I will indeed, sir!eloyd wrote:Remember me when I start asking for MVP nominations next year.
Problem with check_http for https site
neworderfac33
Re: Problem with check_http for https site
neworderfac33
The tar file definitely isn't on the Nagios server, so my colleague must have removed it when he unzipped it
I note that the official Nagios installation guide specifies the following for plugin installation:
how do these user and group parameters fit around the openssl parameter - do I just append them?
Cheers
Pete
cd /tmp/nagios-plugins-2.0
./configure --with-nagios-user=nagios --with-nagios-group=nagios
make
make install
./configure --with-openssl=/usr/bin/openssl --with-nagios-user=nagios --with-nagios-group=nagios
Pete
Last edited by neworderfac33 on Tue Oct 20, 2015 11:24 am, edited 1 time in total.
Yes, but the assumption is that you have created the nagios user and nagios group, which you probably already did, so you can do the command you just listed and it should work.
Make sure you put a space after "./configure" and before the "--with-openssl=/usr/bin/openssl"
neworderfac33
Much obliged sir!
17:25 - home time - yippee! - thanks for all your help - I'll let you know how we get on tomorrow.
Pete
Pete
Thanks Eric/Pete
Let us know what you come up with!
Former Nagios Employee.
me.
me.
neworderfac33
It all worked perfectly - thank you all for your assistance!
Thread can now be closed.
Pete
Pete
Glad to see that this worked for you. I will now close this thread, but feel free to open another if you need more assistance.
