check_npre UNKNOWN: No handler for that command”
bdm0917
Re: check_npre UNKNOWN: No handler for that command”
Post by bdm0917 »
Thanks! it helped; however, there is a new issue...timeout error (60s).
Please see attached.
In your nsc.ini look for -
[External Script]
;# COMMAND TIMEOUT
;  This specifies the maximum number of seconds that the NRPE daemon will allow plug-ins to finish executing before killing them off.
;command_timeout=60
Uncomment the command_time=60 line, and change it to command_time=120.
Restart the NSClient service, and try again.
Let us know the result.
bdm0917
Post by bdm0917 »
That worked!!! Thanks all for your help with troubleshooting this. A combination of edits in the NSC.ini file seemed to help sure up the steps in the documentation. Thanks
Glad to see this working! I'll go ahead and close this thread out now, but feel free to open a new one if you need more assistance in the future!
