errors in config - CHECK_PGACTIVITY plugin
wolf57
Re: errors in config - CHECK_PGACTIVITY plugin
Post by wolf57 »
it all works using IP address
root@montwo:~# su - nagios
nagios@montwo:~$ check_pgactivity -h 10.11.0.200 -s backends -w 80 -c 95
POSTGRES_BACKENDS OK: 2 connections on 297 | postgres=1;80;95;0;297 nagios=0;80;95;0;297 phppgadmin=0;80;95;0;297 repmgrdb=0;80;95;0;297 opm=0;80;95;0;297 test4=0;80;95;0;297 template1=1;80;95;0;297 ima=0;80;95;0;297 test2=0;80;95;0;297 test1=0;80;95;0;297 test3=0;80;95;0;297 maximum_connections=297;80;95;0;297
nagios@montwo:~$ nslookup 10.11.0.200
Server: 140.197.230.100
Address: 140.197.230.100#53
Non-authoritative answer:
200.0.11.10.in-addr.arpa name = pgtest-db.uen.org.
Authoritative answers can be found from:
0.11.10.in-addr.arpa nameserver = ns2.uen.net.
0.11.10.in-addr.arpa nameserver = ns.uen.net.
nagios@montwo:~$ nslookup pgtest-db
Address: 10.11.0.200
Post by Box293 »
Lets go back and check the configs:
Show us the command defined in /etc/nagios3/objects/command.cfg
Show us the service defined in /etc/nagios3/objects/services/check_pgactivity.cfg
Also what is the output of:
grep -R 'check_pgactivity' /etc/nagios3/
wolf57
Post by wolf57 »
command.cfg and check_pgactivity.cfg are attached files
nagios@montwo:~$ grep -R 'check_pgactivity' /etc/nagios3/
/etc/nagios3/objects/services/check_nrpe.cfg: check_command check_nrpe!check_pgactivity! base253
/etc/nagios3/objects/services/check_pgactivity.cfg: service_description check_pgactivity
/etc/nagios3/objects/services/check_pgactivity.cfg: check_command check_pgactivity! -s backends -w 80% -c 95%
/etc/nagios3/objects/services-old/check_pgactivity.cfg: service_description check_pgactivity
/etc/nagios3/objects/services-old/check_pgactivity.cfg: check_command check_pgactivity!5432!backends!80!95
/etc/nagios3/objects/commands.cfg: command_name check_pgactivity
/etc/nagios3/objects/commands.cfg: command_line $USER1$/check_pgactivity -h $HOSTADDRESS$ $ARG1$
check_pgactivity.cfg.txt
(1.18 KiB) Downloaded 192 times
command.cfg.txt
(11.52 KiB) Downloaded 252 times
Post by Box293 »
It's possible this old config file is being read in and overwritting the first one:
Try moving it to /tmp and the restart nagios service.
wolf57
Post by wolf57 »
I don't see how it can, It gets the info from nagios.cfg. I did move the whole directory out of /etc/nagios3/object but still getting the same error
Post by Box293 »
Are you using Nagios XI ?
wolf57
Post by wolf57 »
Nagios3 version 3.2.3-3ubuntu1.1 This is an Ubuntu 12.04 server, I used apt-get to install Nagios
Post by Box293 »
In the left pane under System click Configuration
Select Services
Click Continue
In the top right type in check_pgactivity
Click Update
Can you send a screenshot of that
You might need two as it will get wide
Click the Check Command (it's a hyperlink)
Please make sure you are posting in the correct section of the forum. The XI section of the forum should be used for XI questions. I will be moving this to the Core section.
wolf57
Post by wolf57 »
I'm no longer able to send PDF file, its been deactivated. If I try to attach as rich text it fails after the download. Not sure why this was turned off
