Ok so I got it working but this happened when it was done:
How to make that update check not fail?
Also, not sure if it's just me but the update absolutely hosed my home dashboard since everything somehow got re-sized to massive.
Errors in DB trying to upgrade to XI 5
- snapon_admin
Re: Errors in DB trying to upgrade to XI 5
Both of these issues are known bugs. We are planning a bugfix release for latter this week as far as I know.
Former Nagios Employee.
me.
me.
- snapon_admin
Awesome, sounds good! Go ahead and lock this up, I'll get to bug hunting and let you know if I find anything else.
Perfect, I'll lock it up. Good luck on your XI5 journey!
me.
me.
