There are currently two scripts, modify_user and modify_usermeta It would seem that a fairly straightforward modification of those scripts would do the trick. I've seen the MySQL and have been too busy to write one myself, it is fairly straightforward, though.
I know the scripts do not address this problem, but you must be 95% of the way to using it to create users, just a bit more code (or less, you don't have to read the user from MySQL.)
Nagios XI 5R1.0 AD settings
Re: Nagios XI 5R1.0 AD settings
@jkinning did you have anything else you needed or are we good to close this? Haven't heard from you in a week or so.
You can close. At this time I have marked it up as a worthless feature for our environment. Hopefully improvements come real soon.
