Recurring downtime scheduling for wrong dates
hsmith
Agent Smith
Re: Recurring downtime scheduling for wrong dates
Post by hsmith »
Thanks for the help, Willem.
Fred Kroeger wrote:However, I'm going to have to wait for the fix.
I wish I could provide an ETA, but I do not have one at this time. Thank you for your patience. :)
Former Nagios Employee.
me.
Fred Kroeger
Post by Fred Kroeger »
OK - but you do realise that this is a major problem for Non-US users?
Fred
ssax
Dreams In Code
Post by ssax »
I'll see if I can whip something up.
ssax
Dreams In Code
Post by ssax »
This is for XI 5.2.3.
*** Note: This will get reverted if you upgrade and will need to be reimplemented.
*** Make sure that you have known-good backups/vm snapshots before making any modifications
Edit this file:
/usr/local/nagiosxi/html/includes/components/xicore/downtime.php
Around line 615 you will find this code:
    $start_time = date('m-d-Y H:i:s', strtotime($start_time));
    $end_time = date('m-d-Y H:i:s', strtotime($end_time));
Replace it with this code:
    // Get timezone datepicker format
    if (isset($_SESSION['date_format']))
        $format = $_SESSION['date_format'];
    else {
        if (is_null($format = get_user_meta(0, 'date_format')))
            $format = get_option('default_date_format');
    // Set the date format to the user's preference so we can convert properly
    if ($format == DF_ISO8601) {
        $date_format = 'Y-m-d H:i:s';
    } else if ($format == DF_US) {
        $date_format = 'm/d/Y H:i:s';
    } else if ($format == DF_EURO) {
        $date_format = 'd/m/Y H:i:s';
    $start_date = date_create_from_format("$date_format", "$start_time");
    $end_date = date_create_from_format("$date_format", "$end_time");
    $start_time = date_format($start_date, 'm-d-Y H:i:s');
    $end_time = date_format($end_date, 'm-d-Y H:i:s');
That should make it work properly according to your date preferences.
Let me know if this works for you and if you run into any problems.
Thank you
Fred Kroeger
Applied the changes to my test system - it didn't break but it didn't fix it either for me.
Made the changes to downtime.php & restarted both Nagios & httpd services
I Scheduled downtime via the Advanced Tab of the Host - and just changed the end time year value to 2017
Then looking at scheduled downtime, you can see that the date of the schedule is correct, but the start/end downtime were saved in mm/dd/yyyy
Regards... Fred
ssax
Dreams In Code
Post by ssax »
Sorry, I only updated the one for Home > Scheduled Downtime, I'll take a look at that one as well.
Test Home > Scheduled Downtime out to see if it works properly for you there and let me know.
Thank you
Fred Kroeger
Still the same problem via <Home><Scheduled Downtme> - scheduled a downtime for today - 10/02/16 and it shows it as being scheduled for 02/10/16
regards... Fred
ssax
Dreams In Code
Post by ssax »
Please attach your /usr/local/nagiosxi/html/includes/components/xicore/downtime.php file so that I can review it.
Still working on a solution for the other place.
Fred Kroeger
Good News! The downtime problem appears to be fixed! I left the patched file on my Test server and today scheduling downtime works as expected. The only difference that I can identify betwwen last time and this time is that I shutdown my PC in between - so maybe the old php had been cached by my browser? I just tested it with another user and it is also working for them. I will test it on another box and let you know.
While you're looking at the same downtime scheduling problem from the Host/Status details page, can you also review the Recurring Downtime script and see if it is also affected? I've got a user complaining that the Recurring Downtime they had scheduled isn't working anymore. I know that you don't actually insert a date (just Days of Month & Days of Week) but I'm wondering if the swap to MM/DD problem may also be happening with Recurring downtime when it gets scheduled via the cron process.
Just confirmed it's OK on another server - just had to clear my browser cache.
regards... Fred
I am glad we are moving to the right direction! :)
I will do a little bit more digging into the recurring downtime, but it will take a while. Meanwhile, I will keep this thread open in case you have some more questions/issues/feedback, etc.
