This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
Posts: 9190 Joined: Thu Oct 30, 2014 9:02 am
Post
by tgriep » Tue Jan 26, 2016 11:00 am
In the XI GUI, can you click on Home > Services detail, select the service that is failing, click on the Advanced Tab and post a screen capture of it?
I looked at the script and it uses a temporary file to store the results, maybe that could be the issue.
Can you login as root on the XI server, run the following commands and post the output?
ls -al /usr/lib64/
ls -al /usr/lib64/nagios/
ls -al /usr/lib64/nagios/plugins/
ls -al /usr/lib64/nagios/plugins/tmp/
Be sure to check out our
Knowledgebase for helpful articles and solutions!
brandon.pal
Posts: 129 Joined: Wed Feb 19, 2014 10:18 pm
Post
by brandon.pal » Tue Jan 26, 2016 5:29 pm
Advanced
Per Data
[root@nagios:/usr/local/nagios/var]$ ls -al /usr/lib64/
total 67844
dr-xr-xr-x. 54 root root 36864 Sep 29 22:10 .
drwxr-xr-x. 13 root root 4096 Apr 5 2013 ..
drwxr-xr-x 3 root root 4096 Feb 12 2014 alsa-lib
drwxr-xr-x 2 root root 4096 Feb 12 2014 apr-util-1
drwxr-xr-x 2 root root 4096 Feb 12 2014 atlas
drwxr-x---. 2 root root 4096 Jun 22 2012 audit
drwxr-xr-x 4 root root 4096 Feb 12 2014 bonobo
drwxr-xr-x. 2 root root 4096 Apr 5 2013 coreutils
lrwxrwxrwx. 1 root root 36 Apr 5 2013 cracklib_dict.hwm -> ../../usr/share/cracklib/pw_dict.hwm
lrwxrwxrwx. 1 root root 36 Apr 5 2013 cracklib_dict.pwd -> ../../usr/share/cracklib/pw_dict.pwd
lrwxrwxrwx. 1 root root 36 Apr 5 2013 cracklib_dict.pwi -> ../../usr/share/cracklib/pw_dict.pwi
-rw-r--r-- 1 root root 1648 Nov 21 2013 crt1.o
-rw-r--r-- 1 root root 1504 Nov 21 2013 crti.o
-rw-r--r-- 1 root root 760 Nov 21 2013 crtn.o
drwxr-xr-x 2 root root 4096 Feb 12 2014 elfutils
drwxr-xr-x 4 root root 4096 Feb 12 2014 evolution-openldap
dr-xr-xr-x. 2 root root 4096 Sep 23 2011 games
drwxr-xr-x 3 root root 4096 Feb 12 2014 GConf
drwxr-xr-x. 2 root root 12288 Feb 12 2014 gconv
-rw-r--r-- 1 root root 2392 Nov 21 2013 gcrt1.o
drwxr-xr-x. 3 root root 4096 Nov 22 2013 gio
drwxr-xr-x 4 root root 4096 Feb 12 2014 gnome-keyring
drwxr-xr-x 3 root root 4096 Feb 12 2014 gnome-vfs-2.0
drwxr-xr-x 2 root root 4096 Feb 12 2014 graphviz
drwxr-xr-x 2 root root 4096 Feb 12 2014 gstreamer-0.10
drwxr-xr-x 5 root root 4096 Feb 12 2014 gtk-2.0
drwxr-xr-x 3 root root 4096 Feb 12 2014 httpd
drwxr-xr-x. 3 root root 4096 Sep 10 2013 krb5
drwxr-xr-x 3 root root 4096 Feb 12 2014 lftp
lrwxrwxrwx 1 root root 23 Feb 12 2014 libanl.so -> ../../lib64/libanl.so.1
lrwxrwxrwx 1 root root 17 Feb 12 2014 libapr-1.so.0 -> libapr-1.so.0.3.9
-rwxr-xr-x 1 root root 181792 Jun 14 2012 libapr-1.so.0.3.9
lrwxrwxrwx 1 root root 21 Feb 12 2014 libaprutil-1.so.0 -> libaprutil-1.so.0.3.9
-rwxr-xr-x 1 root root 146080 Jun 25 2011 libaprutil-1.so.0.3.9
lrwxrwxrwx 1 root root 23 Feb 12 2014 libart_lgpl_2.so.2 -> libart_lgpl_2.so.2.3.20
-rwxr-xr-x 1 root root 102608 Aug 18 2010 libart_lgpl_2.so.2.3.20
-rwxr-xr-x 1 root root 28856 Jul 19 2011 libasm-0.152.so
lrwxrwxrwx 1 root root 15 Feb 12 2014 libasm.so.1 -> libasm-0.152.so
lrwxrwxrwx 1 root root 19 Feb 12 2014 libasyncns.so.0 -> libasyncns.so.0.3.1
-rwxr-xr-x 1 root root 19856 Aug 18 2010 libasyncns.so.0.3.1
lrwxrwxrwx 1 root root 22 Feb 12 2014 libatk-1.0.so.0 -> libatk-1.0.so.0.3009.1
-rwxr-xr-x 1 root root 133608 Nov 22 2013 libatk-1.0.so.0.3009.1
lrwxrwxrwx 1 root root 24 Feb 12 2014 libavahi-client.so.3 -> libavahi-client.so.3.2.5
-rwxr-xr-x 1 root root 66112 Feb 21 2013 libavahi-client.so.3.2.5
lrwxrwxrwx 1 root root 24 Feb 12 2014 libavahi-common.so.3 -> libavahi-common.so.3.5.1
-rwxr-xr-x 1 root root 48712 Feb 21 2013 libavahi-common.so.3.5.1
lrwxrwxrwx 1 root root 22 Feb 12 2014 libavahi-glib.so.1 -> libavahi-glib.so.1.0.1
-rwxr-xr-x 1 root root 11040 Feb 21 2013 libavahi-glib.so.1.0.1
-rwxr-xr-x. 1 root root 926864 Feb 21 2013 libbfd-2.20.51.0.2-5.36.el6.so
lrwxrwxrwx 1 root root 18 Feb 12 2014 libbind9.so.80 -> libbind9.so.80.0.4
-rwxr-xr-x 1 root root 49936 Jan 20 2014 libbind9.so.80.0.4
lrwxrwxrwx 1 root root 20 Feb 12 2014 libbonobo-2.so.0 -> libbonobo-2.so.0.0.0
-rwxr-xr-x 1 root root 481760 Jun 22 2012 libbonobo-2.so.0.0.0
lrwxrwxrwx 1 root root 29 Feb 12 2014 libbonobo-activation.so.4 -> libbonobo-activation.so.4.0.0
-rwxr-xr-x 1 root root 110408 Jun 22 2012 libbonobo-activation.so.4.0.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libbonoboui-2.so.0 -> libbonoboui-2.so.0.0.0
-rwxr-xr-x 1 root root 460888 Nov 11 2010 libbonoboui-2.so.0.0.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libboundparam.so.2 -> libboundparam.so.2.0.0
-rwxr-xr-x 1 root root 30424 Nov 29 2012 libboundparam.so.2.0.0
lrwxrwxrwx 1 root root 32 Feb 12 2014 libBrokenLocale.so -> ../../lib64/libBrokenLocale.so.1
lrwxrwxrwx 1 root root 15 Feb 12 2014 libbsd.a -> libbsd-compat.a
-rw-r--r-- 1 root root 1338 Nov 21 2013 libbsd-compat.a
lrwxrwxrwx 1 root root 21 Feb 12 2014 libcairo.so.2 -> libcairo.so.2.10800.8
-rwxr-xr-x 1 root root 494624 Nov 10 2010 libcairo.so.2.10800.8
drwxr-xr-x 2 root root 4096 Feb 12 2014 libcanberra-0.22
lrwxrwxrwx 1 root root 24 Feb 12 2014 libcanberra-gtk.so.0 -> libcanberra-gtk.so.0.1.5
-rwxr-xr-x 1 root root 17160 Dec 2 2011 libcanberra-gtk.so.0.1.5
lrwxrwxrwx 1 root root 20 Feb 12 2014 libcanberra.so.0 -> libcanberra.so.0.2.1
-rwxr-xr-x 1 root root 65640 Dec 2 2011 libcanberra.so.0.2.1
lrwxrwxrwx 1 root root 15 Feb 12 2014 libcdt.so.4 -> libcdt.so.4.0.0
-rwxr-xr-x 1 root root 20912 Sep 19 2012 libcdt.so.4.0.0
lrwxrwxrwx 1 root root 18 Feb 12 2014 libcgraph.so.4 -> libcgraph.so.4.0.0
-rwxr-xr-x 1 root root 87176 Sep 19 2012 libcgraph.so.4.0.0
lrwxrwxrwx 1 root root 24 Feb 12 2014 libcidn.so -> ../../lib64/libcidn.so.1
lrwxrwxrwx 1 root root 24 Feb 12 2014 libck-connector.so.0 -> libck-connector.so.0.0.0
-rwxr-xr-x 1 root root 11832 Nov 10 2010 libck-connector.so.0.0.0
lrwxrwxrwx 1 root root 17 Feb 12 2014 libcloog.so.0 -> libcloog.so.0.0.0
-rwxr-xr-x 1 root root 131424 Nov 10 2010 libcloog.so.0.0.0
-rw-r--r-- 1 root root 22854 Nov 21 2013 libc_nonshared.a
-rw-r--r-- 1 root root 17416 Nov 22 2013 libcom_err.a
lrwxrwxrwx 1 root root 22 Feb 12 2014 libcom_err.so -> /lib64/libcom_err.so.2
lrwxrwxrwx. 1 root root 17 Apr 5 2013 libcrack.so.2 -> libcrack.so.2.8.1
-rwxr-xr-x. 1 root root 38712 Jun 25 2011 libcrack.so.2.8.1
lrwxrwxrwx 1 root root 21 Feb 12 2014 libcroco-0.6.so.3 -> libcroco-0.6.so.3.0.1
-rwxr-xr-x 1 root root 249040 Aug 21 2010 libcroco-0.6.so.3.0.1
lrwxrwxrwx 1 root root 19 Feb 12 2014 libcrypto.so -> libcrypto.so.1.0.1e
lrwxrwxrwx 1 root root 19 Feb 12 2014 libcrypto.so.10 -> libcrypto.so.1.0.1e
-rwxr-xr-x 1 root root 1950976 Jan 8 2014 libcrypto.so.1.0.1e
-rw-r--r-- 1 root root 65 Jan 8 2014 .libcrypto.so.1.0.1e.hmac
lrwxrwxrwx 1 root root 25 Feb 12 2014 .libcrypto.so.10.hmac -> .libcrypto.so.1.0.1e.hmac
lrwxrwxrwx 1 root root 25 Feb 12 2014 libcrypt.so -> ../../lib64/libcrypt.so.1
-rw-r--r-- 1 root root 253 Nov 21 2013 libc.so
lrwxrwxrwx 1 root root 14 Feb 12 2014 libct.so.4 -> libct.so.4.0.0
-rwxr-xr-x 1 root root 361368 Feb 27 2012 libct.so.4.0.0
-rwxr-xr-x 1 root root 60360 Aug 17 2013 libcupscgi.so.1
-rwxr-xr-x 1 root root 35576 Aug 17 2013 libcupsdriver.so.1
-rwxr-xr-x 1 root root 102080 Aug 17 2013 libcupsimage.so.2
-rwxr-xr-x 1 root root 22392 Aug 17 2013 libcupsmime.so.1
-rwxr-xr-x 1 root root 120504 Aug 17 2013 libcupsppdc.so.1
-rwxr-xr-x 1 root root 323800 Aug 17 2013 libcups.so.2
lrwxrwxrwx. 1 root root 16 Apr 5 2013 libcurl.so.4 -> libcurl.so.4.1.1
-rwxr-xr-x. 1 root root 340968 Feb 22 2013 libcurl.so.4.1.1
lrwxrwxrwx 1 root root 24 Feb 12 2014 libdb-4.7.so -> ../../lib64/libdb-4.7.so
-rwxr-xr-x 1 root root 1645008 Sep 12 2013 libdb_cxx-4.7.so
lrwxrwxrwx 1 root root 16 Feb 12 2014 libdb_cxx.so -> libdb_cxx-4.7.so
lrwxrwxrwx 1 root root 24 Feb 12 2014 libdb.so -> ../../lib64/libdb-4.7.so
lrwxrwxrwx. 1 root root 23 Apr 5 2013 libdbus-glib-1.so.2 -> libdbus-glib-1.so.2.1.0
-rwxr-xr-x. 1 root root 142312 Feb 26 2013 libdbus-glib-1.so.2.1.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libdl.so -> ../../lib64/libdl.so.2
lrwxrwxrwx 1 root root 16 Feb 12 2014 libdns.so.81 -> libdns.so.81.4.1
-rwxr-xr-x 1 root root 1671904 Jan 20 2014 libdns.so.81.4.1
lrwxrwxrwx. 1 root root 21 Apr 5 2013 libdrm_intel.so.1 -> libdrm_intel.so.1.0.0
-rwxr-xr-x. 1 root root 131640 Feb 21 2013 libdrm_intel.so.1.0.0
lrwxrwxrwx. 1 root root 24 Apr 5 2013 libdrm_nouveau2.so.2 -> libdrm_nouveau2.so.2.0.0
-rwxr-xr-x. 1 root root 23304 Feb 21 2013 libdrm_nouveau2.so.2.0.0
lrwxrwxrwx. 1 root root 23 Apr 5 2013 libdrm_nouveau.so.1 -> libdrm_nouveau.so.1.0.0
-rwxr-xr-x. 1 root root 21208 Feb 21 2013 libdrm_nouveau.so.1.0.0
lrwxrwxrwx. 1 root root 22 Apr 5 2013 libdrm_radeon.so.1 -> libdrm_radeon.so.1.0.1
-rwxr-xr-x. 1 root root 39864 Feb 21 2013 libdrm_radeon.so.1.0.1
lrwxrwxrwx. 1 root root 15 Apr 5 2013 libdrm.so.2 -> libdrm.so.2.4.0
-rwxr-xr-x. 1 root root 43976 Feb 21 2013 libdrm.so.2.4.0
-rwxr-xr-x 1 root root 218552 Jul 19 2011 libdw-0.152.so
lrwxrwxrwx 1 root root 14 Feb 12 2014 libdw.so.1 -> libdw-0.152.so
lrwxrwxrwx 1 root root 21 Feb 12 2014 libecpg_compat.so -> libecpg_compat.so.3.1
lrwxrwxrwx 1 root root 21 Feb 12 2014 libecpg_compat.so.3 -> libecpg_compat.so.3.1
-rwxr-xr-x 1 root root 18096 Oct 29 2013 libecpg_compat.so.3.1
lrwxrwxrwx 1 root root 14 Feb 12 2014 libecpg.so -> libecpg.so.6.1
lrwxrwxrwx 1 root root 14 Feb 12 2014 libecpg.so.6 -> libecpg.so.6.1
-rwxr-xr-x 1 root root 65128 Oct 29 2013 libecpg.so.6.1
lrwxrwxrwx 1 root root 17 Feb 12 2014 libedit.so.0 -> libedit.so.0.0.27
-rwxr-xr-x 1 root root 178816 Aug 19 2010 libedit.so.0.0.27
lrwxrwxrwx 1 root root 21 Feb 12 2014 libeggdbus-1.so.0 -> libeggdbus-1.so.0.0.0
-rwxr-xr-x 1 root root 295592 Nov 11 2010 libeggdbus-1.so.0.0.0
-rwxr-xr-x. 1 root root 84352 Jul 19 2011 libelf-0.152.so
lrwxrwxrwx. 1 root root 15 Apr 5 2013 libelf.so.1 -> libelf-0.152.so
lrwxrwxrwx 1 root root 18 Feb 12 2014 libesoobS.so.2 -> libesoobS.so.2.0.0
-rwxr-xr-x 1 root root 7416 Nov 29 2012 libesoobS.so.2.0.0
lrwxrwxrwx 1 root root 21 Sep 29 22:10 libevent-1.4.so.2 -> libevent-1.4.so.2.1.3
-rwxr-xr-x 1 root root 106656 Jun 22 2012 libevent-1.4.so.2.1.3
lrwxrwxrwx 1 root root 26 Sep 29 22:10 libevent_core-1.4.so.2 -> libevent_core-1.4.so.2.1.3
-rwxr-xr-x 1 root root 40280 Jun 22 2012 libevent_core-1.4.so.2.1.3
lrwxrwxrwx 1 root root 27 Sep 29 22:10 libevent_extra-1.4.so.2 -> libevent_extra-1.4.so.2.1.3
-rwxr-xr-x 1 root root 84536 Jun 22 2012 libevent_extra-1.4.so.2.1.3
-rw-r--r-- 1 root root 311096 Jun 13 2012 libexpat.a
lrwxrwxrwx 1 root root 29 Feb 12 2014 libexpat.so -> ../../lib64/libexpat.so.1.5.2
lrwxrwxrwx 1 root root 18 Feb 12 2014 libexslt.so.0 -> libexslt.so.0.8.15
-rwxr-xr-x 1 root root 81688 Sep 13 2012 libexslt.so.0.8.15
drwxr-xr-x 2 root root 4096 Feb 12 2014 libfakeroot
lrwxrwxrwx. 1 root root 15 Apr 5 2013 libfam.so.0 -> libfam.so.0.0.0
-rwxr-xr-x. 1 root root 30096 Nov 11 2010 libfam.so.0.0.0
lrwxrwxrwx. 1 root root 15 Apr 5 2013 libffi.so.5 -> libffi.so.5.0.6
-rwxr-xr-x. 1 root root 31720 Nov 11 2010 libffi.so.5.0.6
lrwxrwxrwx 1 root root 18 Feb 12 2014 libFLAC++.so.6 -> libFLAC++.so.6.2.0
-rwxr-xr-x 1 root root 98320 Nov 11 2010 libFLAC++.so.6.2.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libFLAC.so.8 -> libFLAC.so.8.2.0
-rwxr-xr-x 1 root root 238688 Nov 11 2010 libFLAC.so.8.2.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libfontconfig.so -> libfontconfig.so.1.4.4
lrwxrwxrwx 1 root root 22 Feb 12 2014 libfontconfig.so.1 -> libfontconfig.so.1.4.4
-rwxr-xr-x 1 root root 220584 Nov 11 2010 libfontconfig.so.1.4.4
lrwxrwxrwx. 1 root root 14 Apr 5 2013 libform.so.5 -> libform.so.5.7
-rwxr-xr-x. 1 root root 63072 Aug 18 2010 libform.so.5.7
lrwxrwxrwx. 1 root root 15 Apr 5 2013 libformw.so.5 -> libformw.so.5.7
-rwxr-xr-x. 1 root root 67328 Aug 18 2010 libformw.so.5.7
lrwxrwxrwx. 1 root root 26 Apr 5 2013 libfreebl3.chk -> ../../lib64/libfreebl3.chk
lrwxrwxrwx. 1 root root 25 Apr 5 2013 libfreebl3.so -> ../../lib64/libfreebl3.so
lrwxrwxrwx 1 root root 21 Feb 12 2014 libfreetype.so -> libfreetype.so.6.3.22
lrwxrwxrwx 1 root root 21 Feb 12 2014 libfreetype.so.6 -> libfreetype.so.6.3.22
-rwxr-xr-x 1 root root 642600 Jan 31 2013 libfreetype.so.6.3.22
-rw-r--r-- 1 root root 1338 Nov 21 2013 libg.a
lrwxrwxrwx 1 root root 21 Feb 12 2014 libgailutil.so.18 -> libgailutil.so.18.0.1
-rwxr-xr-x 1 root root 29784 Nov 23 2013 libgailutil.so.18.0.1
lrwxrwxrwx. 1 root root 20 Apr 5 2013 libgamin-1.so.0 -> libgamin-1.so.0.1.10
-rwxr-xr-x. 1 root root 30096 Nov 11 2010 libgamin-1.so.0.1.10
lrwxrwxrwx 1 root root 19 Feb 12 2014 libgconf-2.so.4 -> libgconf-2.so.4.1.5
-rwxr-xr-x 1 root root 258976 Aug 23 2010 libgconf-2.so.4.1.5
lrwxrwxrwx 1 root root 15 Feb 12 2014 libgcr.so.0 -> libgcr.so.0.0.0
-rwxr-xr-x 1 root root 279128 Oct 4 2012 libgcr.so.0.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libgdbm.so -> libgdbm.so.2.0.0
lrwxrwxrwx. 1 root root 16 Apr 5 2013 libgdbm.so.2 -> libgdbm.so.2.0.0
-rwxr-xr-x. 1 root root 25920 Nov 11 2010 libgdbm.so.2.0.0
lrwxrwxrwx 1 root root 29 Feb 12 2014 libgdk_pixbuf-2.0.so.0 -> libgdk_pixbuf-2.0.so.0.2000.1
-rwxr-xr-x 1 root root 127656 Nov 23 2013 libgdk_pixbuf-2.0.so.0.2000.1
lrwxrwxrwx 1 root root 34 Feb 12 2014 libgdk_pixbuf_xlib-2.0.so.0 -> libgdk_pixbuf_xlib-2.0.so.0.2000.1
-rwxr-xr-x 1 root root 66976 Nov 23 2013 libgdk_pixbuf_xlib-2.0.so.0.2000.1
lrwxrwxrwx 1 root root 26 Feb 12 2014 libgdk-x11-2.0.so.0 -> libgdk-x11-2.0.so.0.2000.1
-rwxr-xr-x 1 root root 766520 Nov 23 2013 libgdk-x11-2.0.so.0.2000.1
lrwxrwxrwx 1 root root 14 Feb 12 2014 libgd.so -> libgd.so.2.0.0
lrwxrwxrwx 1 root root 14 Feb 12 2014 libgd.so.2 -> libgd.so.2.0.0
-rwxr-xr-x 1 root root 272552 Sep 17 2012 libgd.so.2.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libgfortran.so.3 -> libgfortran.so.3.0.0
-rwxr-xr-x 1 root root 988032 Nov 21 2013 libgfortran.so.3.0.0
drwxr-xr-x 3 root root 4096 Feb 12 2014 libglade
lrwxrwxrwx 1 root root 21 Feb 12 2014 libglade-2.0.so.0 -> libglade-2.0.so.0.0.7
-rwxr-xr-x 1 root root 103952 Aug 19 2010 libglade-2.0.so.0.0.7
lrwxrwxrwx. 1 root root 15 Apr 5 2013 libgmp.so.3 -> libgmp.so.3.5.0
-rwxr-xr-x. 1 root root 374408 Mar 7 2012 libgmp.so.3.5.0
lrwxrwxrwx. 1 root root 17 Apr 5 2013 libgmpxx.so.4 -> libgmpxx.so.4.1.0
-rwxr-xr-x. 1 root root 15424 Mar 7 2012 libgmpxx.so.4.1.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libgnome-2.so.0 -> libgnome-2.so.0.2800.0
-rwxr-xr-x 1 root root 92592 Nov 11 2010 libgnome-2.so.0.2800.0
lrwxrwxrwx 1 root root 28 Feb 12 2014 libgnomecanvas-2.so.0 -> libgnomecanvas-2.so.0.2600.0
-rwxr-xr-x 1 root root 213056 Nov 11 2010 libgnomecanvas-2.so.0.2600.0
lrwxrwxrwx 1 root root 25 Feb 12 2014 libgnome-keyring.so.0 -> libgnome-keyring.so.0.1.1
-rwxr-xr-x 1 root root 86256 Oct 4 2012 libgnome-keyring.so.0.1.1
lrwxrwxrwx 1 root root 24 Feb 12 2014 libgnomeui-2.so.0 -> libgnomeui-2.so.0.2400.1
-rwxr-xr-x 1 root root 645728 Nov 11 2010 libgnomeui-2.so.0.2400.1
lrwxrwxrwx 1 root root 25 Feb 12 2014 libgnomevfs-2.so.0 -> libgnomevfs-2.so.0.2400.2
-rwxr-xr-x 1 root root 436888 Nov 11 2010 libgnomevfs-2.so.0.2400.2
lrwxrwxrwx 1 root root 27 Feb 12 2014 libgnutls-extra.so.26 -> libgnutls-extra.so.26.14.12
-rwxr-xr-x 1 root root 31736 May 30 2013 libgnutls-extra.so.26.14.12
lrwxrwxrwx 1 root root 21 Feb 12 2014 libgnutls.so.26 -> libgnutls.so.26.14.12
-rwxr-xr-x 1 root root 668496 May 30 2013 libgnutls.so.26.14.12
lrwxrwxrwx 1 root root 23 Feb 12 2014 libgnutlsxx.so.26 -> libgnutlsxx.so.26.14.12
-rwxr-xr-x 1 root root 58240 May 30 2013 libgnutlsxx.so.26.14.12
lrwxrwxrwx 1 root root 16 Feb 12 2014 libgomp.so.1 -> libgomp.so.1.0.0
-rwxr-xr-x 1 root root 55080 Nov 21 2013 libgomp.so.1.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libgp11.so.0 -> libgp11.so.0.0.0
-rwxr-xr-x 1 root root 115192 Oct 4 2012 libgp11.so.0.0.0
lrwxrwxrwx. 1 root root 26 Apr 5 2013 libgpgme-pthread.so.11 -> libgpgme-pthread.so.11.6.6
-rwxr-xr-x. 1 root root 197832 Nov 11 2010 libgpgme-pthread.so.11.6.6
lrwxrwxrwx. 1 root root 22 Apr 5 2013 libgpgme-pth.so.11 -> libgpgme-pth.so.11.6.6
-rwxr-xr-x. 1 root root 197896 Nov 11 2010 libgpgme-pth.so.11.6.6
lrwxrwxrwx. 1 root root 18 Apr 5 2013 libgpgme.so.11 -> libgpgme.so.11.6.6
-rwxr-xr-x. 1 root root 197792 Nov 11 2010 libgpgme.so.11.6.6
lrwxrwxrwx 1 root root 15 Apr 8 2014 libgpm.so.2 -> libgpm.so.2.1.0
-rwxr-xr-x 1 root root 23720 Sep 23 2011 libgpm.so.2.1.0
lrwxrwxrwx 1 root root 17 Feb 12 2014 libgraph.so.4 -> libgraph.so.4.0.0
-rwxr-xr-x 1 root root 53776 Sep 19 2012 libgraph.so.4.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libgsf-1.so.114 -> libgsf-1.so.114.0.15
-rwxr-xr-x 1 root root 258024 Nov 11 2010 libgsf-1.so.114.0.15
lrwxrwxrwx 1 root root 33 Feb 12 2014 libgssapi_krb5.so -> ../../lib64/libgssapi_krb5.so.2.2
lrwxrwxrwx 1 root root 28 Feb 12 2014 libgssrpc.so -> ../../lib64/libgssrpc.so.4.1
lrwxrwxrwx 1 root root 25 Feb 12 2014 libgstbase-0.10.so.0 -> libgstbase-0.10.so.0.25.0
-rwxr-xr-x 1 root root 255512 Nov 11 2010 libgstbase-0.10.so.0.25.0
lrwxrwxrwx 1 root root 31 Feb 12 2014 libgstcontroller-0.10.so.0 -> libgstcontroller-0.10.so.0.25.0
-rwxr-xr-x 1 root root 173432 Nov 11 2010 libgstcontroller-0.10.so.0.25.0
lrwxrwxrwx 1 root root 33 Feb 12 2014 libgstdataprotocol-0.10.so.0 -> libgstdataprotocol-0.10.so.0.25.0
-rwxr-xr-x 1 root root 19336 Nov 11 2010 libgstdataprotocol-0.10.so.0.25.0
lrwxrwxrwx 1 root root 24 Feb 12 2014 libgstnet-0.10.so.0 -> libgstnet-0.10.so.0.25.0
-rwxr-xr-x 1 root root 24408 Nov 11 2010 libgstnet-0.10.so.0.25.0
lrwxrwxrwx 1 root root 27 Feb 12 2014 libgstreamer-0.10.so.0 -> libgstreamer-0.10.so.0.25.0
-rwxr-xr-x 1 root root 924216 Nov 11 2010 libgstreamer-0.10.so.0.25.0
lrwxrwxrwx 1 root root 26 Feb 12 2014 libgtk-x11-2.0.so.0 -> libgtk-x11-2.0.so.0.2000.1
-rwxr-xr-x 1 root root 4668816 Nov 23 2013 libgtk-x11-2.0.so.0.2000.1
lrwxrwxrwx 1 root root 18 Feb 12 2014 libgtrtst.so.2 -> libgtrtst.so.2.0.0
-rwxr-xr-x 1 root root 4920 Nov 29 2012 libgtrtst.so.2.0.0
lrwxrwxrwx 1 root root 15 Feb 12 2014 libgvc.so.5 -> libgvc.so.5.0.0
-rwxr-xr-x 1 root root 512696 Sep 19 2012 libgvc.so.5.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libgvpr.so.1 -> libgvpr.so.1.0.0
-rwxr-xr-x 1 root root 485592 Sep 19 2012 libgvpr.so.1.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libgxim.so.2 -> libgxim.so.2.1.1
-rwxr-xr-x 1 root root 308136 Nov 11 2010 libgxim.so.2.1.1
lrwxrwxrwx 1 root root 15 Feb 12 2014 libhal.so.1 -> libhal.so.1.0.0
-rwxr-xr-x 1 root root 66512 Jul 19 2011 libhal.so.1.0.0
lrwxrwxrwx 1 root root 23 Feb 12 2014 libhal-storage.so.1 -> libhal-storage.so.1.0.0
-rwxr-xr-x 1 root root 41808 Jul 19 2011 libhal-storage.so.1.0.0
lrwxrwxrwx. 1 root root 17 Apr 5 2013 libhistory.so.6 -> libhistory.so.6.0
-rwxr-xr-x. 1 root root 33616 Jun 22 2012 libhistory.so.6.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libibus.so.2 -> libibus.so.2.0.0
-rwxr-xr-x 1 root root 271936 Dec 7 2011 libibus.so.2.0.0
lrwxrwxrwx 1 root root 15 Feb 12 2014 libICE.so.6 -> libICE.so.6.3.0
-rwxr-xr-x 1 root root 99224 Aug 16 2010 libICE.so.6.3.0
lrwxrwxrwx 1 root root 17 Feb 12 2014 libIDL-2.so.0 -> libIDL-2.so.0.0.0
-rwxr-xr-x 1 root root 178608 Aug 19 2010 libIDL-2.so.0.0.0
-rw-r--r-- 1 root root 2848 Nov 21 2013 libieee.a
lrwxrwxrwx 1 root root 22 Feb 12 2014 libimsettings.so.4 -> libimsettings.so.4.2.0
-rwxr-xr-x 1 root root 90968 Jun 22 2012 libimsettings.so.4.2.0
lrwxrwxrwx 1 root root 26 Feb 12 2014 libimsettings-xim.so.1 -> libimsettings-xim.so.1.0.3
-rwxr-xr-x 1 root root 123560 Jun 22 2012 libimsettings-xim.so.1.0.3
lrwxrwxrwx 1 root root 18 Feb 12 2014 libisccc.so.80 -> libisccc.so.80.0.0
-rwxr-xr-x 1 root root 32056 Jan 20 2014 libisccc.so.80.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libisccfg.so.82 -> libisccfg.so.82.0.1
-rwxr-xr-x 1 root root 137536 Jan 20 2014 libisccfg.so.82.0.1
lrwxrwxrwx 1 root root 16 Feb 12 2014 libisc.so.83 -> libisc.so.83.0.3
-rwxr-xr-x 1 root root 355952 Jan 20 2014 libisc.so.83.0.3
lrwxrwxrwx 1 root root 18 Feb 12 2014 libjasper.so.1 -> libjasper.so.1.0.0
-rwxr-xr-x 1 root root 337136 Dec 17 2011 libjasper.so.1.0.0
lrwxrwxrwx 1 root root 17 Feb 12 2014 libjpeg.so -> libjpeg.so.62.0.0
lrwxrwxrwx 1 root root 17 Feb 12 2014 libjpeg.so.62 -> libjpeg.so.62.0.0
-rwxr-xr-x 1 root root 262896 Dec 9 2013 libjpeg.so.62.0.0
lrwxrwxrwx 1 root root 30 Feb 12 2014 libk5crypto.so -> ../../lib64/libk5crypto.so.3.1
lrwxrwxrwx 1 root root 23 Feb 12 2014 libkadm5clnt_mit.so -> libkadm5clnt_mit.so.8.0
lrwxrwxrwx 1 root root 23 Feb 12 2014 libkadm5clnt_mit.so.8 -> libkadm5clnt_mit.so.8.0
-rwxr-xr-x 1 root root 89216 Sep 10 2013 libkadm5clnt_mit.so.8.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libkadm5clnt.so -> libkadm5clnt_mit.so
lrwxrwxrwx 1 root root 22 Feb 12 2014 libkadm5srv_mit.so -> libkadm5srv_mit.so.8.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libkadm5srv_mit.so.8 -> libkadm5srv_mit.so.8.0
-rwxr-xr-x 1 root root 122640 Sep 10 2013 libkadm5srv_mit.so.8.0
lrwxrwxrwx 1 root root 18 Feb 12 2014 libkadm5srv.so -> libkadm5srv_mit.so
lrwxrwxrwx 1 root root 14 Feb 12 2014 libkdb5.so -> libkdb5.so.6.0
lrwxrwxrwx 1 root root 14 Feb 12 2014 libkdb5.so.6 -> libkdb5.so.6.0
-rwxr-xr-x 1 root root 77080 Sep 10 2013 libkdb5.so.6.0
lrwxrwxrwx 1 root root 23 Sep 29 22:10 libkeyutils.so -> /lib64/libkeyutils.so.1
lrwxrwxrwx 1 root root 26 Feb 12 2014 libkrb5.so -> ../../lib64/libkrb5.so.3.3
lrwxrwxrwx 1 root root 33 Feb 12 2014 libkrb5support.so -> ../../lib64/libkrb5support.so.0.1
lrwxrwxrwx 1 root root 10 Feb 12 2014 liblber-2.4.so.2 -> liblber.so
lrwxrwxrwx 1 root root 27 Feb 12 2014 liblber.so -> /lib64/liblber-2.4.so.2.5.6
lrwxrwxrwx 1 root root 10 Feb 12 2014 libldap-2.4.so.2 -> libldap.so
lrwxrwxrwx 1 root root 12 Feb 12 2014 libldap_r-2.4.so.2 -> libldap_r.so
lrwxrwxrwx 1 root root 29 Feb 12 2014 libldap_r.so -> /lib64/libldap_r-2.4.so.2.5.6
lrwxrwxrwx 1 root root 27 Feb 12 2014 libldap.so -> /lib64/libldap-2.4.so.2.5.6
lrwxrwxrwx 1 root root 10 Feb 12 2014 libldif-2.4.so.2 -> libldif.so
lrwxrwxrwx 1 root root 27 Feb 12 2014 libldif.so -> /lib64/libldif-2.4.so.2.5.6
lrwxrwxrwx 1 root root 21 Feb 12 2014 liblftp-jobs.so.0 -> liblftp-jobs.so.0.0.0
-rwxr-xr-x 1 root root 283304 Feb 11 2014 liblftp-jobs.so.0.0.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 liblftp-tasks.so.0 -> liblftp-tasks.so.0.0.0
-rwxr-xr-x 1 root root 570160 Feb 11 2014 liblftp-tasks.so.0.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libltdl.so.7 -> libltdl.so.7.2.1
-rwxr-xr-x 1 root root 36880 Aug 24 2010 libltdl.so.7.2.1
-rwxr-xr-x. 1 root root 183920 Aug 19 2010 liblua-5.1.so
lrwxrwxrwx 1 root root 18 Feb 12 2014 liblwres.so.80 -> liblwres.so.80.0.2
-rwxr-xr-x 1 root root 73336 Jan 20 2014 liblwres.so.80.0.2
lrwxrwxrwx. 1 root root 16 Apr 5 2013 liblzma.so.0 -> liblzma.so.0.0.0
-rwxr-xr-x. 1 root root 134920 Aug 22 2010 liblzma.so.0.0.0
lrwxrwxrwx. 1 root root 17 Apr 5 2013 libmagic.so.1 -> libmagic.so.1.0.0
-rwxr-xr-x. 1 root root 115768 Oct 4 2012 libmagic.so.1.0.0
-rw-r--r-- 1 root root 11776 Nov 21 2013 libmcheck.a
lrwxrwxrwx 1 root root 16 Feb 12 2014 libmcpp.so.0 -> libmcpp.so.0.3.0
-rwxr-xr-x 1 root root 138264 Aug 18 2010 libmcpp.so.0.3.0
lrwxrwxrwx 1 root root 18 Feb 12 2014 libmcrypt.so -> libmcrypt.so.4.4.8
lrwxrwxrwx 1 root root 18 Feb 12 2014 libmcrypt.so.4 -> libmcrypt.so.4.4.8
-rwxr-xr-x 1 root root 185616 Jul 9 2010 libmcrypt.so.4.4.8
-rwxr-xr-x 1 root root 23336 Nov 21 2013 libmemusage.so
lrwxrwxrwx. 1 root root 14 Apr 5 2013 libmenu.so.5 -> libmenu.so.5.7
-rwxr-xr-x. 1 root root 29656 Aug 18 2010 libmenu.so.5.7
lrwxrwxrwx. 1 root root 15 Apr 5 2013 libmenuw.so.5 -> libmenuw.so.5.7
-rwxr-xr-x. 1 root root 30456 Aug 18 2010 libmenuw.so.5.7
lrwxrwxrwx 1 root root 18 Feb 12 2014 libmimerS.so.2 -> libmimerS.so.2.0.0
-rwxr-xr-x 1 root root 5976 Nov 29 2012 libmimerS.so.2.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libmpfr.so.1 -> libmpfr.so.1.2.0
-rwxr-xr-x 1 root root 318648 Nov 11 2010 libmpfr.so.1.2.0
lrwxrwxrwx. 1 root root 15 Apr 5 2013 libmp.so.3 -> libmp.so.3.1.14
-rwxr-xr-x. 1 root root 203528 Mar 7 2012 libmp.so.3.1.14
lrwxrwxrwx 1 root root 21 Feb 12 2014 libm.so -> ../../lib64/libm.so.6
lrwxrwxrwx 1 root root 25 Feb 12 2014 libnetsnmpagent.so.20 -> libnetsnmpagent.so.20.0.0
-rwxr-xr-x 1 root root 302448 Nov 22 2013 libnetsnmpagent.so.20.0.0
lrwxrwxrwx 1 root root 27 Feb 12 2014 libnetsnmphelpers.so.20 -> libnetsnmphelpers.so.20.0.0
-rwxr-xr-x 1 root root 153544 Nov 22 2013 libnetsnmphelpers.so.20.0.0
lrwxrwxrwx 1 root root 24 Feb 12 2014 libnetsnmpmibs.so.20 -> libnetsnmpmibs.so.20.0.0
-rwxr-xr-x 1 root root 1680160 Nov 22 2013 libnetsnmpmibs.so.20.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libnetsnmp.so.20 -> libnetsnmp.so.20.0.0
-rwxr-xr-x 1 root root 672320 Nov 22 2013 libnetsnmp.so.20.0.0
lrwxrwxrwx 1 root root 25 Feb 12 2014 libnetsnmptrapd.so.20 -> libnetsnmptrapd.so.20.0.0
-rwxr-xr-x 1 root root 42904 Nov 22 2013 libnetsnmptrapd.so.20.0.0
lrwxrwxrwx. 1 root root 18 Apr 5 2013 libnewt.so.0.52 -> libnewt.so.0.52.11
-rwxr-xr-x. 1 root root 83752 Sep 23 2011 libnewt.so.0.52.11
drwxr-xr-x 2 root root 4096 Sep 29 22:10 libnfsidmap
lrwxrwxrwx 1 root root 20 Sep 29 22:10 libnfsidmap.so.0 -> libnfsidmap.so.0.3.0
-rwxr-xr-x 1 root root 31672 Jul 24 2015 libnfsidmap.so.0.3.0
lrwxrwxrwx 1 root root 14 Feb 12 2014 libnn.so.2 -> libnn.so.2.0.0
-rwxr-xr-x 1 root root 87144 Nov 29 2012 libnn.so.2.0.0
lrwxrwxrwx 1 root root 18 Feb 12 2014 libnotify.so.1 -> libnotify.so.1.2.3
-rwxr-xr-x 1 root root 36552 Nov 11 2010 libnotify.so.1.2.3
lrwxrwxrwx 1 root root 23 Feb 12 2014 libnsl.so -> ../../lib64/libnsl.so.1
-rwxr-xr-x. 1 root root 1284048 Feb 22 2013 libnss3.so
-rwxr-xr-x. 1 root root 598232 Feb 22 2013 libnssckbi.so
lrwxrwxrwx 1 root root 27 Sep 16 2014 libnss_compat_ossl.so.0 -> libnss_compat_ossl.so.0.0.0
-rwxr-xr-x 1 root root 81832 Jul 5 2011 libnss_compat_ossl.so.0.0.0
lrwxrwxrwx 1 root root 30 Feb 12 2014 libnss_compat.so -> ../../lib64/libnss_compat.so.2
-rw-r--r--. 1 root root 478 Dec 7 2011 libnssdbm3.chk
-rwxr-xr-x. 1 root root 162776 Dec 7 2011 libnssdbm3.so
lrwxrwxrwx 1 root root 27 Feb 12 2014 libnss_dns.so -> ../../lib64/libnss_dns.so.2
lrwxrwxrwx 1 root root 29 Feb 12 2014 libnss_files.so -> ../../lib64/libnss_files.so.2
lrwxrwxrwx 1 root root 30 Feb 12 2014 libnss_hesiod.so -> ../../lib64/libnss_hesiod.so.2
lrwxrwxrwx 1 root root 31 Feb 12 2014 libnss_nisplus.so -> ../../lib64/libnss_nisplus.so.2
lrwxrwxrwx 1 root root 27 Feb 12 2014 libnss_nis.so -> ../../lib64/libnss_nis.so.2
-rwxr-xr-x. 1 root root 150712 Feb 22 2013 libnsspem.so
-rwxr-xr-x. 1 root root 10352 Feb 22 2013 libnsssysinit.so
-rwxr-xr-x. 1 root root 175288 Feb 22 2013 libnssutil3.so
lrwxrwxrwx 1 root root 18 Feb 12 2014 libodbccr.so.2 -> libodbccr.so.2.0.0
-rwxr-xr-x 1 root root 40416 Nov 29 2012 libodbccr.so.2.0.0
lrwxrwxrwx 1 root root 24 Feb 12 2014 libodbcdrvcfg1S.so.2 -> libodbcdrvcfg1S.so.2.0.0
-rwxr-xr-x 1 root root 4656 Nov 29 2012 libodbcdrvcfg1S.so.2.0.0
lrwxrwxrwx 1 root root 24 Feb 12 2014 libodbcdrvcfg2S.so.2 -> libodbcdrvcfg2S.so.2.0.0
-rwxr-xr-x 1 root root 4296 Nov 29 2012 libodbcdrvcfg2S.so.2.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libodbcinst.so -> libodbcinst.so.2.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libodbcinst.so.2 -> libodbcinst.so.2.0.0
-rwxr-xr-x 1 root root 68928 Nov 29 2012 libodbcinst.so.2.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libodbcminiS.so.2 -> libodbcminiS.so.2.0.0
-rwxr-xr-x 1 root root 4832 Nov 29 2012 libodbcminiS.so.2.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libodbcmyS.so -> libodbcmyS.so.2.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libodbcmyS.so.2 -> libodbcmyS.so.2.0.0
-rwxr-xr-x 1 root root 7128 Nov 29 2012 libodbcmyS.so.2.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libodbcnnS.so.2 -> libodbcnnS.so.2.0.0
-rwxr-xr-x 1 root root 4432 Nov 29 2012 libodbcnnS.so.2.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libodbcpsqlS.so -> libodbcpsqlS.so.2.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libodbcpsqlS.so.2 -> libodbcpsqlS.so.2.0.0
-rwxr-xr-x 1 root root 6768 Nov 29 2012 libodbcpsqlS.so.2.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libodbc.so -> libodbc.so.2.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libodbc.so.2 -> libodbc.so.2.0.0
-rwxr-xr-x 1 root root 417720 Nov 29 2012 libodbc.so.2.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libodbctxtS.so.2 -> libodbctxtS.so.2.0.0
-rwxr-xr-x 1 root root 6696 Nov 29 2012 libodbctxtS.so.2.0.0
lrwxrwxrwx 1 root root 15 Feb 12 2014 libogg.so.0 -> libogg.so.0.6.0
-rwxr-xr-x 1 root root 23208 Aug 18 2010 libogg.so.0.6.0
-rwxr-xr-x. 1 root root 987584 Feb 21 2013 libopcodes-2.20.51.0.2-5.36.el6.so
lrwxrwxrwx 1 root root 20 Feb 12 2014 liboplodbcS.so.2 -> liboplodbcS.so.2.0.0
-rwxr-xr-x 1 root root 7896 Nov 29 2012 liboplodbcS.so.2.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 liboraodbcS.so.2 -> liboraodbcS.so.2.0.0
-rwxr-xr-x 1 root root 5184 Nov 29 2012 liboraodbcS.so.2.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libORBit-2.so.0 -> libORBit-2.so.0.1.0
-rwxr-xr-x 1 root root 457664 Nov 13 2012 libORBit-2.so.0.1.0
lrwxrwxrwx 1 root root 28 Feb 12 2014 libORBitCosNaming-2.so.0 -> libORBitCosNaming-2.so.0.1.0
-rwxr-xr-x 1 root root 26472 Nov 13 2012 libORBitCosNaming-2.so.0.1.0
lrwxrwxrwx 1 root root 27 Feb 12 2014 libORBit-imodule-2.so.0 -> libORBit-imodule-2.so.0.0.0
-rwxr-xr-x 1 root root 34448 Nov 13 2012 libORBit-imodule-2.so.0.0.0
lrwxrwxrwx. 1 root root 15 Apr 5 2013 libpanel.so.5 -> libpanel.so.5.7
-rwxr-xr-x. 1 root root 11680 Aug 18 2010 libpanel.so.5.7
lrwxrwxrwx. 1 root root 16 Apr 5 2013 libpanelw.so.5 -> libpanelw.so.5.7
-rwxr-xr-x. 1 root root 11680 Aug 18 2010 libpanelw.so.5.7
lrwxrwxrwx 1 root root 24 Feb 12 2014 libpango-1.0.so.0 -> libpango-1.0.so.0.2800.1
-rwxr-xr-x 1 root root 307576 Nov 28 2012 libpango-1.0.so.0.2800.1
lrwxrwxrwx 1 root root 29 Feb 12 2014 libpangocairo-1.0.so.0 -> libpangocairo-1.0.so.0.2800.1
-rwxr-xr-x 1 root root 49088 Nov 28 2012 libpangocairo-1.0.so.0.2800.1
lrwxrwxrwx 1 root root 27 Feb 12 2014 libpangoft2-1.0.so.0 -> libpangoft2-1.0.so.0.2800.1
-rwxr-xr-x 1 root root 173432 Nov 28 2012 libpangoft2-1.0.so.0.2800.1
lrwxrwxrwx 1 root root 25 Feb 12 2014 libpangox-1.0.so.0 -> libpangox-1.0.so.0.2800.1
-rwxr-xr-x 1 root root 50648 Nov 28 2012 libpangox-1.0.so.0.2800.1
lrwxrwxrwx 1 root root 27 Feb 12 2014 libpangoxft-1.0.so.0 -> libpangoxft-1.0.so.0.2800.1
-rwxr-xr-x 1 root root 32152 Nov 28 2012 libpangoxft-1.0.so.0.2800.1
lrwxrwxrwx 1 root root 20 Feb 12 2014 libpathplan.so.4 -> libpathplan.so.4.0.0
-rwxr-xr-x 1 root root 31328 Sep 19 2012 libpathplan.so.4.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libpcap.so.1 -> libpcap.so.1.4.0
-rwxr-xr-x 1 root root 258504 Nov 22 2013 libpcap.so.1.4.0
lrwxrwxrwx. 1 root root 22 Apr 5 2013 libpciaccess.so.0 -> libpciaccess.so.0.11.1
-rwxr-xr-x. 1 root root 34440 Feb 21 2013 libpciaccess.so.0.11.1
-rwxr-xr-x 1 root root 8816 Nov 21 2013 libpcprofile.so
lrwxrwxrwx. 1 root root 19 Apr 5 2013 libpcrecpp.so.0 -> libpcrecpp.so.0.0.0
-rwxr-xr-x. 1 root root 33088 Sep 7 2012 libpcrecpp.so.0.0.0
lrwxrwxrwx. 1 root root 21 Apr 5 2013 libpcreposix.so.0 -> libpcreposix.so.0.0.0
-rwxr-xr-x. 1 root root 7312 Sep 7 2012 libpcreposix.so.0.0.0
lrwxrwxrwx 1 root root 17 Feb 12 2014 libpgtypes.so -> libpgtypes.so.3.1
lrwxrwxrwx 1 root root 17 Feb 12 2014 libpgtypes.so.3 -> libpgtypes.so.3.1
-rwxr-xr-x 1 root root 65008 Oct 29 2013 libpgtypes.so.3.1
lrwxrwxrwx 1 root root 21 Feb 12 2014 libpixman-1.so.0 -> libpixman-1.so.0.26.2
-rwxr-xr-x 1 root root 557672 Dec 20 2013 libpixman-1.so.0.26.2
lrwxrwxrwx. 1 root root 27 Apr 5 2013 libply-boot-client.so.2 -> libply-boot-client.so.2.0.0
-rwxr-xr-x. 1 root root 17616 Feb 22 2013 libply-boot-client.so.2.0.0
lrwxrwxrwx 1 root root 18 Feb 12 2014 libpng12.so -> libpng12.so.0.49.0
lrwxrwxrwx 1 root root 18 Feb 12 2014 libpng12.so.0 -> libpng12.so.0.49.0
-rwxr-xr-x 1 root root 155456 Apr 25 2012 libpng12.so.0.49.0
lrwxrwxrwx 1 root root 11 Feb 12 2014 libpng.so -> libpng12.so
lrwxrwxrwx 1 root root 16 Feb 12 2014 libpng.so.3 -> libpng.so.3.49.0
-rwxr-xr-x 1 root root 168616 Apr 25 2012 libpng.so.3.49.0
lrwxrwxrwx 1 root root 26 Feb 12 2014 libpolkit-agent-1.so.0 -> libpolkit-agent-1.so.0.0.0
-rwxr-xr-x 1 root root 90712 Sep 19 2013 libpolkit-agent-1.so.0.0.0
lrwxrwxrwx 1 root root 28 Feb 12 2014 libpolkit-backend-1.so.0 -> libpolkit-backend-1.so.0.0.0
-rwxr-xr-x 1 root root 267472 Sep 19 2013 libpolkit-backend-1.so.0.0.0
lrwxrwxrwx 1 root root 28 Feb 12 2014 libpolkit-gobject-1.so.0 -> libpolkit-gobject-1.so.0.0.0
-rwxr-xr-x 1 root root 143184 Sep 19 2013 libpolkit-gobject-1.so.0.0.0
lrwxrwxrwx 1 root root 17 Feb 12 2014 libppl_c.so.2 -> libppl_c.so.2.1.0
-rwxr-xr-x 1 root root 3563944 Nov 11 2010 libppl_c.so.2.1.0
lrwxrwxrwx 1 root root 15 Feb 12 2014 libppl.so.7 -> libppl.so.7.1.0
-rwxr-xr-x 1 root root 748000 Nov 11 2010 libppl.so.7.1.0
lrwxrwxrwx 1 root root 12 Feb 12 2014 libpq.so -> libpq.so.5.2
lrwxrwxrwx 1 root root 12 Feb 12 2014 libpq.so.5 -> libpq.so.5.2
-rwxr-xr-x 1 root root 162600 Oct 29 2013 libpq.so.5.2
-rw-r--r-- 1 root root 1780 Nov 21 2013 libpthread_nonshared.a
-rw-r--r-- 1 root root 222 Nov 21 2013 libpthread.so
lrwxrwxrwx. 1 root root 17 Apr 5 2013 libpth.so.20 -> libpth.so.20.0.27
-rwxr-xr-x. 1 root root 77800 Nov 11 2010 libpth.so.20.0.27
-rwxr-xr-x 1 root root 323352 Jul 12 2012 libpulsecommon-0.9.21.so
lrwxrwxrwx 1 root root 24 Feb 12 2014 libpulse-simple.so.0 -> libpulse-simple.so.0.0.3
-rwxr-xr-x 1 root root 15416 Jul 12 2012 libpulse-simple.so.0.0.3
lrwxrwxrwx 1 root root 18 Feb 12 2014 libpulse.so.0 -> libpulse.so.0.12.2
-rwxr-xr-x 1 root root 271256 Jul 12 2012 libpulse.so.0.12.2
lrwxrwxrwx 1 root root 29 Feb 12 2014 libpyglib-2.0-python.so -> libpyglib-2.0-python.so.0.0.0
lrwxrwxrwx 1 root root 29 Feb 12 2014 libpyglib-2.0-python.so.0 -> libpyglib-2.0-python.so.0.0.0
-rwxr-xr-x 1 root root 15216 Nov 11 2010 libpyglib-2.0-python.so.0.0.0
-r-xr-xr-x 1 root root 1669872 Jan 22 2014 libpython2.6.so.1.0
lrwxrwxrwx 1 root root 26 Feb 12 2014 libresolv.so -> ../../lib64/libresolv.so.2
lrwxrwxrwx 1 root root 21 Sep 29 22:10 librpcsecgss.so.3 -> librpcsecgss.so.3.0.0
-rwxr-xr-x 1 root root 63008 Jul 24 2015 librpcsecgss.so.3.0.0
-rw-r--r-- 1 root root 54974 Nov 21 2013 librpcsvc.a
lrwxrwxrwx 1 root root 20 Feb 12 2014 librpmbuild.so.1 -> librpmbuild.so.1.0.0
-rwxr-xr-x 1 root root 155312 Nov 22 2013 librpmbuild.so.1.0.0
lrwxrwxrwx 1 root root 17 Feb 12 2014 librpmio.so.1 -> librpmio.so.1.0.0
-rwxr-xr-x 1 root root 183968 Nov 22 2013 librpmio.so.1.0.0
lrwxrwxrwx 1 root root 15 Feb 12 2014 librpm.so.1 -> librpm.so.1.0.0
-rwxr-xr-x 1 root root 433640 Nov 22 2013 librpm.so.1.0.0
lrwxrwxrwx 1 root root 15 Feb 12 2014 librrd.so.4 -> librrd.so.4.0.7
-rwxr-xr-x 1 root root 221800 Aug 21 2010 librrd.so.4.0.7
lrwxrwxrwx 1 root root 18 Feb 12 2014 librrd_th.so.4 -> librrd_th.so.4.0.7
-rwxr-xr-x 1 root root 217552 Aug 21 2010 librrd_th.so.4.0.7
lrwxrwxrwx 1 root root 19 Feb 12 2014 librsvg-2.so.2 -> librsvg-2.so.2.26.0
-rwxr-xr-x 1 root root 233672 Feb 4 2014 librsvg-2.so.2.26.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 librt.so -> ../../lib64/librt.so.1
lrwxrwxrwx 1 root root 18 Feb 12 2014 libsapdbS.so.2 -> libsapdbS.so.2.0.0
-rwxr-xr-x 1 root root 5304 Nov 29 2012 libsapdbS.so.2.0.0
lrwxrwxrwx 1 root root 18 Feb 12 2014 libsasl2.so -> libsasl2.so.2.0.23
lrwxrwxrwx. 1 root root 18 Apr 5 2013 libsasl2.so.2 -> libsasl2.so.2.0.23
-rwxr-xr-x. 1 root root 106160 Nov 27 2012 libsasl2.so.2.0.23
lrwxrwxrwx 1 root root 27 Feb 12 2014 libselinux.so -> ../../lib64/libselinux.so.1
lrwxrwxrwx 1 root root 19 Feb 12 2014 libsensors.so.4 -> libsensors.so.4.2.0
-rwxr-xr-x 1 root root 66192 Sep 25 2012 libsensors.so.4.2.0
lrwxrwxrwx 1 root root 25 Feb 12 2014 libsepol.so -> ../../lib64/libsepol.so.1
lrwxrwxrwx. 1 root root 17 Apr 5 2013 libslang.so.2 -> libslang.so.2.2.1
-rwxr-xr-x. 1 root root 1090368 Aug 16 2010 libslang.so.2.2.1
-rwxr-xr-x. 1 root root 181168 Feb 22 2013 libsmime3.so
lrwxrwxrwx 1 root root 14 Feb 12 2014 libSM.so.6 -> libSM.so.6.0.1
-rwxr-xr-x 1 root root 31576 Feb 21 2013 libSM.so.6.0.1
lrwxrwxrwx 1 root root 20 Feb 12 2014 libsndfile.so.1 -> libsndfile.so.1.0.20
-rwxr-xr-x 1 root root 392320 Sep 23 2011 libsndfile.so.1.0.20
lrwxrwxrwx 1 root root 17 Feb 12 2014 libsnmp.so.20 -> libsnmp.so.20.0.0
-rwxr-xr-x 1 root root 672312 Nov 22 2013 libsnmp.so.20.0.0
-rw-r--r--. 1 root root 478 Dec 7 2011 libsoftokn3.chk
-rwxr-xr-x. 1 root root 254008 Dec 7 2011 libsoftokn3.so
lrwxrwxrwx. 1 root root 19 Apr 5 2013 libsqlite3.so.0 -> libsqlite3.so.0.8.6
-rwxr-xr-x. 1 root root 583552 Aug 17 2010 libsqlite3.so.0.8.6
lrwxrwxrwx. 1 root root 16 Apr 5 2013 libssh2.so.1 -> libssh2.so.1.0.1
-rwxr-xr-x. 1 root root 161664 Feb 21 2013 libssh2.so.1.0.1
-rwxr-xr-x. 1 root root 221568 Feb 22 2013 libssl3.so
lrwxrwxrwx 1 root root 16 Feb 12 2014 libssl.so -> libssl.so.1.0.1e
lrwxrwxrwx 1 root root 16 Feb 12 2014 libssl.so.10 -> libssl.so.1.0.1e
-rwxr-xr-x 1 root root 437016 Jan 8 2014 libssl.so.1.0.1e
-rw-r--r-- 1 root root 65 Jan 8 2014 .libssl.so.1.0.1e.hmac
lrwxrwxrwx 1 root root 22 Feb 12 2014 .libssl.so.10.hmac -> .libssl.so.1.0.1e.hmac
lrwxrwxrwx 1 root root 34 Feb 12 2014 libstartup-notification-1.so.0 -> libstartup-notification-1.so.0.0.0
-rwxr-xr-x 1 root root 36928 Nov 11 2010 libstartup-notification-1.so.0.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libstdc++.so.6 -> libstdc++.so.6.0.13
-rwxr-xr-x 1 root root 987096 Nov 21 2013 libstdc++.so.6.0.13
lrwxrwxrwx 1 root root 17 Feb 12 2014 libsybdb.so.5 -> libsybdb.so.5.0.0
-rwxr-xr-x 1 root root 429976 Feb 27 2012 libsybdb.so.5.0.0
lrwxrwxrwx 1 root root 17 Feb 12 2014 libtasn1.so.3 -> libtasn1.so.3.1.6
-rwxr-xr-x 1 root root 66320 Mar 27 2012 libtasn1.so.3.1.6
-r-xr-xr-x 1 root root 1216256 Nov 11 2010 libtcl8.5.so
lrwxrwxrwx 1 root root 16 Feb 12 2014 libtdb.so.1 -> libtdb.so.1.2.10
-rwxr-xr-x 1 root root 69432 Feb 21 2013 libtdb.so.1.2.10
lrwxrwxrwx 1 root root 19 Feb 12 2014 libtdsodbc.so.0 -> libtdsodbc.so.0.0.0
-rwxr-xr-x 1 root root 413600 Feb 27 2012 libtdsodbc.so.0.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libtdsS.so.2 -> libtdsS.so.2.0.0
-rwxr-xr-x 1 root root 5072 Nov 29 2012 libtdsS.so.2.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libtemplate.so.2 -> libtemplate.so.2.0.0
-rwxr-xr-x 1 root root 110768 Nov 29 2012 libtemplate.so.2.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libthai.so.0 -> libthai.so.0.1.4
-rwxr-xr-x 1 root root 50168 Nov 11 2010 libthai.so.0.1.4
lrwxrwxrwx 1 root root 29 Feb 12 2014 libthread_db.so -> ../../lib64/libthread_db.so.1
lrwxrwxrwx. 1 root root 13 Apr 5 2013 libtic.so.5 -> libtic.so.5.7
-rwxr-xr-x. 1 root root 77416 Aug 18 2010 libtic.so.5.7
lrwxrwxrwx 1 root root 16 Feb 12 2014 libtiff.so.3 -> libtiff.so.3.9.4
-rwxr-xr-x 1 root root 408752 Dec 18 2012 libtiff.so.3.9.4
lrwxrwxrwx 1 root root 18 Feb 12 2014 libtiffxx.so.3 -> libtiffxx.so.3.9.4
-rwxr-xr-x 1 root root 9224 Dec 18 2012 libtiffxx.so.3.9.4
-rwxr-xr-x 1 root root 1335624 Nov 11 2010 libtk8.5.so
lrwxrwxrwx. 1 root root 19 Apr 5 2013 libusb-0.1.so.4 -> libusb-0.1.so.4.4.4
-rwxr-xr-x. 1 root root 33424 Aug 22 2010 libusb-0.1.so.4.4.4
lrwxrwxrwx. 1 root root 21 Apr 5 2013 libusbpp-0.1.so.4 -> libusbpp-0.1.so.4.4.4
-rwxr-xr-x. 1 root root 21016 Aug 22 2010 libusbpp-0.1.so.4.4.4
drwxr-xr-x. 2 root root 4096 Apr 5 2013 libuser
lrwxrwxrwx. 1 root root 16 Apr 5 2013 libuser.so.1 -> libuser.so.1.2.2
-rwxr-xr-x. 1 root root 102952 Apr 5 2012 libuser.so.1.2.2
lrwxrwxrwx. 1 root root 20 Apr 5 2013 libustr-1.0.so.1 -> libustr-1.0.so.1.0.4
-rwxr-xr-x. 1 root root 205976 Aug 18 2010 libustr-1.0.so.1.0.4
lrwxrwxrwx. 1 root root 20 Apr 5 2013 libutempter.so.0 -> libutempter.so.1.1.5
-rwxr-xr-x. 1 root root 6816 Aug 18 2010 libutempter.so.1.1.5
lrwxrwxrwx 1 root root 24 Feb 12 2014 libutil.so -> ../../lib64/libutil.so.1
-rw-r--r-- 1 root root 29242 Nov 22 2013 libuuid.a
lrwxrwxrwx 1 root root 28 Apr 11 2014 libuuid.so -> ../../lib64/libuuid.so.1.3.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libverto-k5ev.so -> libverto-k5ev.so.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libverto-k5ev.so.0 -> libverto-k5ev.so.0.0
-rwxr-xr-x 1 root root 55944 Sep 10 2013 libverto-k5ev.so.0.0
lrwxrwxrwx 1 root root 15 Feb 12 2014 libverto.so -> libverto.so.0.0
lrwxrwxrwx 1 root root 15 Feb 12 2014 libverto.so.0 -> libverto.so.0.0
-rwxr-xr-x 1 root root 18576 Sep 10 2013 libverto.so.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libvorbisenc.so.2 -> libvorbisenc.so.2.0.6
-rwxr-xr-x 1 root root 1941016 Feb 15 2012 libvorbisenc.so.2.0.6
lrwxrwxrwx 1 root root 22 Feb 12 2014 libvorbisfile.so.3 -> libvorbisfile.so.3.3.2
-rwxr-xr-x 1 root root 30576 Feb 15 2012 libvorbisfile.so.3.3.2
lrwxrwxrwx 1 root root 18 Feb 12 2014 libvorbis.so.0 -> libvorbis.so.0.4.3
-rwxr-xr-x 1 root root 181984 Feb 15 2012 libvorbis.so.0.4.3
lrwxrwxrwx 1 root root 20 Feb 12 2014 libwnck-1.so.22 -> libwnck-1.so.22.3.23
-rwxr-xr-x 1 root root 259248 Jul 19 2011 libwnck-1.so.22.3.23
lrwxrwxrwx 1 root root 15 Feb 12 2014 libX11.so -> libX11.so.6.3.0
lrwxrwxrwx 1 root root 15 Feb 12 2014 libX11.so.6 -> libX11.so.6.3.0
-rwxr-xr-x 1 root root 1297896 Feb 21 2013 libX11.so.6.3.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libX11-xcb.so -> libX11-xcb.so.1.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libX11-xcb.so.1 -> libX11-xcb.so.1.0.0
-rwxr-xr-x 1 root root 4064 Feb 21 2013 libX11-xcb.so.1.0.0
lrwxrwxrwx 1 root root 15 Feb 12 2014 libXau.so -> libXau.so.6.0.0
lrwxrwxrwx 1 root root 15 Feb 12 2014 libXau.so.6 -> libXau.so.6.0.0
-rwxr-xr-x 1 root root 10856 Feb 21 2013 libXau.so.6.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libXaw7.so.7 -> libXaw7.so.7.0.0
-rwxr-xr-x 1 root root 409912 Feb 21 2013 libXaw7.so.7.0.0
lrwxrwxrwx 1 root root 12 Feb 12 2014 libXaw.so.7 -> libXaw7.so.7
lrwxrwxrwx 1 root root 20 Feb 12 2014 libxcb-atom.so.1 -> libxcb-atom.so.1.0.0
-rwxr-xr-x 1 root root 14840 Aug 17 2010 libxcb-atom.so.1.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libxcb-aux.so.0 -> libxcb-aux.so.0.0.0
-rwxr-xr-x 1 root root 10776 Aug 17 2010 libxcb-aux.so.0.0.0
lrwxrwxrwx 1 root root 25 Feb 12 2014 libxcb-composite.so -> libxcb-composite.so.0.0.0
lrwxrwxrwx 1 root root 25 Feb 12 2014 libxcb-composite.so.0 -> libxcb-composite.so.0.0.0
-rwxr-xr-x 1 root root 8976 Feb 21 2013 libxcb-composite.so.0.0.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libxcb-damage.so -> libxcb-damage.so.0.0.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libxcb-damage.so.0 -> libxcb-damage.so.0.0.0
-rwxr-xr-x 1 root root 6992 Feb 21 2013 libxcb-damage.so.0.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libxcb-dpms.so -> libxcb-dpms.so.0.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libxcb-dpms.so.0 -> libxcb-dpms.so.0.0.0
-rwxr-xr-x 1 root root 8304 Feb 21 2013 libxcb-dpms.so.0.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libxcb-dri2.so -> libxcb-dri2.so.0.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libxcb-dri2.so.0 -> libxcb-dri2.so.0.0.0
-rwxr-xr-x 1 root root 15712 Feb 21 2013 libxcb-dri2.so.0.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libxcb-event.so.1 -> libxcb-event.so.1.0.0
-rwxr-xr-x 1 root root 16264 Aug 17 2010 libxcb-event.so.1.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libxcb-glx.so -> libxcb-glx.so.0.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libxcb-glx.so.0 -> libxcb-glx.so.0.0.0
-rwxr-xr-x 1 root root 91840 Feb 21 2013 libxcb-glx.so.0.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libxcb-icccm.so.1 -> libxcb-icccm.so.1.0.0
-rwxr-xr-x 1 root root 16728 Aug 17 2010 libxcb-icccm.so.1.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libxcb-image.so.0 -> libxcb-image.so.0.0.0
-rwxr-xr-x 1 root root 15400 Aug 17 2010 libxcb-image.so.0.0.0
lrwxrwxrwx 1 root root 23 Feb 12 2014 libxcb-keysyms.so.1 -> libxcb-keysyms.so.1.0.0
-rwxr-xr-x 1 root root 8072 Aug 17 2010 libxcb-keysyms.so.1.0.0
lrwxrwxrwx 1 root root 24 Feb 12 2014 libxcb-property.so.1 -> libxcb-property.so.1.0.0
-rwxr-xr-x 1 root root 6592 Aug 17 2010 libxcb-property.so.1.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libxcb-randr.so -> libxcb-randr.so.0.1.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libxcb-randr.so.0 -> libxcb-randr.so.0.1.0
-rwxr-xr-x 1 root root 41520 Feb 21 2013 libxcb-randr.so.0.1.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libxcb-record.so -> libxcb-record.so.0.0.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libxcb-record.so.0 -> libxcb-record.so.0.0.0
-rwxr-xr-x 1 root root 12896 Feb 21 2013 libxcb-record.so.0.0.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libxcb-render.so -> libxcb-render.so.0.0.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libxcb-render.so.0 -> libxcb-render.so.0.0.0
-rwxr-xr-x 1 root root 37424 Feb 21 2013 libxcb-render.so.0.0.0
lrwxrwxrwx 1 root root 27 Feb 12 2014 libxcb-render-util.so.0 -> libxcb-render-util.so.0.0.0
-rwxr-xr-x 1 root root 13096 Aug 17 2010 libxcb-render-util.so.0.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libxcb-reply.so.1 -> libxcb-reply.so.1.0.0
-rwxr-xr-x 1 root root 6760 Aug 17 2010 libxcb-reply.so.1.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libxcb-res.so -> libxcb-res.so.0.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libxcb-res.so.0 -> libxcb-res.so.0.0.0
-rwxr-xr-x 1 root root 8000 Feb 21 2013 libxcb-res.so.0.0.0
lrwxrwxrwx 1 root root 27 Feb 12 2014 libxcb-screensaver.so -> libxcb-screensaver.so.0.0.0
lrwxrwxrwx 1 root root 27 Feb 12 2014 libxcb-screensaver.so.0 -> libxcb-screensaver.so.0.0.0
-rwxr-xr-x 1 root root 7928 Feb 21 2013 libxcb-screensaver.so.0.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libxcb-shape.so -> libxcb-shape.so.0.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libxcb-shape.so.0 -> libxcb-shape.so.0.0.0
-rwxr-xr-x 1 root root 11344 Feb 21 2013 libxcb-shape.so.0.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libxcb-shm.so -> libxcb-shm.so.0.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libxcb-shm.so.0 -> libxcb-shm.so.0.0.0
-rwxr-xr-x 1 root root 7952 Feb 21 2013 libxcb-shm.so.0.0.0
lrwxrwxrwx 1 root root 15 Feb 12 2014 libxcb.so -> libxcb.so.1.1.0
lrwxrwxrwx 1 root root 15 Feb 12 2014 libxcb.so.1 -> libxcb.so.1.1.0
-rwxr-xr-x 1 root root 122312 Feb 21 2013 libxcb.so.1.1.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libxcb-sync.so -> libxcb-sync.so.0.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libxcb-sync.so.0 -> libxcb-sync.so.0.0.0
-rwxr-xr-x 1 root root 17856 Feb 21 2013 libxcb-sync.so.0.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libxcb-xevie.so -> libxcb-xevie.so.0.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libxcb-xevie.so.0 -> libxcb-xevie.so.0.0.0
-rwxr-xr-x 1 root root 7664 Feb 21 2013 libxcb-xevie.so.0.0.0
lrwxrwxrwx 1 root root 23 Feb 12 2014 libxcb-xf86dri.so -> libxcb-xf86dri.so.0.0.0
lrwxrwxrwx 1 root root 23 Feb 12 2014 libxcb-xf86dri.so.0 -> libxcb-xf86dri.so.0.0.0
-rwxr-xr-x 1 root root 13968 Feb 21 2013 libxcb-xf86dri.so.0.0.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libxcb-xfixes.so -> libxcb-xfixes.so.0.0.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libxcb-xfixes.so.0 -> libxcb-xfixes.so.0.0.0
-rwxr-xr-x 1 root root 25056 Feb 21 2013 libxcb-xfixes.so.0.0.0
lrwxrwxrwx 1 root root 24 Feb 12 2014 libxcb-xinerama.so -> libxcb-xinerama.so.0.0.0
lrwxrwxrwx 1 root root 24 Feb 12 2014 libxcb-xinerama.so.0 -> libxcb-xinerama.so.0.0.0
-rwxr-xr-x 1 root root 8496 Feb 21 2013 libxcb-xinerama.so.0.0.0
lrwxrwxrwx 1 root root 24 Feb 12 2014 libxcb-xselinux.so -> libxcb-xselinux.so.0.0.0
lrwxrwxrwx 1 root root 24 Feb 12 2014 libxcb-xselinux.so.0 -> libxcb-xselinux.so.0.0.0
-rwxr-xr-x 1 root root 28656 Feb 21 2013 libxcb-xselinux.so.0.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libxcb-xtest.so -> libxcb-xtest.so.0.0.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libxcb-xtest.so.0 -> libxcb-xtest.so.0.0.0
-rwxr-xr-x 1 root root 6944 Feb 21 2013 libxcb-xtest.so.0.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libxcb-xvmc.so -> libxcb-xvmc.so.0.0.0
lrwxrwxrwx 1 root root 20 Feb 12 2014 libxcb-xvmc.so.0 -> libxcb-xvmc.so.0.0.0
-rwxr-xr-x 1 root root 12656 Feb 21 2013 libxcb-xvmc.so.0.0.0
lrwxrwxrwx 1 root root 18 Feb 12 2014 libxcb-xv.so -> libxcb-xv.so.0.0.0
lrwxrwxrwx 1 root root 18 Feb 12 2014 libxcb-xv.so.0 -> libxcb-xv.so.0.0.0
-rwxr-xr-x 1 root root 25168 Feb 21 2013 libxcb-xv.so.0.0.0
lrwxrwxrwx 1 root root 22 Feb 12 2014 libXcomposite.so.1 -> libXcomposite.so.1.0.0
-rwxr-xr-x 1 root root 9752 Feb 21 2013 libXcomposite.so.1.0.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libXcursor.so.1 -> libXcursor.so.1.0.2
-rwxr-xr-x 1 root root 40096 Jun 6 2013 libXcursor.so.1.0.2
lrwxrwxrwx 1 root root 19 Feb 12 2014 libXdamage.so.1 -> libXdamage.so.1.1.0
-rwxr-xr-x 1 root root 8904 Feb 21 2013 libXdamage.so.1.1.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libxdot.so.4 -> libxdot.so.4.0.0
-rwxr-xr-x 1 root root 11376 Sep 19 2012 libxdot.so.4.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libXext.so.6 -> libXext.so.6.4.0
-rwxr-xr-x 1 root root 78432 Feb 21 2013 libXext.so.6.4.0
lrwxrwxrwx 1 root root 18 Feb 12 2014 libXfixes.so.3 -> libXfixes.so.3.1.0
-rwxr-xr-x 1 root root 23152 Feb 21 2013 libXfixes.so.3.1.0
lrwxrwxrwx 1 root root 15 Feb 12 2014 libXft.so.2 -> libXft.so.2.3.1
-rwxr-xr-x 1 root root 85976 Feb 21 2013 libXft.so.2.3.1
lrwxrwxrwx 1 root root 20 Feb 12 2014 libXinerama.so.1 -> libXinerama.so.1.0.0
-rwxr-xr-x 1 root root 8808 Feb 21 2013 libXinerama.so.1.0.0
lrwxrwxrwx 1 root root 14 Feb 12 2014 libXi.so.6 -> libXi.so.6.1.0
-rwxr-xr-x 1 root root 60352 Feb 21 2013 libXi.so.6.1.0
lrwxrwxrwx. 1 root root 16 Apr 5 2013 libxml2.so.2 -> libxml2.so.2.7.6
-rwxr-xr-x. 1 root root 1380800 Mar 1 2013 libxml2.so.2.7.6
lrwxrwxrwx 1 root root 15 Feb 12 2014 libXmu.so.6 -> libXmu.so.6.2.0
-rwxr-xr-x 1 root root 104928 Feb 21 2013 libXmu.so.6.2.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libXmuu.so.1 -> libXmuu.so.1.0.0
-rwxr-xr-x 1 root root 13928 Feb 21 2013 libXmuu.so.1.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libXpm.so -> libXpm.so.4.11.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libXpm.so.4 -> libXpm.so.4.11.0
-rwxr-xr-x 1 root root 70320 Feb 21 2013 libXpm.so.4.11.0
lrwxrwxrwx 1 root root 18 Feb 12 2014 libXrandr.so.2 -> libXrandr.so.2.2.0
-rwxr-xr-x 1 root root 37512 Feb 22 2013 libXrandr.so.2.2.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libXrender.so.1 -> libXrender.so.1.3.0
-rwxr-xr-x 1 root root 39968 Feb 21 2013 libXrender.so.1.3.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libXRes.so.1 -> libXRes.so.1.0.0
-rwxr-xr-x 1 root root 7712 Feb 21 2013 libXRes.so.1.0.0
drwxr-xr-x 2 root root 4096 Sep 13 2012 libxslt-plugins
lrwxrwxrwx 1 root root 17 Feb 12 2014 libxslt.so.1 -> libxslt.so.1.1.26
-rwxr-xr-x 1 root root 248072 Sep 13 2012 libxslt.so.1.1.26
lrwxrwxrwx 1 root root 14 Feb 12 2014 libXt.so.6 -> libXt.so.6.0.0
-rwxr-xr-x 1 root root 410224 Feb 21 2013 libXt.so.6.0.0
lrwxrwxrwx 1 root root 16 Feb 12 2014 libXtst.so.6 -> libXtst.so.6.1.0
-rwxr-xr-x 1 root root 23520 Feb 21 2013 libXtst.so.6.1.0
lrwxrwxrwx 1 root root 21 Feb 12 2014 libXxf86misc.so.1 -> libXxf86misc.so.1.1.0
-rwxr-xr-x 1 root root 11176 Feb 21 2013 libXxf86misc.so.1.1.0
lrwxrwxrwx 1 root root 19 Feb 12 2014 libXxf86vm.so.1 -> libXxf86vm.so.1.0.0
-rwxr-xr-x 1 root root 20136 Feb 21 2013 libXxf86vm.so.1.0.0
lrwxrwxrwx 1 root root 25 Feb 12 2014 libz.so -> ../../lib64/libz.so.1.2.3
drwxr-xr-x. 3 root root 4096 Apr 5 2013 lua
-rw-r--r-- 1 root root 616 Nov 21 2013 Mcrt1.o
drwxr-xr-x 2 root root 4096 Feb 12 2014 mrtg2
drwxr-xr-x. 3 root root 4096 Feb 12 2014 mysql
drwxr-xr-x 3 root root 4096 Feb 12 2014 notification-daemon-1.0
drwxr-xr-x. 4 root root 4096 Dec 7 2011 nss
drwxr-xr-x. 3 root root 4096 Jan 8 2014 openssl
drwxr-xr-x 2 root root 4096 Feb 12 2014 orbit-2.0
drwxr-xr-x 3 root root 4096 Feb 12 2014 pango
drwxr-xr-x 55 root root 4096 May 7 2015 perl5
drwxr-xr-x 3 root root 4096 Feb 12 2014 pgsql
drwxr-xr-x 4 root root 4096 Feb 12 2014 php
drwxr-xr-x 2 root root 4096 Apr 11 2014 pkgconfig
drwxr-xr-x. 3 root root 4096 Apr 5 2013 plymouth
dr-xr-xr-x. 5 root root 4096 Sep 23 2011 pm-utils
drwxr-xr-x 3 root root 4096 Feb 12 2014 polkit-1
drwxr-xr-x 2 root root 4096 Nov 11 2010 ppl
drwxr-xr-x 3 root root 4096 Feb 12 2014 pygtk
drwxr-xr-x. 24 root root 20480 Apr 18 2014 python2.6
drwxr-xr-x 2 root root 4096 Feb 12 2014 sa
drwxr-xr-x. 2 root root 4096 Nov 27 2012 sasl2
-rw-r--r-- 1 root root 1696 Nov 21 2013 Scrt1.o
dr-xr-xr-x. 2 root root 4096 Sep 23 2011 sse2
drwxr-xr-x. 2 root root 4096 Apr 5 2013 tc
drwxr-xr-x 3 root root 4096 Apr 18 2014 tcl8.5
drwxr-xr-x 2 root root 4096 Apr 18 2014 tk8.5
dr-xr-xr-x. 2 root root 4096 Sep 23 2011 tls
dr-xr-xr-x. 2 root root 4096 Sep 23 2011 X11
ls: cannot access /usr/lib64/nagios/: No such file or directory
ls: cannot access /usr/lib64/nagios/plugins/: No such file or directory
ls: cannot access /usr/lib64/nagios/plugins/tmp/: No such file or directory
To note this check is not running on the NagiosXI server but on all hosts. Which would be why the plugins folders do not exist.
Post
by tgriep » Wed Jan 27, 2016 10:47 am
That is good to know that the check is run on the remote hosts.
Can you show us how that is done?
Can you run the same commands on the remote system?
ls -al /usr/lib64/
brandon.pal
Post
by brandon.pal » Fri Jan 29, 2016 11:58 am
ls -al /usr/lib64/
total 143700
dr-xr-xr-x. 53 root root 36864 May 7 2014 .
drwxr-xr-x. 14 root root 4096 Feb 26 2014 ..
drwxr-xr-x. 3 root root 4096 Feb 24 2014 alsa-lib
drwxr-xr-x. 2 root root 4096 Feb 24 2014 apr-util-1
drwxr-xr-x. 2 root root 4096 Feb 24 2014 atlas
drwxr-xr-x. 2 root root 4096 May 6 2014 autofs
drwxr-xr-x. 2 root root 4096 May 6 2014 coreutils
lrwxrwxrwx. 1 root root 36 Feb 24 2014 cracklib_dict.hwm -> ../../usr/share/cracklib/pw_dict.hwm
lrwxrwxrwx. 1 root root 36 Feb 24 2014 cracklib_dict.pwd -> ../../usr/share/cracklib/pw_dict.pwd
lrwxrwxrwx. 1 root root 36 Feb 24 2014 cracklib_dict.pwi -> ../../usr/share/cracklib/pw_dict.pwi
drwxr-xr-x. 3 root root 4096 Feb 24 2014 crash
-rw-r--r--. 1 root root 1648 Nov 21 2013 crt1.o
-rw-r--r--. 1 root root 1504 Nov 21 2013 crti.o
-rw-r--r--. 1 root root 760 Nov 21 2013 crtn.o
drwxr-xr-x. 2 root root 4096 Feb 24 2014 dri
drwxr-xr-x. 2 root root 4096 Feb 24 2014 elfutils
drwxr-xr-x. 2 root root 12288 Feb 24 2014 gconv
-rw-r--r--. 1 root root 2392 Nov 21 2013 gcrt1.o
drwxr-xr-x. 2 root root 4096 Feb 26 2014 gettext
drwxr-xr-x. 3 root root 4096 Feb 24 2014 ghostscript
drwxr-xr-x. 3 root root 4096 Mar 17 2014 gio
drwxr-xr-x. 2 root root 4096 Feb 24 2014 gstreamer-0.10
drwxr-xr-x. 5 root root 4096 Feb 24 2014 gtk-2.0
drwxr-xr-x. 3 root root 4096 Apr 3 2014 httpd
drwxr-xr-x. 3 root root 4096 Apr 3 2014 krb5
drwxr-xr-x. 3 root root 4096 Feb 24 2014 ldb
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libabrt_dbus.so.0 -> libabrt_dbus.so.0.0.1
-rwxr-xr-x 1 root root 13416 Nov 22 2013 libabrt_dbus.so.0.0.1
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libabrt.so.0 -> libabrt.so.0.0.1
-rwxr-xr-x 1 root root 27368 Nov 22 2013 libabrt.so.0.0.1
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libabrt_web.so.0 -> libabrt_web.so.0.0.1
-rwxr-xr-x 1 root root 21248 Nov 22 2013 libabrt_web.so.0.0.1
lrwxrwxrwx. 1 root root 23 Feb 24 2014 libanl.so -> ../../lib64/libanl.so.1
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libapr-1.so.0 -> libapr-1.so.0.3.9
-rwxr-xr-x. 1 root root 181792 Jun 14 2012 libapr-1.so.0.3.9
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libaprutil-1.so.0 -> libaprutil-1.so.0.3.9
-rwxr-xr-x. 1 root root 146080 Jun 25 2011 libaprutil-1.so.0.3.9
-rwxr-xr-x. 1 root root 31456 Jul 19 2011 libasm-0.152.so
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libasm.so.1 -> libasm-0.152.so
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libasyncns.so.0 -> libasyncns.so.0.3.1
-rwxr-xr-x. 1 root root 19856 Aug 18 2010 libasyncns.so.0.3.1
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libatk-1.0.so.0 -> libatk-1.0.so.0.3009.1
-rwxr-xr-x 1 root root 136168 Nov 22 2013 libatk-1.0.so.0.3009.1
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libaugeas.so.0 -> libaugeas.so.0.16.0
-rwxr-xr-x. 1 root root 312888 Jan 20 2014 libaugeas.so.0.16.0
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libavahi-client.so.3 -> libavahi-client.so.3.2.5
-rwxr-xr-x. 1 root root 68672 Feb 21 2013 libavahi-client.so.3.2.5
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libavahi-common.so.3 -> libavahi-common.so.3.5.1
-rwxr-xr-x. 1 root root 51056 Feb 21 2013 libavahi-common.so.3.5.1
-rwxr-xr-x. 1 root root 929280 Feb 21 2013 libbfd-2.20.51.0.2-5.36.el6.so
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libbind9.so.80 -> libbind9.so.80.0.4
-rwxr-xr-x 1 root root 52944 Jan 20 2014 libbind9.so.80.0.4
lrwxrwxrwx. 1 root root 32 Feb 24 2014 libBrokenLocale.so -> ../../lib64/libBrokenLocale.so.1
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libbsd.a -> libbsd-compat.a
-rw-r--r--. 1 root root 1338 Nov 21 2013 libbsd-compat.a
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libbtparser.so.2 -> libbtparser.so.2.2.2
-rwxr-xr-x. 1 root root 71472 Nov 22 2013 libbtparser.so.2.2.2
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libcairo.so.2 -> libcairo.so.2.10800.8
-rwxr-xr-x. 1 root root 497408 Nov 10 2010 libcairo.so.2.10800.8
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libcares.so.2 -> libcares.so.2.0.0
-rwxr-xr-x. 1 root root 62896 Jun 22 2012 libcares.so.2.0.0
lrwxrwxrwx. 1 root root 27 Feb 24 2014 libcdda_interface.so -> libcdda_interface.so.0.10.2
lrwxrwxrwx. 1 root root 27 Feb 24 2014 libcdda_interface.so.0 -> libcdda_interface.so.0.10.2
-rwxr-xr-x. 1 root root 92440 Nov 10 2010 libcdda_interface.so.0.10.2
lrwxrwxrwx. 1 root root 26 Feb 24 2014 libcdda_paranoia.so -> libcdda_paranoia.so.0.10.2
lrwxrwxrwx. 1 root root 26 Feb 24 2014 libcdda_paranoia.so.0 -> libcdda_paranoia.so.0.10.2
-rwxr-xr-x. 1 root root 42904 Nov 10 2010 libcdda_paranoia.so.0.10.2
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libcidn.so -> ../../lib64/libcidn.so.1
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libck-connector.so.0 -> libck-connector.so.0.0.0
-rwxr-xr-x. 1 root root 14248 Nov 10 2010 libck-connector.so.0.0.0
lrwxrwxrwx. 1 root root 17 Feb 26 2014 libcloog.so.0 -> libcloog.so.0.0.0
-rwxr-xr-x 1 root root 134032 Nov 10 2010 libcloog.so.0.0.0
-rw-r--r--. 1 root root 22854 Nov 21 2013 libc_nonshared.a
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libcollection.so.2 -> libcollection.so.2.0.0
-rwxr-xr-x. 1 root root 47320 Jun 22 2012 libcollection.so.2.0.0
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libcrack.so.2 -> libcrack.so.2.8.1
-rwxr-xr-x. 1 root root 41088 Jun 25 2011 libcrack.so.2.8.1
lrwxrwxrwx 1 root root 19 May 6 2014 libcrypto.so.10 -> libcrypto.so.1.0.1e
-rwxr-xr-x 1 root root 1953536 Apr 7 2014 libcrypto.so.1.0.1e
-rw-r--r-- 1 root root 65 Apr 7 2014 .libcrypto.so.1.0.1e.hmac
lrwxrwxrwx 1 root root 25 May 6 2014 .libcrypto.so.10.hmac -> .libcrypto.so.1.0.1e.hmac
lrwxrwxrwx. 1 root root 25 Feb 24 2014 libcrypt.so -> ../../lib64/libcrypt.so.1
-rw-r--r--. 1 root root 253 Nov 21 2013 libc.so
-rwxr-xr-x. 1 root root 60360 Aug 17 2013 libcupscgi.so.1
-rwxr-xr-x. 1 root root 35576 Aug 17 2013 libcupsdriver.so.1
-rwxr-xr-x 1 root root 105376 Aug 17 2013 libcupsimage.so.2
-rwxr-xr-x. 1 root root 22392 Aug 17 2013 libcupsmime.so.1
-rwxr-xr-x. 1 root root 120504 Aug 17 2013 libcupsppdc.so.1
-rwxr-xr-x 1 root root 326960 Aug 17 2013 libcups.so.2
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libcurl.so.4 -> libcurl.so.4.1.1
-rwxr-xr-x 1 root root 346008 Jun 25 2013 libcurl.so.4.1.1
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libdb-4.7.so -> ../../lib64/libdb-4.7.so
-rwxr-xr-x. 1 root root 1645008 Sep 12 2013 libdb_cxx-4.7.so
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libdb_cxx.so -> libdb_cxx-4.7.so
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libdb.so -> ../../lib64/libdb-4.7.so
lrwxrwxrwx. 1 root root 23 Feb 24 2014 libdbus-glib-1.so.2 -> libdbus-glib-1.so.2.1.0
-rwxr-xr-x 1 root root 144912 Feb 26 2013 libdbus-glib-1.so.2.1.0
lrwxrwxrwx 1 root root 24 May 6 2014 libdcerpc-atsvc.so.0 -> libdcerpc-atsvc.so.0.0.1
-rwxr-xr-x 1 root root 3904 Apr 9 2014 libdcerpc-atsvc.so.0.0.1
lrwxrwxrwx 1 root root 26 May 6 2014 libdcerpc-binding.so.0 -> libdcerpc-binding.so.0.0.1
-rwxr-xr-x 1 root root 102296 Apr 9 2014 libdcerpc-binding.so.0.0.1
lrwxrwxrwx 1 root root 23 May 6 2014 libdcerpc-samr.so.0 -> libdcerpc-samr.so.0.0.1
-rwxr-xr-x 1 root root 3904 Apr 9 2014 libdcerpc-samr.so.0.0.1
lrwxrwxrwx 1 root root 18 May 6 2014 libdcerpc.so.0 -> libdcerpc.so.0.0.1
-rwxr-xr-x 1 root root 161664 Apr 9 2014 libdcerpc.so.0.0.1
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libdhash.so.1 -> libdhash.so.1.0.0
-rwxr-xr-x. 1 root root 13160 Jun 22 2012 libdhash.so.1.0.0
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libdl.so -> ../../lib64/libdl.so.2
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libdns.so.81 -> libdns.so.81.4.1
-rwxr-xr-x 1 root root 1674872 Jan 20 2014 libdns.so.81.4.1
lrwxrwxrwx. 1 root root 30 Feb 24 2014 libdricore9.2.0-devel.so -> libdricore9.2.0-devel.so.1.0.0
lrwxrwxrwx. 1 root root 30 Feb 24 2014 libdricore9.2.0-devel.so.1 -> libdricore9.2.0-devel.so.1.0.0
-rwxr-xr-x. 1 root root 4065136 Dec 13 2013 libdricore9.2.0-devel.so.1.0.0
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libdrm_intel.so.1 -> libdrm_intel.so.1.0.0
-rwxr-xr-x. 1 root root 135736 Nov 22 2013 libdrm_intel.so.1.0.0
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libdrm_nouveau2.so.2 -> libdrm_nouveau2.so.2.0.0
-rwxr-xr-x. 1 root root 23312 Nov 22 2013 libdrm_nouveau2.so.2.0.0
lrwxrwxrwx. 1 root root 23 Feb 24 2014 libdrm_nouveau.so.1 -> libdrm_nouveau.so.1.0.0
-rwxr-xr-x. 1 root root 21208 Nov 22 2013 libdrm_nouveau.so.1.0.0
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libdrm_radeon.so.1 -> libdrm_radeon.so.1.0.1
-rwxr-xr-x. 1 root root 45752 Nov 22 2013 libdrm_radeon.so.1.0.1
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libdrm.so.2 -> libdrm.so.2.4.0
-rwxr-xr-x. 1 root root 43976 Nov 22 2013 libdrm.so.2.4.0
-rwxr-xr-x. 1 root root 221248 Jul 19 2011 libdw-0.152.so
lrwxrwxrwx. 1 root root 14 Feb 24 2014 libdw.so.1 -> libdw-0.152.so
lrwxrwxrwx 1 root root 21 May 6 2014 libecpg_compat.so.3 -> libecpg_compat.so.3.1
-rwxr-xr-x 1 root root 18096 Feb 25 2014 libecpg_compat.so.3.1
lrwxrwxrwx 1 root root 14 May 6 2014 libecpg.so.6 -> libecpg.so.6.1
-rwxr-xr-x 1 root root 65128 Feb 25 2014 libecpg.so.6.1
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libedit.so.0 -> libedit.so.0.0.27
-rwxr-xr-x. 1 root root 178816 Aug 19 2010 libedit.so.0.0.27
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libeggdbus-1.so.0 -> libeggdbus-1.so.0.0.0
-rwxr-xr-x 1 root root 298440 Nov 11 2010 libeggdbus-1.so.0.0.0
-rwxr-xr-x. 1 root root 86976 Jul 19 2011 libelf-0.152.so
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libelf.so.1 -> libelf-0.152.so
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libevent-1.4.so.2 -> libevent-1.4.so.2.1.3
-rwxr-xr-x. 1 root root 106656 Jun 22 2012 libevent-1.4.so.2.1.3
lrwxrwxrwx. 1 root root 26 Feb 24 2014 libevent_core-1.4.so.2 -> libevent_core-1.4.so.2.1.3
-rwxr-xr-x. 1 root root 40280 Jun 22 2012 libevent_core-1.4.so.2.1.3
lrwxrwxrwx. 1 root root 27 Feb 24 2014 libevent_extra-1.4.so.2 -> libevent_extra-1.4.so.2.1.3
-rwxr-xr-x. 1 root root 84536 Jun 22 2012 libevent_extra-1.4.so.2.1.3
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libexslt.so.0 -> libexslt.so.0.8.15
-rwxr-xr-x. 1 root root 84296 Sep 13 2012 libexslt.so.0.8.15
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libfam.so.0 -> libfam.so.0.0.0
lrwxrwxrwx. 1 root root 14 Feb 24 2014 libfa.so.1 -> libfa.so.1.4.0
-rwxr-xr-x. 1 root root 89224 Jan 20 2014 libfa.so.1.4.0
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libffi.so.5 -> libffi.so.5.0.6
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libFLAC++.so.6 -> libFLAC++.so.6.2.0
-rwxr-xr-x. 1 root root 98320 Nov 11 2010 libFLAC++.so.6.2.0
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libFLAC.so.8 -> libFLAC.so.8.2.0
-rwxr-xr-x. 1 root root 241128 Nov 11 2010 libFLAC.so.8.2.0
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libfontconfig.so.1 -> libfontconfig.so.1.4.4
-rwxr-xr-x. 1 root root 223040 Nov 11 2010 libfontconfig.so.1.4.4
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libfontenc.so.1 -> libfontenc.so.1.0.0
-rwxr-xr-x. 1 root root 30056 Aug 17 2010 libfontenc.so.1.0.0
lrwxrwxrwx. 1 root root 14 Feb 24 2014 libform.so.5 -> libform.so.5.7
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libformw.so.5 -> libformw.so.5.7
-rwxr-xr-x. 1 root root 69816 Aug 18 2010 libformw.so.5.7
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libfprint.so.0 -> libfprint.so.0.0.0
-rwxr-xr-x 1 root root 211288 Nov 12 2010 libfprint.so.0.0.0
lrwxrwxrwx 1 root root 26 May 6 2014 libfreebl3.chk -> ../../lib64/libfreebl3.chk
lrwxrwxrwx 1 root root 25 May 6 2014 libfreebl3.so -> ../../lib64/libfreebl3.so
lrwxrwxrwx. 1 root root 21 Feb 26 2014 libfreetype.so -> libfreetype.so.6.3.22
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libfreetype.so.6 -> libfreetype.so.6.3.22
-rwxr-xr-x. 1 root root 644912 Jan 31 2013 libfreetype.so.6.3.22
-rw-r--r--. 1 root root 1338 Nov 21 2013 libg.a
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libgailutil.so.18 -> libgailutil.so.18.0.1
-rwxr-xr-x. 1 root root 29784 Nov 23 2013 libgailutil.so.18.0.1
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libgamin-1.so.0 -> libgamin-1.so.0.1.10
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libgdbm.so -> libgdbm.so.2.0.0
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libgdbm.so.2 -> libgdbm.so.2.0.0
lrwxrwxrwx. 1 root root 29 Feb 24 2014 libgdk_pixbuf-2.0.so.0 -> libgdk_pixbuf-2.0.so.0.2000.1
-rwxr-xr-x 1 root root 130488 Nov 23 2013 libgdk_pixbuf-2.0.so.0.2000.1
lrwxrwxrwx. 1 root root 34 Feb 24 2014 libgdk_pixbuf_xlib-2.0.so.0 -> libgdk_pixbuf_xlib-2.0.so.0.2000.1
-rwxr-xr-x. 1 root root 66976 Nov 23 2013 libgdk_pixbuf_xlib-2.0.so.0.2000.1
lrwxrwxrwx. 1 root root 26 Feb 24 2014 libgdk-x11-2.0.so.0 -> libgdk-x11-2.0.so.0.2000.1
-rwxr-xr-x 1 root root 770112 Nov 23 2013 libgdk-x11-2.0.so.0.2000.1
lrwxrwxrwx 1 root root 18 May 6 2014 libgensec.so.0 -> libgensec.so.0.0.1
-rwxr-xr-x 1 root root 147640 Apr 9 2014 libgensec.so.0.0.1
-rwxr-xr-x. 1 root root 1186968 Nov 11 2010 libgettextlib-0.17.so
-rwxr-xr-x. 1 root root 252560 Nov 11 2010 libgettextsrc-0.17.so
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libgfortran.so.3 -> libgfortran.so.3.0.0
-rwxr-xr-x. 1 root root 988032 Nov 21 2013 libgfortran.so.3.0.0
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libgif.so.4 -> libgif.so.4.1.6
-rwxr-xr-x. 1 root root 36912 Nov 11 2010 libgif.so.4.1.6
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libglapi.so -> libglapi.so.0.0.0
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libglapi.so.0 -> libglapi.so.0.0.0
-rwxr-xr-x. 1 root root 147080 Dec 13 2013 libglapi.so.0.0.0
lrwxrwxrwx. 1 root root 14 Feb 24 2014 libGL.so.1 -> libGL.so.1.2.0
-rwxr-xr-x. 1 root root 388328 Dec 13 2013 libGL.so.1.2.0
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libGLU.so.1 -> libGLU.so.1.3.1
-rwxr-xr-x. 1 root root 522976 Dec 13 2013 libGLU.so.1.3.1
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libgmp.so.3 -> libgmp.so.3.5.0
-rwxr-xr-x 1 root root 376792 Mar 7 2012 libgmp.so.3.5.0
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libgmpxx.so.4 -> libgmpxx.so.4.1.0
-rwxr-xr-x 1 root root 17992 Mar 7 2012 libgmpxx.so.4.1.0
lrwxrwxrwx 1 root root 27 May 6 2014 libgnutls-extra.so.26 -> libgnutls-extra.so.26.14.12
-rwxr-xr-x 1 root root 31736 Mar 4 2014 libgnutls-extra.so.26.14.12
lrwxrwxrwx 1 root root 21 May 6 2014 libgnutls.so.26 -> libgnutls.so.26.14.12
-rwxr-xr-x 1 root root 671104 Mar 4 2014 libgnutls.so.26.14.12
lrwxrwxrwx 1 root root 23 May 6 2014 libgnutlsxx.so.26 -> libgnutlsxx.so.26.14.12
-rwxr-xr-x 1 root root 58240 Mar 4 2014 libgnutlsxx.so.26.14.12
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libgomp.so.1 -> libgomp.so.1.0.0
-rwxr-xr-x. 1 root root 57712 Nov 21 2013 libgomp.so.1.0.0
lrwxrwxrwx. 1 root root 26 Feb 24 2014 libgpgme-pthread.so.11 -> libgpgme-pthread.so.11.6.6
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libgpgme-pth.so.11 -> libgpgme-pth.so.11.6.6
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libgpgme.so.11 -> libgpgme.so.11.6.6
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libgpm.so.2 -> libgpm.so.2.1.0
-rwxr-xr-x. 1 root root 26104 Sep 23 2011 libgpm.so.2.1.0
lrwxrwxrwx. 1 root root 13 Feb 26 2014 libgs.so -> libgs.so.8.70
lrwxrwxrwx. 1 root root 13 Feb 24 2014 libgs.so.8 -> libgs.so.8.70
-rwxr-xr-x 1 root root 7958192 Nov 22 2013 libgs.so.8.70
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libgstapp-0.10.so.0 -> libgstapp-0.10.so.0.20.0
-rwxr-xr-x. 1 root root 50944 Nov 20 2012 libgstapp-0.10.so.0.20.0
lrwxrwxrwx. 1 root root 26 Feb 24 2014 libgstaudio-0.10.so.0 -> libgstaudio-0.10.so.0.20.0
-rwxr-xr-x. 1 root root 142520 Nov 20 2012 libgstaudio-0.10.so.0.20.0
lrwxrwxrwx. 1 root root 25 Feb 24 2014 libgstbase-0.10.so.0 -> libgstbase-0.10.so.0.25.0
-rwxr-xr-x 1 root root 258216 Nov 11 2010 libgstbase-0.10.so.0.25.0
lrwxrwxrwx. 1 root root 25 Feb 24 2014 libgstcdda-0.10.so.0 -> libgstcdda-0.10.so.0.20.0
-rwxr-xr-x. 1 root root 36864 Nov 20 2012 libgstcdda-0.10.so.0.20.0
lrwxrwxrwx. 1 root root 31 Feb 24 2014 libgstcontroller-0.10.so.0 -> libgstcontroller-0.10.so.0.25.0
-rwxr-xr-x. 1 root root 173432 Nov 11 2010 libgstcontroller-0.10.so.0.25.0
lrwxrwxrwx. 1 root root 33 Feb 24 2014 libgstdataprotocol-0.10.so.0 -> libgstdataprotocol-0.10.so.0.25.0
-rwxr-xr-x. 1 root root 19336 Nov 11 2010 libgstdataprotocol-0.10.so.0.25.0
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libgstfft-0.10.so.0 -> libgstfft-0.10.so.0.20.0
-rwxr-xr-x. 1 root root 37960 Nov 20 2012 libgstfft-0.10.so.0.20.0
lrwxrwxrwx. 1 root root 31 Feb 24 2014 libgstinterfaces-0.10.so.0 -> libgstinterfaces-0.10.so.0.20.0
-rwxr-xr-x 1 root root 72736 Nov 20 2012 libgstinterfaces-0.10.so.0.20.0
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libgstnet-0.10.so.0 -> libgstnet-0.10.so.0.25.0
-rwxr-xr-x. 1 root root 24408 Nov 11 2010 libgstnet-0.10.so.0.25.0
lrwxrwxrwx. 1 root root 30 Feb 24 2014 libgstnetbuffer-0.10.so.0 -> libgstnetbuffer-0.10.so.0.20.0
-rwxr-xr-x. 1 root root 9096 Nov 20 2012 libgstnetbuffer-0.10.so.0.20.0
lrwxrwxrwx. 1 root root 28 Feb 24 2014 libgstpbutils-0.10.so.0 -> libgstpbutils-0.10.so.0.20.0
-rwxr-xr-x. 1 root root 57200 Nov 20 2012 libgstpbutils-0.10.so.0.20.0
lrwxrwxrwx. 1 root root 27 Feb 24 2014 libgstreamer-0.10.so.0 -> libgstreamer-0.10.so.0.25.0
-rwxr-xr-x 1 root root 926944 Nov 11 2010 libgstreamer-0.10.so.0.25.0
lrwxrwxrwx. 1 root root 25 Feb 24 2014 libgstriff-0.10.so.0 -> libgstriff-0.10.so.0.20.0
-rwxr-xr-x. 1 root root 48528 Nov 20 2012 libgstriff-0.10.so.0.20.0
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libgstrtp-0.10.so.0 -> libgstrtp-0.10.so.0.20.0
-rwxr-xr-x. 1 root root 91952 Nov 20 2012 libgstrtp-0.10.so.0.20.0
lrwxrwxrwx. 1 root root 25 Feb 24 2014 libgstrtsp-0.10.so.0 -> libgstrtsp-0.10.so.0.20.0
-rwxr-xr-x. 1 root root 102496 Nov 20 2012 libgstrtsp-0.10.so.0.20.0
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libgstsdp-0.10.so.0 -> libgstsdp-0.10.so.0.20.0
-rwxr-xr-x. 1 root root 29616 Nov 20 2012 libgstsdp-0.10.so.0.20.0
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libgsttag-0.10.so.0 -> libgsttag-0.10.so.0.20.0
-rwxr-xr-x. 1 root root 98304 Nov 20 2012 libgsttag-0.10.so.0.20.0
lrwxrwxrwx. 1 root root 26 Feb 24 2014 libgstvideo-0.10.so.0 -> libgstvideo-0.10.so.0.20.0
-rwxr-xr-x 1 root root 35400 Nov 20 2012 libgstvideo-0.10.so.0.20.0
lrwxrwxrwx. 1 root root 26 Feb 24 2014 libgtk-x11-2.0.so.0 -> libgtk-x11-2.0.so.0.2000.1
-rwxr-xr-x 1 root root 4672488 Nov 23 2013 libgtk-x11-2.0.so.0.2000.1
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libgudev-1.0.so.0 -> libgudev-1.0.so.0.0.1
-rwxr-xr-x. 1 root root 30528 Nov 22 2013 libgudev-1.0.so.0.0.1
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libhal.so.1 -> libhal.so.1.0.0
-rwxr-xr-x. 1 root root 68928 Jul 19 2011 libhal.so.1.0.0
lrwxrwxrwx. 1 root root 23 Feb 24 2014 libhal-storage.so.1 -> libhal-storage.so.1.0.0
-rwxr-xr-x. 1 root root 44256 Jul 19 2011 libhal-storage.so.1.0.0
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libhesiod.so.0 -> libhesiod.so.0.0.0
-rwxr-xr-x. 1 root root 16168 Aug 22 2010 libhesiod.so.0.0.0
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libhistory.so.5 -> libhistory.so.5.2
-rwxr-xr-x. 1 root root 33232 Nov 10 2010 libhistory.so.5.2
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libhistory.so.6 -> libhistory.so.6.0
-rwxr-xr-x. 1 root root 62056 Dec 7 2011 libhugetlbfs.so
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libhunspell-1.2.so.0 -> libhunspell-1.2.so.0.0.0
-rwxr-xr-x. 1 root root 269448 Nov 11 2010 libhunspell-1.2.so.0.0.0
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libhwloc.so.5 -> libhwloc.so.5.1.0
-rwxr-xr-x. 1 root root 166336 Feb 21 2013 libhwloc.so.5.1.0
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libICE.so.6 -> libICE.so.6.3.0
-rwxr-xr-x. 1 root root 101608 Aug 16 2010 libICE.so.6.3.0
-rw-r--r--. 1 root root 2848 Nov 21 2013 libieee.a
-rwxr-xr-x. 1 root root 19736 Nov 22 2013 libijs-0.35.so
lrwxrwxrwx. 1 root root 14 Feb 26 2014 libijs.so -> libijs-0.35.so
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libini_config.so.2 -> libini_config.so.2.0.0
-rwxr-xr-x. 1 root root 34504 Jun 22 2012 libini_config.so.2.0.0
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libipa_hbac.so.0 -> libipa_hbac.so.0.0.1
-rwxr-xr-x. 1 root root 8192 Jan 6 2014 libipa_hbac.so.0.0.1
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libisccc.so.80 -> libisccc.so.80.0.0
-rwxr-xr-x. 1 root root 34696 Jan 20 2014 libisccc.so.80.0.0
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libisccfg.so.82 -> libisccfg.so.82.0.1
-rwxr-xr-x 1 root root 140568 Jan 20 2014 libisccfg.so.82.0.1
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libisc.so.83 -> libisc.so.83.0.3
-rwxr-xr-x. 1 root root 358560 Jan 20 2014 libisc.so.83.0.3
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libitm.so.1 -> libitm.so.1.0.0
-rwxr-xr-x. 1 root root 127664 Nov 22 2013 libitm.so.1.0.0
lrwxrwxrwx. 1 root root 18 Feb 26 2014 libjasper.so -> libjasper.so.1.0.0
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libjasper.so.1 -> libjasper.so.1.0.0
-rwxr-xr-x. 1 root root 339576 Dec 17 2011 libjasper.so.1.0.0
lrwxrwxrwx. 1 root root 17 Feb 26 2014 libjpeg.so -> libjpeg.so.62.0.0
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libjpeg.so.62 -> libjpeg.so.62.0.0
-rwxr-xr-x. 1 root root 265280 Dec 9 2013 libjpeg.so.62.0.0
lrwxrwxrwx 1 root root 23 May 6 2014 libkadm5clnt_mit.so.8 -> libkadm5clnt_mit.so.8.0
-rwxr-xr-x 1 root root 89216 Apr 3 2014 libkadm5clnt_mit.so.8.0
lrwxrwxrwx 1 root root 22 May 6 2014 libkadm5srv_mit.so.8 -> libkadm5srv_mit.so.8.0
-rwxr-xr-x 1 root root 122640 Apr 3 2014 libkadm5srv_mit.so.8.0
lrwxrwxrwx 1 root root 14 May 6 2014 libkdb5.so.6 -> libkdb5.so.6.0
-rwxr-xr-x 1 root root 77080 Apr 3 2014 libkdb5.so.6.0
lrwxrwxrwx. 1 root root 17 Feb 26 2014 liblcms.so -> liblcms.so.1.0.19
lrwxrwxrwx. 1 root root 17 Feb 24 2014 liblcms.so.1 -> liblcms.so.1.0.19
-rwxr-xr-x. 1 root root 226552 Aug 20 2010 liblcms.so.1.0.19
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libldb.so.1 -> libldb.so.1.1.13
-rwxr-xr-x 1 root root 188672 Feb 22 2013 libldb.so.1.1.13
-rwxr-xr-x. 1 root root 16818664 Nov 22 2013 libLLVM-3.3-mesa.so
-rwxr-xr-x. 1 root root 146200 Nov 11 2010 libltaudit.so.0.5.9
lrwxrwxrwx. 1 root root 16 Feb 26 2014 libltdl.so -> libltdl.so.7.2.1
lrwxrwxrwx. 1 root root 16 Feb 26 2014 libltdl.so.7 -> libltdl.so.7.2.1
-rwxr-xr-x. 1 root root 36880 Aug 24 2010 libltdl.so.7.2.1
-rwxr-xr-x. 1 root root 186296 Aug 19 2010 liblua-5.1.so
lrwxrwxrwx. 1 root root 18 Feb 24 2014 liblwres.so.80 -> liblwres.so.80.0.2
-rwxr-xr-x. 1 root root 75936 Jan 20 2014 liblwres.so.80.0.2
lrwxrwxrwx. 1 root root 16 Feb 24 2014 liblzma.so.0 -> liblzma.so.0.0.0
-rwxr-xr-x. 1 root root 137264 Aug 22 2010 liblzma.so.0.0.0
lrwxrwxrwx. 1 root root 16 Feb 24 2014 liblzo2.so.2 -> liblzo2.so.2.0.0
-rwxr-xr-x. 1 root root 136384 Aug 19 2010 liblzo2.so.2.0.0
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libmagic.so.1 -> libmagic.so.1.0.0
-rwxr-xr-x. 1 root root 118112 Oct 4 2012 libmagic.so.1.0.0
-rw-r--r--. 1 root root 11776 Nov 21 2013 libmcheck.a
-rwxr-xr-x. 1 root root 23336 Nov 21 2013 libmemusage.so
lrwxrwxrwx. 1 root root 14 Feb 24 2014 libmenu.so.5 -> libmenu.so.5.7
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libmenuw.so.5 -> libmenuw.so.5.7
-rwxr-xr-x. 1 root root 32936 Aug 18 2010 libmenuw.so.5.7
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libmng.so.1 -> libmng.so.1.0.0
-rwxr-xr-x. 1 root root 472080 Nov 11 2010 libmng.so.1.0.0
lrwxrwxrwx. 1 root root 16 Feb 26 2014 libmpfr.so.1 -> libmpfr.so.1.2.0
-rwxr-xr-x 1 root root 321064 Nov 11 2010 libmpfr.so.1.2.0
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libmp.so.3 -> libmp.so.3.1.14
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libm.so -> ../../lib64/libm.so.6
lrwxrwxrwx 1 root root 23 May 6 2014 libndr-krb5pac.so.0 -> libndr-krb5pac.so.0.0.1
-rwxr-xr-x 1 root root 41152 Apr 9 2014 libndr-krb5pac.so.0.0.1
lrwxrwxrwx 1 root root 19 May 6 2014 libndr-nbt.so.0 -> libndr-nbt.so.0.0.1
-rwxr-xr-x 1 root root 86336 Apr 9 2014 libndr-nbt.so.0.0.1
lrwxrwxrwx 1 root root 15 May 6 2014 libndr.so.0 -> libndr.so.0.0.1
-rwxr-xr-x 1 root root 84936 Apr 9 2014 libndr.so.0.0.1
lrwxrwxrwx 1 root root 24 May 6 2014 libndr-standard.so.0 -> libndr-standard.so.0.0.1
-rwxr-xr-x 1 root root 3190328 Apr 9 2014 libndr-standard.so.0.0.1
lrwxrwxrwx 1 root root 14 May 6 2014 libnetapi.so -> libnetapi.so.0
-rwxr-xr-x 1 root root 6740536 Mar 25 2014 libnetapi.so.0
lrwxrwxrwx 1 root root 25 May 6 2014 libnetsnmpagent.so.20 -> libnetsnmpagent.so.20.0.0
-rwxr-xr-x 1 root root 302448 Mar 24 2014 libnetsnmpagent.so.20.0.0
lrwxrwxrwx 1 root root 27 May 6 2014 libnetsnmphelpers.so.20 -> libnetsnmphelpers.so.20.0.0
-rwxr-xr-x 1 root root 153544 Mar 24 2014 libnetsnmphelpers.so.20.0.0
lrwxrwxrwx 1 root root 24 May 6 2014 libnetsnmpmibs.so.20 -> libnetsnmpmibs.so.20.0.0
-rwxr-xr-x 1 root root 1684256 Mar 24 2014 libnetsnmpmibs.so.20.0.0
lrwxrwxrwx 1 root root 20 May 6 2014 libnetsnmp.so.20 -> libnetsnmp.so.20.0.0
-rwxr-xr-x 1 root root 674784 Mar 24 2014 libnetsnmp.so.20.0.0
lrwxrwxrwx 1 root root 25 May 6 2014 libnetsnmptrapd.so.20 -> libnetsnmptrapd.so.20.0.0
-rwxr-xr-x 1 root root 42904 Mar 24 2014 libnetsnmptrapd.so.20.0.0
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libnewt.so.0.52 -> libnewt.so.0.52.11
-rwxr-xr-x. 1 root root 86288 Sep 23 2011 libnewt.so.0.52.11
drwxr-xr-x. 2 root root 4096 Feb 24 2014 libnfsidmap
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libnfsidmap.so.0 -> libnfsidmap.so.0.3.0
-rwxr-xr-x. 1 root root 27520 Feb 21 2013 libnfsidmap.so.0.3.0
lrwxrwxrwx. 1 root root 23 Feb 24 2014 libnsl.so -> ../../lib64/libnsl.so.1
-rwxr-xr-x. 1 root root 1299096 Feb 11 2014 libnss3.so
lrwxrwxrwx. 1 root root 38 Feb 24 2014 libnssckbi.so -> /etc/alternatives/libnssckbi.so.x86_64
lrwxrwxrwx. 1 root root 27 Feb 24 2014 libnss_compat_ossl.so.0 -> libnss_compat_ossl.so.0.0.0
-rwxr-xr-x 1 root root 84704 Jul 5 2011 libnss_compat_ossl.so.0.0.0
lrwxrwxrwx. 1 root root 30 Feb 24 2014 libnss_compat.so -> ../../lib64/libnss_compat.so.2
-rw-r--r-- 1 root root 899 Apr 14 2014 libnssdbm3.chk
-rwxr-xr-x 1 root root 165552 Apr 14 2014 libnssdbm3.so
lrwxrwxrwx. 1 root root 27 Feb 24 2014 libnss_dns.so -> ../../lib64/libnss_dns.so.2
lrwxrwxrwx. 1 root root 29 Feb 24 2014 libnss_files.so -> ../../lib64/libnss_files.so.2
lrwxrwxrwx. 1 root root 30 Feb 24 2014 libnss_hesiod.so -> ../../lib64/libnss_hesiod.so.2
lrwxrwxrwx. 1 root root 31 Feb 24 2014 libnss_nisplus.so -> ../../lib64/libnss_nisplus.so.2
lrwxrwxrwx. 1 root root 27 Feb 24 2014 libnss_nis.so -> ../../lib64/libnss_nis.so.2
-rwxr-xr-x. 1 root root 150744 Feb 11 2014 libnsspem.so
-rwxr-xr-x. 1 root root 10352 Feb 11 2014 libnsssysinit.so
-rwxr-xr-x. 1 root root 182112 Dec 12 2013 libnssutil3.so
lrwxrwxrwx 1 root root 26 May 6 2014 libnss_winbind.so -> /lib64/libnss_winbind.so.2
lrwxrwxrwx 1 root root 23 May 6 2014 libnss_wins.so -> /lib64/libnss_wins.so.2
-rwxr-xr-x. 1 root root 38872 Nov 22 2013 libnuma.so.1
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libogg.so.0 -> libogg.so.0.6.0
-rwxr-xr-x. 1 root root 25520 Aug 18 2010 libogg.so.0.6.0
lrwxrwxrwx. 1 root root 19 Feb 24 2014 liboil-0.3.so.0 -> liboil-0.3.so.0.3.0
-rwxr-xr-x. 1 root root 582952 Aug 19 2010 liboil-0.3.so.0.3.0
-rwxr-xr-x. 1 root root 990040 Feb 21 2013 libopcodes-2.20.51.0.2-5.36.el6.so
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libopenjpeg.so.2 -> libopenjpeg.so.2.1.3.0
-rwxr-xr-x. 1 root root 128592 Dec 17 2013 libopenjpeg.so.2.1.3.0
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libp11-kit.so.0 -> libp11-kit.so.0.0.0
-rwxr-xr-x 1 root root 134304 Jan 28 2014 libp11-kit.so.0.0.0
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libpanel.so.5 -> libpanel.so.5.7
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libpanelw.so.5 -> libpanelw.so.5.7
-rwxr-xr-x. 1 root root 14032 Aug 18 2010 libpanelw.so.5.7
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libpango-1.0.so.0 -> libpango-1.0.so.0.2800.1
-rwxr-xr-x 1 root root 310240 Nov 28 2012 libpango-1.0.so.0.2800.1
lrwxrwxrwx. 1 root root 29 Feb 24 2014 libpangocairo-1.0.so.0 -> libpangocairo-1.0.so.0.2800.1
-rwxr-xr-x 1 root root 52144 Nov 28 2012 libpangocairo-1.0.so.0.2800.1
lrwxrwxrwx. 1 root root 27 Feb 24 2014 libpangoft2-1.0.so.0 -> libpangoft2-1.0.so.0.2800.1
-rwxr-xr-x 1 root root 176240 Nov 28 2012 libpangoft2-1.0.so.0.2800.1
lrwxrwxrwx. 1 root root 25 Feb 24 2014 libpangox-1.0.so.0 -> libpangox-1.0.so.0.2800.1
-rwxr-xr-x 1 root root 53376 Nov 28 2012 libpangox-1.0.so.0.2800.1
lrwxrwxrwx. 1 root root 27 Feb 24 2014 libpangoxft-1.0.so.0 -> libpangoxft-1.0.so.0.2800.1
-rwxr-xr-x 1 root root 35104 Nov 28 2012 libpangoxft-1.0.so.0.2800.1
lrwxrwxrwx. 1 root root 18 Feb 26 2014 libpano13.so.2 -> libpano13.so.2.0.0
-rwxr-xr-x 1 root root 499528 Mar 31 2013 libpano13.so.2.0.0
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libpath_utils.so.1 -> libpath_utils.so.1.0.0
-rwxr-xr-x. 1 root root 13864 Jun 22 2012 libpath_utils.so.1.0.0
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libpcap.so.1 -> libpcap.so.1.4.0
-rwxr-xr-x. 1 root root 260880 Nov 22 2013 libpcap.so.1.4.0
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libpciaccess.so.0 -> libpciaccess.so.0.11.1
-rwxr-xr-x. 1 root root 8816 Nov 21 2013 libpcprofile.so
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libpcrecpp.so.0 -> libpcrecpp.so.0.0.0
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libpcreposix.so.0 -> libpcreposix.so.0.0.0
-rwxr-xr-x. 1 root root 9656 Sep 7 2012 libpcreposix.so.0.0.0
-rwxr-xr-x 1 root root 209880 Apr 9 2014 libpdb.so.0
lrwxrwxrwx 1 root root 17 May 6 2014 libpgtypes.so.3 -> libpgtypes.so.3.1
-rwxr-xr-x 1 root root 64976 Feb 25 2014 libpgtypes.so.3.1
lrwxrwxrwx 1 root root 18 May 6 2014 libphonon.so.4 -> libphonon.so.4.3.1
lrwxrwxrwx 1 root root 18 May 6 2014 libphonon.so.4.3 -> libphonon.so.4.3.1
-rwxr-xr-x 1 root root 303976 Feb 24 2014 libphonon.so.4.3.1
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libpixman-1.so.0 -> libpixman-1.so.0.26.2
-rwxr-xr-x. 1 root root 560200 Dec 20 2013 libpixman-1.so.0.26.2
lrwxrwxrwx. 1 root root 27 Feb 24 2014 libply-boot-client.so.2 -> libply-boot-client.so.2.0.0
lrwxrwxrwx. 1 root root 18 Feb 26 2014 libpng12.so -> libpng12.so.0.49.0
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libpng12.so.0 -> libpng12.so.0.49.0
-rwxr-xr-x. 1 root root 157960 Apr 25 2012 libpng12.so.0.49.0
lrwxrwxrwx. 1 root root 11 Feb 26 2014 libpng.so -> libpng12.so
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libpng.so.3 -> libpng.so.3.49.0
-rwxr-xr-x. 1 root root 168616 Apr 25 2012 libpng.so.3.49.0
lrwxrwxrwx. 1 root root 26 Feb 24 2014 libpolkit-agent-1.so.0 -> libpolkit-agent-1.so.0.0.0
-rwxr-xr-x. 1 root root 90712 Sep 19 2013 libpolkit-agent-1.so.0.0.0
lrwxrwxrwx. 1 root root 28 Feb 24 2014 libpolkit-backend-1.so.0 -> libpolkit-backend-1.so.0.0.0
-rwxr-xr-x 1 root root 270368 Sep 19 2013 libpolkit-backend-1.so.0.0.0
lrwxrwxrwx. 1 root root 28 Feb 24 2014 libpolkit-gobject-1.so.0 -> libpolkit-gobject-1.so.0.0.0
-rwxr-xr-x 1 root root 146000 Sep 19 2013 libpolkit-gobject-1.so.0.0.0
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libpoppler.so.5 -> libpoppler.so.5.0.0
-rwxr-xr-x. 1 root root 1947720 Jun 24 2011 libpoppler.so.5.0.0
lrwxrwxrwx. 1 root root 17 Feb 26 2014 libppl_c.so.2 -> libppl_c.so.2.1.0
-rwxr-xr-x 1 root root 3566576 Nov 11 2010 libppl_c.so.2.1.0
lrwxrwxrwx. 1 root root 15 Feb 26 2014 libppl.so.7 -> libppl.so.7.1.0
-rwxr-xr-x 1 root root 750600 Nov 11 2010 libppl.so.7.1.0
lrwxrwxrwx 1 root root 12 May 6 2014 libpq.so.5 -> libpq.so.5.2
-rwxr-xr-x 1 root root 166032 Feb 25 2014 libpq.so.5.2
drwxr-xr-x. 3 root root 4096 Feb 24 2014 libproxy
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libproxy.so.0 -> libproxy.so.0.0.0
-rwxr-xr-x. 1 root root 32656 Feb 20 2013 libproxy.so.0.0.0
-rw-r--r--. 1 root root 1780 Nov 21 2013 libpthread_nonshared.a
-rw-r--r--. 1 root root 222 Nov 21 2013 libpthread.so
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libpth.so.20 -> libpth.so.20.0.27
-rwxr-xr-x. 1 root root 80176 Nov 11 2010 libpth.so.20.0.27
-rwxr-xr-x. 1 root root 323352 Jul 12 2012 libpulsecommon-0.9.21.so
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libpulse-simple.so.0 -> libpulse-simple.so.0.0.3
-rwxr-xr-x. 1 root root 15416 Jul 12 2012 libpulse-simple.so.0.0.3
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libpulse.so.0 -> libpulse.so.0.12.2
-rwxr-xr-x. 1 root root 271256 Jul 12 2012 libpulse.so.0.12.2
lrwxrwxrwx. 1 root root 25 Feb 24 2014 libpytalloc-util.so.2 -> libpytalloc-util.so.2.0.7
-rwxr-xr-x. 1 root root 6864 Feb 21 2013 libpytalloc-util.so.2.0.7
-r-xr-xr-x. 1 root root 1672576 Jan 22 2014 libpython2.6.so.1.0
lrwxrwxrwx 1 root root 22 May 6 2014 libQt3Support.so.4 -> libQt3Support.so.4.6.2
lrwxrwxrwx 1 root root 22 May 6 2014 libQt3Support.so.4.6 -> libQt3Support.so.4.6.2
-rwxr-xr-x 1 root root 2964896 Feb 24 2014 libQt3Support.so.4.6.2
lrwxrwxrwx 1 root root 29 May 6 2014 libQtAssistantClient.so.4 -> libQtAssistantClient.so.4.6.2
lrwxrwxrwx 1 root root 29 May 6 2014 libQtAssistantClient.so.4.6 -> libQtAssistantClient.so.4.6.2
-rwxr-xr-x 1 root root 23976 Feb 24 2014 libQtAssistantClient.so.4.6.2
lrwxrwxrwx 1 root root 21 May 6 2014 libQtCLucene.so.4 -> libQtCLucene.so.4.6.2
lrwxrwxrwx 1 root root 21 May 6 2014 libQtCLucene.so.4.6 -> libQtCLucene.so.4.6.2
-rwxr-xr-x 1 root root 912784 Feb 24 2014 libQtCLucene.so.4.6.2
lrwxrwxrwx 1 root root 18 May 6 2014 libQtCore.so.4 -> libQtCore.so.4.6.2
lrwxrwxrwx 1 root root 18 May 6 2014 libQtCore.so.4.6 -> libQtCore.so.4.6.2
-rwxr-xr-x 1 root root 2509168 Feb 24 2014 libQtCore.so.4.6.2
lrwxrwxrwx 1 root root 18 May 6 2014 libQtDBus.so.4 -> libQtDBus.so.4.6.2
lrwxrwxrwx 1 root root 18 May 6 2014 libQtDBus.so.4.6 -> libQtDBus.so.4.6.2
-rwxr-xr-x 1 root root 466344 Feb 24 2014 libQtDBus.so.4.6.2
lrwxrwxrwx 1 root root 32 May 6 2014 libQtDesignerComponents.so.4 -> libQtDesignerComponents.so.4.6.2
lrwxrwxrwx 1 root root 32 May 6 2014 libQtDesignerComponents.so.4.6 -> libQtDesignerComponents.so.4.6.2
-rwxr-xr-x 1 root root 2695056 Feb 24 2014 libQtDesignerComponents.so.4.6.2
lrwxrwxrwx 1 root root 22 May 6 2014 libQtDesigner.so.4 -> libQtDesigner.so.4.6.2
lrwxrwxrwx 1 root root 22 May 6 2014 libQtDesigner.so.4.6 -> libQtDesigner.so.4.6.2
-rwxr-xr-x 1 root root 7191432 Feb 24 2014 libQtDesigner.so.4.6.2
lrwxrwxrwx 1 root root 17 May 6 2014 libQtGui.so.4 -> libQtGui.so.4.6.2
lrwxrwxrwx 1 root root 17 May 6 2014 libQtGui.so.4.6 -> libQtGui.so.4.6.2
-rwxr-xr-x 1 root root 10638536 Feb 24 2014 libQtGui.so.4.6.2
lrwxrwxrwx 1 root root 18 May 6 2014 libQtHelp.so.4 -> libQtHelp.so.4.6.2
lrwxrwxrwx 1 root root 18 May 6 2014 libQtHelp.so.4.6 -> libQtHelp.so.4.6.2
-rwxr-xr-x 1 root root 524744 Feb 24 2014 libQtHelp.so.4.6.2
lrwxrwxrwx 1 root root 24 May 6 2014 libQtMultimedia.so.4 -> libQtMultimedia.so.4.6.2
lrwxrwxrwx 1 root root 24 May 6 2014 libQtMultimedia.so.4.6 -> libQtMultimedia.so.4.6.2
-rwxr-xr-x 1 root root 152264 Feb 24 2014 libQtMultimedia.so.4.6.2
lrwxrwxrwx 1 root root 21 May 6 2014 libQtNetwork.so.4 -> libQtNetwork.so.4.6.2
lrwxrwxrwx 1 root root 21 May 6 2014 libQtNetwork.so.4.6 -> libQtNetwork.so.4.6.2
-rwxr-xr-x 1 root root 1032616 Feb 24 2014 libQtNetwork.so.4.6.2
lrwxrwxrwx 1 root root 20 May 6 2014 libQtOpenGL.so.4 -> libQtOpenGL.so.4.6.2
lrwxrwxrwx 1 root root 20 May 6 2014 libQtOpenGL.so.4.6 -> libQtOpenGL.so.4.6.2
-rwxr-xr-x 1 root root 800000 Feb 24 2014 libQtOpenGL.so.4.6.2
lrwxrwxrwx 1 root root 20 May 6 2014 libQtScript.so.4 -> libQtScript.so.4.6.2
lrwxrwxrwx 1 root root 20 May 6 2014 libQtScript.so.4.6 -> libQtScript.so.4.6.2
-rwxr-xr-x 1 root root 2004872 Feb 24 2014 libQtScript.so.4.6.2
lrwxrwxrwx 1 root root 25 May 6 2014 libQtScriptTools.so.4 -> libQtScriptTools.so.4.6.2
lrwxrwxrwx 1 root root 25 May 6 2014 libQtScriptTools.so.4.6 -> libQtScriptTools.so.4.6.2
-rwxr-xr-x 1 root root 744896 Feb 24 2014 libQtScriptTools.so.4.6.2
lrwxrwxrwx 1 root root 17 May 6 2014 libQtSql.so.4 -> libQtSql.so.4.6.2
lrwxrwxrwx 1 root root 17 May 6 2014 libQtSql.so.4.6 -> libQtSql.so.4.6.2
-rwxr-xr-x 1 root root 248296 Feb 24 2014 libQtSql.so.4.6.2
lrwxrwxrwx 1 root root 17 May 6 2014 libQtSvg.so.4 -> libQtSvg.so.4.6.2
lrwxrwxrwx 1 root root 17 May 6 2014 libQtSvg.so.4.6 -> libQtSvg.so.4.6.2
-rwxr-xr-x 1 root root 348496 Feb 24 2014 libQtSvg.so.4.6.2
lrwxrwxrwx 1 root root 18 May 6 2014 libQtTest.so.4 -> libQtTest.so.4.6.2
lrwxrwxrwx 1 root root 18 May 6 2014 libQtTest.so.4.6 -> libQtTest.so.4.6.2
-rwxr-xr-x 1 root root 139936 Feb 24 2014 libQtTest.so.4.6.2
lrwxrwxrwx 1 root root 25 May 6 2014 libQtXmlPatterns.so.4 -> libQtXmlPatterns.so.4.6.2
lrwxrwxrwx 1 root root 25 May 6 2014 libQtXmlPatterns.so.4.6 -> libQtXmlPatterns.so.4.6.2
-rwxr-xr-x 1 root root 4569624 Feb 24 2014 libQtXmlPatterns.so.4.6.2
lrwxrwxrwx 1 root root 17 May 6 2014 libQtXml.so.4 -> libQtXml.so.4.6.2
lrwxrwxrwx 1 root root 17 May 6 2014 libQtXml.so.4.6 -> libQtXml.so.4.6.2
-rwxr-xr-x 1 root root 275072 Feb 24 2014 libQtXml.so.4.6.2
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libref_array.so.1 -> libref_array.so.1.0.0
-rwxr-xr-x. 1 root root 10088 Jun 22 2012 libref_array.so.1.0.0
lrwxrwxrwx 1 root root 20 May 6 2014 libregistry.so.0 -> libregistry.so.0.0.1
-rwxr-xr-x 1 root root 140520 Apr 9 2014 libregistry.so.0.0.1
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libreport.so.0 -> libreport.so.0.0.1
-rwxr-xr-x 1 root root 97632 Nov 22 2013 libreport.so.0.0.1
lrwxrwxrwx. 1 root root 26 Feb 24 2014 libresolv.so -> ../../lib64/libresolv.so.2
lrwxrwxrwx. 1 root root 21 Feb 24 2014 librpcsecgss.so.3 -> librpcsecgss.so.3.0.0
-rwxr-xr-x. 1 root root 63008 Feb 21 2013 librpcsecgss.so.3.0.0
-rw-r--r--. 1 root root 54974 Nov 21 2013 librpcsvc.a
lrwxrwxrwx. 1 root root 20 Feb 24 2014 librpmbuild.so.1 -> librpmbuild.so.1.0.0
-rwxr-xr-x. 1 root root 158472 Nov 22 2013 librpmbuild.so.1.0.0
lrwxrwxrwx. 1 root root 17 Feb 24 2014 librpmio.so.1 -> librpmio.so.1.0.0
-rwxr-xr-x. 1 root root 186920 Nov 22 2013 librpmio.so.1.0.0
lrwxrwxrwx. 1 root root 15 Feb 24 2014 librpm.so.1 -> librpm.so.1.0.0
-rwxr-xr-x. 1 root root 436736 Nov 22 2013 librpm.so.1.0.0
lrwxrwxrwx. 1 root root 22 Feb 24 2014 librt.so -> ../../lib64/librt.so.1
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libruby.so.1.8 -> libruby.so.1.8.7
-rwxr-xr-x 1 root root 951064 Nov 26 2013 libruby.so.1.8.7
lrwxrwxrwx 1 root root 29 May 6 2014 libsamba-credentials.so.0 -> libsamba-credentials.so.0.0.1
-rwxr-xr-x 1 root root 65696 Apr 9 2014 libsamba-credentials.so.0.0.1
lrwxrwxrwx 1 root root 28 May 6 2014 libsamba-hostconfig.so.0 -> libsamba-hostconfig.so.0.0.1
-rwxr-xr-x 1 root root 225576 Apr 9 2014 libsamba-hostconfig.so.0.0.1
lrwxrwxrwx 1 root root 24 May 6 2014 libsamba-policy.so.0 -> libsamba-policy.so.0.0.1
-rwxr-xr-x 1 root root 54680 Apr 9 2014 libsamba-policy.so.0.0.1
lrwxrwxrwx 1 root root 22 May 6 2014 libsamba-util.so.0 -> libsamba-util.so.0.0.1
-rwxr-xr-x 1 root root 208408 Apr 9 2014 libsamba-util.so.0.0.1
lrwxrwxrwx 1 root root 17 May 6 2014 libsamdb.so.0 -> libsamdb.so.0.0.1
-rwxr-xr-x 1 root root 82760 Apr 9 2014 libsamdb.so.0.0.1
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libsasl2.so.2 -> libsasl2.so.2.0.23
-rwxr-xr-x 1 root root 108728 Nov 27 2012 libsasl2.so.2.0.23
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libSDL-1.2.so.0 -> libSDL-1.2.so.0.11.3
-rwxr-xr-x. 1 root root 453720 Apr 3 2012 libSDL-1.2.so.0.11.3
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libsensors.so.4 -> libsensors.so.4.2.0
-rwxr-xr-x. 1 root root 68608 Sep 25 2012 libsensors.so.4.2.0
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libsgutils2.so.2 -> libsgutils2.so.2.0.0
-rwxr-xr-x. 1 root root 159288 Jun 19 2013 libsgutils2.so.2.0.0
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libslang.so.2 -> libslang.so.2.2.1
-rwxr-xr-x. 1 root root 1092872 Aug 16 2010 libslang.so.2.2.1
lrwxrwxrwx 1 root root 25 May 6 2014 libsmbclient-raw.so.0 -> libsmbclient-raw.so.0.0.1
-rwxr-xr-x 1 root root 219080 Apr 9 2014 libsmbclient-raw.so.0.0.1
-rwxr-xr-x 1 root root 506792 Apr 9 2014 libsmbconf.so.0
-rwxr-xr-x 1 root root 40320 Apr 9 2014 libsmbldap.so.0
-rwxr-xr-x. 1 root root 183928 Feb 11 2014 libsmime3.so
lrwxrwxrwx. 1 root root 14 Feb 24 2014 libSM.so.6 -> libSM.so.6.0.1
-rwxr-xr-x 1 root root 34024 Feb 21 2013 libSM.so.6.0.1
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libsnappy.so.1 -> libsnappy.so.1.1.4
-rwxr-xr-x. 1 root root 22392 Nov 22 2013 libsnappy.so.1.1.4
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libsndfile.so.1 -> libsndfile.so.1.0.20
-rwxr-xr-x. 1 root root 394928 Sep 23 2011 libsndfile.so.1.0.20
lrwxrwxrwx 1 root root 17 May 6 2014 libsnmp.so.20 -> libsnmp.so.20.0.0
-rwxr-xr-x 1 root root 672312 Mar 24 2014 libsnmp.so.20.0.0
-rw-r--r-- 1 root root 899 Apr 14 2014 libsoftokn3.chk
-rwxr-xr-x 1 root root 273128 Apr 14 2014 libsoftokn3.so
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libsqlite3.so.0 -> libsqlite3.so.0.8.6
-rwxr-xr-x. 1 root root 586000 Aug 17 2010 libsqlite3.so.0.8.6
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libssh2.so.1 -> libssh2.so.1.0.1
-rwxr-xr-x 1 root root 164504 Feb 21 2013 libssh2.so.1.0.1
-rwxr-xr-x. 1 root root 252960 Feb 11 2014 libssl3.so
lrwxrwxrwx 1 root root 16 May 6 2014 libssl.so.10 -> libssl.so.1.0.1e
-rwxr-xr-x 1 root root 444040 Apr 7 2014 libssl.so.1.0.1e
-rw-r--r-- 1 root root 65 Apr 7 2014 .libssl.so.1.0.1e.hmac
lrwxrwxrwx 1 root root 22 May 6 2014 .libssl.so.10.hmac -> .libssl.so.1.0.1e.hmac
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libsss_idmap.so.0 -> libsss_idmap.so.0.0.1
-rwxr-xr-x. 1 root root 17216 Jan 6 2014 libsss_idmap.so.0.0.1
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libstdc++.so.6 -> libstdc++.so.6.0.13
-rwxr-xr-x. 1 root root 989840 Nov 21 2013 libstdc++.so.6.0.13
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libtalloc.so.2 -> libtalloc.so.2.0.7
-rwxr-xr-x 1 root root 43760 Feb 21 2013 libtalloc.so.2.0.7
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libtar.so.1 -> libtar.so.1.2.11
-rwxr-xr-x. 1 root root 39000 Oct 10 2013 libtar.so.1.2.11
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libtasn1.so.3 -> libtasn1.so.3.1.6
-rwxr-xr-x. 1 root root 68704 Mar 27 2012 libtasn1.so.3.1.6
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libtdb.so.1 -> libtdb.so.1.2.10
-rwxr-xr-x 1 root root 72040 Feb 21 2013 libtdb.so.1.2.10
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libtevent.so.0 -> libtevent.so.0.9.18
-rwxr-xr-x 1 root root 55472 Nov 22 2013 libtevent.so.0.9.18
lrwxrwxrwx 1 root root 23 May 6 2014 libtevent-util.so.0 -> libtevent-util.so.0.0.1
-rwxr-xr-x 1 root root 8256 Apr 9 2014 libtevent-util.so.0.0.1
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libthai.so.0 -> libthai.so.0.1.4
-rwxr-xr-x. 1 root root 50168 Nov 11 2010 libthai.so.0.1.4
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libtheoradec.so.1 -> libtheoradec.so.1.1.3
-rwxr-xr-x. 1 root root 64888 Nov 11 2010 libtheoradec.so.1.1.3
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libtheoraenc.so.1 -> libtheoraenc.so.1.1.2
-rwxr-xr-x. 1 root root 186936 Nov 11 2010 libtheoraenc.so.1.1.2
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libtheora.so.0 -> libtheora.so.0.3.9
-rwxr-xr-x. 1 root root 213152 Nov 11 2010 libtheora.so.0.3.9
lrwxrwxrwx. 1 root root 29 Feb 24 2014 libthread_db.so -> ../../lib64/libthread_db.so.1
lrwxrwxrwx. 1 root root 13 Feb 24 2014 libtic.so.5 -> libtic.so.5.7
-rwxr-xr-x. 1 root root 79832 Aug 18 2010 libtic.so.5.7
lrwxrwxrwx 1 root root 16 May 6 2014 libtiff.so -> libtiff.so.3.9.4
lrwxrwxrwx 1 root root 16 May 6 2014 libtiff.so.3 -> libtiff.so.3.9.4
-rwxr-xr-x 1 root root 411360 Feb 27 2014 libtiff.so.3.9.4
lrwxrwxrwx 1 root root 18 May 6 2014 libtiffxx.so -> libtiffxx.so.3.9.4
lrwxrwxrwx 1 root root 18 May 6 2014 libtiffxx.so.3 -> libtiffxx.so.3.9.4
-rwxr-xr-x 1 root root 9224 Feb 27 2014 libtiffxx.so.3.9.4
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libtopology.so.0 -> libtopology.so.0.3
-rwxr-xr-x. 1 root root 16888 Aug 17 2010 libtopology.so.0.3
lrwxrwxrwx. 1 root root 17 Feb 24 2014 libungif.so.4 -> libungif.so.4.1.6
-rwxr-xr-x. 1 root root 3640 Nov 11 2010 libungif.so.4.1.6
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libusb-0.1.so.4 -> libusb-0.1.so.4.4.4
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libusb-1.0.so.0 -> libusb-1.0.so.0.1.0
-rwxr-xr-x. 1 root root 63256 Feb 21 2013 libusb-1.0.so.0.1.0
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libusbpp-0.1.so.4 -> libusbpp-0.1.so.4.4.4
drwxr-xr-x. 2 root root 4096 Feb 24 2014 libuser
lrwxrwxrwx. 1 root root 16 Feb 24 2014 libuser.so.1 -> libuser.so.1.2.2
-rwxr-xr-x 1 root root 105624 Apr 5 2012 libuser.so.1.2.2
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libustr-1.0.so.1 -> libustr-1.0.so.1.0.4
-rwxr-xr-x. 1 root root 208416 Aug 18 2010 libustr-1.0.so.1.0.4
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libutempter.so.0 -> libutempter.so.1.1.5
-rwxr-xr-x. 1 root root 9264 Aug 18 2010 libutempter.so.1.1.5
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libutil.so -> ../../lib64/libutil.so.1
lrwxrwxrwx 1 root root 20 May 6 2014 libverto-k5ev.so -> libverto-k5ev.so.0.0
lrwxrwxrwx 1 root root 20 May 6 2014 libverto-k5ev.so.0 -> libverto-k5ev.so.0.0
-rwxr-xr-x 1 root root 55944 Apr 3 2014 libverto-k5ev.so.0.0
lrwxrwxrwx 1 root root 15 May 6 2014 libverto.so -> libverto.so.0.0
lrwxrwxrwx 1 root root 15 May 6 2014 libverto.so.0 -> libverto.so.0.0
-rwxr-xr-x 1 root root 18576 Apr 3 2014 libverto.so.0.0
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libvisual-0.4.so.0 -> libvisual-0.4.so.0.0.0
-rwxr-xr-x. 1 root root 270544 Aug 19 2010 libvisual-0.4.so.0.0.0
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libvorbisenc.so.2 -> libvorbisenc.so.2.0.6
-rwxr-xr-x. 1 root root 1943424 Feb 15 2012 libvorbisenc.so.2.0.6
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libvorbisfile.so.3 -> libvorbisfile.so.3.3.2
-rwxr-xr-x. 1 root root 30576 Feb 15 2012 libvorbisfile.so.3.3.2
lrwxrwxrwx. 1 root root 18 Feb 24 2014 libvorbis.so.0 -> libvorbis.so.0.4.3
-rwxr-xr-x. 1 root root 184360 Feb 15 2012 libvorbis.so.0.4.3
-rwxr-xr-x 1 root root 51560 Mar 25 2014 libwbclient.so.0
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libX11.so.6 -> libX11.so.6.3.0
-rwxr-xr-x. 1 root root 1300376 Feb 21 2013 libX11.so.6.3.0
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libX11-xcb.so.1 -> libX11-xcb.so.1.0.0
-rwxr-xr-x. 1 root root 4064 Feb 21 2013 libX11-xcb.so.1.0.0
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libXau.so.6 -> libXau.so.6.0.0
-rwxr-xr-x. 1 root root 13168 Feb 21 2013 libXau.so.6.0.0
lrwxrwxrwx. 1 root root 25 Feb 24 2014 libxcb-composite.so.0 -> libxcb-composite.so.0.0.0
-rwxr-xr-x. 1 root root 8976 Feb 21 2013 libxcb-composite.so.0.0.0
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libxcb-damage.so.0 -> libxcb-damage.so.0.0.0
-rwxr-xr-x. 1 root root 6992 Feb 21 2013 libxcb-damage.so.0.0.0
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libxcb-dpms.so.0 -> libxcb-dpms.so.0.0.0
-rwxr-xr-x. 1 root root 8304 Feb 21 2013 libxcb-dpms.so.0.0.0
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libxcb-dri2.so.0 -> libxcb-dri2.so.0.0.0
-rwxr-xr-x. 1 root root 15712 Feb 21 2013 libxcb-dri2.so.0.0.0
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libxcb-glx.so.0 -> libxcb-glx.so.0.0.0
-rwxr-xr-x. 1 root root 91840 Feb 21 2013 libxcb-glx.so.0.0.0
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libxcb-randr.so.0 -> libxcb-randr.so.0.1.0
-rwxr-xr-x. 1 root root 41520 Feb 21 2013 libxcb-randr.so.0.1.0
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libxcb-record.so.0 -> libxcb-record.so.0.0.0
-rwxr-xr-x. 1 root root 12896 Feb 21 2013 libxcb-record.so.0.0.0
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libxcb-render.so.0 -> libxcb-render.so.0.0.0
-rwxr-xr-x. 1 root root 37424 Feb 21 2013 libxcb-render.so.0.0.0
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libxcb-res.so.0 -> libxcb-res.so.0.0.0
-rwxr-xr-x. 1 root root 8000 Feb 21 2013 libxcb-res.so.0.0.0
lrwxrwxrwx. 1 root root 27 Feb 24 2014 libxcb-screensaver.so.0 -> libxcb-screensaver.so.0.0.0
-rwxr-xr-x. 1 root root 7928 Feb 21 2013 libxcb-screensaver.so.0.0.0
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libxcb-shape.so.0 -> libxcb-shape.so.0.0.0
-rwxr-xr-x. 1 root root 11344 Feb 21 2013 libxcb-shape.so.0.0.0
lrwxrwxrwx. 1 root root 19 Feb 24 2014 libxcb-shm.so.0 -> libxcb-shm.so.0.0.0
-rwxr-xr-x. 1 root root 7952 Feb 21 2013 libxcb-shm.so.0.0.0
lrwxrwxrwx. 1 root root 15 Feb 24 2014 libxcb.so.1 -> libxcb.so.1.1.0
-rwxr-xr-x. 1 root root 124728 Feb 21 2013 libxcb.so.1.1.0
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libxcb-sync.so.0 -> libxcb-sync.so.0.0.0
-rwxr-xr-x. 1 root root 17856 Feb 21 2013 libxcb-sync.so.0.0.0
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libxcb-xevie.so.0 -> libxcb-xevie.so.0.0.0
-rwxr-xr-x. 1 root root 7664 Feb 21 2013 libxcb-xevie.so.0.0.0
lrwxrwxrwx. 1 root root 23 Feb 24 2014 libxcb-xf86dri.so.0 -> libxcb-xf86dri.so.0.0.0
-rwxr-xr-x. 1 root root 13968 Feb 21 2013 libxcb-xf86dri.so.0.0.0
lrwxrwxrwx. 1 root root 22 Feb 24 2014 libxcb-xfixes.so.0 -> libxcb-xfixes.so.0.0.0
-rwxr-xr-x. 1 root root 25056 Feb 21 2013 libxcb-xfixes.so.0.0.0
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libxcb-xinerama.so.0 -> libxcb-xinerama.so.0.0.0
-rwxr-xr-x. 1 root root 8496 Feb 21 2013 libxcb-xinerama.so.0.0.0
lrwxrwxrwx. 1 root root 24 Feb 24 2014 libxcb-xselinux.so.0 -> libxcb-xselinux.so.0.0.0
-rwxr-xr-x. 1 root root 28656 Feb 21 2013 libxcb-xselinux.so.0.0.0
lrwxrwxrwx. 1 root root 21 Feb 24 2014 libxcb-xtest.so.0 -> libxcb-xtest.so.0.0.0
-rwxr-xr-x. 1 root root 6944 Feb 21 2013 libxcb-xtest.so.0.0.0
lrwxrwxrwx. 1 root root 20 Feb 24 2014 libxcb-xvmc.so.0 -> libxcb-xvmc.so.0.0.0
-rwxr-xr-x. 1 root root 12656 Feb 21 2013 libxcb-xvmc.so.0.0.0
brandon.pal
Posts: 129 Joined: Wed Feb 19, 2014 10:18 pm
Post
by brandon.pal » Fri Jan 29, 2016 11:59 am
ls -al /usr/lib64/nagios/
total 48
drwxr-xr-x. 3 root root 4096 Feb 24 2014 .
dr-xr-xr-x. 53 root root 36864 May 7 2014 ..
drwxrwxr-x. 3 root root 4096 Dec 30 11:43 plugins
ls -al /usr/lib64/nagios/plugins/
total 3356
drwxrwxr-x. 3 root root 4096 Dec 30 11:43 .
drwxr-xr-x. 3 root root 4096 Feb 24 2014 ..
-rwxr-xr-x 1 root root 2683 Nov 18 16:26 activemq_watch.pl
-rwxr-xr-x 1 root root 682 Jun 19 2015 check_activetcp.sh
-rwxr-xr-x 1 root root 353 Jun 17 2014 check_all_diskstat.sh
-rwxr-xr-x 1 root root 7654 Jun 20 2014 check_apache.pl
-rwxr-xr-x 1 root root 1694 Jul 10 2014 check_apacheWraper.sh
-rwxr-xr-x. 1 root root 2253 Oct 17 2013 check_breeze
-rwxr-xr-x. 1 root root 58272 Oct 17 2013 check_by_ssh
-rwxr-xr-x 1 root root 1975 Jun 17 2014 check_cdmsq.sh
-rwxr-xr-x 1 root root 2953 Jun 17 2014 check_cdms.sh
lrwxrwxrwx. 1 root root 9 Feb 24 2014 check_clamd -> check_tcp
-rwxr-xr-x. 1 root root 41568 Oct 17 2013 check_cluster
-rwxr-xr-x 1 root root 3832 Aug 12 2014 check_cpu.sh
-rwxr-xr-x 1 root root 5438 May 26 2014 check_cpu_stats.sh
-rwsr-x---. 1 root nagios 56256 Oct 17 2013 check_dhcp
-rwxr-xr-x. 1 root root 52520 Oct 17 2013 check_dig
-rwxr-xr-x. 1 root root 128736 Oct 17 2013 check_disk
-rwxr-xr-x 1 root root 1955 Jul 24 2014 check_disk_io.sh
-rwxr-xr-x. 1 root root 9147 Oct 17 2013 check_disk_smb
-rwxr-xr-x 1 root root 2398 Dec 29 2014 check_diskSpace.sh
-rwxr-xr-x 1 root root 4835 Jun 17 2014 check_diskstat.sh
-rwxr-xr-x. 1 root root 56704 Oct 17 2013 check_dns
-rwxr-xr-x. 1 root root 33608 Oct 17 2013 check_dummy
-rwxr-xr-x 1 root root 4530 Mar 31 2015 check_excc.sh
-rwxr-xr-x 1 root root 2389 May 26 2014 check_exc_notify.sh
-rwxr-xr-x 1 root root 2769 May 26 2014 check_exc_query.sh
-rwxr-xr-x 1 root root 1847 Jul 15 2014 check_exc.sh
-rwxr-xr-x. 1 root root 3055 Oct 17 2013 check_file_age
-rwxr-xr-x. 1 root root 6317 Oct 17 2013 check_flexlm
-rwsr-x---. 1 root nagios 54840 Oct 17 2013 check_fping
lrwxrwxrwx. 1 root root 9 Feb 24 2014 check_ftp -> check_tcp
-rwxr-xr-x. 1 root root 46288 Oct 17 2013 check_game
-rwxr-xr-x 1 root root 1851 Jun 17 2014 check_haproxy.sh
-rwxr-xr-x. 1 root root 52416 Oct 17 2013 check_hpjd
-rwxr-xr-x 1 root root 183208 Oct 17 2013 check_http
-rwsr-x---. 1 root nagios 61336 Oct 17 2013 check_icmp
-rwsr-x---. 1 root nagios 44792 Oct 17 2013 check_ide_smart
-rwxr-xr-x 1 root root 5470 Aug 15 2014 check_ifutil.pl
lrwxrwxrwx. 1 root root 9 Feb 24 2014 check_imap -> check_tcp
-rwxr-xr-x 1 root root 3458 Jul 15 2014 check_ims.sh
-rwxr-xr-x 1 root root 748 May 26 2014 check_init_service
-rwxr-xr-x. 1 root root 6889 Oct 17 2013 check_ircd
lrwxrwxrwx. 1 root root 9 Feb 24 2014 check_jabber -> check_tcp
-rwxr-xr-x 1 root root 57 Jun 17 2014 check_java.conf
-rw-r--r-- 1 root root 60 Jun 17 2014 check_java.curline
-rw-r--r-- 1 root root 1 Jun 17 2014 check_java.incremental.log
-rw-r--r-- 1 root root 60 Jun 17 2014 check_java.oldline
-rwxr-xr-x 1 root root 2877 Jun 17 2014 check_java.SH
-rwxr-xr-x 1 root root 2247 Jul 8 2015 check_java.sh
-rwxr-xr-x 1 root root 9213 Jul 27 2015 check_jbossPool.sh
-rwxr-xr-x 1 root root 8833 Aug 6 14:40 check_jstat.sh
-rwxr-xr-x 1 root root 1058 Jun 19 2014 check_lbpool.sh
-rwxr-xr-x 1 root root 55024 Oct 17 2013 check_ldap
lrwxrwxrwx. 1 root root 10 Feb 24 2014 check_ldaps -> check_ldap
-rwxr-xr-x 1 root root 77810 May 26 2014 check_load
-rwxr-xr-x. 1 root root 6020 Oct 17 2013 check_log
-rwxr-xr-x. 1 root root 20286 Oct 17 2013 check_mailq
-rwxr-xr-x 1 root root 3395 Nov 20 2014 check_mem
-rwxr-xr-x 1 root root 58456 Nov 13 2014 check_mongodb.py
-rwxr-xr-x 1 root root 10573 May 26 2014 check_mountpoints.sh
-rwxr-xr-x 1 root root 1561 Jun 18 2014 check_mq.sh
-rwxr-xr-x. 1 root root 45192 Oct 17 2013 check_mrtg
-rwxr-xr-x. 1 root root 44680 Oct 17 2013 check_mrtgtraf
-rwxr-xr-x 1 root root 1986 Aug 8 2014 check_multiProcs.sh
-rwxr-xr-x 1 root root 65168 Oct 17 2013 check_mysql
-rwxr-xr-x 1 root root 61392 Oct 17 2013 check_mysql_query
-rwxr-xr-x 1 root root 2683 Oct 1 2014 check_mysql.sh
-rwxr-xr-x. 1 root root 46384 Oct 17 2013 check_nagios
-rwxr-xr-x 1 root root 25602 May 26 2014 check_netstat.pl
-rwxr-xr-x 1 root root 529 Jul 15 2014 check_nfs.sh
lrwxrwxrwx. 1 root root 9 Feb 24 2014 check_nntp -> check_tcp
lrwxrwxrwx. 1 root root 9 Feb 24 2014 check_nntps -> check_tcp
-rwxr-xr-x. 1 root root 59840 Oct 17 2013 check_nt
-rwxr-xr-x. 1 root root 58560 Oct 17 2013 check_ntp
-rwxr-xr-x. 1 root root 56256 Oct 17 2013 check_ntp_peer
-rwxr-xr-x. 1 root root 14283 Oct 17 2013 check_ntp.pl
-rwxr-xr-x. 1 root root 53512 Oct 17 2013 check_ntp_time
-rwxr-xr-x. 1 root root 70656 Oct 17 2013 check_nwstat
-rwxr-xr-x 1 root root 3089 Aug 4 13:57 check_oms.sh
-rwxr-xr-x 1 root root 3260 May 26 2014 check_open_files.pl
-rwxr-xr-x. 1 root root 8324 Oct 17 2013 check_oracle
-rwxr-xr-x. 1 root root 50848 Oct 17 2013 check_overcr
-rwxr-xr-x 1 root root 58808 Oct 17 2013 check_pgsql
-rwxr-xr-x. 1 root root 59704 Oct 17 2013 check_ping
lrwxrwxrwx. 1 root root 9 Feb 24 2014 check_pop -> check_tcp
-rwxr-xr-x 1 root root 372120 May 26 2014 check_procs
-rwxr-xr-x 1 root root 500 Jun 9 2014 check_procs.sh
-rwxr-xr-x. 1 root root 50152 Oct 17 2013 check_real
-rwxr-xr-x. 1 root root 9583 Oct 17 2013 check_rpc
-rwxr-xr-x. 1 root root 1412 Oct 17 2013 check_sensors
-rwxr-xr-x 1 root root 2174 May 26 2014 check_services
lrwxrwxrwx. 1 root root 9 Feb 24 2014 check_simap -> check_tcp
-rwxr-xr-x 1 root root 143984 Oct 17 2013 check_smtp
-rwxr-xr-x. 1 root root 162600 Oct 17 2013 check_snmp
lrwxrwxrwx. 1 root root 9 Feb 24 2014 check_spop -> check_tcp
-rwxr-xr-x. 1 root root 47520 Oct 17 2013 check_ssh
lrwxrwxrwx. 1 root root 9 Feb 24 2014 check_ssmtp -> check_tcp
-rwxr-xr-x. 1 root root 48464 Oct 17 2013 check_swap
-rwxr-xr-x 1 root root 67368 Oct 17 2013 check_tcp
-rwxr-xr-x. 1 root root 49328 Oct 17 2013 check_time
-rwxr-xr-x 1 root root 6622 Aug 4 15:36 check_tungsten.sh
-rwxr-xr-x 1 root root 1920 May 26 2014 check_tungsten.sh.bk
-rwxr-xr-x 1 root root 3669 Oct 7 2014 check_tungsten_status.sh
lrwxrwxrwx. 1 root root 9 Feb 24 2014 check_udp -> check_tcp
-rwxr-xr-x. 1 root root 55112 Oct 17 2013 check_ups
-rwxr-xr-x 1 root root 73555 May 26 2014 check_users
-rwxr-xr-x 1 root root 6173 Jul 30 2014 check_varnish.pl
-rwxr-xr-x 1 root root 4725 Dec 30 11:43 check_varnish.sh
-rwxr-xr-x. 1 root root 2938 Oct 17 2013 check_wave
-rwxr-xr-x 1 root root 3060 May 26 2014 custom_check_mem
-rwxr-xr-x 1 root root 915 May 26 2014 custom_check_procs
-rwxr-xr-x 1 root root 97 May 26 2014 info_fstab
-rwxr-xr-x. 1 root root 43360 Oct 17 2013 negate
drwxr-xr-x 2 nrpe nrpe 4096 Jul 24 2014 tmp
-rwxr-xr-x. 1 root root 39928 Oct 17 2013 urlize
-rw-r--r--. 1 root root 2091 Oct 17 2013 utils.pm
-rwxr-xr-x. 1 root root 2728 Oct 17 2013 utils.sh
ls -al /usr/lib64/nagios/plugins/tmp/
total 32
drwxr-xr-x 2 nrpe nrpe 4096 Jul 24 2014 .
drwxrwxr-x. 3 root root 4096 Dec 30 11:43 ..
-rw-r--r-- 1 nrpe nrpe 424 Jan 29 11:53 .check_disk_io
-rw-r--r-- 1 nrpe nrpe 576 Jul 24 2014 .check_disk_io_inodes
-rw-r--r-- 1 nrpe nrpe 264 Jan 29 11:55 .check_disk_io_inodes2
-rw-r--r-- 1 nrpe nrpe 212 Jan 29 11:53 .check_disk_io_results
-rw-r--r-- 1 nrpe nrpe 0 Jul 8 2015 java.errorlog
-rw-r--r-- 1 nrpe nrpe 0 Jul 9 2015 java.out
-rw-r--r-- 1 nrpe nrpe 229 Jan 29 11:52 .multiProc.checkDetials
-rw-r--r-- 1 nrpe nrpe 1347 Jan 29 11:52 .multiProc.output
Posts: 9190 Joined: Thu Oct 30, 2014 9:02 am
Post
by tgriep » Fri Jan 29, 2016 2:02 pm
Can you login to the XI GUI, go to Core Config Manager > Service, find one of the service checks that if having the issue, click on the floppy icon so you can view the settings, copy it and post it here so we can view it.
Can you run the check from a command prompt on the XI server and show the output here?
Be sure to check out our
Knowledgebase for helpful articles and solutions!
brandon.pal
Post
by brandon.pal » Tue Feb 02, 2016 10:22 pm
We have found the issue.
The VictorOps config file had "process perf data = 1". We have set it to 0 and our graphs are now back.
Posts: 13589 Joined: Mon May 23, 2011 12:15 pm
Post
by lmiltchev » Wed Feb 03, 2016 9:59 am
I am glad your issues has been resolved. I will be locking this topic now. If you have any more questions/issues, please start a new thread.
bwallace
Posts: 1145 Joined: Tue Nov 17, 2015 1:57 pm
Post
by bwallace » Wed Feb 03, 2016 10:00 am
Thanks for that update and glad to hear you found the issue. Did you have any other questions or may we lock this thread?
Be sure to check out the
