pls, have a look at my configs
vvz
Re: pls, have a look at my configs
Post by vvz »
Actually I can see this group in both cache files,
line 344 in vim
that's new obj.cache (renamed to obj.txt) after restarting nagios
thank you for your help
obj.txt
(148.69 KiB) Downloaded 331 times
Opps, typo on my part. I meant "in the new service check" not "and the new service check"
This is what I found in your objects.cache file. It doesn't show your changes that you added for the pagerduty-warning, etc. Can you post your the config files so we can review them or PM them to me?
	host_name	vnode2-concert-site
	service_description	root partition amount
	check_period	24x7
	check_command	run-nsca-script
	contacts	pagerduty-critical
	notification_period	24x7
	initial_state	o
	check_interval	1.000000
	retry_interval	1.000000
	max_check_attempts	1
	is_volatile	0
	parallelize_check	1
	active_checks_enabled	0
	passive_checks_enabled	1
	obsess_over_service	1
	event_handler_enabled	1
	low_flap_threshold	0.000000
	high_flap_threshold	0.000000
	flap_detection_enabled	0
	flap_detection_options	o,w,u,c
	freshness_threshold	60
	check_freshness	0
	notification_options	c
	notifications_enabled	1
	notification_interval	10.000000
	first_notification_delay	0.000000
	stalking_options	n
	process_perf_data	1
	failure_prediction_enabled	1
	retain_status_information	1
	retain_nonstatus_information	1
vvz
Post by vvz »
yeah, you are right - only pagerduty-critical contact in service definition, do not understand why...
let me check ...
sorry, which configs are you asking?
sure I'll provide them
vvz
Post by vvz »
I guess this one
hostgroup_name root-partition-status-passive
check_interval 1
retry_interval 1
check_period 24x7
contacts pagerduty-warning
notification_interval 30
notification_options w
check_freshness 0
is_volatile 0
Last thing to try is to delete the objects.cache, objects.precache and the retention.dat files to see if the settings get updated.
The downside of this is that your system will lose the Duration time, Last Check time and it will act like the system is brand new and it will start to check all of the hosts and services.
If you are willing to do this, run the following.
service nagios stop
rm /var/log/nagios/objects.cache
rm var/log/nagios/objects.precache
rm /var/log/nagios/retention.dat
service nagios start
Let us know if this resolves the issue.
