Scheduling queue freezes
aisebouma
Re: Scheduling queue freezes
Post by aisebouma »
rkennedy wrote:I found a post here that may correlate to the issue you are experiencing - https://support.nagios.com/forum/viewto ... 10#p112580
Can you post the contents of the file below for us to review?
/etc/sysctl.conf
cat /etc/sysctl.conf
# /etc/sysctl.conf - Configuration file for setting system variables
# See /etc/sysctl.d/ for additional system variables.
# See sysctl.conf (5) for information.
#kernel.domainname = example.com
# Uncomment the following to stop low-level messages on console
#kernel.printk = 3 4 1 3
##############################################################3
# Functions previously found in netbase
# Uncomment the next two lines to enable Spoof protection (reverse-path filter)
# Turn on Source Address Verification in all interfaces to
# prevent some spoofing attacks
#net.ipv4.conf.default.rp_filter=1
#net.ipv4.conf.all.rp_filter=1
# Uncomment the next line to enable TCP/IP SYN cookies
# See http://lwn.net/Articles/277146/
# Note: This may impact IPv6 TCP sessions too
#net.ipv4.tcp_syncookies=1
# Uncomment the next line to enable packet forwarding for IPv4
#net.ipv4.ip_forward=1
# Uncomment the next line to enable packet forwarding for IPv6
#  Enabling this option disables Stateless Address Autoconfiguration
#  based on Router Advertisements for this host
#net.ipv6.conf.all.forwarding=1
# Additional settings - these settings can improve the network
# security of the host and prevent against some network attacks
# including spoofing attacks and man in the middle attacks through
# redirection. Some network environments, however, require that these
# settings are disabled so review and enable them as needed.
# Do not accept ICMP redirects (prevent MITM attacks)
#net.ipv4.conf.all.accept_redirects = 0
#net.ipv6.conf.all.accept_redirects = 0
# _or_
# Accept ICMP redirects only for gateways listed in our default
# gateway list (enabled by default)
# net.ipv4.conf.all.secure_redirects = 1
# Do not send ICMP redirects (we are not a router)
#net.ipv4.conf.all.send_redirects = 0
# Do not accept IP source route packets (we are not a router)
#net.ipv4.conf.all.accept_source_route = 0
#net.ipv6.conf.all.accept_source_route = 0
# Log Martian Packets
#net.ipv4.conf.all.log_martians = 1
Can you give the instructions I linked to a try and let us know if it occurs again?
Open /etc/sysctl.conf with a text editor. Edit the file to match the following values:
# Controls the maximum size of a message, in bytes
kernel.msgmnb = 131072000
# Controls the default maxmimum size of a mesage queue
kernel.msgmax = 131072000
# Controls the maximum shared segment size, in bytes
kernel.shmmax = 4294967295
# Controls the maximum number of shared memory segments, in pages
kernel.shmall = 268435456
## The maximum number of messages allowed in any one message queue
kernel.msgmni = 256000
Note: If you don't have these entries in the "/etc/sysctl.conf" file, just add them to the end of the file.
After these settings are saved to the file, run:
sysctl -p
aisebouma
Post by aisebouma »
OK, I followed your instructions. I will let you know if this fixes it.
Sounds good. I'll leave this thread open, let us know if this works for you.
aisebouma
Post by aisebouma »
Unfortunately the scheduling queue froze again yesterday. I will leave it in this state in case you want to look at some files while the scheduling is not working.
This might be related to an NDO bug that was fixed in recent versions. What is the output of ipcs -q on your Nagios system?
aisebouma
Post by aisebouma »
tmcdonald wrote:This might be related to an NDO bug that was fixed in recent versions. What is the output of ipcs -q on your Nagios system?
------ Message Queues --------
key        msqid      owner      perms      used-bytes   messages
0x68010002 65536      nagios     600        16384        16
0xc3013798 131073     nagios     600        16384        16
Queue looks fine, and our dev said he found nothing of note in the retention.dat.
If you are comfortable patching and recompiling Core, we have a patch that will add in some debug logging for the Compensating messages. I have attached it here, let us know if you need assistance.
freeze.diff
(3.71 KiB) Downloaded 820 times
aisebouma
Post by aisebouma »
tmcdonald wrote:Queue looks fine, and our dev said he found nothing of note in the retention.dat.
I patched it and recompiled. Now running with the patched version. I report back when the queue froze again?
Yes. We are looking for the "DebugQueueFreeze" messages in nagios.log.
