Your session has timed out.
ranjitw
Re: Your session has timed out.
Post by ranjitw »
Hi ,
I have attached the requested files . Please review.
Regards,
Ranjit W
Regards,
Ranjit W
Can you edit the process_perfdata.cfg file and change this line from
LOG_LEVEL = 0
to
LOG_LEVEL = 2
Save it out and that will start to add debug information to the log file.
Take a look at the debug file and post the errors you can find in it.
ranjitw
Post by ranjitw »
I have changed the debug log level to 2 but perfdata.log file is not generated. Please help.
tail -50 /usr/local/nagios/var/perfdata.log
tail: cannot open `/usr/local/nagios/var/perfdata.log' for reading: No such file or directory
Regards,
Ranjit W
Regards,
Ranjit W
Post by Box293 »
Try restarting npcd and check again.
service npcd restart
Also, what is the file count at again?
ls -al /usr/local/nagios/var/spool/perfdata/ | wc -l
ls -al /usr/local/nagios/var/spool/xidpe/ | wc -l
ranjitw
Post by ranjitw »
Hi ,
Below is the output for the commands:
9248
193036
Regards,
Ranjit W
Regards,
Ranjit W
Post by Box293 »
You are going to need to run this command again:
cd /usr/local/nagios/var/spool/xidpe/
for f in *; do rm -f $f; done
Then
Then after this watch the logs and see what is going on.
ranjitw
Post by ranjitw »
Hi ,
Have run the commands mentioned but still getting below message :
Please suggest,
Regards,
Ranjit W
Regards,
Ranjit W
Post by Box293 »
Lets go back to basics.
Follow the FAQ entry below to increase the log level of process_perfdata and npcd:
http://support.nagios.com/wiki/index.ph ... leshooting
Wait 15 - 20 minutes and then get a tail of the logs:
tail -250 /usr/local/nagios/var/perfdata.log > /tmp/perfdata.txt
tail -250 /usr/local/nagios/var/npcd.log > /tmp/npcd.txt
Send us a copy of /tmp/perfdata.txt and /tmp/npcd.txt
Don't forget to turn down the log level as per the FAQ when you are done!
ranjitw
Post by ranjitw »
Thanks a lot for sharing detailed steps I could now capture the logs . I have attached it to the case.
Regards,
Ranjit W
Regards,
Ranjit W
Did removing the perfdata files from the "/usr/local/nagios/var/spool/xidpe/" directory and restarting the npcd help? What is the specific issue that you are currently having? Are you still having difficulties acceding the "http://x.x.x.x/nagiosxi/includes/compon ... w=services"?
