These definition can be placed in their own file or added to
Re: These definition can be placed in their own file or adde
bmurtha wrote:After chaning all the files to chmod 755 I get this as the output
Usage: java [-options] class [args...]
           (to execute a class)
   or  java [-options] -jar jarfile [args...]
           (to execute a jar file)
where options include:
    -d32          use a 32-bit data model if available
    -d64          use a 64-bit data model if available
    -client       to select the "client" VM
    -server       to select the "server" VM
    -hotspot      is a synonym for the "client" VM  [deprecated]
                  The default VM is client.
    -cp <class search path of directories and zip/jar files>
    -classpath <class search path of directories and zip/jar files>
                  A : separated list of directories, JAR archives,
                  and ZIP archives to search for class files.
    -D<name>=<value>
                  set a system property
    -verbose:[class|gc|jni]
                  enable verbose output
    -version      print product version and exit
    -version:<value>
                  require the specified version to run
    -showversion  print product version and continue
    -jre-restrict-search | -no-jre-restrict-search
                  include/exclude user private JREs in the version search
    -? -help      print this help message
    -X            print help on non-standard options
    -ea[:<packagename>...|:<classname>]
    -enableassertions[:<packagename>...|:<classname>]
                  enable assertions with specified granularity
    -da[:<packagename>...|:<classname>]
    -disableassertions[:<packagename>...|:<classname>]
                  disable assertions with specified granularity
    -esa | -enablesystemassertions
                  enable system assertions
    -dsa | -disablesystemassertions
                  disable system assertions
    -agentlib:<libname>[=<options>]
                  load native agent library <libname>, e.g. -agentlib:hprof
                  see also, -agentlib:jdwp=help and -agentlib:hprof=help
    -agentpath:<pathname>[=<options>]
                  load native agent library by full pathname
    -javaagent:<jarpath>[=<options>]
                  load Java programming language agent, see java.lang.instrument
    -splash:<imagepath>
                  show splash screen with specified image
See http://www.oracle.com/technetwork/java/javase/documentation/index.html for more details.
./check_sqljob.sh: line 42: /usr/local/nagios/libexec/SqlJobMon.class: cannot execute binary file
UNKNOWN:
Good - looks like Java is installed. Can you provide an example of where you're seeing this error? What is the input?
bmurtha
Post by bmurtha »
I'm invoking it from the command line this way:
"check_sqljob -H 10.70.5.45 -u sa -p s22css"
ssax
Dreams In Code
Post by ssax »
Please unzip the modified one, run it again with it, and then post the full output.
check_sqljob.zip
(753 Bytes) Downloaded 282 times
Thank you
bmurtha
Post by bmurtha »
Hi Ssax,
It seems to work, what I got was <a href=/nagios/sqllog/10.32.35.180-2016-03-11.html target=main> CRITICAL: Number of Jobs Failed:5|count=5</a>
Thank you,
I just need to setup the command and service calls now.
Regards,
Bryan
bmurtha
Post by bmurtha »
One problem, When I actually went to /usr/local/nagios/sqllog/ there was nothing in that directory.
bmurtha
Post by bmurtha »
I give up, I'm going to use a simple python script that does the same thing, thanks for all of your help. But it's like trying to make a pig fly at this point.
Regards,
Bryan
Did you end up getting this figured out with your python script, or do you need our assistance further?
bmurtha
Post by bmurtha »
I got the python script working I think,
CRITICAL - Number of failed jobs: 3 - Failed Jobs: BondsInfo last run at 03/14/2016 13:00:00, Websense_IBT_DRIVER__newlogdb last run at 03/14/2016 02:00:00, Websense_Maintenance_Job__newlogdb last run at 03/14/2016 01:00:00
Pretty certain it's ok if I invoke it from the command line everything seems ok, just wondering how do I setup the service and command files to invoke it from the Nagios scheduler? I got the python script from here: https://github.com/jetole/MSSQL-Job-History
He doesn't give an example of the command or service files. I'm trying to figure out what they should look like and where should I place them.
Regards,
Bryan
Got it, figuring out the service and command definition shouldn't be too dificult. What is the full command you're entering to receive that result?
bmurtha
Post by bmurtha »
./check_mssql_job_history.py -H msqlHost -U mssqlUser -P mssqlPassword
