Yeah, I agree, I will submit it as a bug report since they really shouldn't overlap like that.
For the missing bulk modifications value box, are you seeing any javascript errors or anything in your /var/log/httpd/error_log?
Google Maps Hostgroup Functionality
Re: Google Maps Hostgroup Functionality
Bug report submitted:
NEW TASK ID 7030 created - Nagios XI Bug Report: Google Maps Component - Multiple markers in same place only shows the last marker.Re: Google Maps Hostgroup Functionality
No errors. Nothing for days.
[root@USSTPD0NAGXISTG ~]# cat /var/log/httpd/error_log
[Sun Nov 15 03:12:08 2015] [notice] Digest: generating secret for digest authentication ...
[Sun Nov 15 03:12:08 2015] [notice] Digest: done
[Sun Nov 15 03:12:09 2015] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
Please zip up your /usr/local/nagiosxi/html/includes/components/bulkmodifications directory and attach it here so that I can review it and see if there are differences in the code.
Thank you
Thank you
Here it is.
What version of XI are you running, I just reverted mine to a snapshot and then replace the files and it works fine on 5.2.2
Installed Version: 5.2.0
Sean is out of the office this week, and we will be closed tomorrow and Friday for U.S. holidays. There is already a feature request in for this, and either Sean or the developers will need to take it from here. It will probably be fastest to wait until Sean comes back, as these modifications were made by him and the developers aren't likely to put this on top of their priority list.
Has any progress been made towards this?
Oh, actually, can you try clearing your browser cache and see if that fixes it?
If not, please send an email to [email protected] with a descriptive subject and a detailed body with a link back to this thread so that we can get a remote session setup.
Thank you
Thank you
