MS IIS Application Pool
jkinning
Re: MS IIS Application Pool
Post by jkinning »
I tested out your new code but got an error.
./check_nrpe -H eas3t -t 30 -c check_ms_iis_application_pool -a '-A EasServices'
At C:\Program
Files\NSClient++\scripts\powershell\check_ms_iis_application_pool.ps1:19
char:13
+ #Requires ▒?"Version 2.0
The string is missing the terminator: ".
At C:\Program
char:11
Cannot process the #requires statement because it is not in the correct format.
The #requires statement must be in one of the following formats:
 "#requires -shellid <shellID>"
 "#requires -version <major.minor>"
 "#requires -pssnapin <psSnapInName> [-version <major.minor>]"
 "#requires -modules <ModuleSpecification>"
 "#requires -runasadministrator"
    + CategoryInfo          : ParserError: (:) [], ParseException
    + FullyQualifiedErrorId : TerminatorExpectedAtEndOfString
Changed line to #Requires –Version 2.0 and no more errors. I downloaded the tar.gz version of the latest code.
Thanks for this and the quick modification to the code! I don't know what issues or the differences between OnDemand and AlwaysRunning but I did just change the startup type to fix the problem originally. I am using the latest code with OnDemand so I'll give it a couple days and if any issues I'll report them here. Otherwise, I'll post it is safe to close this one.
Post by mcapra »
Keep us posted for sure!
WillemDH
Post by WillemDH »
Weird, I'm using
in alot of my scripts. Never had any issues with it. I just tested this latest verion and I'm not seeing that error.
Grtz
Nagios XI 5.8.1
https://outsideit.net
I'll leave this open should anything else come up over the weekend!
