SNMP troubles after 5R1.0 upgrade
dlukinski
Re: SNMP troubles after 5R1.0 upgrade
Post by dlukinski »
After few week of usage I noticed that snmpwalk via GUI (apache) works from time to time even with 60-70 hosts (by now in our development) under monitoring.
Or it fails on the first attempt ("Next" to the 2nd scree), but works after "Back" and "Next" done once again.
Clearly something is not ideal, nor it is completely broken. Might be attributed to our highly virtualized environment.
Hope to see this addressed in future patches.
ssax
Dreams In Code
Post by ssax »
I've reached out to the developer who wrote that functionality, we'll see what he says.
60-70 hosts is a fairly small environment (depending on the number of service checks) so it shouldn't really affect that wizard.
What does your load look like?
uptime
top
ssax
Dreams In Code
Post by ssax »
Also, edit your /etc/php.ini and increase your memory_limit:
memory_limit = 256M
Then restart HTTPD and try it again:
service httpd restart
dlukinski
Post by dlukinski »
ssax wrote:I've reached out to the developer who wrote that functionality, we'll see what he says.
uptime
top
ssax
Dreams In Code
Post by ssax »
Did you adjust the php memory_limit from the post after?
dlukinski
Post by dlukinski »
ssax wrote:Did you adjust the php memory_limit from the post after?
Yes I doubled it (and could probably quadruple later on if required)
- please let me run snmpwalks for a week and let you know if there was a definite improvement
hsmith
Agent Smith
Post by hsmith »
Let us know.
Thanks!
Former Nagios Employee.
me.
dlukinski
Post by dlukinski »
hsmith wrote:Let us know.
Thanks!
For very remote snmpwalks this still fails, but for local ones things work
I wonder if this has to be doubled again (?)
ssax
Dreams In Code
Post by ssax »
What is the output of these commands:
snmpwalk -v 2c -c COMMUNITY X.X.X.X:161 .1.3.6.1.2.1.25.2.3.1.3
snmpwalk -v 2c -c COMMUNITY X.X.X.X:161 .1.3.6.1.4.1.77.1.2.3.1.1
snmpwalk -v 2c -c COMMUNITY X.X.X.X:161 .1.3.6.1.2.1.25.4.2.1.2
Try running them multiple times to see if it fails as well.
Now let's check the size:
snmpwalk -v 2c -c COMMUNITY X.X.X.X:161 .1.3.6.1.2.1.25.2.3.1.3 > /tmp/snmp_output_1.txt
snmpwalk -v 2c -c COMMUNITY X.X.X.X:161 .1.3.6.1.4.1.77.1.2.3.1.1 > /tmp/snmp_output_2.txt
snmpwalk -v 2c -c COMMUNITY X.X.X.X:161 .1.3.6.1.2.1.25.4.2.1.2 /tmp/snmp_output_3.txt
ls -l /tmp/snmp_output*
dlukinski
Post by dlukinski »
ssax wrote:What is the output of these commands:
- did not fail against two very remote SNMPWALKs (except that 2nd command returns no object)
[root@fikc-nagxiprod01 ~]# ls -l /tmp/snmp_output*
-rw-r--r-- 1 root root 875 Nov 11 17:10 /tmp/snmp_output_1.txt
-rw-r--r-- 1 root root 90 Nov 11 17:11 /tmp/snmp_output_2.txt
#3 not created.
