I check the commands.cfg file between Nagios core with Nagios XI.
I found the check_nt command line had option '-s'.
It's password needed for the request.
The problem solved.
Thanks a lot.
Best Regards,
Lance
The CPU_Load.XML error in PNP4Nagiosxi
Re: The CPU_Load.XML error in PNP4Nagiosxi
Shall we close the post for you?
Yes!tgriep wrote:Shall we close the post for you?
Thank you.
Glad we were able to help. We'll lock this thread now and feel free to open another should you require assistance with anything else.
