mail queue error
RubenLatorre
Re: mail queue error
Post by RubenLatorre »
rkennedy wrote:It doesn't look like NRPE is compiled - did you compile it yet?
Here's a document that explains how to configure / compile NRPE -
It is complied because I'm monitorig the check_total_procs service with check_nrpe of this remote host
Check out this configuration file, can you post it for us to review?
/usr/local/nagios/etc/nrpe.cfg
RubenLatorre
rkennedy wrote:Check out this configuration file, can you post it for us to review?
There are the two nrpe.cnf files, the nrpe.cfg nagios host and the nrpe.cfg remote host.
nrperemotehost.cfg
(7.88 KiB) Downloaded 295 times
nrpenagioshost.cfg
(7.9 KiB) Downloaded 299 times
Are you running NRPE standalone, or through xinetd?
Were those files found on the Nagios machine, or the client machine?
The command that needs to be added to the proper config file is -
command[check_mailq]=/usr/local/nagios/libexec/check_mailq -w 15 -c 20
RubenLatorre
rkennedy wrote:Are you running NRPE standalone, or through xinetd?
In nagios machine I have two files about nrpe, the first one is on the /usr/local/nagios/etc/nrpe.cfg.
And the second one is on /etc/xinetd.d/nrpe, and the contain of that file is what I have puted on the screenshot.
This is getting a bit confusing, the only one we need to modify at this point is the remote (client machine) one.
Please post the output of these two commands -
cat /usr/local/nagios/etc/nrpe.cfg
cat /etc/xinetd.d/nrpe
RubenLatorre
rkennedy wrote:This is getting a bit confusing, the only one we need to modify at this point is the remote (client machine) one.
I have modified the /usr/local/nagios/etc/nrpe.cfg file, in which I have defined the check_mailq command and I have allowed the nagios host ip.
In the /etc/xinetd.d/nrpe, What I have to modify? Only to add the nagios ip host, in this case "192.168.0.4" I attach a screenshot with the content of the file.
When I finish of modify that file, Have I to do a "service nrpe restart"?
jolson
Attack Rabbit
Post by jolson »
You may have to restart xinetd to get the new configuration to apply. Give the following a try:
service xinetd restart
Also, I'm interested in the following:
grep nrpe /etc/services
ps -ef | egrep "xinetd|nrpe"
Twits Blog
RubenLatorre
hsmith
Agent Smith
Post by hsmith »
That looks all right.
jolson wrote:You may have to restart xinetd to get the new configuration to apply.
After you did this step, did the problem get resolved?
Former Nagios Employee.
me.
