Lookback period issue regression in 1.4
weveland
Re: Lookback period issue regression in 1.4
Post by weveland »
Well Stallman is silly hipster hippie so there!
Umm no, plenty of disk space.
[root@nagiosls ~]# df -h
Filesystem      Size  Used Avail Use% Mounted on
rootfs             99G   58G   40G  60%   /
devtmpfs        16G  156K   16G   1%   /dev
tmpfs             16G     0      16G   0%   /dev/shm
/dev/sda1      99G   58G   40G  60%   /
/dev/sdb     1008G 106G  852G 12%   /logdump
/dev/sdc       739G   47G  655G  7%   /backups
(Can't we just get a fixed-width font here, for the love of all that is holy???)
weveland
Post by weveland »
I know what I said was tantamount to blasphemy. But I said it. So there!
weveland
Post by weveland »
Oh come on guys. I didn't upset you that much did I?
jolson
Attack Rabbit
Post by jolson »
It hurt so much that I switched from vim to emacs :(
I don't know what's wrong with the Administration page - there are no obvious problems. My best guess is that the kibana-int database is somehow different than it was before this happened - was there a particular event that caused this to begin failing?
I'd like you to backup your config backups just in case we wind up needing to restore to one of them:
cp /store/backups/nagioslogserver/* ~
Could I have you open a second thread for this issue? We can tackle the lookback regression here, and then we can tackle the disappearing Administration screen in the second thread. Thanks Wayne!
Twits Blog
weveland
Post by weveland »
emacs, bloody hell. I'm sorry but we can't be friends anymore.
What's next? Windows??
Sigh..
I will open a new topic.
jolson
Attack Rabbit
Post by jolson »
Regarding the alert misses, I think that it would be a good idea to disable your backup system for a few days (set the interval to 3 days or so under Administration -> Command Subsystem). After the backups have been paused, I'm interested in seeing if the alert subsystem continues to misfire. I am wondering if the new backup system interferes with the alert subsystem.
Thanks Wayne!
Twits Blog
weveland
Post by weveland »
I'd love to. But the Administration panel is missing remember?
-W
jolson
Attack Rabbit
Post by jolson »
I do - so we'll get that fixed before proceeding with the lookback regression. Now that we have a theory I'll see if I can't replicate the problem in the lab while we work on the Administration panel.
Twits Blog
weveland
Post by weveland »
Gentlemen,
Changing the PHP max ram allocation didn't fix the issue. The alert still fired this morning around the same timeframe.
Down 6:45 AM - Recovery 7:00AM
jolson
Attack Rabbit
Post by jolson »
Alright, in that case could you temporarily disable your backup system from firing - for perhaps a day or so to see whether or not the backup system is impacting the alert subsystem. Go to the command subsystem and schedule the backup_maintenance command a few days out to accomplish this - if that doesn't help we'll investigate why. Thanks!
Twits Blog
