missing bandwidth perf data for network devices
Re: missing bandwidth perf data for network devices
here you go
real 4m56.104s
user 0m48.401s
sys 0m3.153s
real 4m56.104s
user 0m48.401s
sys 0m3.153s
- Box293
- Too Basu
Excellent, this is where the problem is occurring.bosecorp wrote:real 4m56.104s
MRTG runs every 5 minutes as a cron job
When the next 5 minute interval occurs, the cron job tries to run again but MRTG detects its already running so it does not continue, hence NO DATA is collected at that five minute interval.
This will keep happening until the existing MRTG cron job completes, no data is collected
So if no data is being collected then you will have gaps in your graphs
The "Forks: 4" option in /etc/mrtg/mrtg.cfg makes MRTG run faster as it processes x mount of configs (in this case 4) when it runs, it is forking instead or running one after the other.
You can increase the Forks number to suit the size of your server.
Try "Forks: 16" and then then see if that fixes the gaps problem.
it did not fix the issue
Can you post your /etc/mrtg/mrtg.cfg file so we can look at it to see if there is an entry causing this issue?
How many config files are in this folder /etc/mrtg/conf.d/ and what is the average number of ports per device are you monitoring?
Also, run the following commands and post the output.
tail -100 /usr/local/nagios/var/perfdata.log
tail -100 /usr/local/nagios/var/npcd.logBe sure to check out our Knowledgebase for helpful articles and solutions!
I have 301 files
few have more than 300, average is 50
and here is the other one
root@nagmonus1:(02-23 16:23): /root
# tail -100 /usr/local/nagios/var/perfdata.log
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamefnmrpt.bose.com / Memory_Usage ('Physical Memory Used'=3168428032Bytes; 'Physical Memory Utilisation'=37%;80;90;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for us-notoriginalprefex-inet-fesx-448.bose.com / GigabitEthernet9_Bandwidth (in=0Mb/s;50;80 out=0Mb/s;50;80)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for us-notoriginalprefex-asr.bose.com / Port_9_Bandwidth (in=0Gb/s;4;6 out=0Gb/s;4;6)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameADFSSF01 / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamekbdb1.bose.com / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameie.bose.com / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameibmridev.bose.com / Check_Service_-_Eracent ('Total Service Count'=0; 'Service Count OK State'=0; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameequus2.bose.com / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamemdt.bose.com / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostname3SVCAT-PA.bose.com / Drive_C__Disk_Usage ('C: Space'=17.24GB; 'C: Utilisation'=28.9%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamebugfix1.bose.com / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostname4REM-D / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamemsupprod1.bose.com / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamemobile-pro.bose.com / Memory_Usage ('Physical Memory Used'=5643177984Bytes; 'Physical Memory Utilisation'=66%;98;99;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameidmdev.bose.com / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamesblprd5.bose.com / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamemsupprod2.bose.com / Check_Service_-_Eracent ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamelogsvr.bose.com / Drive_C__Disk_Usage ('C: Space'=36.87GB; 'C: Utilisation'=92.9%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameASDBUILD09 / CPU_Usage ('Avg CPU Utilisation'=0.08%;100;99;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamefacil2.bose.com / Drive_C__Disk_Usage ('C: Space'=40.48GB; 'C: Utilisation'=67.5%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameexca03.bose.com / Check_Service_-_Eracent ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostname5AST-D / Memory_Usage ('Physical Memory Used'=6018600960Bytes; 'Physical Memory Utilisation'=93%;99;100;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamemrsprod2.bose.com / Page_File_Usage ('C:\\pagefile.sys Page File Size'=4293918720Bytes; 'C:\\pagefile.sys Used'=27262976Bytes; 'C:\\pagefile.sys Utilisation'=1%;80;90; 'C:\\pagefile.sys Peak Used'=44040192Bytes; 'C:\\pagefile.sys Peak Utilisation'=1%;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamemsupcdb2.bose.com / Drive_E__Disk_Usage ('E: Space'=0.09GB; 'E: Utilisation'=0.1%;80;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostname7VALOR-PA / Check_Service_-_Eracent ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for ra06-svr1.bose.com / Drive_D__Disk_Usage ('D: Space'=144.46GB; 'D: Utilisation'=15.5%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamesaraddb.bose.com / Drive_C__Disk_Usage ('C: Space'=46.12GB; 'C: Utilisation'=76.9%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostname23AQUA-P / Check_Service_-_SCCM ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamevmbuild.bose.com / Drive_C__Disk_Usage ('C: Space'=22.38GB; 'C: Utilisation'=37.5%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameBDCFMP / Check_Service_-_SCCM ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamelivecomp01.bose.com / Drive_S__Disk_Usage ('S: Space'=16.09GB; 'S: Utilisation'=50.3%;80;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamemedeshed.bose.com / CPU_Usage ('Avg CPU Utilisation'=7.93%;99;100;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameicswin2003.bose.com / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamemobile-dev.bose.com / Memory_Usage ('Physical Memory Used'=5319176192Bytes; 'Physical Memory Utilisation'=62%;99;100;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostname2MEIS-D / Drive_F__Disk_Usage ('F: Space'=31.20GB; 'F: Utilisation'=15.5%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamefrasdsrv1.bose.com / Drive_C__Disk_Usage ('C: Space'=21.90GB; 'C: Utilisation'=54.7%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostname7JAMA-D / Drive_E__Disk_Usage ('E: Space'=7.80GB; 'E: Utilisation'=10.4%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostname7VALOR-P / Check_Service_-_SCCM ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostname-MATLAB01 / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostname23AQUA-PA / Check_Service_-_Eracent ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamemdprod1.bose.com / Memory_Usage ('Physical Memory Used'=9775837184Bytes; 'Physical Memory Utilisation'=76%;99;100;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameexclient2.bose.com / CPU_Usage ('Avg CPU Utilisation'=0.69%;80;90;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for db-etpint.bose.com / Drive_D__Disk_Usage ('D: Space'=48.28GB; 'D: Utilisation'=6.9%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameremapp4.bose.com / Drive_C__Disk_Usage ('C: Space'=24.24GB; 'C: Utilisation'=40.6%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for delhi-fp3.bose.com / CPU_Usage ('Avg CPU Utilisation'=0.23%;100;99;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for japan-bkk-dc2.bose.com / Server_For_NIS ('Total Service Count'=0; 'Service Count OK State'=0; 'Service Count Problem State'=0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for us-rdg-223-isr.bose.com / Ping (rta=34.473ms;3000.000;5000.000;0; pl=20%;80;100;; rtmax=34.828ms;;;; rtmin=33.750ms;;;;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameaciconfig-p.bose.com / CPU_Usage ('Avg CPU Utilisation'=0.67%;80;90;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for nagmonusdev1.bose.com / Check_Mem (TOTAL=12329836KB;;;; USED=11491848KB;12317506;12329836;; FREE=837988KB;;;; CACHES=5870216KB;;;;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameARC3 / Drive_D__Disk_Usage ('D: Space'=22.33GB; 'D: Utilisation'=8.0%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameBOPROD-DB5 / Drive_F__Disk_Usage ('F: Space'=27.13GB; 'F: Utilisation'=34.3%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameARC14 / CPU_Usage ('Avg CPU Utilisation'=0.20%;100;99;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for oz-pivotal6.bose.com / Ping (rta=143.418ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=144.720ms;;;; rtmin=142.504ms;;;;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameARC10-N1 / Drive_C__Disk_Usage ('C: Space'=152.48GB; 'C: Utilisation'=54.6%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameARC2 / Check_Service_-_Eracent ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameARC2-N3 / Check_Service_-_SCCM ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameARC2-N4 / Drive_C__Disk_Usage ('C: Space'=61.34GB; 'C: Utilisation'=22.6%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameARC2-N2 / CPU_Usage ('Avg CPU Utilisation'=18.39%;100;99;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameARC4 / Memory_Usage ('Physical Memory Used'=4083822592Bytes; 'Physical Memory Utilisation'=8%;99;100;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameARC10-N3 / Memory_Usage ('Physical Memory Used'=5425324032Bytes; 'Physical Memory Utilisation'=2%;99;100;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for japan-bakk-dc1.bose.com / Ping (rta=57.827ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=63.452ms;;;; rtmin=55.486ms;;;;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for nagmondb1.bose.com / Check_usr (/usr=4094MB;7982;7982;0;8063)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for usst-mdf-2960.bose.com / Port_10137_Bandwidth (in=0Mb/s;5;8 out=0Mb/s;5;8)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalprefex-nga.bose.com / BPW-Span-ssid-B-Employee-user-3_Bandwidth (in=0Mb/s;50;80 out=0Mb/s;50;80)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for usrd-6880-vss-1.bose.com / conf-vid1386_Bandwidth (in=0Mb/s;500;800 out=0Mb/s;500;800)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for us-notoriginalprefex-asr.bose.com / Port_17_Bandwidth (in=0Mb/s;500;800 out=0Mb/s;500;800)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostname23AQUA-PA / Ping (rta=5.052ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=9.268ms;;;; rtmin=3.996ms;;;;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostname7VALOR-PA / Ping (rta=3.924ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=7.215ms;;;; rtmin=0.411ms;;;;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamefnmsqlstg.bose.com / Ping (rta=4.298ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=9.074ms;;;; rtmin=0.427ms;;;;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for india-dc1.bose.com / Server_For_NIS ('Total Service Count'=0; 'Service Count OK State'=0; 'Service Count Problem State'=0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameARC2 / Ping (rta=1.968ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=2.074ms;;;; rtmin=1.879ms;;;;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameARC6 / Ping (rta=1.898ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=1.924ms;;;; rtmin=1.854ms;;;;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameARC10-N4 / Ping (rta=2.108ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=2.322ms;;;; rtmin=2.024ms;;;;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for japan-bakk-dc1.bose.com / DHCP_Server ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamedoors02.bose.com / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for penang-dc3.bose.com / Drive_E__Disk_Usage ('E: Space'=8.80GB; 'E: Utilisation'=12.6%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for hk-lab01.bose.com / Memory_Usage ('Physical Memory Used'=2087006208Bytes; 'Physical Memory Utilisation'=22%;99;100;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameca5.bose.com / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamefmi.bose.com / Check_Service_-_Networker ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0;0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameacicconfig-a.bose.com / Drive_E__Disk_Usage ('E: Space'=1.02GB; 'E: Utilisation'=0.7%;80;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for tijuana-dc2.bose.com / Kerberos_Key_Distribution_Center ('Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0; 'Excluded Service Count'=0;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameastsqlprod.bose.com / Drive_C__Disk_Usage ('C: Space'=37.09GB; 'C: Utilisation'=62.2%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamebodev-s2.bose.com / CPU_Usage ('Avg CPU Utilisation'=1.19%;100;99;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameplmwcqpva1.bose.com / Memory_Usage ('Physical Memory Used'=3122688000Bytes; 'Physical Memory Utilisation'=36%;99;100;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamebodev-s2.bose.com / Memory_Usage ('Physical Memory Used'=11997466624Bytes; 'Physical Memory Utilisation'=70%;99;100;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameav4.bose.com / CPU_Usage ('Avg CPU Utilisation'=15.52%;100;99;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameconnectdev.bose.com / CPU_Usage ('Avg CPU Utilisation'=2.05%;80;90;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for dcn-r04c02-pdu2.bose.com / Total_Load_Bank_1 (total_load=0;18;20;24)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameaoshare.bose.com / Drive_F__Disk_Usage ('F: Space'=0.47GB; 'F: Utilisation'=3.9%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamecrmdev1.bose.com / Memory_Usage ('Physical Memory Used'=2470473728Bytes; 'Physical Memory Utilisation'=58%;80;90;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameav5.bose.com / Drive_E__Disk_Usage ('E: Space'=0.09GB; 'E: Utilisation'=0.6%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostname2qbase-pa.bose.com / Memory_Usage ('Physical Memory Used'=2340638720Bytes; 'Physical Memory Utilisation'=55%;99;100;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamebodev-w1.bose.com / Drive_E__Disk_Usage ('E: Space'=69.94GB; 'E: Utilisation'=87.4%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for delhi-fp4.bose.com / Drive_C__Disk_Usage ('C: Space'=16.31GB; 'C: Utilisation'=21.0%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostname7bluesky-p.bose.com / Memory_Usage ('Physical Memory Used'=3047927808Bytes; 'Physical Memory Utilisation'=18%;99;100;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnameboprod-w1.bose.com / Drive_C__Disk_Usage ('C: Space'=50.46GB; 'C: Utilisation'=84.5%;90;95;)
2016-02-23 16:23:31 [11518] [1] Found Performance Data for notoriginalhostnamesapafa.bose.com / Page_File_Usage ('F:\\pagefile.sys Page File Size'=2138046464Bytes; 'F:\\pagefile.sys Used'=38797312Bytes; 'F:\\pagefile.sys Utilisation'=2%;80;90; 'F:\\pagefile.sys Peak Used'=42991616Bytes; 'F:\\pagefile.sys Peak Utilisation'=2%;)
2016-02-23 16:23:31 [11518] [1] 818 lines processed
2016-02-23 16:23:31 [11518] [1] /var/nagiosramdisk/spool/perfdata/service-perfdata.1456262595-PID-11518 deleted
2016-02-23 16:23:31 [11518] [1] PNP exiting (runtime 1.123104s) ..and here is the other one
# tail -100 /usr/local/nagios/var/npcd.log
[02-23-2016 16:23:30] NPCD: Processing file 'host-perfdata.1456262594'
[02-23-2016 16:23:30] NPCD: Regular File: service-perfdata.1456262595
[02-23-2016 16:23:30] NPCD: Processing file service-perfdata.1456262595 with ID 140665102309120 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /var/nagiosramdisk/spool/perfdata/service-perfdata.1456262595
[02-23-2016 16:23:30] NPCD: A thread was started on thread_counter = 1
[02-23-2016 16:23:30] NPCD: Processing file 'service-perfdata.1456262595'
[02-23-2016 16:23:30] NPCD: Have to wait: Filecounter = 2 - thread_counter = 2
[02-23-2016 16:23:31] NPCD: No more files to process... waiting for 15 seconds
[02-23-2016 16:23:46] NPCD: Found 4 files in /var/nagiosramdisk/spool/perfdata
[02-23-2016 16:23:46] NPCD: DEBUG: load 4.430000/500.000000
[02-23-2016 16:23:46] NPCD: ThreadCounter 0/5 File is .
[02-23-2016 16:23:46] NPCD: ThreadCounter 0/5 File is ..
[02-23-2016 16:23:46] NPCD: ThreadCounter 0/5 File is host-perfdata.1456262610
[02-23-2016 16:23:46] NPCD: Regular File: host-perfdata.1456262610
[02-23-2016 16:23:46] NPCD: A thread was started on thread_counter = 0
[02-23-2016 16:23:46] NPCD: ThreadCounter 1/5 File is service-perfdata.1456262610
[02-23-2016 16:23:46] NPCD: Regular File: service-perfdata.1456262610
[02-23-2016 16:23:46] NPCD: Processing file host-perfdata.1456262610 with ID 140665123284736 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /var/nagiosramdisk/spool/perfdata/host-perfdata.1456262610
[02-23-2016 16:23:46] NPCD: Processing file 'host-perfdata.1456262610'
[02-23-2016 16:23:46] NPCD: A thread was started on thread_counter = 1
[02-23-2016 16:23:46] NPCD: Have to wait: Filecounter = 2 - thread_counter = 2
[02-23-2016 16:23:46] NPCD: Processing file service-perfdata.1456262610 with ID 140665102309120 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /var/nagiosramdisk/spool/perfdata/service-perfdata.1456262610
[02-23-2016 16:23:46] NPCD: Processing file 'service-perfdata.1456262610'
[02-23-2016 16:23:46] NPCD: No more files to process... waiting for 15 seconds
[02-23-2016 16:24:01] NPCD: Found 6 files in /var/nagiosramdisk/spool/perfdata
[02-23-2016 16:24:01] NPCD: DEBUG: load 4.200000/500.000000
[02-23-2016 16:24:01] NPCD: ThreadCounter 0/5 File is .
[02-23-2016 16:24:01] NPCD: ThreadCounter 0/5 File is ..
[02-23-2016 16:24:01] NPCD: ThreadCounter 0/5 File is host-perfdata.1456262624
[02-23-2016 16:24:01] NPCD: Regular File: host-perfdata.1456262624
[02-23-2016 16:24:01] NPCD: A thread was started on thread_counter = 0
[02-23-2016 16:24:01] NPCD: ThreadCounter 1/5 File is host-perfdata.1456262640
[02-23-2016 16:24:01] NPCD: Regular File: host-perfdata.1456262640
[02-23-2016 16:24:01] NPCD: A thread was started on thread_counter = 1
[02-23-2016 16:24:01] NPCD: ThreadCounter 2/5 File is service-perfdata.1456262624
[02-23-2016 16:24:01] NPCD: Regular File: service-perfdata.1456262624
[02-23-2016 16:24:01] NPCD: Processing file host-perfdata.1456262640 with ID 140665102309120 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /var/nagiosramdisk/spool/perfdata/host-perfdata.1456262640
[02-23-2016 16:24:01] NPCD: A thread was started on thread_counter = 2
[02-23-2016 16:24:01] NPCD: Processing file 'host-perfdata.1456262640'
[02-23-2016 16:24:01] NPCD: ThreadCounter 3/5 File is service-perfdata.1456262640
[02-23-2016 16:24:01] NPCD: Regular File: service-perfdata.1456262640
[02-23-2016 16:24:01] NPCD: Processing file service-perfdata.1456262624 with ID 140665010779904 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /var/nagiosramdisk/spool/perfdata/service-perfdata.1456262624
[02-23-2016 16:24:01] NPCD: A thread was started on thread_counter = 3
[02-23-2016 16:24:01] NPCD: Processing file 'service-perfdata.1456262624'
[02-23-2016 16:24:01] NPCD: Have to wait: Filecounter = 4 - thread_counter = 4
[02-23-2016 16:24:01] NPCD: Processing file host-perfdata.1456262624 with ID 140665123284736 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /var/nagiosramdisk/spool/perfdata/host-perfdata.1456262624
[02-23-2016 16:24:01] NPCD: Processing file 'host-perfdata.1456262624'
[02-23-2016 16:24:01] NPCD: Processing file service-perfdata.1456262640 with ID 140664989804288 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /var/nagiosramdisk/spool/perfdata/service-perfdata.1456262640
[02-23-2016 16:24:01] NPCD: Processing file 'service-perfdata.1456262640'
[02-23-2016 16:24:02] NPCD: No more files to process... waiting for 15 seconds
[02-23-2016 16:24:17] NPCD: Found 2 files in /var/nagiosramdisk/spool/perfdata
[02-23-2016 16:24:17] NPCD: DEBUG: load 4.260000/500.000000
[02-23-2016 16:24:17] NPCD: ThreadCounter 0/5 File is .
[02-23-2016 16:24:17] NPCD: ThreadCounter 0/5 File is ..
[02-23-2016 16:24:17] NPCD: No more files to process... waiting for 15 seconds
[02-23-2016 16:24:32] NPCD: Found 6 files in /var/nagiosramdisk/spool/perfdata
[02-23-2016 16:24:32] NPCD: DEBUG: load 3.990000/500.000000
[02-23-2016 16:24:32] NPCD: ThreadCounter 0/5 File is .
[02-23-2016 16:24:32] NPCD: ThreadCounter 0/5 File is ..
[02-23-2016 16:24:32] NPCD: ThreadCounter 0/5 File is host-perfdata.1456262654
[02-23-2016 16:24:32] NPCD: Regular File: host-perfdata.1456262654
[02-23-2016 16:24:32] NPCD: A thread was started on thread_counter = 0
[02-23-2016 16:24:32] NPCD: ThreadCounter 1/5 File is host-perfdata.1456262670
[02-23-2016 16:24:32] NPCD: Processing file host-perfdata.1456262654 with ID 140665123284736 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /var/nagiosramdisk/spool/perfdata/host-perfdata.1456262654
[02-23-2016 16:24:32] NPCD: Regular File: host-perfdata.1456262670
[02-23-2016 16:24:32] NPCD: Processing file 'host-perfdata.1456262654'
[02-23-2016 16:24:32] NPCD: A thread was started on thread_counter = 1
[02-23-2016 16:24:32] NPCD: Processing file host-perfdata.1456262670 with ID 140665102309120 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /var/nagiosramdisk/spool/perfdata/host-perfdata.1456262670
[02-23-2016 16:24:32] NPCD: Processing file 'host-perfdata.1456262670'
[02-23-2016 16:24:32] NPCD: ThreadCounter 2/5 File is service-perfdata.1456262655
[02-23-2016 16:24:32] NPCD: Regular File: service-perfdata.1456262655
[02-23-2016 16:24:32] NPCD: A thread was started on thread_counter = 2
[02-23-2016 16:24:32] NPCD: Processing file service-perfdata.1456262655 with ID 140665010779904 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /var/nagiosramdisk/spool/perfdata/service-perfdata.1456262655
[02-23-2016 16:24:32] NPCD: Processing file 'service-perfdata.1456262655'
[02-23-2016 16:24:32] NPCD: ThreadCounter 3/5 File is service-perfdata.1456262670
[02-23-2016 16:24:32] NPCD: Regular File: service-perfdata.1456262670
[02-23-2016 16:24:32] NPCD: A thread was started on thread_counter = 3
[02-23-2016 16:24:32] NPCD: Processing file service-perfdata.1456262670 with ID 140664989804288 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /var/nagiosramdisk/spool/perfdata/service-perfdata.1456262670
[02-23-2016 16:24:32] NPCD: Have to wait: Filecounter = 4 - thread_counter = 4
[02-23-2016 16:24:32] NPCD: Processing file 'service-perfdata.1456262670'
[02-23-2016 16:24:33] NPCD: No more files to process... waiting for 15 seconds
[02-23-2016 16:24:48] NPCD: Found 2 files in /var/nagiosramdisk/spool/perfdata
[02-23-2016 16:24:48] NPCD: DEBUG: load 4.830000/500.000000
[02-23-2016 16:24:48] NPCD: ThreadCounter 0/5 File is .
[02-23-2016 16:24:48] NPCD: ThreadCounter 0/5 File is ..
[02-23-2016 16:24:48] NPCD: No more files to process... waiting for 15 seconds
Reason: Please use [code][/code] tags around long output
Hmm, please post the output of this command again so we can see if the forks improved it:
time LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var/lib/mrtg/mrtg.okRe: missing bandwidth perf data for network devices
here you go
real 2m23.740s
user 0m57.267s
sys 0m5.563s
real 2m23.740s
user 0m57.267s
sys 0m5.563s
- Box293
- Too Basu
Find the Current Load service for the XI server.
Can you show us a screenshot of that performance graph for the past 24 hours.
Then also show us a screenshot of a performance graph for the past 24 hours which is showing gaps.
here you go
I've seen improvement, but still I see gaps
- Box293
- Too Basu
Can you also show us a graph for the same time period which has gaps.
If you are only seeing gaps in bandwidth graphs, then this must be mrtg related and not a system wide problem.
If this is the case, I would suggest doubling the amount of forks again.
