Bandwidth on passive host
Re: Bandwidth on passive host
Oh nice that started fine, no errors reported. I'll have to get Nagios to handle the data checks now.
Does that mean that this one is resolved?Jam1987 wrote:Oh nice that started fine, no errors reported. I'll have to get Nagios to handle the data checks now.
Former Nagios Employee.
me.
me.
umm I still have to get the checks working properly in the Nagios Web interface, so not fully solved just yet.
Thanks for the reply.
Quick question, I have a nrpe config file but when I go to run a nrpe command it says check_nrpe is not found. So I went looking in the libexec folder and it isn't there. Does this mean I should reinstall the nrpe plugin?
When you say reinstall...you had it at one point?Jam1987 wrote:Quick question, I have a nrpe config file but when I go to run a nrpe command it says check_nrpe is not found. So I went looking in the libexec folder and it isn't there. Does this mean I should reinstall the nrpe plugin?
find / -name check_nrpeFormer Nagios Employee.
me.
me.
I believe I started to install it due to thinking I needed it then I may have stopped. I'll be honest I can't remember. I'm gonna install from scratch to make sure. Sorry for the kerfuffle.
No worries, I forgive you since you used the word kerfuffle.Jam1987 wrote:I believe I started to install it due to thinking I needed it then I may have stopped. I'll be honest I can't remember. I'm gonna install from scratch to make sure. Sorry for the kerfuffle.
me.
me.
Ok now NRPE is installed:
But when I run the command check_nrpe it just says:
The file exists in libexec:
Am I missing something?
./check_nrpe -H localhost
NRPE v2.15
check_nrpe: command not found
/home/futuresign/Downloads/nagios/nrpe-2.14/src/check_nrpe
/usr/local/nagios/libexec/check_nrpe
You have to either call it by the actual path(/usr/local/nagios/libexec/check_nrpe), or be in the directory that the binary is sitting in. If you wanted to you COULD "make your own command" to make this easier.Jam1987 wrote:Ok now NRPE is installed:
But when I run the command check_nrpe it just says:Code: Select all
./check_nrpe -H localhost NRPE v2.15
The file exists in libexec:Code: Select all
Am I missing something?Code: Select all
find / -name check_nrpe /home/futuresign/Downloads/nagios/nrpe-2.14/src/check_nrpe /usr/local/nagios/libexec/check_nrpe
me.
me.
