VMWare Monitoring
raamardhani7
Re: VMWare Monitoring
Post by raamardhani7 »
tgriep wrote:Lets try and see if you can connect to the VMWare server using the VMWare Perl SDK tools to see if we can get those to work.
Your path to the tool could be different from ours as we are using the SDK version 5.5 and not 6.
Change to the following directory
/usr/lib/vmware-vcli/apps/general
Run this to test to see if you can connect to the VMWare VCenter server
./connect.pl --url https://xxx.xxx.xxx.xxx/sdk/vimService --username <username> --password <password>
If the above passes, go to this directory.
/usr/lib/vmware-vcli/apps/host
Run this to test to see if you can get the list of hosts connected to the VMWare VCenter server
./hostinfo.pl --url https://xxx.xxx.xxx.xxx/sdk/vimService --username <username> --password <password>
Remember to replace xxx.xxx.xxx.xxx with the IP address of your VCenter server and to put in the correct username and password.
Please post any errors
Hi Tom,
Please find the update.
[root@lussvpnagiosxi00 general]# ./connect.pl --url https://xx.xx.xx.xx/sdk/vimservice --username 'domain\user' --password passwd
Connection Successful
Server Time : 2016-02-04T14:56:22.981082Z
[root@lussvpnagiosxi00 general]# ls -ltra
total 84
-r-xr-xr-x  1 root root  1228 Dec  4 00:11 connect.pl
-r-xr-xr-x  1 root root  8065 Dec  4 00:11 viversion.pl
-r-xr-xr-x  1 root root 12784 Dec  4 00:11 vidiscovery.pl
-r-xr-xr-x  1 root root 21667 Dec  4 00:11 fileaccess.pl
-r-xr-xr-x  1 root root  6071 Dec  4 00:11 extractlog.pl
-r-xr-xr-x  1 root root 12792 Dec  4 00:11 credstore_admin.pl
drwxr-xr-x  2 root root  4096 Dec  4 00:11 .
drwxr-xr-x 10 root root  4096 Dec  4 00:11 ..
I couldn't find hostinfo.pl.
As per our discussion, is it mandatory to have local access created. if yes, how is it different from Domain user access. Our VMware team wanted to understand on this, I am not sure i can take that question. could you please help me this question too. thanks.
I received the email ticket for this issue, do you want to move this post to the ticket?
raamardhani7
tgriep wrote:I received the email ticket for this issue, do you want to move this post to the ticket?
Hi Tom,
Please close this thread. thanks.
