I have not updated this yet, but noticed that while I was away, performance graphs are no longer working again. I rebooted this morning, but the performance graphs are still missing. I can't seem to get them to show up....
# tail -25 /usr/local/nagios/var/npcd.log
[01-28-2016 10:04:25] NPCD: ThreadCounter 4/5 File is 1454003856.perfdata.host
[01-28-2016 10:04:25] NPCD: Regular File: 1454003856.perfdata.host
[01-28-2016 10:04:25] NPCD: A thread was started on thread_counter = 4
[01-28-2016 10:04:25] NPCD: DEBUG: load 11.510000/20.000000
[01-28-2016 10:04:25] NPCD: ThreadCounter 5/5 File is 1454003856.perfdata.service
[01-28-2016 10:04:25] NPCD: Regular File: 1454003856.perfdata.service
[01-28-2016 10:04:25] NPCD: WARN: MAX Thread reached: 1454003856.perfdata.service comes later with ThreadCounter: 5
[01-28-2016 10:04:25] NPCD: DEBUG: Will wait for th['4']
[01-28-2016 10:04:25] NPCD: Processing file 1454003856.perfdata.host with ID 140518939485952 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1454003856.perfdata.host
[01-28-2016 10:04:25] NPCD: Processing file '1454003856.perfdata.host'
[01-28-2016 10:04:43] NPCD: DEBUG: Will wait for th['3']
[01-28-2016 10:05:10] NPCD: ERROR: Executed command exits with return code '7'
[01-28-2016 10:05:10] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1454003826.perfdata.service'
[01-28-2016 10:05:14] NPCD: ERROR: Executed command exits with return code '7'
[01-28-2016 10:05:14] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1454003842.perfdata.service'
[01-28-2016 10:05:16] NPCD: DEBUG: Will wait for th['2']
[01-28-2016 10:05:16] NPCD: DEBUG: Will wait for th['1']
[01-28-2016 10:05:16] NPCD: DEBUG: Will wait for th['0']
[01-28-2016 10:05:16] NPCD: DEBUG: load 7.470000/20.000000
[01-28-2016 10:05:16] NPCD: ThreadCounter 0/5 File is 1454003856.perfdata.service
[01-28-2016 10:05:16] NPCD: Regular File: 1454003856.perfdata.service
[01-28-2016 10:05:16] NPCD: A thread was started on thread_counter = 0
[01-28-2016 10:05:16] NPCD: Have to wait: Filecounter = 46 - thread_counter = 1
[01-28-2016 10:05:16] NPCD: Processing file 1454003856.perfdata.service with ID 140518970955520 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1454003856.perfdata.service
[01-28-2016 10:05:16] NPCD: Processing file '1454003856.perfdata.service'
]# tail -25 /usr/local/nagios/var/perfdata.log
2016-01-28 10:05:47 [6831] [1] Found Performance Data for L2E-LAN-B02 / CPU_Busy_5_Sec ('CPU Busy 5 Sec'=1;80;90;)
2016-01-28 10:05:47 [6831] [2] No Custom Template found for check_snmp (/usr/local/nagios/etc/pnp/check_commands/check_snmp.cfg)
2016-01-28 10:05:47 [6831] [2] Template is check_snmp.php
2016-01-28 10:05:47 [6831] [2] data2rrd called
2016-01-28 10:05:47 [6831] [2] RRDs::update /usr/local/nagios/share/perfdata/L2E-LAN-B02/CPU_Busy_5_Sec.rrd 1454003842:1
2016-01-28 10:05:47 [6831] [2] /usr/local/nagios/share/perfdata/L2E-LAN-B02/CPU_Busy_5_Sec.rrd updated
2016-01-28 10:05:47 [6831] [2] Processing Line 77
2016-01-28 10:05:47 [6831] [2] Datatype set to 'SERVICEPERFDATA'
2016-01-28 10:05:47 [6831] [1] Found Performance Data for L2E-LAN-B01 / VPC-3_to_KDCNBUFLT-SW-01_Po3_Port_Channel_Bandwidth (in=.000005Gb/s;7;8 out=.000767Gb/s;7;8)
2016-01-28 10:05:47 [6831] [2] No Custom Template found for check_xi_service_mrtgtraf (/usr/local/nagios/etc/pnp/check_commands/check_xi_service_mrtgtraf.cfg)
2016-01-28 10:05:47 [6831] [2] Template is check_xi_service_mrtgtraf.php
2016-01-28 10:05:47 [6831] [2] RRDs::update /usr/local/nagios/share/perfdata/L2E-LAN-B01/VPC-3_to_KDCNBUFLT-SW-01_Po3_Port_Channel_Bandwidth.rrd 1454003842:.000005:.000767
2016-01-28 10:05:47 [6831] [2] /usr/local/nagios/share/perfdata/L2E-LAN-B01/VPC-3_to_KDCNBUFLT-SW-01_Po3_Port_Channel_Bandwidth.rrd updated
2016-01-28 10:05:47 [6831] [2] Processing Line 78
2016-01-28 10:05:47 [6831] [1] Found Performance Data for L2E-LAN-B01 / e2_2_UCS_Domain__1_Interconnect_A_1_18_Bandwidth (in=.032351Gb/s;7;8 out=.027169Gb/s;7;8)
2016-01-28 10:05:47 [6831] [2] RRDs::update /usr/local/nagios/share/perfdata/L2E-LAN-B01/e2_2_UCS_Domain__1_Interconnect_A_1_18_Bandwidth.rrd 1454003842:.032351:.027169
# free -m
total used free shared buffers cached
Mem: 15950 6375 9574 27 104 4565
-/+ buffers/cache: 1705 14244
Swap: 2015 0 2015
top - 10:09:48 up 1:09, 1 user, load average: 5.21, 7.13, 6.31
Tasks: 338 total, 1 running, 337 sleeping, 0 stopped, 0 zombie
Cpu(s): 11.5%us, 4.2%sy, 0.0%ni, 70.9%id, 12.3%wa, 0.1%hi, 1.0%si, 0.0%st
Mem: 16333268k total, 6565848k used, 9767420k free, 106868k buffers
Swap: 2064380k total, 0k used, 2064380k free, 4717636k cached
