monitor clustered shared volumes in 2012 R2 using Nagios
Re: monitor clustered shared volumes in 2012 R2 using Nagios
Post by Box293 »
The queues performance counter is an option. Examples here:
http://sites.box293.com/nagios/guides/c ... erformance
WillemDH
Post by WillemDH »
this script does monitor latency of standalone disk. I would like to monitor latency of clustered shared volumes.
I'm using it to monitor cluster disks latency's. Just create a host for the cluster ip address and use that as host. By the way my syntax looks like this:
COMMAND: /usr/local/nagios/libexec/check_nrpe -H f1rebase.ddns.net -t 45 -c check_ms_win_disk_load -a '-dl E -ms 5'
OUTPUT: OK: Drive E: Avg of 5 samples: {Rate (Read: 0.00000MB/s)(Write: 0.00000MB/s)} {Avg Nr of (Reads: 0.00000r/s)(Writes: 0.00000w/s)} {Latency (Read: 0.00000ms)(Write: 0.00000ms)} {Queue Length (Read: 0.00000ql)(Write: 0.00000ql)} |'Read_Latency'=0ms 'Write_Latency'=0ms 'Read_Queue'=0ql 'Write_Queue'=0ql 'Number_of_Reads'=0r/s 'Number_of_Writes'=0w/s 'Read_Rate'=0MB/s 'Write_Rate'=0MB/s
It's possible my website is a bit outdated. in the past you needed to include at least one parameter, but I solved that. Check the screenshot of my config.
Let me know if you get it working.
Nagios XI 5.8.1
https://outsideit.net
Thanks @WillemDH!
@jyoti22 let us know if this helps.
jyoti22
Post by jyoti22 »
Thanks @WillemDH!
This works fine. However my clients New requirement is to check IO latency for SAN disk (SAN connected drives) on HyperV servers. . Can you please help me on it.
WillemDH
Post by WillemDH »
Sorry I'm using VMware, I dont have alot of knowledge of hyperv.. I'm guessing you already tried to search the Nagios Exchange? Maybe this? https://exchange.nagios.org/directory/P ... ce/details
Nagios XI 5.8.1
Are you looking to monitor the IO from the Hyper-V host or from a Hyper-V client?
