SERVICE_NAME=KCTCQA.konecranes.comCode: Select all
--connect '10.x.x.237:1521/KCTCQA'Code: Select all
--connect '10.x.x.237:1521/KCTCQA.konecranes.com'Code: Select all
--connect '10.x.x.237:1521/KCTCQA.konecranes.com'Same host unreachable (thank you for the finding) :-\lmiltchev wrote:In the "tnsnames.ora" file you have:but in your command you use:Code: Select all
SERVICE_NAME=KCTCQA.konecranes.comThe service name needs to match... Try using:Code: Select all
Re-confirmed some things and was able to read Oracle server connection time: WARNING - 1.24 seconds to connect as nagiosxilmiltchev wrote:Hm-m, have you tried connecting to another Oracle host? Let us know what the Oracle Admin had to say. We will keep the thread open.
create user nagios identified by oradbmon;
grant create session to nagios;
grant select any dictionary to nagios;
grant select on V_$SYSSTAT to nagios;
grant select on V_$INSTANCE to nagios;
grant select on V_$LOG to nagios;
grant select on SYS.DBA_DATA_FILES to nagios;
grant select on SYS.DBA_FREE_SPACE to nagios;Code: Select all
grant select on sys.dba_tablespaces to nagios;
grant select on dba_temp_files to nagios;
grant select on sys.v_$Temp_extent_pool to nagios;
grant select on sys.v_$TEMP_SPACE_HEADER to nagios;
grant select on sys.v_$session to nagios;lmiltchev wrote:You will need to check with your Oracle admin to make sure that the user has sufficient privileges. I found some examples of how to set up a user with specific privileges, required for collecting the information from the database.-- if somebody still uses Oracle 8.1.7...Code: Select all
create user nagios identified by oradbmon; grant create session to nagios; grant select any dictionary to nagios; grant select on V_$SYSSTAT to nagios; grant select on V_$INSTANCE to nagios; grant select on V_$LOG to nagios; grant select on SYS.DBA_DATA_FILES to nagios; grant select on SYS.DBA_FREE_SPACE to nagios;Hope this helps.Code: Select all
grant select on sys.dba_tablespaces to nagios; grant select on dba_temp_files to nagios; grant select on sys.v_$Temp_extent_pool to nagios; grant select on sys.v_$TEMP_SPACE_HEADER to nagios; grant select on sys.v_$session to nagios;
