how can play an alarm or bib with warning or critical
baber
Re: how can play an alarm or bib with warning or critical
Post by baber »
tgriep wrote:The sound will play on your PC and not the server. As long as you have a web browser open to the Nagios system and a status changes, it will play the sound file on that PC.
Now what is my problem why my sound not play ?
I have to just edit cgi. Cfg file is that enough?
Why not work
Yes, you should just need to edit the file.
What browser are you using? I couldn't get it to work on Firefox, but it worked fine on Chrome. Every time I loaded the status.cgi page, and a service was in warning state -- it played the sound.
baber
Post by baber »
rkennedy wrote:Yes, you should just need to edit the file.
I have just checked with firefox
Ok i will test with chrome do i hve need install any plugin or ... For chrome ??
Take a look at this post for an addon to firefox.
https://support.nagios.com/forum/viewto ... =7&t=21619
baber
Post by baber »
tgriep wrote:Take a look at this post for an addon to firefox.
Now i am confused in previous post you said sound not support on mozilla but here put a guide for mozilla ??
@tgriep posted another addon you can use, that will work with Firefox. I don't believe so, as long as your machine can play .wav files.
baber
Post by baber »
i have appeared with new problem with chrome when i add this line
service_critical_sound=/usr/local/nagios/share/media/warn.wav
it don't play any sound
but when i add this line
service_critical_sound=warn.wav
it play a sound every time i click on every item on nagios such as server hostgroups problem and .... and also this wav file is not that file i have selected why ?
rkennedy wrote:Change this -
service_warning_sound=warning.wav
to (since you're file is called warn.wav) -
service_warning_sound=warn.wav
As I mentioned, you need to use direct file names not full paths. It isn't expecting a full path.
Yes, this is how it works. It plays a sound if there are any warning / critical alerts on your system at all. When everything is at an OK status, you can leave the browser open and when something switches to warning / critical it'll play the sound as the page refreshes.
baber
Post by baber »
Dear friend
So thanks
Now with appear warning alarm will be play just there is a problem with each page refresh the alarm will be play is there any config on nagios core that can config to play alarm if warning appear every 5 min untill problem solve
How can do this??
BR
Babak
I don't see any options aside from just specifying the sound files to use, and whether to play sounds. There does not appear to be anything regarding a repeat frequency.
