID : .1.3.6.1.4.1.12356.1.8.0
OID returned noSuchObject
Argument "noSuchObject" isn't numeric in printf at ./check_snmp_load.pl line 602.
CPU used 0.0% (<50) : OK
What is the make and model of the device you are trying to monitor?
raamardhani7
tgriep wrote:What is the make and model of the device you are trying to monitor?
It is fortigate device.
T1 interface WAN
Model I am not aware.. :(, but if it is mandatory I can get that information.
I don't think we need the model number.
The plugin looks like it can only check the CPU load for your device and that's all.
Can you run the snmpwalk command and post the output here?
