failed to upgrade from 5.2.0 to 5.2.2
Re: failed to upgrade from 5.2.0 to 5.2.2
Which way did you upgrade the XI system? Manually from the command line or through the Web interface?
Can you upload the upgrade.log files so we can review them?
It can be located in these 2 locations.
/usr/local/nagiosxi/tmp/upgrade.log
/tmp/nagiosxi/tmp/upgrade.log
doneil326
Post by doneil326 »
i have now tried with 5.2.3 with the same error. attached is the upgrade.log. the same error occures manually/gui.
I see that a ticket has been created for this issue, I will close this thread out so that we can continue there.
